Any help answering this question would be appreciated.
Keep us posted.
Best regards,
Shipo
Another question...does it pay to put a tranny cooler on these vans? I do some towing of a boat, normally not long distances, but sometimes a couple hours one way. I am not going to keep the van for more than 8 months longer as I want to get back into another Expedition. Not sure if I should look at investing in a tranny cooler for it.
I had another thought regarding your leak; I've heard sporadic reports that the tranny cooler lines occasionally leak, especially at the point where they enter the radiator. Give those a good look-see while you're checking things out.
Best regards,
Shipo
Well, my future brother-in-law came over and we added a quart of ATF-4 tranny fluid. I had forward, reverse and all other drive gears. No noises, clunking, nothing. They all worked good. There was some tranny fluid dripping off of one of the tranny solenoid brackets. Now, if the solenoid needs replacing is there any other parts that should be replaced at the same time? I thought I read somewhere that there is another part that often goes bad at the same time. Also, any guestimates on what I could expect for a cost to fix this if it is not the tranny itself?
Thanks for all the help!!!
Chuck
FWIW, the transmissions in the Gen 3 vans were a weak point, that said, when the transmission went out in our 3.8 liter 1998 DGC after 109,000 miles, I gladly put a new one in as opposed to disposing of the van. Why? Because prior to that point the van had cost me a whopping $8.00 in unscheduled maintenance since it was brand new. I am also happy to report that after the new tranny went in I drove the van another 70,000 miles before trading it in, and during that time the unscheduled maintenance was extremely low (like $400 for a starter, a window regulator, and a muffler). In fact, I was so impressed by the vans mechanical reliability that when we needed a third vehicle for our family, I went out and found a fully tarted up 1998 Chrysler Town & Country LXi with 180,000 miles on it and bought it. I have no doubt that the T&C will soldier on in our family for a number of years.
Long story short, I understand being frustrated with needing to pony up for a large maintenance expense, but given that your van is eleven years old, and given that there are many folks that are getting three, four, and even five hundred-thousand miles out of these vehicles, you might A) forgive the van for the failed transmission, and
Best regards,
Shipo
I realize that you can have problems with any vehicle...new or used, but with my fiancee having a mid 1990's Caravan that went through 2 transmissions before I met her, we both vowed to never go with another Dodger/Chrysler product. I just hope that this van now makes it until fall when I hope to be able to afford my larger SUV.
1) "Flushing" most automatic transmissions is generally considered both a bad idea and a way for a service center to empty your wallet. Why? Because your transmission wasn't designed to have the fluid run through it in reverse and because more often than not, the fluid that ends up in your transmission is worse than what you had in it to begin with.
2) More often than not, Gen 2 and Gen 3 41TE transmissions have failed due to either the incorrect fluid being put into the transmission and/or the transmission being flushed. Bear in mind that the ONLY fluid that should be put in the 41TE is Mopar ATF+4 (or its predecessor ATF+3). If any other transmission fluid, be it Dextron. Mercon, Amsoil, Pennzoil Universal (I've heard rumors that Pennzoil does sell a Mopar approved ATF+4 which is acceptable), then you are almost assured of a transmission failure.
As for your towing, some vans had the "Towing Package"; most did not. If you're driving a van without the package and your boat is heavier than what is outlined in the Owner's Manual, once again, you are highly likely to experience a failed transmission.
Best regards,
Shipo
My question is can i put a transmission in the van out of a different make and modle of van? and if i can what would be the best kind to try? :confuse:
Yes, you can put a transmission in from either a Chrysler Town & Country or a Dodge Caravan.
Sorry, the Devil made me say that. :P
Long story short, your best bet would be to put in a remanufactured transmission as opposed to having yours rebuilt. Remanufactured transmissions can be had for about the price you're being quoted for the work on yours and come with the additional benefits of a 3 year / 36,000 mile warranty and of having certain updates that will effectively match the latest engineering build of the Gen 3 transmission, which by the way was from 2000. While you're at it, you might consider adding a transmission cooler into the mix.
Once you get the new tranny in, perform a pan drop, filter change and oil top-off every 30,000 miles. If you do this the transmission will most likely last the rest of the life of your van.
Care and feeding guidelines for your new transmission:
- Do not under any circumstances have the transmission "flushed". Flushing is a bad idea for most transmissions and especially bad for the 41TE.
- Buy your transmission filters from a dealership. I've heard of entirely too many trannys failing because of cheap aftermarket filters.
- Buy MOPAR approved ATF+4 transmission oil. Said another way, the various "Universal ATFs" or Dextron, or Mercon are NOT acceptable for these transmissions. Using anything other than ATF+4 will most likely result in a transmission failure in the not too distant future.
- Do NOT use any transmission additives regardless of what is written on the packaging.
I was also told that there are no Dodge/Chrylser products assembled in the United States after 2002. Dodge/Chrysler I guess are done in Canada and Plymouth products are done in Mexico or something. I have my next vehicle choice as a 2005 or newer Suburban or Yukon XL. Completely different vehicle that I am sure I will be much happier with.
FWIW #1, there was a minor redesign of the transmissions for the1998 model year that eliminated a number of problems, and a much more substantial one in 2001 for the Gen 4 vans that made the transmissions fully compatible with ATF+4.
FWIW #2, I am a moderator on another board that is dedicated exclusively to Chrysler minivans and have been tracking the transmission issue for a number of years now, and the number of Gen 4 vans (which include the 2001 and 2002 model years) that have had transmissions are very few indeed. The transmission in our 2003 is identical to the unit used in the 2001 and 2002 vans, and it now has 140,000 miles on it without so much as a fluid and fiter change (thank you ATF+4).
FWIW #3, North American (i.e. Canada, Mexico AND the U.S.) Chrysler produced vehicles continues to this day.
A few points:
- 1. Your Owner's Manual makes no recommendation for any transmission service for the life of the vehicle under "Normal Driving".
- 2. If you operate under the "Severe Service" category, then your Owner's Manual says the following: "Every 60,000 miles/100,000 kilometers'60 months, change the automatic transmission fluid & filter if using your vehicle for any of the following: police, taxi, fleet or frequent trailer towing."
- 3. Under no circumstances should have the transmission "Flushed", this service is only useful for "flushing" the contents out of your wallet, not to mention the fact that there are entirely too many reports of transmissions failing shortly after a "flush".
2) Try shopping for one yourself via the likes of Napa, Autozone...
3) While I have occasionally heard of the Evap Sensor failing in these cars, I have heard of far more cases where the evap system integrity is compromised due to a cracked rubber hose (such as those that connect to the evap cannister).
Keep us posted.
I owed a '96 G/C w/3.8 for 10 years and was amazed that it always shifted smoothly for over a 100k with one power flush @ 60K. Though it had its share of problems i.e. a/c loosing charge ever year after 8 yrs, serpentine belts annually shredding till I found out the water pump pulley bearing was loose and causing misalignment. But all in all it was a pleasure to own.
My '07 with 24K was dropped off this morning for a couple of routine items however we have experienced the common tranny problem of the initial cold morning hard shift from 0-20 mph. Last time in they performed the software update and though it seams better I am concerned that over time this will cause wear or damage. I am not sure at this time if it warrants my pursuing the dealer to change out the torque converter. I have told my wife to ease through those cold morning first shifts. Any input would be appreciated. :confuse:
Thanks for any help
the 3.0,3.3 and 3.8 are the ones that go in there but hey if you can manufacture and weld mounts , axles and exhaust then sure it will fit lol
http://www.toolsource.com/dipstick-nag1-transmission-p-100198.html
but reads that it's for the 3.5l engine. Does anyone know if this is the best way to check the trans fluid, and will this one work? Anyone know a better way, they want 72 bucks for the thing.
It's under warranty, thinking I should leave it alone....
If you'd rather change engines, get the 3.8, it's got a ton of torque and is still good on mileage. In a short wheelbase (non-Grand) van it would be fun to drive. Try to get one from the same year van if you can. Town & Country vans often had the 3.8 so start looking for those.
http://www.governmentauctions.org/blog/index.php/2010/05/24/2003-dodge-grand-car- avan-grandiose/?dt_p=Monday,%20May%2024,%202010&tm_p=12:23%20PM&cat_p=Online%20A- uction%20Items,%20Seized&tag_p=Auto,Automobile,car,Dodge,Grand%20Caravan,Minivan- ,vehicle,
