Visitor Agreement.
Cliffy, You mentioned that the rebuilds are now getting the new valve cover... "You will also get the new valve cover which has a different part to reduce the chances of a recurrence"..
I'd be willing to pay for the part for my (non-sludged) Toyota since it's now available for rebuilds. I bought my Toyota because of it's reputation for reliability and would like to try to prevent any potential problems with the engine if that's an option.
Do you happen to know what the dealer price would be if I ordered one?
Thx.
That said, I'll try to remember to ask my shop guys tomorrow.
At 16,500 miles, dealer rotated tires. First trip thereafter I experienced shimmy at about 70 mph. After stopping and inspecting tires, continued on with no problem until ten minutes later and same problem.
Returned to dealer and balanced all tires.
At 17,000 miles, same problem on family vacation. Problem is intermittent and stops when vehicle stops. Noticeable bad vibration in steering wheel and entire car. When brake is depressed, same shimmy felt in pedal.
Help...
Also, lately we have been hearing what seems like a bird chirping each time we turned on the AC from a cold start. It does go away after about 10 seconds but we weren't hearing it before.
i've been running 91 octane or higher since day 1. with 91 octane, you will get more mileage and maybe a little bit more power. you can mix up the type of gas but it's best to stick to one kind.
the chirping you hear could be coming from your belt or bearing. during cold weather, moisture forms around your pulleys/belt - when you fire up the engine, it takes a a few seconds to dry up the moisture on the belt as it rubs against the pulley. so u get this squeak/chirp. it could be also coz' your belt needs to be tightened up a bit. if the chirp sound is constantly there, then it's probably the bearing.
i also wait until the engine is at normal operating temp. before i turn on the a/c. i never turn it on as soon as the engine fires up.
We don't hear the chirping sound during cold weather. It only started this summer and with the hot weather we've been getting lately, we need to turn on the AC before everybody jumps in because the inside is way too hot. I guess I could wait a few minutes before we turn it on and just leave the windows open for a while to cool the interior.
Thanks for the info.
another reason could be your brakes. you may want to ask them to check your front brakes.
San Jose, CA
this is why both reg. and 91+ octane can be used, although the maximum performance will be gained by using 91+ octane so computer doesn't have to retard the timing. retarding timing loses performance. the octane of the gas itself has no bearing on performance. its ability to reduce knock in relation to compression is what make higher octane gas special."
so to sum it up, there is a reason why some car makers recommends 91+ octane for their engines. 91+ is not a waste of money if used properly.
Now, for a really stupid question. If I mix 87 octane with a 91 octane, would the mix result in an 89 octane gas rating?
Steve
But for newer engines equipped with an engine management system, for *your* driving conditions you can use different octanes to find the one that gives you the best power and fuel economy. If the engine is already at that peak, increasing the octane beyond that will only cause your wallet to get thinner, since you are wasting your money.
As I read it, start with the 87 octane as a benchmark. Then move to 89 octane for a while. If you do not notice any increase in mileage or performance, return to 87 octane as that will be the 'peak' setting for *your* driving conditions.
If you do notice a difference, proceed to 92 octane and re-evaluate in the same manner. Then decide whether to stay at 92 or return to 89.
Well, its going to take a month and a half to get the 1999 Sludged Sienna (68,000 miles) in for a "rebuild." My Toyota dealer said I was 6th in line for the work.
Anyone have there 3.0 V6 engine rebuilt because of sludge? How did it go? Hows it run? What was the warranty on the rebuild engine? Did they use different parts to help prevent engine sludge from coming back? And if it does, will Toyota cover another "rebuild?"
Love our Sienna, even though its smoking now and then on startup it, runs smooth as silk.
Jason
As far as high-octane for emissions tests, in our state (CT), the word is to use Mobil Super + (93 octane) to clean your valves a little to pass your test. You can also use some Chevron Techron (which has a Porsche part number!) to clean your injectors and valves.
If I lived where it was available, I'd use Chevron fuels, which contain Techron; here, I use Mobil Super +...
My reasoning is due to the variable timing in the engine (VVT-i). The engine should sense knock and move the cam shafts accordingly (along with spark) to allow the engine to run with the timing advanced. This would allow for more power with less gas. The high octane allows the timing to be advanced without knock longer than regular gas.
Not sure of the technical reasons but I get 24 - 25 mpg with it. Usually Gulf 93 octane - with the Fleet Gulf card discount it comes out to be around the same as the mid-level juice.
% waste = % of extra cost - % of performance/economy gain
In November 2001 issue of Car and Driver, an article titled "Regular or premium" looked at this issue by doing comparison tests on five different vehicles using 87 vs. 91 Octane, plus some good technical explanation on what Octane rating is all about. Below is the web link for the article; the hardcopy has more charts, which are not shown on the web.
http://www.caranddriver.com/xp/Caranddriver/keyword_searchresults.xml
Two things to keep in mind when interpreting and relating the results:
1. Performance variability - Even under identical test conditions, the performance of a simply electrical/mechanical device often vary slightly during different test runs, or even during the same test run as the system heats up, which can be observed easily with accurate test instruments. An engine behaves much the same way. If you tests a engine and measured 200 HP and you repeat the test five more times, you should be in the neighborhood of 200 HP, but you may get a slightly higher or lower result (by a few percents) each time. The Honda Accord (V6 with VTEC, probably the one most similar to Sienna's engine in application) tested actually lost a little performance when 91 Octane was used instead of 87 Octane. The Mustang and the Ram gained a little. In each case, the small measured differences could easily be due to the natural performance variability between test runs, rather than the result of the Octane rating change.
2. Test condition vs. normal driving condition - The fairly small performance difference reported in the article is based on the maximum power condition - you floor it and keep it there. The performance difference at "normal" speed that 99% of us drive at 99% of the time would be much smaller still.
Why would a reasonable person want to consistently pay 15-20% more for anything and get not much benefit in return?
San Jose, CA
San Jose, CA
your engine is idling.
jeprox is right about it happening at any speed, but my experience is that it usually happens on acceleration. My truck was doing it when I kept a steady 73 MPH also. If I accelerated or took my foot off the gas it went away. (That's because those things change the conditions that cause the ping in the first place.)
Everything I've been able to dig up on pinging has told me that there are several causes, but the damage can be extremely severe. All the sources said to get it taken care of, or suffer major engine damage.
Here are the things I found out:
Improper fuel - octane too low
Ignition timing - Timing set too advanced
Spark plugs - old and/or not properly gapped
Overheating - bad thermostat, ignition timing off, bad water pump, clogged passageway
Wrong oil - Oil viscosity is too low; getting past the rings, burns in the engine, creating deposits
(that was my problem. I put the 5W30 meant for the Sienna into the truck, which should have had 10W40. D'oh!)
If your engine knocks you would know it, and with the VVTI it shouldn't, EVER! You cannot justify an add'l 25 cents plus per gallon to me to run 91+ octane gas.
I used to race, we went with the highest compression we could, The higher the compression the higher the octane necessary to control detonation. Timing also plays a factor here in controlling detonation but on this vehicle mostly with power and at certain engine loads, more timing on acceleration, less at cruising.
If you drive your Sienna like a drag racer, you might like what 91 octane can do, if you drive like a civilized human being you will probably never know the difference.
Gas in southeast Texas is $1.16 for 87 octane and $1.40+ for high octane. Maybe you wish you could buy premium for $1.40 up north, but no matter what you pay for it, premium gas costs too much for the benefit.
I don't hear any other sound when cruising and iddling. I have actually re-started the var when the engine is already running coz it was just too quite.
The pinging/knocking is quite different. If you have a older vehicle try accelerating rapidly and you might here the sound. You shouldnt hear it on the sienna which has the knock sensor. I have a 87 camry which pings if i accelerate rapidly and i have lived with this for atleast 4 yrs. I use 89 octane and since its an around the town car i will not bother with 91 octane.
I run 87 octane in my Sienna, and it runs fine. I get 24 mpg highway, and it runs very quietly. I've been very pleased with it.
$1.56 for regular (87 Octane); $1.78 for super (91 Octane).
San Jose, CA
Question is-----what is recommended. I do a city/highway mix of driving, I favor a smooth, quiet ride. Weather is NOT really a factor in Central California. The size 215/65x15 seems to limit choices. I am specifically considering Michelin Symmmetrys. Any suggestions??? Thanks!
Now the comment: if the price difference was as great as elsewhere, I'd re-evaluate my choice to use the fuel for which the engine was designed, namely 91 octane fuel.
If you want better treadwear (longer life) take a look at the X-One or equivilant, they are rated even higher and can be had for about $115 each. The Michelin.com website gives some good facts. Note that Michelin makes essentially the same tire for Sears, Sams, and tire dealers, but calls them different names to make prices shopping more difficult.
this is the first time i heard an explanation like yours! do u ever get your wheels aligned every few thousand miles/kms.?
Anyway, does anyone have a fix for these creaking and popping sliding doors?!?!?!? We love this van but his is the one thing that really irritates us. 5 previous Toyotas with no rattles at all and this thing sounds like a 10 year old Dodge. Any suggestions appreciated!
Please advise on what may be causing it, how to fix it, or at least how to temporarily "deactivate" the alarm system.
Sure I can take it into the shop, but I am asking for help BEFORE I take it in so I do not have to pay an excessive labor charge to pinpoint the problem.
I am sincerely grateful for your help, thanks!
On my 2001, when the sun visor is down and to the side - that is when blocking sun coming in the side window, the visor pivot is too loose. When I make a left turn, the visor swings around and hits me in the head. On one occasion making a hard left at a traffic light, my head was in just the right position where the visor swung around, knocked my clip-on sun glasses off, and knocked my eye glasses out of position. It's lucky that the shock and sudden reduction in vision due to suddenly looking out the wrong part of my glasses lens didn't cause me to mess up the turn and plow into the curb.
The passenger side has the same problem, though at least it only hits the passenger during right turns and is less of a safety hazard.
I did see any other entries on this subject in this message board, but with over 2,000 messages, it would be easy to miss, so if this is "old news" I appologise.
The dealer, Miller Toyota in Mannassas VA, has said that they will order new visors and replace them (no argument there), but the service folks do not think that will solve the problem as all of the new Sienna's on the lot seem to have much the same problem.
While this is not a busted suspension, fire hazard, etc., it would seem like a potential safety recall issue as the distraction and potential for knocking a driver's eye glasses off their face could potentially cause the driver to mess-up a turn and take out a pedestrian or another car.
It would also seem like a simple thing to fix - less lubrication, a tighter pivot tube (or however the pivot works), or maybe even a little goop stuffed into the pivit to increase friction.
Any comments, thoughts, suggestions?
I will probably have the dealer replace the visors as I did not notice the problem until the van was > 1 year old, so maybe the new visors will work better for a year. Then I may have to consider a home-grown solution such as trying to clog the mechanism with dust or using a tiny piece of velcro to hold the visor in place with pushed against the door frame area.
i was told that toyota is limiting its dealers as to how many vehicles the dealer can order each month and this is creating a very long wait list for customers! the vehicles i'm referring to are the 03' corolla and matrix.
thank u.
This is not a new situation. The Siennas used to be like this, as did the '96 and '97 4Runners. Toyota built them as quickly as they could but demand out paced production. Smaller dealers and dealers that didn't turn them quickly ended up with virtually nothing to sell.
Thanks again, Flyrod
If not, I'm as stumped as you are.
San Jose, CA
Would it do anything to remove the battery terminals and then re-attach them?
By the way, today the demon is gone! My Sienna is very well behaved currently. I am sure it will come back to possess my Sienna very soon, as it has before.
Does anyone know what is happening here?
Also, I've read a couple of people's comments regarding the loose visor. Can anyone point me to an answer to this problem as well? What message number? Thanks.
