Brian,
Do you have any pictures of the Project car you could share with us. I am quite curious on how it's looking under the hood. You probualy already guessed that I have a V6 which has a different zip-hose compared to the V8. I want to replace the stock one with a bigger diameter hose. Would look fantastic if someone made a carbon-fiber hose for the looks.
Einarvikng,
I was intrigued by your speech, I guess thats why your an engineer and I'm not. I should go back to collage and take some more chem. and physics.
Have a good day,
Mike
If you want low restriction, take the filter out.
If you live in the desert (we have lots of dust), get a filter that removes it.
If you want to try to show/prove that a particular filtration system does or does not lead to premature engine failure, bring me 20 samples of each approach, all 40 of which endured the same environment. Yeah, . . .right.
It's highly unlikely to happen. That's why all this anectodal stuff will continue to be posted. First person to bring actual data wins.
Carbon fiber is definitely being considered once I make sure the prototype really works like I think it does.
Brian
Tom
For me, I'll not be using a K&N filter unless it can be shown to achieve at least the same level of filtration than the OE paper filter. How about you Steve?
"Our filters are tested by 2 outside, independent laboratories.
They have been proven to stop at least 97% of particles on a SAE fine dust test.
This test uses mostly particles in the 0 - 5 micron range but goes up to 20
microns. For comparison, a paper filter stops 98% on the same test and the
OEM minimum standard is 95%. Foam is generally the worst media with a
typical efficiency rating of 75%. To get higher ratings, the foam must be
more dense and therefore way more restrictive. The "tack" characteristic of
a K&N allows for increase filtration without loss of flow as well. As it
get dirty, the effectiveness rises to 99% without a loss of flow. Paper too
hits 99% but with a significant loss of flow."
Now I can't prove these figures are correct but I can't disprove them either. Can we let the dead horse lie?
Tom
Anyone else have the airbag light on problem?
I told the service writer it was 1G cornering that was simulating a crash so the sensors were activating. Just joking.
for example
In the case of mounting the intake low during summer with say 90 degree air temps and the 130 degree near road temp mentioned, these two temperatures have nothing to do with each other. With respect to Carnot that is. The radiator sees 90F, the value that would affect in the formula, (the coolant temp actually dictates here), the combustion chamber sees 130F plus any changes in air temp on the way to the combustion chamber.
I do agree with the statement of the bigger the difference in temperatures, the bigger the bang...for the reasons stated in the previous post...greater expansion due to the change in the T in the PV=mRT formula. ie larger delta T greater delta V therefore grater power(actually torque)but who's counting?
With regard to the project car, there is NO ram effect at low speeds. The increase in power is due to decreased friction, read restrictions, in the system. The next time you take the car to the dyno, try sticking an 100 mph high cfm fan infront of the intake. You will see a great increase in power. That is the RAM effect. That has quite bit to do with Bernuelli's equation(s), minus non-linearities due to the compressability of air. In the case of this, some carefully designed restrictions would be helpful by producing greater static pressure, ie denser air.
But anyway, let's not go there for fear of more non-LS discussion.
to Stanny1, I hope I have not offended you in any way, that was not the intent.
With regard to K&N, I have one. There is well documented trade off here too. The fact is in this case you trade off engine protection with reduced maintenance freaquency and increased power/efficiency. That is a fact. The question really is how much power do you gain for how much engine wear is increased due to increased particulate infestation. That is debatable.
Have fun.................
Scott
I'm experimenting with a re-calibrator that will allow adjustment of the voltages coming out of the sensor which will allow a richer or leaner air fuel mixture compared to stock.
Looks like Brian is really getting into "electronic hot rodding".
Mike
Geez, I REALLY miss the days of just jetting the Holley double-pumpers and changing the springs in the distributor. Life was SOOOOO much simpler then and you didn't need a degree in electronics to bump up the power
On the other note, both Magnaflow and Borla will be less restrictive than the stock mufflers. If you are going to custom-fit them you probably should go with the biggest (longest) mufflers that you can fit under there. The straight-through muffler types such as these don't lose performance like the baffle types. If you switch them out without switching out the stock pipes you won't see much of a performance increase, which is relatively small anyway. There is at least one club member who has put on Flowmasters and is also happy with the sound. Personally the Flowmasters and Dynomax have a bit too raspy sound for me. The Borlas and Magnaflows have a deeper sound. Whatever you do don't remove the resonators unless you want a giant headache from the very loud resonance that will occur.
On the V-6 the pipe diameters get ridiculously small at some of the crush bends that are in the system, I think 1 5/8 inside diameter is what I measured. The Borla system starts with 2 1/4 pipe and keeps that constant. Several people have the system on the V-6 and it sounds very Continental (as in European, not Lincoln ). It also seems to free the V-6 up more to rev.
Brian,
Where do I get one of these re-calibrators and how much do they cost? Does it adjust itself automaticley for future mods?
Thanks for all the help guys,
Mike
for the first time in 7 winters, since the noise is horrendous on a car with 4 studded snows.
The tire rack sells that size winterfire at $62. I bought mine locally at $75 complete. I nabbed
4 16" LS rims on Ebay for $212.50 inclusing shipping from San Diego to New Hampshire.
They supposedly had only 300 miles on them when removed from the car, but the actual
condition was way more than that, as evidenced by the build-up of brake dust on the insides, even melted asphalt chunks on them, as well as moved (rebalanced) wheel weights. Regardless of that, they cleaned up nicely with wheel cleaner and $3.00 in a coin-op car wash. Now I'm set. Thanks for the reassurance on the fit of 16" wheels on sport suspension/front calipers.
If only we could upgrade 2000 LS 6M to electronic traction control...how hard could that be with 4-channel ABS already installed?
Mike in balmy (65 degree) New Hampshire
Mike
Charter Member, LLSOC
With the Borla, you have the perfect gentleman's car when polite and the right amount of raunchiness when cruising the boulevard staulking the lower class appliances. Mike and I agree that the sanitized stock exhaust leaves the LS without aural personality. Oh, the idle. It "burrbles". I don't know what the Auto sounds like under torque converter load but I have two distinct idles. One is with the clutch engaged in neutral and one is with the clutch pedal in,in any gear. The unloading of the trans load makes the Borla "burble" more. Also of note is the downshifting mode. Coming off 5th down to third and reducing speed to 60 for the 25mph corner causes the Borla go into "orgasmic" mode or "Super Burble". I actually expected a real raspy/boomy when doing forced downshifts but the Borla is like a one way noise device. I credit the lack of stupendous downshift raspies to the computer which cuts off air and fuel flow at idle. So I have to introduce some throttle opening on the corner to maintain proper sound to match the tire sliding sounds as the car does a four wheel drift on the off ramp turn. And of course even larger throttle openings if you want to really break traction and slide more.
It really depends on your personality. When I take clients out in a coat and tie to look at houses I shift early and slowly. The Borla is fairly transparent. Then I take off my tie and make sure I don't get more than 20k on the Firestones. At $69 each, I can afford to have a little fun. I didn't buy my LS to drive straight all the time. But I'm only 53. You younger guys should use caution when driving as I get an AARP discount on insurance and have taken a "Mature Driver" course (although the lobotomy didn't work). For inspiration I regularly review proper driving technique by watching "Bullitt" and my all-time champeen instructional video "Vanishing Point". So, to make this real short, this is how "The Borla" sounds to me.
Stanny1 - Certified Cone Killer-Mania 1.
Mike in "Bone Dry" New Hampshire
It doesn't automatically adjust itself for mods. It has two tiny plastic adjustment screws that you have to manipulate while using a voltmeter. The biggest hassle is that with such a short lead, you can't move it into the car and adjust it on the fly. You have to adjust it, do a test run, and re-adjust it.
Brian
LLSOC Prez
The next Mania event is being tentatively scheduled for Feb. 15-17 (Fri-Sun). The Friday may change to Monday depending on some scheduling issues that have to be worked out.
The Friday or Monday events will be held at Lincoln World Headquarters in Irvine, CA and will probably occupy a goodly portion of the day.
The Saturday event will be an autocross run by the SCCA at either Hollywood Park or at San Diego Qualcomm Stadium. This will be a public autocross run under SCCA rules. That means we'll be able to run against the other rif-raf that look down their noses at the LS.
I don't have more information at this time, but as usual with Mania events, there will be a few surprises thrown in to keep everything interesting!
As usual this will be a LLSOC members-only event with membership cards being verified at the door of Lincoln HQ. So if you're not a member yet and want to go, click over to www.llsoc.com and follow the Membership link to sign up.
I'll keep you posted as we get things finalized.
Brian
LLSOC Prez
BTW-I just checked weather.com.
Phoenix-59º
Outside my building-69º
December in NY?
This will be the latest I've had to go into winter car washing mode (insulated rubber gloves, warm water, long underwear, etc). Not to be consrued as a complaint.
Artie. Charter Member LLSOC- with moonroof open in Dec.
ahhh the simple things in life....
We had frost on the ground this morning when I let the dogs out, although last night's low was only 41 degrees. We're supposed to get to 70 today, but I dont think so . . . only 61 right now (not that I'm complaining, today's high temp is 55 degrees LOWER than what we had in August, so it feels kind of chilly to us desert dwellers!)
I'll put in an order for balmy temps for your arrival!
Also, thank you for the anology on passing up those rice-boys with thier ugly as hell pocket-rockets and those hidious-looking rear spoilers. I hope for God-sake that no one ever puts on one of those mufflers with the 5" exhaust tips coming out of the back of an LS. Thats IMNSHO.
It's right around 78 degrees right now in Sunny Florida. I'm complaing; this is too much for this time of year. I would like to see it get cooler like eg. 40-60 degree weather(I'm origianly from Chicago) where I can use the heater in my car to test it out,hehehe.
Mike
I can get you a good deal on a keyboard that has an key.
Weather is funky. I'm from Montreal originally and a week ago it was colder (28) in Dallas than it was in Montreal. Spent the week in the Cleveland area where it was 70 yesterday and drove over to Dearborn today.
Every LS I saw in the 3 hour drive was driven by a woman.(I'm not out to start a sexist war) but just looking at them, my feeling is they bought a mini town car. I don't care who buys it, they just don't realize what they have under them. Hope marketing doesn't discover this and try and dumb down the car to this market segment.
Now who do I call for another ride in the black LS tomorrow?
Ray
Charter LS member
It's a VERY realistic simulator that scared the bejeebers out of my wife and best friend. They each emerged from their 6-minute ride literally (accurate usage of the word) sweating. Wife said "Never again". Best friend declined the opportunity to drive; said his clothes were sticking to him.
There are only a few in the country, I found one at Opryland Mills in Nashville, and another near Grand Rapids, MI.
Details on www.SMSonline.com
I highly recommend this for any leadfoot or gearhead. Try the Richmond track & let us know your times.
I agree with what stanny1 said. The burble when you let off the gas is worth the price of admission :~).
Personally I like the tips that exit in the stock location. They stick out about an inch or so and just enough to let people who know notice that it's not a stock exhaust.
Brian
LLSOC Prez
Looks great. I personally prefer to have my tips coming straight out with chrome tips. My tips are 2". They must be brought out to just the right length and aligned perfectly to look good.
BTW, I have scrapped the tips more than once on steep drives etc.
Long story short...I could not be happier with the Borla. The sound descriptions above are right on. My 78 year old mother in law does not like noise and she was worried when I got it. Her only comment has been that "it sounds rich and powerful". The tone is really pleasant without being obtrusive.
I was all set to cut through the rear valance and put on a set of 3.5 inch rolled stainless tips. No need...the chrome Borla tips look great and protrude just enough to let people see that this ain't no ordinary Lincoln. While I have no dyno data, the LS feels faster, especially at 30 to 50 MPH, and if I wasn't punching it so much I would be getting better mileage. As it is, my MPG stayed constant at about 21 MPG. A great add on!
Gary
LLSOC member
I let my wife drive ours every day. She spends part of her day on the road. I bought the LS because it's a rear wheel drive V8 and it's not a tank. I wanted the performance. I wanted her to be safe. :-) I drive a putzy company car. But after she goes to bed......... Best damn "family" car I've ever driven.
Ray
Charter llsoc member
They are all-season, but I don't think they'd do great in a foot of snow (what all-season would?).
I bought 17s for $89 each for my ZX2.
I have the same situation as you, only my wife scares the bejesus out of me with her aggressive driving. When we travel together she usually drives and I hold on to the grab handle and chew on my nails. She has made her 50 mile trip home from work in 45 minutes. If you’re ever on the Jersey Turnpike and see a blond in an aqua blue 2002 LS in your rearview mirror, just get out of the way. There are a lot of old folks in my area with LS’s and I also wonder if they understand the high performance aspects of their car. Even if they don’t, these performance qualities make them and everyone around them safer in a panic situation. I also would rather they pull into a parking space next to me in their LS rather then a Town Car.
Tom
Charter LLSOC Member
Just wondering..
I have peace of mind knowing that, if need be, she could actually drive this car because it's not a manual. However, if she doesn't eventually put more miles on it, or feel compelled to drive it more, I may re-evaluate my transimssion selection for my next vehicle. If a LS8 manual happens to hit the market in a few years, I just might sign up for one!
Ray
Now, Teaching I have a cousin like that and we all have tried, she just doesn't want to learn to drive a manual, can but won't.
Now on to the Kumhos, my friend just ordered some for there amazingly low price, but I don't think I would get any sounds like they really bite in the winter and while they grip good in the wet and dry, from the REVIEWS it sounded like they were a bit unrefined... Serious Out of Round issues, very temperamental Stiff when cold, actually a little bit noisy, and uneven wear (even though this might have been from alignment but the guy sounded like he really kept the alignment up etc.)
My friend ordered his for a Civic, and you for a ZX2, I don't know if that would be a good Idea for the LS. Besides NO snow traction, Maybe o.k. on FWD cars but add that to a RWD LS and Laters... See you at the next ditch! Unless of course you switch to Blizz's in the winter.
Airwolf
Rolling in the LSO (Get it like BENZO) That is the slang way I refer to my LS as a fly ride.. Now that being said No Vinyl Tops or Daytons on the ride.
I cheated and made life a bit easier by always having them start on a downhill slope. Once they gain confidence in letting out the clutch without stalling the rest comes easy. My wife learned to drive a stick on my 69 Chevelle with a 350/350. It had enough torque you could roll off in 4th. It could also coast a quarter of a mile while she fiddled to get it into the next gear.
Come to think of it, rent something to have them grind the gears on rather than your LS.
