Subaru Impreza WRX
Doesn't the lack of a Limited Slip differential (in the Impreza RS) also mean, that in cases when both the right wheels of the car, OR both the left wheels of the RS, does not have traction (eg. when one side of the car is on ice), the car, INSPITE OF HAVING AWD, is NOT GOING ANYWHERE ? Tires Spinning with the car not going forward ??!!! Unlike, the WRX, where due to the presence of the Limited Slip differential, the car would power out of such situations, due to the side to side power transfer in the above mentioned scenarios ?
Later...AH
TWRX
In fact, the situation mentioned is a very rare one, and one seldom faces it in real-world driving, even though we cannot totally rule it out. I think the RS should be good enough for almost anything....but the WRX goes even beyond that, in terms of acceleration, handling and foul weather capabilities. Also, the RS was definitely not an option for me, since I needed a wagon. The TS wagon unfortunately was ruled out, since it was equipped with rear wheel drum brakes, in addition to not having the rear Limited Slip Differential.
IF the WRX wagon came with the H6, it would have been PERRRRFECT for me but rarely is this world "perfect" ;-| As it stands, I am thoroughly happy with what the WRX offers.
Later...AH
I think I read the same article. It wasn't the WRX, it was the RS. The MP3 placed 1st, and the RS placed second, ahead of the Jetta 1.8T, another car (can't remember), and the Neon.
BG
For example: I was riding with my cousin in his 02 RS, following a WRX and a 00 RS (that has LSD) on some twisties. We were REALLY pushing it! But the 02 RS was making more noise for some reason (both of them said we were making the noise, and we could tell too) and it took me awhile to realize it, but it was the open diff in the back as oposed to the rear LSD.
So ya, it makes a difference. Find a wrecked WRX and swap out the rear axle if it means that much of a difference :P (Yes, I am also displeased they had it in the 00/01 RS and droped it in the 02 RS, but the 02 RS costs $500 less too)
I don't think any of us drive anywhere close to 9/10ths.....someone like Mario Andretti might push it to those levels... I would think extremely adventurous and skilled drivers among us might go upto about 7/10ths or so.
On a different vein, the rear LSD is definitely working and makes a difference at all speeds, just that it does it seamlessly. The point I made is NOT about extreme driving. The point is that without a rear LSD, the car INSPITE OF BEING EQUIPPED WITH AWD, will not move an inch if EITHER SIDE of the car, whether THE RIGHT HAND SIDE or THE LEFT HAND SIDE, is on a surface where traction is un-available.
There is no SIDE TO SIDE POWER TRANSFER in a vehicle that does not have the LSD. The RS would ONLY transfer power FRONT TO BACK (OR BACK TO FRONT), which should suffice in pretty much all conditions.
For example, if BOTH THE WHEELS ON THE FRONT lose traction OR IF BOTH THE REAR WHEELS lose traction, the RS would be fine. It would power out of those situations.
But if BOTH THE WHEELS ON THE LEFT or BOTH THE WHEELS ON THE RIGHT lose traction, the RS is like a helpless baby, while the WRX would smoothly power out of those situations.
Later...AH
Ed
Apart from that - drive both, think/read for 1 week, drive them again - think/read another week. By then your answer should be cooked to perfection. For me, I drove the WRX once and was sold and have never regretted it since I'm afflicted with speed addiction even after 20 years of driving.
Ed
Bob
Ed
I don't know if you know this, but the Sentra's just went on wholesale on the 15th, and Nissan told me they won't be at dealers for another month or so.
Bob
doormatt--I am trying to get a new job that will make my commute a trip through some mountains. From employees making that same commute, I have heard it can get really hairy in the winter months. Hence my leaning towards the RS
TWRX
-mike
It doesnt make that big of a difference really.
Why Dont I like the SE-R already? Cause its FWD. Sure, FWD is fine for most folks, but not for me after I had some annoying experiences with Torque steer and massive Understeer... I can replicate the conditions for anyone if they want to witness it too.
BTW, Ive been hearing that people are getting the WRX/Impreza for $100-200 over Invoice!!! That means you can get a WRX for like $22k, or a RS for under 18 easy. GO DO SOME HAGGLING!
-mike
While an LSD is great to have, it doesn't guarantee that you'll never get stuck. I
I've driven in a fair amount of snow and ice and have never been in a situation where I'd wished I had one.
Although while recently talking to an owner of a dealership about the OB VDC, he said he had never been stuck with ANY Subaru. He's been driving them for 16 years in the hills of western NJ.
Kosta - Actually if you're slipping in the snow, hit the accelerator. This directs power to the appropriate wheels quicker.
Dennis
Someone mentioned earlier on the board about installing a thicker rear sway bar to help with the handling of the RS. It comes with a 13mm standard and the post said to get a 17-20mm. Does everyone agree with that? Will it really help?
Since you're worried about costs, I'm surprised you would even consider the added expense of upgrading...
Bob
The engine and LSD front diffy sound good, but I don't like the non-independent rear suspension (bouncy on rough roads, at least the similar setup in the Maxima is). C&D complained loudly about the shifter, and I sampled an Altima 3.5SE that also had poor shift quality, so I believe it.
The Altima was great except for wicked torque steer and that shifter. Very fast, very flexible engine, though. Loved the styling. Just fix the shifter, please, and toss in the helical LSD from the Sentra in that unmanaged front axle. Better yet, offer AWD.
The same day, I test drove a Protege5. Very nice car, balanced handling, no torque steer. Of course, there isn't much torque to begin with. You could add a bunch of power, but that might upset the balance of the FWD powertrain. I say MP3 the bad boy and come up with 10 more hp. Any more than that and it needs AWD or at least a front LSD.
-juice
Keep it under 4krpm for the first 1000 miles, except for emergencies. Try to be easy on the brakes and tranny, too. In other words, drive smoothly. Also, vary your speeds if you can.
-juice
I drive mine like I stole em from day one.
-mike
That manual has not been put together by opinionated morons at a dealership, nor has it originated from OPINIONS at such forums. It has been put together with INPUTS FROM ENGINEERS WHO DESIGNED YOUR VEHICLE. If they specifically ask you to do something, they must have a reason. So let us not assume superior knowledge and abuse a new car, contrary to what the designers of the car have stated.
The manual clearly asks us to do the following:
1) Maintain the *ENGINE RPMS* below 4000 during the break-in. It has NOT ASKED US to maintain the speed of the vehicle below any figure like say, 60mph. You can drive faster than 70mph, as long as you do not go above 4000rpm.
2) Never drive your vehicle constantly at a specific speed, either fast or slow. In other words, DO NOT use cruise control and go at a set speed, during the break-in period. What this basically means is that do not maintain a CONSTANT ENGINE RPM while driving. Constantly vary the Engine RPM as much as possible, of course without exceeding 4000rpm.
3) Do not slam on your brakes unless it is an emergency. Slamming on the brakes induce a transmission kick-down, which does not help a new engine and transmission who are learning to work together.
4) Suddenly slamming the accelerator. Again can induce a transmission kickdown and also raises the engine RPM beyond what is recommended.
Basically, we have got years and years to drive the way we want to. Stick to the recommendations of Subaru engineers for the 1st 1000 miles AT LEAST. You will certainly not regret it, and definitely be glad that you did.
Later...AH
TWRX
Stephen
Thanks twrx and Stephen for the info on the bar.
Celia...er...celcam.:)
The point is that when you increase the diameter of the rear sway bar, the vehicle reduces its understeering tendency (which is a safety factor automakers build in, into these vehicles), and tend to over-steer more. So you could go the route taken by Stephen, by adding a front sway bar, which will rein in the tendency of the vehicle to oversteer. But the downside to adding too much stiffness into the sway bars is that you lose the ride compliance of your independent suspension equipped vehicle.
Later...AH
ps: In the hands of an average driver, an under-steering vehicle is safer than one that oversteers.
Bob
Dont forget, that these cars arent 100k works of art, and they had to cut costs somewhere. Think of them more as a blank slate with which to work with rather than a finished product.
However, if Colin McRae or someone like that were to buy a car, they would probably change the handling balance to "neutral", since they are pros and can understand the nuances of the handling of the vehicle, and have a clear knowledge of how far they can push it. In the hands of the common Joe on the street (like you and me ??), an under-steering car is "safer", since it leaves a certain cushion of safety, before the car develops the tendency to spin.
Later...AH
On dry pavement the tail will only come out in very extreme situations, such as a high speed U-turn where you drop the throttle in the middle. Getting back on the gas brings her back in line nicely.
Yes, for regular folks, that's not the ideal setup.
Man, wait 'til winter. WRXs only came out in the Spring, so owners have not yet had a winter to try out the AWD.
-juice
-mike
Anyhow, the front turn in is crisp and overall the car just seems tighter. The ride is a bit less compliant but nothing to complain about.
Stephen
My question is to recent Canadian buyers of the WRX: what was the price you paid for your cars "out the door".
The Subaru website says the MSRP for the WRX with auto transmission is $36,500, and CarCostCanada says that the Dealer Invoice for the same car is $33,164. The dealer I've been talking to says that prices are not negotiable; I'll have to pay the MSRP. I'm not sure if this is because I'm looking for an automatic and these are rarer? He claims that Subaru of Canada has adopted a "haggle-free" policy like Saturn, so prices are out of his control. Should I beleive him?
I'd visit a different dealer. Full MSRP in the midst of an economic down turn? Right.
-juice
No Impreza Turbos (as they're called there pre-2001) were available for rent (there was a VERY nice Benz E320 TURBO DIESEL available though). I did see about three on the road. Two sounded like they had aftermarket exhausts and one had a P1 wing. What did really impress me was a sighting of an Excort RS Cosworth in Kilkenny. WOW! I can't believe it's never been available here. Even crawling through traffic, it sounded pretty mean. None of that buzzy tin can stuff of Hondas, but a growly thrum. Looked pretty good too. Other than that, I was imressed by the number of cars there that we've never seen stateside, especially all the French cars and Opels. Even familiar marques look strange. For example, if the hatchback Toyota Corolla didn't say "Toyota Corolla" on the back, you'd never recognize it. Even when the body is the same there's something different. For example, there's the Lexus IS 200, with only a 2.0 liter six. The most common BMW 3-series I saw was a 318 (no NOT the hatchback).
I drove a rented Renault Laguna manual there for 7 days. And there's a reason why there are no French cars on the US market -- they suck. It took a while to get used to driving on the wrong side of the road and shifting on the left. The roads there are tiny and are full of curves and bends. One can easily see why Imprezas are viewed as king of the road there! Also there are hardly any potholes, due to there being no infrastructure under many of the roads as we have. As a result, most of the cars there have stiffer suspensions and handle pretty well, though they lack the power due to gas being about $2.40 for a gallon of unleaded.
Young men drive pretty fast anyway. One friend gave me a ride in his Benz E320 with said turbo diesel engine and took it down one of those narrow windy roads up to 110. I believe he still has imprints of my fingernails in his dash. By the by, that engine was so smooth and powerful, you'd never know it was a turbo, much less a diesel. The suspension was also stiffer than U.S.-spec E-class sedans I've been in. The same guy told me that WRX's are a favorite in ireland for bank robbers, because the police simply can't can't catch thieves in them on those twisty roads.
All in all, it's good to be back on the right side fo the road again. When I first drove back here n NYC, I automatically reached for the shifter with my left hand!
