Visitor Agreement.
The owners guide tells me how to get to the ESN that I need for the Sirius activation. It does not work!
Can you tell me how it is done?
update discs on its website!
Maybe I am dreaming and this slow down is just because this model is out of production for almost 3 years but these forums seem to have really died off from multiple entries each week to nothing for almost a month. I suspect there are other owners of fairly new Ms out there who will make use of this data as their cars age and they need some repair advice in the next few years.
Still a happy newer 300M owner in SE MN
If you click on "track this group", you will be subscribed to all of the 300M discussions. You can choose to have an email sent to you whenever a new message is added and/or simply click on "Read New Posts" when you log in again.
Hope that helps!
Stu7
It has been a great car for the 7 years I have driven it, and I have loved every one of the 105,000 miles, but the economics are against putting that much into repairs.
You can all be sure I will be envious when I see you drive by in your M's.
I had 2 cars go south around 108K miles, so I know that is frustrating when you hope to get around 150K or so. One was an early Dodge Caravan minivan where both the head gasket and valves went at once basically requiring $1500 worth of repairs on a vehicle worth $3K at best. The other was just 2 years ago, a kid car 95 Pontiac worth $2K needing a $1K+ valve job and 2 mechanics telling me it wasn't worth it. I was lucky and got money out of both cars but owning both with a lot of TLC since they were new really bugged me. Luckily most of my other vehicles including my 2004 300M have had better fates, at least so far. I am contemplating with only 1 warranty problem in 31 months if I need the extended warranty beyond the 7/70 on my M, but of course none of those run past 100K miles anyway.
Anyway, during a scheduled oil change I mentioned it to the dealer yesterday and he ran some combustion chamber cleaner through the system which at least temporarily quieted it down. The service tech cautioned me if I hear it again in the next few hundred miles or couple weeks to bring it in as they have concerns on the valves/lifters. So I am hopefully it's fixed (stay tuned to this forum if it's not), but it's a wakeup call that even simple noises not causing anything obvious with the engine starting, power or computer codes is worth bringing in. There are so many times they can't either find it or dismiss a problem (eg, the infamous CHECK ENGINE light due to a loose gas cap) but other seemingly minor things can be a real problem.
Beyond that if others have advice they can comment. There are good online sites with brake replacement diagrams, even popularmechanics.com has that. Good luck.
This did not seem to be a major problem as the dealer told me 2 weeks ago it was ok to drive, but it was not an easy fix with just combustion chamber cleaner as I posted beforer. I did a search on this TSB number on this forum but no hits, so perhaps it's just now showing up or only on the 04s? Other than a cam sensor, it's the only problem I have had in almost 3 years ... still a satisfied customer, debating if I need at least the basic (steering,brakes,electrical) added extended warranty.
I am looking for a used chrysler 300M in the market. Here is one:
Year: 2002 CHRYSLER 300M sedan Mileage: ~ 97000 miles
Exterior Color: Tan Interior Color: Tan
Body Style: Sedan Doors: Four Door
Engine: 6 Cylinder Transmission: Automatic
Drive Type: 2 wheel drive Stereo: Premium Sound System
Fuel Type: Gasoline
Air Conditioning, Cruise Control, Driver Air Bag, Leather Seats Passenger Air Bag, Power Door Locks , Power Steering
Power Windows , Sunroof/Moonroof , Tilt Wheel
The carfex report is clean (a rental car for its first year and a leasing car later).
My question is:
Do you think it is a deal or not?
Do you think the mileage is too high or not?
Will such milage cause some severe troubles?
Should I have to change some important parts (timing belt, for example) at this milage if I buy it?
I added radiator flush and after a days downtime I will began to drain.
FYI, I notice that the last filler of coolant used prestone dex-cool and the antifreeze appeared to have broken down and slugging.
I'll keep u posted on the results.
I have a 2000 300M and the left driver's side door speaker is "rattling" so how did you replace yours? Do you have to take the door apart or just pop off the speaker screen and replace it that way? Hopefully it is not difficult and I will replace both door speakers. Where did you get the replacement ones? Thanks
It sounds insane! Anyone replaced one of these plastic hand grip cups in a 300M? Note that there are 4 of these cups in the 300M, one in each door arm.
1. Never stalls around town, only after driving awhile at highway speeds, then only as I come to a stop.
2. As I slow to a stop, I notice the tach bouncing up and down around idle point, but just goes a little lower each time until engine dies.
3. Cranks right up.
4. Never stalls while at steady speeds.
5. Once I get back into town and drive at slower speeds for awhile, problem goes away.
6. Plenty of pep, good acceleration in town and on highway.
Any guesses what I might try next?
Water on driver's side door.
Yea, this seem to be common when it rains or during a heavy car wash, so look at the trim on the driver's side at the top of the door and the front windshield glass, it should be black in color and about 1/2 inch, this area has been the usual leaky point. Pull on it just a little bit to see if it is loosen or weaken from the adhesive. It easily snaps up so you may want to get some adhesive or RTV to try and plug the void.
After you add the RTV or which ever your chose, monitor it during the rain or wash.
Hopefully this works for you.
rider62(lb)
I used to be active on this board years ago, but quit as it grew less active. Just would like to check in to report that my '99 is still running very strong at 140K, and looks great. The candy apple red paint has held up very well, and so have my chromed razorstars, which look like new when polished. People don't believe that the car is 8 years old! I plan to keep it quite a while yet, since it just keeps running like the energizer bunny. I have had to replace suspension components (front struts, sway bars, etc.) a couple of times, possibly because I have a bad habit of zooming over speed bumps. Took it to a 5 star (which I seldom do) last year and they fixed the light show that was starting to occur with the interior lights, and also stopped the fuel gauge from chiming and bopping up and down (they cleaned the electrical contacts).
A previous post was inquiring the best route to go for a tranny; I was wondering the same thing, thinking mine can't last too much longer, although it seems fine. Think I will try the local junkyard which I know offers a warranty. I'm also surprised that the exhaust system has never needed a new pipe or muffler. I know it's made of stainless steel but I never had one last so long before; very nice! If anyone has any advice on what problems might occur w/my high mileage car I'd appreciate it. Normally I would be rid of a car by now. Happy 'M Cruising!
Blue Sky
I have just recently purchased a 300M. I would like to know if the controls on the steering wheel (Cruse control, set, coast etc.) are supposed to light up at night? Also, whether the heater control knob is supposed to light up?
Thanks for any assistance!
I have just recently purchased a 2004 300M. I would like to know if the controls on the steering wheel (Cruse control, set, coast etc.) are supposed to light up at night? Also, whether the heater control (Fan) knob is supposed to light up?
