Visitor Agreement.
this is kind of embarrassing for an 8-cylinder. Especially at that price.
Mike
BTW those red calipers look good! Now mine look bad, never noticed before. Damn you! Just kidding...lol
Mike
http://www.ritchiefamily.com/300m.htm
Goto
http://www.vogue-tyre.com/index-accessories.html
and then look up Chrysler 300m, you will see what I mean! Verrrrrrry Interesting!!!!
YUK!
thats like taking a shower wearing a raincoat---I prefer the bare look myself ;-)
Easyrider300M
The clue is 16 inch wheels.
On the other hand, buying my daughter's 2001 VW Jetta GLs (yup, a gurlz car 8+Þ ..), I went in with TWO folders--one from edmunds.com--THANK YOU, edmunds--and got the car for $200 UNDER dealer invoice. Was the end of da month--quota's ya know....
Speaking of Jetta's--my oldest also has 1999 Jetta. comes home Sunday-anounces front left head light not working...this after I just get out of shower after ripping down Sanitas and washing walls down..gack... I go out, cram my 6' 6" frame under the steering wheel and open the fuse panel. check fuse-looks okay go to put BACK in, and fuse immediately finds nearest hole under dash to fall into. dissassemble 50% of left interior panels trying to retrieve fuse-successful. Find out then left bliker not working-check that fuse-blown. NO replacement fuses in VW--surprise. Ask neighbor for spare-got it and put in. Signal left blinker gives me buzzzzzzz sound. Pop trunk, pull light module to find-broken bulb. I'm telling you, what a pain in the butttocks...
Other news...
I've been asked to do some Flash work for guyfriend of youngest daughter's boyfriend...) starting up a vinyl decal business for cars, boats, cats, dogs....wherever you'd want to put a decal. In return for Flash services rendered (not THAt kind of Flash...) he's prepared to give Club members a 25% discount on stuff. I have NO idea what he's looking for as far as Flash is concerned, nor what his prices might be. i will report back with further info.
PS
It helps if you have steady hands and good eyesight. Also do it it the daylight not in the garage.
forresth: Hey, this is amod I can do. do you have to use high temperature paint, or would Rustoleum do?
300Michael: Targét (the French prounciation: Tar-shay) finally got the blue neon 'wire' in, but I don't like the idea of supergluing the wire down..Any better ideas to afix the wire to surfaces?....
Also tried to contact via email Wildcat Gil--message returned: no such user. I hope all is alright with him.
The Doc
Forrest
Do you think an M would look cool/intimidating if a windshield decal with "FEAR THIS" lettering is applied? How about a huge Chrysler wings logo on the rear window?
http://www.acura-cl.com/forums/showthread.php?s=&threadid=67425
1. I can’t reach my license unless you hold my beer.
2. Sorry, Officer, I didn’t realize my radar detector wasn’t plugged in.
3. Aren’t you the guy from the Village People?
4. Hey, you must’ve been doin’ about 125 mph to keep up with me. Good job!
5. Are You Andy or Barney?
6. I thought you had to be in relatively good physical condition to be a police officer.
7. You’re not gonna check the trunk, are you?
8. I pay your salary!
9. Gee, Officer! That’s terrific. The last officer only gave me a warning too!
10. Do you know why you pulled me over? Okay, just so one of us does
11. I was trying to keep up with traffic. Yes, I know there are no other cars around. That’s how far ahead of me they are !
12. When the Officer says “Gee Son....Your eyes look red, have you been drinking?” You probably shouldn’t respond with,”Gee Officer your eyes look glazed, have you been eating doughnuts?”
Power steering pump, cooler, lines & fittings.
> ..a piece of buttered bread will ALWAYS fall butter-side down on a rug...
I've got one better; one summer at the cottage, getting ready to clean some fish, I was carrying the fish on a stringer along with a sharp filet knife, upside down in a plastic sheath. The knife slipped out, dropped to the deck, bounced on the handle back up 18 inches, turned 180º, landed and stuck upright in my big toe, (barefoot, of course)OW! That's gonna leave a mark.
But; what will Murphy do if you butter a cat's back and drop it onto a carpet???
>...the paint softening the plastic intake runners from solvents...
I don't think it'll be a problem, they're made of plastic composite, which is unaffected by heat and most chemicals.
I did a check later and was able to loosen the damaged screws using the same method, when engine cold.
If you use the screw remover kit and "drill out" to remove damaged screw keep in mind you have to reinstall same screw unless you replace it. I doubt using that screw remover kit will allow you to reinstall same screw, but I'm guessing.
I will eventually replace all the screws and those plastic spacer/keepers. But I'm not sure how the new spacers get properly crimped once over the screw threads. although that may not matter much.
hold it. that spacer being crimped on to the screw shaft is probably to keep it from falling down into the head or elsewhere on the engine when changing the plugs, so I guess it would matter.
The bigger issue to me was having to remove/bust off/cut off the old spacer to allow the damaged screw to slide out of the coilpack. The screws were $.35, I'm sure the plastic spacer/keepers are also an inexpensive item.
I just wanted to get my 300M back on road ASAP.
tnsc300m
My brother stopped by and he just finished installing duals on his Dodge Ram truck. It sounded and looked great and now I got the itch too.
I'm trying to find a custom muffler shop around here to do the work this summer. Even tho I have an LHS I should be able to use the basic ideas posted here....problably just need longer pipes.
(HEY...I just thought of a real politically incorrect decal I could make...."LHS Owners Have Longer Pipes" )
Yours actually does not look too bad ( I am not a decal fan myself). color match is pretty good.
Its those tough-boy ones that are lame and laughable.
Did not mean to offend you.
I'm looking for a vendor that has:
- the overhead console trip piece
- the piece between the map lights (next to the overhead console)
- the 2 strips on each side of the radio/heater piece
- the angled pieces on each front door
- the "one-Piece" 3 hole center vent piece
- the small pieces around the heated seats controls
- the small pieces around the side-view mirror power control
I have seen many layouts on eBay but none with all of these pieces. Any assistance would be appreciated!
I just wanted to make sure I was not putting myself in the same category as guys who do this:
or this:
or this!!!
good luck
Just a note....the setup I used gives the car a mild growl, not very loud at all if you're into loud exhaust. If you want a little louder, go with the Rhino. If you want even louder, put a Flowmaster muffler on it.
M
My 2000 PHP has the 16 inch razorstars, built on December 13, 1999 (I checked, that was a Mon. not a Fri.):<)
They did not have the Magnaflow collector in stock, but had everything else we used. I kept the stock collector and intermediate pipe, but went with a Flowmaster for the back instead of the Dynomax. The Dynomax was in stock, as well. They had a pretty fair selection of tips and I went with chrome, slash cut duals. I am very satisfied with my system. The Flowmaster has no packing to burn out, so it will not get progressively louder with age.
I had to do the cutting on my bumper cover for the right side exit, but it wasn't very hard if you make a good pattern from the left side.
http://dodgeboy.cjb.net
MOPAR or no car!
