Lincoln LS
18687899192299
  • alphansteinalphanstein Member Posts: 95
    What is it and why is it important to the ability to shift? I saw this come up in a few discussions but never thought to ask. Now I am curious and want to know more.
    The discussions from Mark would speak about how the torque convertor would lock, but I don't know what this means to me.
    Also, all this talk about airbox, why not put a cone filter on the intake? Is the heat in the engine compartment that detrimental to having the increased airflow? At highway speeds and normal driving, the cone would seem like a good fit since the air flowing into the car would be relatively cooling. But in traffic or at standstill, would the gas consumption increase that much do to the sucking in of hot engine air? And would this increase be compensated for by normal driving conditions and a great increase in MPG? I have also heard that cones tend to be noiser than traditional airboxes.
    Hey Brian, maybe this is the next test for the project car?
    Jeff
  • mkovalskmkovalsk Member Posts: 114
    One of the features of a torque converter is that it allows slip between the engine and the transmission. Without this slip the engine would stall every time you stopped the car. Think of a manual transmission car. If you stop without releasing the clutch the engine stalls. If the converter didn't slip the same would happen on an automatic.
    With a manual transmission you press the clutch to disconnect the engine from the transmission when you need to shift. The torque converter slip does this function for an automatic.
    The slip also has a down side. When you are not stopped and not shifting you are losing fuel economy with that slip because some of the engine's power goes to turning slip into wasted heat. When the computer sees that the car does not need the converter to slip it activates a clutch inside the torque converter. This clutch locks the torque converter input and ouptut so that there is no slip. That's what is called lockup.
    Mark
  • buckwheatbuckwheat Member Posts: 396
    Ford extends halt in Thunderbird, LS sedan production.
    http://auto.com/industry/iwirf21_20010821.htm
    Speaking of perception, in reading this article it is my conclusion that if it were not for the Thunderbird both production lines might not have been stopped. The automaker is "being super, super cautious" with the 2002 Thunderbird according to a Ford spokesperson.
    The assembly of these cars using Mickey Mouse suppliers of parts made to Ford engineers' specifications does not exude quality and only supports marketing research in an analysis that "Ford is sloppy when it comes to quality." The mantra, "Ford quality is job one" is recognized only in the stalls of various restrooms. "You cannot keep having these kinds of problems."
    It appears Ford maintains a status of being re-active instead of pro-active. The fact that they caught this problem on the production line does not address the quality of part and supplier.
    My feelings on this can easily be as a result of the constant bombardment of Ford failures in the print, TV and other media outlets. A realization has to set in sooner or later that Ford is it's own worst enemy.
  • noshonosho Member Posts: 119
    IIRC, the inlet air temperature is measured inside the airbox. The engine management system calculates air mass based on this inlet temperature and how much air is flowing by the MAF sensor. A cone filter would result in an inaccurate air mass calculation and thus mess up fuel mass calculations.
    Amen.
    Back in the'80's, Ford "had a better idea." It was Total Quality Management, or whatever they called it that week. I rented (by default) a number of Ford products back then when our corporation was allied with Hertz and was, in fact, really impressed.
    I haven't read the right books lately, so I'm not sure if this is common knowledge, but it takes 10 to 20 years to completely integrate a "Total Quality" system in a corporation. But the worst is. . .it's cheaper to blow it off to achieve quarterly or annual "metrics." To see the results of customer-driven TQ programs requires years. Management is judged quarterly or at least annually. Can anyone spell "director and higher bonus programs?" If senior management stands behind TQ, it will eventually pay off, but if they blink, they can look really, really good for a quarter or two.
    And that's for companies that don't have to deal with tire liability that goes to the moon and a couple of other recalls that we don't need to go into here.
    One person's opinion.
  • ezaircon4jcezaircon4jc Member Posts: 793
    I have a 2000. The radio problem was there upon delivery. I don't think there is a TSB, but there should be. I would just tell your dealer that the radio is the problem and have them change it out. This should be a known problem.
    My steering controls didn't work like this: mute, didn't work; channel up, volume up; channel down, volume up; the volume and media button worked as they should.
  • leadfoot4leadfoot4 Member Posts: 593
    I'd also be interested in the new style airbox, but I have one question. Does it use the same airfilter as my 2000 ? I already have a K&N filter, and I'd hate to have to toss it in favor of another.
    Speaking of air filters, I put the K&N in just about a year ago. I inspected it a couple of weeks ago, and it was quite clean and free of debris. The cabin air filter, however, was quite another story. In a word, it was filthy !! I guess the base of the windshield is indeed a source of high pressure air.......Ram air anyone ???
  • goodyrlgoodyrl Member Posts: 83
    Can somebody please tell me what color the heated seat indicator lights should be ? My drivers side is a non-distracting green and passenger side is a bright orange. Thanks
  • stanny1stanny1 Member Posts: 962
    Leadfoot- the filter is the same. The 2002 airbox has a different "bottom". According to Brian: "It has two inlets. The regular one that we have and an additional horn halfway up the snorkel right about where it can suck air in from the opening in the front crossmember next to the driver side headlight to take in air from the front grill".
    I can't visualize this until I take off my air box and look around. When Airconhall showed me his mods, he first took off that black plastic piece that goes across the front above the grill by twisting off four "screws". Then access to to the airbox is much easier.
    Can somebody please tell me what color the heated seat indicator lights should be ? My drivers side is a non-distracting green and passenger side is a bright orange WHEN THE HEADLIGHTS/DASHLIGHTS ARE ON AND SEAT LIGHTS OFF. THAT'S THE ILLUMINATION I AM SPEAKING OF.
  • packv12packv12 Member Posts: 95
    Both of my switches are the non-distracting green that you mention. They only light up orange when the seat heaters are operating.
  • carjimcarjim Member Posts: 155
    How does this sound to you, owners and potential buyers of a prestige brand? "BLOW OUT ON ALL 99 CONTINENTALS, all clean and low mi." A blow out of a Lincoln vehicle? Where's the protection of the brand?
    Do you think this hurts Lincoln? I do. Even if you view the Conti as a dressed up Taurus/Sable, doesn't the name LINCOLN deserve better treatment?
    Surely the company can put some pressure on volume thinking like this. For anyone who could do so, the culprit is Mac Churchill in Ft Worth.
  • thomas_lthomas_l Member Posts: 134
    Here's the How Stuff Works transmission page.
  • jschwartz2jschwartz2 Member Posts: 4
    When will the 2002 models arrive at the dealers ?
    I see on autoweb that the 2001 V6 is rated at 210HP and the 2002 V6 is rated at 210 HP . Is there really a 10 HP increase for 2002 ? If you have a V6, are you satisfied with acceleration ?
    I have the six, and with the Borla and "improved" airbox, I am quite satisfied! I must be pushing 200 horses at the wheels!
  • garnesgarnes Member Posts: 950
    cone filters - caddyinfo.com (I know GM) has an interesting experiment with the cone filter induction system vs the stock air box. They noticed a slight DECREASE in HP with the cone. They did say that the bottom of the air box was not removed for the test (I have no idea why as this would let more fresh air from the opening below the box). Hot air off the engine is a concern.
    The cone filter induction systems wound need a port for the temperature sensor though in order to work properly. I think you are best off modifying the stock box the best you can and keeping the air intake fresh.
  • akirbyakirby Member Posts: 8,062
    Continentals and Town Cars have had very high dealer incentives for years. They could be routinely bought for several thousand dollars below regular invoice. I believe the pricing was lowered this year to reflect that fact. This hurt the resale % because the car actually sold for thousands less than invoice but the residual value was based on a much higher initial sales price. Besides - these are 99 models. 3 years old. I don't think it says anything at all about Lincoln in general.
    Cone filter kits don't use an airbox, do they? I mean, that's the whole point - to get rid of the restrictive snorkel and airbox, isn't it? Or was this just a cone shaped normal air filter?
  • ls1bmw0ls1bmw0 Member Posts: 782
    Some of the GM models use a cone filter inside a round airbox. Our Suburban has one, so I wonder if it is the same in the Caddy.
  • ronniepoohronniepooh Member Posts: 339
    I used to belong to the National BMWCCA club, and recall a local club event where the guys dynotested a 95 or so M3 during a cone filter test. The underhood heat wasnt the biggest factor, (although it was a factor), it was the disruption of air flow to the filter due to fan wash. It was interesting to see the dyno numbers improve right in front of your eyes when the guys would place a simple piece of cardboard between the engine fan and the cone filter. Removing the cardboard would cause the hp/torque numbers to drop. I cant recall the specific numbers, but I recall the absolute optimum setup being a car that had a homemade heat "shield" installed/made from a sheet of tin purchased at Home Depot. The other mod was a long piece of aluminum house dryer tube connected from the lower portion of the bumper (cool air down there) back up to the front of the cone. Yeah, looked really homemade, but it improved things more than just a plain naked cone sitting in the engine compartment.
    And yes, the cone filter does increase acceleration noise. Some may like it, some may not.
    YMMV.
    Wonder if any Lincoln engineers can answer this. If we 2000-2001 LSV6 owners decide to upgrade to the 2003 airbox for the added hp, wouldnt the PCM need a reflash to accomodate the increased airflow?
    Ooooh, I can answer that since I asked when I saw it! :)
    If you upgrade to the 2002 airbox there is no reflash necessary. The computer learns about the change and automatically adjusts for the increased air flow by increasing the fuel flow also.
    Yeah, I'm talking about an aftermarket cone filter that is exposed to the engine compartment air. It would be fitted with a short tube (with an air temp sensor on it)to the engine. I have no idea why the test I mentioned left the bottom portion of the air box on.
    The FIPK kits that K&N sells for some cars are essentially just this, except many do have the "heat shield" mentioned by ronnie.
    Okay, all your feedback seems to verify that the issue of airflow is more complex than I ever imagined.
    Brians comment about the computer making automatic readjustments for the new airbox leads me to wonder if it will do so for a cone filter, or will the temperature be so out of range that it would throw off the calculations?
    Alex Borla talks about computer recalibration after installing an exhaust system on his web site. The computer should re-adjust in under 1000 miles OR you can disconnect the negative battery terminal and let the computer find new sensor values. There should be no need to do a "reflash".
  • heyjewelheyjewel Member Posts: 1,046
    Oooh - just what I needed: *more* fuel flowing into my engine! :>)
  • scottc8scottc8 Member Posts: 617
    Can the new airbox be retrofitted to the V8? Or will we have to wait for the supercharger?
    OK, just the first question, please.:)
  • riezriez Member Posts: 2,361
    Before hitting the beach I bought the September issue of AMI AutoWorld at a K-Mart. Had never seen this magazine before. The Passat cover story really interested me (thinking about V-6 AWD version) but happened to read their review of the Crown Victoria LX with optional Handling & Performance and ABS/TC packages. Couldn't believe the good things they said about its performance. Shocked me to see them quote 0-60 mph time at only 7.0 seconds. Can't believe that is accurate. And braked from 70-0 mph in only 164 feet. Can this be right? Is an LS this quick? Heavy Crown Victoria has only 235 hp and 4-speed automatic.
    Looked at V6 engine. The air temp is measured immediately after the MAF sensor in the air tube between the MAF and the throttle body. Airbox isn't needed....
    The LS-V8 could be faster than 7.0 (mid 6's) if it had a proper first gear. It doesn't so it is slower even with a more powerful engine.
  • johnnylincjohnnylinc Member Posts: 308
    Lincoln does, in fact, have fairly specific and stringent rules regarding the wording and content of ads for new Lincolns. Since the factory is heavily involved in the financial end of the advertising part of the business, this is understandable, particularly regarding the image the manufacturer wants to put forth.
    Since the case you mentioned involves used cars, though, I doubt that Lincoln would (or should) have much influence. If a dealer goes to an auction and buys a bunch of used Continentals and spends his own money advertising them, I don't see how Lincoln could have much say in the matter. I hear what you're saying, but if Lincoln isn't helping to pay for the ads, then they probably shouldn't be able to dictate content. Just my .02 worth...
    Note: I have no idea how the used-car advertising deal works--does the factory support dealer used-car advertising?
  • drolds1drolds1 Member Posts: 247
    We were out of town from 7 AM Sat. morning until 2 AM. Mon. morning. Didn't have a chance to check yesterday. I can't beleive the number of posts I had to catch up on!
    Tell you what though. It sure is gratifying to see the board looking like it used to; the kind of give and take that got me involved in the first place. I've enjoyed reading each and every one of them & that's something I couldn't say of late.
    We'll be heading out on our annual summer trek to Maine next week. I can't imagine how many posts I'll have to catch up on if things stay like this. It's great. Keep 'em comin'!
    Artie
    From my observations, the air box is the same. Someone in the past mentioned that the F-150 airbox would adapt to the LS and is big enough for a cone filter. And one of my clients paid almost $200 for a K&N "kit" that had a cone filter and a larger air meter for a late model Explorer. Maybe K&N could build something for the LS....Help Brian!
  • reneleblancreneleblanc Member Posts: 144
    Did anybody see this news item?
    http://www.auto.com/industry/irep21_20010821.htm
    I hope production will be underway for LS Mania 2.
    Also, I hope my 2000 LS's hydraulic cooling fan keeps working perfectly... I wonder if the production problem was related to something that just recently occurred.
    Thanks, stanny. I'd like to retrofit mine if it can be done with stock parts. I'm satisfied with the V8 hp but breathing is a matter of efficiency, and that has a lot of appeal. Guess I could go over to the 300M board and find out where Hatboy got his bitchin' hood scoop. :)
    Since the overheating was found in the factory testing before the cars left, and we haven't heard about this problem on current cars, I conclude that this must be a change for the 2002 models only.
    With all the bad press about Ford's problems I'm almost beginning to think that they would be better off (publicity wise) to ship these vehicles with known problems and fix them at the dealerships silently under warranty. Geez - they put a process in place to find problems before they leave the factory (I'm thinking of the LS/Tbird overheating and the Explorer V8 engine problems, plus I think there were a few more in that category lately) - it works - and people start griping about poor quality. Damned if you do - damned if you don't. You can't expect something as complex as an automobile to be perfect. Actually, you could - but nobody here would be able to afford one. I personally applaud Ford for halting shipments until the problem is fixed. I would rather have a vehicle with 4 recalls in the first 2 months than have one with 2 problems that they know about but don't tell you and don't try to fix until they break.
    This is only related to the new cars on the production line, 2002s. Ford found a problem in production line testing and halted the line until the supplier corrected the problem. Since Ford, like most of the auto. manufacturers, operates with a fairly stringent and lean just-in-time inventory supply, they now have to wait until the supplier can get them new modules that work.
    I think Ford is so much under a microscope right now, that anything that happens, no matter what, is going to be reported as news. While this is a serious problem, I think in years past it wouldn't have even rated a mention. I'd be curious to know how demoralizing it must be for the Wixom people to have to function this way. Production line problems have always existed, inside and outside of Ford.
    nosho wrote:
    "The LS-V8 could be faster than 7.0 (mid 6's) if it had a proper first gear. It doesn't so it is slower even with a more powerful engine."
    What would be a proper first gear? The automatic's first gear is 3.25:1. What would you propose as a proper first gear?
    Mark
    What would be easier would be to change the rear ratio from the 3:31 in the LS V-8 to the deeper 3:58 as used in the T-Bird. Although the T-Bird is heavier, the deeper rear ratio propels it to a faster 0-60 (C&D 7.0 sec).
    Mark, was the rear ratio change dictated by the fact that the limited production of T-Birds would be more CAFE friendly?
    Would installing a 3:58 by current LS V-8 owners screw up the TC, ABS sensors?
    Thanks, Stan
    and there were a choice of how to get more power what type of powerplant improvement would you choose and why. If we assume weight and power is considered the same across the board and any of the choices keep the same weight balance and price here are some possible choices that I thought of:
    1. Upsize the engine to a larger displacement engine. (Good ol' American hotrodding mentality. No substitute for cubic inches)
    2. Supercharge the current engine and add VVT to the mix (More exotic but relatively commonplace)
    3. State-of-the-art components (not sure what that would be since they would be state-of-the-art and complex )(Head-of-the-heap type stuff that you would read about typically from BMW)
    My preference would be the first one purely from a service perspective. If the power increase would be the same, a relatively simple engine transplant to a bigger engine that produced more horsepower would be simpler to fix in the middle of nowhere if the car broke down. If it was built off of an existing block there would be more parts available. Granted, this approach doesn't quite have the panache of the other two.
    P.S. This is completely blue-sky stuff, since Lincoln isn't doing anything, but I thought it would be fun to daydream for a while plus I'm curious about how the rest of you would build the M-killer if we could! :)
    Brian
    M5 Killer? If I was LM, I'd say 540i killer. The M5 is a true exotic with little market. LM wouldn't sell enough, especially at the price necessary.
    It would be easy enough to make a 540i killer, though. The parts are already on the shelf. Easy.
    Take the LS as it is. Raise the srping rates a bit for the slightly heavier drivetrain. Drop the Cobra engine in, AS IS. Put the entire IRS Cobra rear end in, AS IS, including the (missing in the LS) limited slip differential. Just modify the mounting hardware. The Tremec is not a "world-class" six-speed to LM, but I would take it. Ok, build a new flywheel housing to take the Cobra clutch and the six-speed Getrag but this is gonna cost money. It would be simpler just to put the WHOLE Cobra drivetrain in the LS.
    Yes, you could fuss with the 3.9. Jag it to 4+ litres, add VVT, etc. But the American approach has always been to be simple and do it the least expensive way. Toyota put the Supra drivetrain in the Cressida in 1982 for a four-door Supra. Why not a four-door Cobra. American car companies have yet to realize what BMW discovered long ago: The ONLY difference between a two door and a four door IS two doors. You don't have to throw in demo or psychographics when you add two doors. No, marketing #%$^@s, four door buyers don't suddenly get older, slower, poorer or whatever. They want a dual purpose car. If you don't make them, they hop-up Civics, modify Trucks, buy BMWs instead. At least pick-up trucks have RWD at a reasonable price. So Ford can build a 21st century 4 door GTO if they want to. Instead of some of those styling gurus with the long hair, you could hire Jim Wangers for some input. He has a place up in Carlsbad, Ca that car companies use.
    Ford has the parts, they just don't have the will.
    But sit still, and the market will come to us. The new Sentra SE-R has a six-speed. The Infiniti G35 must be creating nightmares for many marketing wonks. RWD, limited slip, six-speed, 270hp, 3.5 litre.
    It's time LM realizes that there are two distinct markets for the LS - Luxury and Performance. For the Conti replacement market, the non-sport LS as is. For the BMW wanna-be market (at a better price point, because BMW's are IMHO overpriced at the performance levels), the LS needs to do serious homework. Cars vs. appliance buyers - you can make them all happy. And it's already in the parts bin.
    Ah, that was better than a dry dream.
    Given the reliability/serviceablity "issues" we've been dealing with for much simpler bits of the vehicle, what's the best approach?
    #2 works for me. A bigger engine probably won't fit and has all kinds of CAFE baggage.
    I'm 95% convinced that CAFE is behind many of the problems we discuss here: miserable AT gear spacing (somewhat due to other applications), driveability issues with the manual (why is it that so many of us who have driven manuals for 30 years kill this engine so often?), absolutely abysmal fuel mileage relative to the competion, and on and on.
    But, I digress (as usual). Turbo- or superchargers (plus the obvious VVT that most cars in this category already have) offer the biggest bang for the buck, because with proper computer magic, the emissions stay reasonable, the package doesn't get (much) bigger, and the motor gets much stronger. Good tradeoffs.
    Then there's the counterpoint, which I think is irrelevant to most users (hate to say buyers) of the LS. A lot of this stuff impacts long-term reliability. While many folks who populate these forums think long-term is 18 weeks (or 3000 miles, whichever comes first), one or two of us are thinking in terms of 6 - 8 years and 150K miles.
    Having only participated in the Edmunds forums for the past 18 months, I've learned that many (if not most) of the people who are pumped up about cars could care less about whether it's possible to afford them when the warranty doesn't cover whatever goes wrong. Lease it, pay the monthly, lease the next one. If that's where everyone is going, I only have one question. What happens to all those cars coming off the lease?
    Ya think the value of your car could go south if the off-lease vehicles sell for $1.85?
    Just a thought. . .or so.
    has a blower for the Duratec equipped Escape. Kinda makes me wonder......
  • lolaj42lolaj42 Member Posts: 420
    I'm thinking of BOTH options 1 and 2. A larger displacement is the easiest thing to do. The current 3.9 liter V8 can easily be bored to 4.3 (isn't Jag already doing that?) Adding VVT get's you better low-end torque without sacrificing hi-end hp. The VVT feature also adds to the level of engine refinement, and sophistication . . . in keeping with the Luxury aspects of the LS as well as performance (IMHO). By adding a blower, the high altitude, mountian performance noticeably improves, and would really cater to the folks that NEED the better 0-60 times.
    How's that for compromise? . . . I want it ALL!!!
  • klarson1klarson1 Member Posts: 60
    For the past 3 weeks I have been driving around with Silver Duct tape holding up my RR window.
    18 inches long and 6 inches wide...of course I change it regularly to keep it looking fresh..
    Now that would be a great TV spot to show the "Lincoln Committment" to customer satisfaction..
    Kevin
    Who's still waiting for the dealer to call and tell me to bring her in for the second RR window repair....by the way... for those interested... the dealer insists that I got the "upgraded"
    regulator assembly the first time it was fixed...so if they are telling me the truth (which by the way I doubt... from past experience) I look forward to spending lots of time at Home Depot replenishing my supply of Duct Tape...at least until the darn thing is paid for and I can trade it in on a BMW. ( that was a joke... really... can't afford a BMW... at least not yet..)
    A "proper" (decent) first gear would be 4.40:1 instead of the 3.25:1.
    1st now shift around 47mph. A 4.40 would shift at 35mph but would lower the 0-60 time from 7.4 seconds to 6.7 seconds.
    This is a significant improvement without any "major" changes (because of the interaction of the drive and overdrive gears it probably is "major").
    IIRC the LS doesn't normally launch in 1st anyway, unless 60% throttle occurs, so fuel economy wouldn't be effected but launch "feel" would be greatly improved for those occasions when a quick launch is necessary.
    This is assuming the engine is revving at 2900 rpm for launch (which the mags do for their "fast" runs - except for the M-B C32 AMG reviewed in the sep. R&T which has a maximum launch rpm at 1500 due to wheel spin).
    (3.58 Rear: not practical due to gas mileage - it effects ALL gears. Nor is it strictly necessary as changing "just" first gives the desired off-the-line push without effecting gas mileage significantly.)
  • jnowskijnowski Member Posts: 96
    I wouldn't buy one even if I COULD afford one. Besides the obvious "yuppie scum" image/baggage it has, I simply do not pay for "intangibles". Give me substance for my cash!!!
    In D4 & D5 you get a first gear start. Only in SST mode ,or you've selected 2nd or 3rd, will you not start in 1st. BTW, the way I've always understood it, he who shifts first usually loses. I raced a Chevy 2spd in my '65 4spd Mustang (way back when...). At about 40, I had to shift. He was winning as long as he stayed in 1st (about 65). After his shift to second (I was in 3rd), I finally passed him. I had a 289, he had a 283, Malibu, I think.
    I agree w/stanny, the M5 is a little too far out there. I know this is Blue Sky, but for me it's more fun if it's feasible. The 540i seems to be a perfect target, especially since, as has been said, the parts are on the shelves. I love the idea of the Cobra engine, but concerned about the weight. Is it aluminum? Can't help thinking about what Jaguar is doing with small-displacement engines. They're getting something like 385 hp from a supercharged 4.3 litre engine.
    So, for me, leave the suspension and balance alone, add limited slip to the current LS rear end, some serious wheels and tires, and give me everything Jaguar (or Aston-Martin!) has under the hood. This won't just blast 540s, it will "make the rubble bounce". M5s may still drive away from us, but slowly.
    jnowski: Hear, hear!
    I like the cobra idea - manual tranny with off-the-shelf parts.
    Easier - super-charger: look at the M-B C32-AMG. A 3.2L V6 that does 0-60 in 5.1 seconds @ 3780 lbs weight and an automatic (with a 540i price though). A less expensive SC would give 540i performance with maybe an ~$2K cost.
    SHIFTING - it all depends on the engines torque curve. High revving engines with "poor" low rpm torque need fast 1st gears to get the rpm's up to the torque band. I've run a simulation using the LLSOC published torque curve and the present transmission does 0-60 in 7.4 where-as a 4.40 1st (all other gears the same as now) does 0-60 in 6.7.
    I've simulated the ZO6/C32AMG/Maxima/3.2TL-S/SHO/A6-2.7T/M roadster/SLK32AMG/boxster-S/etc and all simulations are very close (+/- 0.3) to the actual numbers that the mags are getting so I have confidence in the numbers I'm getting.
