Visitor Agreement.
http://www.jayelen.com/atf78/exhaust.html
-juice
Yes - some modifications will result in a warranty claim denial. The warranty will not be voided, but each claim issue would be evaluated.
For the most part, folks do not have a problem. However, the people that do have a problem are a lot more vocal than people that don't. If you plan to modify your vehicle, that's fine. Just be aware that you may be responsible for resulting damage.
The torn trunk carpet on the vehicle with the modified exhaust - I don't think so. Only if there is evidence that the carpet was damaged by an outside influence and I think that the exhaust would be way outside!! If your friend has an issue with this, please have him/her call us and we can check it out.
Take care and enjoy your WRX!!
Patti
They seemed to get one of the first models that came over here (wrapped up test in early August). I have heard that the initial batch of WRXs had their share of problems that have since been rectified.
Does this sound normal, or were the earlier models more prone to problems.
P.S. you have to log in at www.autoweek.com. to see the article.
The one thing I didn't understand was the shifter cable comment -- the WRX doesn't have a cable shifter IIRC.
Ken
Here is the quote, and the link, article from August of 2002:
"But its next owner is going to have to deal with a few potentially costly problems in the near future. The struts were pretty worn as were the brakes, and the clutch was beginning to slip. Second gear had become notchy and the shift linkage was in need of overhaul (a chance to install the short-throw shifter kit). And there were numerous squeaks and rattles throughout the cabin—further evidence of its year of yeomen duty."
http://www.autoweek.com/search/search_display.mv?port_code=&cat_code=longtermtests&content_code=01 908222&Search_Type=STD&Search_ID=508040&record=6
(had to break up link into 2 to post)
28K miles in one year with 12 different drivers is pretty heavy-duty usage! I would imagine the WRX got rental car-like abuse during that time not to mention that they did take it on gravel roads. I have a feeling that their other vehicles probably don't go through quite as much in a year.
Ken
They will have to replace at 28K:
1. Tires (25K miles)
2. Struts
3. Brakes
4. Shifter
Sounds like excessive abuse to me!! Also, Autoweek was having technical problems with this car right from the get-go. Just read the first quarter report!
If their car saw off road or gravel duty, I can understand the struts going also, street driving just doesn't hammer the suspension like that.
Shifter - This seems to repeat a concern of several people on I-Club who have synchro issues, etc. I am planning to get the short shifter, but I don't expect that to have a positive or negative effect on the shifter's wear.
I bet it was a fun year
-juice
All things considered, the car did pretty well, despite the fact it was being treated like a race car and never got race car-quality maintenance! For all their concern over the second-gear trouble, I'm willing to bet they never swapped the tranny fluid.
The factory brakes with the Hawk (was that the name?) pads did quite well, very close to some of the brake kits.
-juice
Ken
The upgraded brakes are for you if you're noticing fade, but don't seem to be a whole lot better on that first stop, from what I've seen of that test.
-mike
http://forums.i-club.com/forums/showthread.php?threadid=226013&referrerid=767
-Dennis
-juice
So, what options are out there if one wanted to increase the swept area on the WRX brakes? What about the STi 4-pots?
Ken
I know they've been posted before but the search engine doesn't seem to be working either. Any comments, tips on the CEL?
Nothing out of the ordinary has taken place to cause this. The gas I'm on is 125mi old and drove it to work anyway (26mi approx) w/ the tunes off and didn't notice anything either.
The dealer can't look at it till Monday.
Stephen
-Brian
Does anyone know how much this usually costs to have done by a mechanic or dealer?
Kevin
Platinum tipped spark plugs can be used for 60K miles without any trade off in performance compared to a regular plug.
Ken
So Stephen, how do you reset the CEL? Do you communicate with it through your PDA?
THanks again...
Brian: Yes, you're correct. The CEL history is retained in the ECU even after the light has gone out. I believe it stays there until the ECU is reset.
Rob: Here's the link: www.pocketlogger.com
Stephen
My dw is beginning to want a Palm Pilot. I could see a use for it - for me at least - with the pocketlogger on both of our vehicles. Hmmmmm.....
-Brian
If you want a wagon, get the wagon. If you want the sedan, get the sedan. Have test driven both?
The sway bar is easily remedied.
As for the track, it might hurt you by 10mm as to what size tires you can put on, but other than that, unless your name is Richard or Tommie, then you aren't gonna notice the difference in track width.
-mike
So the only trade off would be the 80 extra pounds, but you'd still have $300 towards mods.
-juice
Another fairly persuasive (IMHO) argument against CAIs is that in a turbocharged car like the WRX, cooling the intake charge is the job of the intercooler, and slight variances in charge temperature going into the intercooler have a pretty much negligible effect on the temps coming out the other side. Hence upgrading your intercooler would have much more of a performance effect than a CAI.
If you do some snooping around i-club, you should find discussions of WRXs making upwards of 350HP, and very few (if any) of these use CAI setups. That says a lot to me.
Believe me, I've crossed water with a big splash. The area around the stock intake got wet. That's where one of the horns goes, behind the passenger side head light.
I did get some sand/dust on my air filter, but I was following someone the entire time, and they were kicking up dust because of the drought.
-juice
Stephen
Oh, and there's that moral dilemma of me buying HER the m100 for MY us. LOL!
-Brian
Any events a little closer to DC?
-juice
Ken
