Subaru Impreza WRX
It would be easier on the car to use higher rpms (4000 to 5000) in a lower gear than to make the turbo work in a higher gear.
Turbos hate to spin with cold oil and they will make a more distinct whine.
Over time, you can get a pretty good idea how the turbos ought to sound under different conditions, so the turbo noise can be your "oil temp" gauge.
As paisan noted, a good rule of thumb is to wait until the water is up to temp, but if the turbo still complain more than it should, the oil is not yet warm enough.
was totally ignored.
When you are on the Owners Club board, you are looking at some discussions that are exclusive to that board, and some that reside on other boards but are linked to the Owners club for convenience.
In the Subaru Owners Club, there are two WRX discussions that are actually hosted on the Station Wagons board, and one hosted here on the Sedans board. Since the Town Hall is divided into Sedans, Station Wagons, Hatchbacks, SUVs, etc., it does make sense to maintain separate discussions on each of the appropriate boards.
I'm not sure why there are two separate discussions under Station Wagons, though. Perhaps a post to Revka asking about that would give you an explanation.
I realize this doesn't resolve your request, but I hope it helps you understand why you see what you do.
If you use subscriptions, it is very easy to keep up with new posts in all discussions of interest to you by using your Message Center and the Read Subscriptions button. If you haven't tried this, I highly recommend it.
Happy holidays to everyone!!
Pat
Sedans Message Board
-mike
To answer your original question, the acrylic deflectors do the job well--we have one on our Forester--no real wind noise that I've noticed, and help protect your windshield too.
--RA
-mike
-mike
I'm not even sure Subaru recommends towing with the WRX.
Bob
But I'll go along with installing the mudflaps to protect the paint.
Say, where can I get a satellite dish to mount on the roof . . .ok, just kidding--I'll give it a rest
-mike
The Stongard is not really a car bra in the conventional sense. It is a clear plastic that is applied with adhesive directly to the front end--protects very well, although it will set you back several hundred bucks or more, depending on where you go.
--RA
Wait, I know. What am I thinking? The deflectors are used to ward off Klingon torpedoes.
-mike
Bob
-mike
A good window tint shop can put it on for you--yes, it might yellow a bit after a number of years but will stay nice for quite a while--as far as I know, you can't really take it off without damage to your paint and warping the pieces.
--RA
Generally I use the milemarkers and a stopwatch doing 60mph or compare it to a friend's vehicle or now that I have GPS I compare it to that. All the cars I own are dead on balls accurite.
-mike
FWIW, I use my hitch for the bike rack more often than I tow.
-juice
Later...AH
-mike
-Dennis
They also say that 10% is the UK law.
-Dennis
The dealer insists that I should use regular oil only. I would prefer to use synthetic oil (Mobil 1) instead, but I do not want to go against what the dealer is stating.
Should I stick with the dealer's recommendation, and use regular oil, and change every 3,000 miles? Or alternatively, should I use synthetic oil, and use the same 3,000 mile interval, or possibly extend to 5,000 miles?
The manual recommends 5W/30 oil, but does list 10W/30 in hotter weather. I live around New York City, where the coldest days in winter are around 5-10F, and the hottest days in summer are around 95F. Should I use a different grade of oil in winter vs. summer, or just use 10W/30 all year round? Or should I use synthetic 5W/30 all year, and take advantage of the more durable synthetic oil, and lower viscosity for better cold weather protection?
Any help or suggestions would be appreciated. Thank you!
-mike
I think that dealer hopes that each 3000 miles you will visit his/her shop. Ask wheather the place where you change the oil makes any difference.
Krzys
PS I would use Mobil 1 at 3000 miles. If manual says 5W/30 use it. I have been using Mobil 1 for 6 years in my Neon at it still works (5W/30 too).
I think 5W/30 is quite safe for year round but if you want to you can try to use 0W/30 for winter and 10W/30 in summer.
I am using "easy" schedule for my oil changes and it is 5000 miles but sometimes I stretch it to 7500. In Europe car manufacturers are recomending 12500 intervals but they have cleaner gasoline (I think).
Use it if you can afford it and want to keep the car a long time. (It's actually cheaper than regular oil in the long run, because fewer engine overhauls.)
Subaru's official line is it's OK to use after the first 1000 miles.
Mobil 1 now uses a special ester in the formula which helps the rings seal like regular dino oil, so my feeling is you can use it from day 1 (but best to stick to what Subaru advises to avoid warranty problems).
Your climate sounds a lot like Denver and 5W/30 year round works fine out here.
Best to change every 3000 if you do a lot of stop and go city driving--if you do a lot of hwy miles, you could go 6000 without any problem. Mobil changed it every 7500 mi. in the BMW test and the engine was still like new after a million miles. The nice thing about synthetic--if you forget and go a little too long between changes, it's not going to hurt that much.
--RA
When I was talking to a shop foreman about synthetics, he had seen the inside of an engine that used Mobil1 and it was "spotless".
Like everything, different dealers have different opinions.
RA - Where did you read about Subaru's official line on synthetic.
-Dennis
It's good to hear about other Subie owners using it--it's great stuff for any car--not just for rich guys with Jaguars and Porsches!
--RA
Later...AH
I think Subaru may be going after the mini-SUV crowd especially via wagon owners by including this towing rating. Why give up your performance car for an SUV just to tow a couple 300lb jet skis 4 miles to the local pond.
Maybe it's a little hard on the clutch, but most people won't tow with this car more than 5-6 times a year. One good launch from a stoplight probably puts as much wear on the clutch as a weekend of light towing.
Never know when you're going to have to outrun a Klingon battle-cruiser!
AH--if you decide to put it in your WRX now, I promise you it won't hurt a thing.
When Mobil first came out with synthetic back in the '70's the formula was a little raw and engines were not manufactured to the precise tolerances they are today--so you needed to wait for the engine to break in 10,000 mi.
Today is different--the formula is perfected and the engines are better, tho I can't vouch for every synthetic out there--Mobil has the most experience and definitely a trustworthy product,IMO.
--RA
-juice
--RA
www.ebay.romulan.cloak
- Hutch
Mike
--RA
Still waiting (damn it!)
Eric
-Dennis
- Hutch
