Visitor Agreement.
JB Weld glue did not hold.
How did the welding hold for you and is is hard with a MIG wire welder? thanks Roger
Sounds like ur troubles could be a power steering pump or rack, but get these items checked out first (p/s pump filter and hose, p/s pump pulley, p/s reservoir, and the p/s pump) make sure there is adequate fluid. U may go this website for more info:
www.carsteering.com/chrysler_300m_steering_rack.htm also look at these sites from the National Highway Traffic Safety Administration;
www.recalls.gov, www-odi.nhtsa.dot.gov/cars.
If the steering rack or pump is the problem and u do not have an extended warranty, u can figure on paying between $650 - $850.00 at ur local auto repair.
Hopefully this is helpful
I am considering buying a 2000 300M, but I am not sure about how much trouble they really are. It has quite a lot of KMs on it, so that adds to "the joy". Could anybody help me with listing some most common 2000 300M problems along with symptoms? I bought a Lincoln LS without doing my homework and I've spent quite a lot of cash on fixing it already, so I want to be careful this time.
Thanks a lot! All help will be appreicated!
Matt Newelski
www.newelski.com
mnewelski /at/ gmail /dot/ com
One suggestion if no one comes through with the coupon or you can't get the affiliates: check with your banks or credit unions. Or do you belong to Sams Club? I heard from a guy a few years back they offered some type of service. I am sure there are places out there and with car sales pretty tanked out buying the last day of the month these dealers gotta be chomping at the bit unless you are buying a hot seller vehicle. Good luck!
Do some searches around the web, google, TireRack.com to get more ideas but it is a very common problem (and thanks for posting on this forum, it's been pretty dead lately).
However a year ago I did buy the 7/70 maxcare service contract extended warranty on the 300M. I questioned doing it but with dealer negotiations I got the $1300 price down to $900 and some, then my wife had a $100 off coupon Chrylser mailed to her (it's her car but not sure why she had the coupon since I do all the car work?!) and they took that off too. And sure enough last summer there is problem 3 which would not have been covered otherwise. It seemed simple enough - intermittently the instrument panel dash speedometer/tach dash light would not work. But the 300M has an electroluminescent panel to give it that even green tinted white glow! And replacing it for part & labor cost $700. I also had a door speaker replaced due to a frequency sensitive rattle to help justify the $100 deductible, but have covered 2/3 of my ext warranty cost already with 3 years left to go. I will be driving the 300M more this summer since it get's about 50 percent better MPG than our Jeep, looking forward to a Spring wax and wheel polishing nice weekend day soon.
Keep us posted on how yours runs over the years as I do plan to run mine for 9-10 years and -still- like the looks of it vs the newer styles. Despite what some have said on winter traction I am VERY satisfied even in Minnesota now that we upgraded to Goodrich Traction TAs, excellent tires compared to the stock Michelins.
1)hmmm, i don't get snow where I live... can't help ya there.
2)Hasn't happened to me
3)That ticking noise is your lifters, check your oil level... it happens to me sometimes and when i get the oil changed and filled, it stops!
4)My temp controller didn't make any noise until I cleaned all of the dust out of it... The unit is fine, the motor that turns the fan behind the display is simply making noise and I have no problems with it other than a slight annoyance.
I noticed this is a very old post but it still might help any unanswered questions you may have...
peace and safe driving.
but if you do decide to buy aftermarket to replace them, depending on your particular model, they may be 2-ohm speakers.. watch out and good luck!
As for the previous comment about water damage to the front speakers...if water is getting in your door panel at such a high rate as to damage the speakers then you have another issue that needs to be addressed, but I highly doubt that is the problem. These speakers are known for not lasting too long, and as with everything else, they wear-out with use over time.
Front brake rotors. Our first set warped by 20K miles and were replaced with another set of stock rotors (they warp because of heat; turning them lessens their thickness and they warp sooner the next time so they are usually replaced). They warped by 40K miles and we bit the bullet and paid for Brembo rotors to end the problem.
Struts. Stiff ride to begin with (standard model, not the high performance model) that got really bad by around 20K. Replaced all the stock struts with Monroe (mistake, should have gone for the LHS struts for a more comfortable ride) and discovered the strut mounts were shot/broken/kaput. Replaced the mounts with Monroe. 42K miles and the car clanks over bumps. Good wheel and axle shop discovers the front strut mounts are shot/loose/damaged/separated/kaput. Replaced front strut mounts with whatever high quality brand the shop used. Our 300M now rides almost like new, but we are certainly poorer.
Window controls. We had all 4 replaced under warranty, one twice the first three years of ownership. No problem for years, then the front passenger side window stops responding to the front passenger's window control. Still can open it with the driver's control. Will get this fixed eventually as it is a PITA.
Why do we still have this car? We average almost 20 mpg in all around driving. It's 8 years old and still looks better than 90% of the cars in any parking lot. The engine is first rate. Great power and acceleration without bad gas mileage. Roomy interior with great leather seats that would be hard to find in a replacement vehicle. Great handling performance (as long as you keep the tires, brakes, and struts up to snuff). To get a replacement equivalent to this car we would have to spend at least $40K and we can't quite afford that.
My 2002 300M is now approaching 88,000 miles. Just had to replace the evaporator for the A/C system at a cost of $1450. Earlier in the year, replaced the battery (preventative maintenance) and tires (I actually got Eagle LS-2's and they have been fine).
Also got the TSB taken care of for cracking bolts on front buckets (if you have not gotten this attended to, I strongly recommend you do so - for some reason the bolts fail after a while). I have the usual brake pad problems and consider it the price of having a good car.
I have driven the new 300 Base and Touring, and both are very nice, but I have become very attached to my 300M, which is the best car I have ever owned, including fine Buicks and Oldsmobiles through the years. I think Chrysler over-engineered and over-equipped the 1999 - 2004 car, which they did not do with the new 300's, probably because M-B cut costs in order to offset the installation of their fine rear suspension system.
Hard to believe how the interior has been cheapened in the new series, though I understand it was upgraded for 2008.
Best to all.
Now, hopefully the leak wont get bigger!!
http://www.autotrucktoys.com/300/Chrysler-300-Chrome-Trim-Accessories-C3046.aspx-
Also, sorry one more thing. I need an owners manual, any idea where I can get one for a "great" price?
Thank you for any and all help!!
:P
This is an odd one. I have a 99 300M and wife has the 99 CONcorde. Recently -last three mos. she has had start problems a dozen times. The car will start then immed. die. Then turning the key has no response at all. Wait several minutes and does same. Unplug her IPOD or GPS from the cigarette lighter plug and it starts right up and runs fine. I didn't believe it and then saw it happen twice this weekend. Her cigarette plug is in the on always position. Any ideas? Thanks Roger /Nashville
70+ mph average conditions (no headwind or AC) gets 26mpg and on a trip a month ago on slower backrounds at 55 mph I was getting 28-29mpg. I consider those excellent for a comfortable 5 seater sedan with OOMPH. But if you drive it hard those will drop, and it's hard not to stomp the gas on this beauty occasionally.
I replaced the cam postion sensor, $20.00 problem is gone!
