Visitor Agreement.
Any suggestions for the best tire for a 300M for riding comfort and minimal road noise?
For tires, the best value and still good performance have been Kumhos. I suspect they're made in China since they were such a good value, but they rate well as high performance all season tires by Consumer Reports, who has good tire reviews. tirerack also has a lot of good info on tires, in terms of ratings. The Traction T/As I think are not high performance, but only all season. I had them in the past with a prior car. Now they make all season high-performance so I would be sure to get those, just get a pair that's fairly quiet.
My red '99 is going strong at 155K. I love keeping the cars a long time... A work van ran into me about 2 years ago, a small fender bender, totally his fault, and the body shop repainted my hood, the lower front fascia, and the side fender that wasn't even dented, as part of the deal. So I got new paint where I needed it for free, although a lot of inconvenience getting hit, but the bottom line is it looks great. Plan to keep it another 3 years and then decide what to do...
Happy Cruising!
Happy Holidays to all!
As quoted below this 200C is based on the 300C platform so it will be interesting to see if it replaces or complements the current 300. It's an obvious return to the more aero styling of our old 300Ms which I still like way more than the 300C design even after almost 5 years of owning my 04 300M. However Chrysler has to EXIST long enough to make & market a 2010 model, a big gamble as of this writing (I also own a Jeep GC and I'd bet at least that brand will be around longer than Chrysler current course & speed).
http://www.popularmechanics.com/content/imageview.cfm?img=http%3A//media.popular- mechanics.com/images/C200EVSide.jpg&caption=
http://www.popularmechanics.com/blogs/technology_news/4298925.html
"The four-passenger 200C EV is based on a shortened version of the rear-drive, full-size car platform that underpins the Chrysler 300C, Dodge Charger and Dodge Challenger. Chrysler says the 200C EV is powered by a plug-in, range-extended hybrid powertrain, similar in concept to the Chevy Volt. The Chrysler system here is said to develop a total of 268 hp. And the company says the concept can scoot to 60 mph in 7 seconds, travel 40 miles in electric-only mode and cruise for a total of 400 miles, thanks to that gasoline engine acting as a generator. And it can be recharged using a 110-volt or 220-volt outlet." Credit to popularmechanics.com
I use Mobile 1 synthetic oil and change the oil and filter every 7,500 miles. It will use about a quart of oil during that time. I have not had any trouble with the transmission. I check the fluid level regularly but have not done anything to it. It is the smoothest shifting automatic I have ever had. I am coming up on having to change the timing belt, water pump, coolant, and idler pulleys again, I did it at 100,000 miles and will do it again at 200,000.
On the down side, I did replace the AC compressor and evaporator a few years ago and my dash has the dreaded cracks over the passenger air bag. That has been hidden with a DashMate Suede cover. I hope to replace the dash sometime.
Overall, I am very happy with this car and like the looks of it far better than the beast they came out with in 2005. I like the smooth, streamline look much better than the boxy look the Chrysler's have now.
0442= Evap Leak Monitor Medium Leak Detected = A small leak has been detected in the evaporative system
Could be caused by filling the tank after hose automatacally shuts off, or a leak in the hoses connected to the tank or crack in the plastic evap system canister under the hood.
I have a 99 concorde and 99 300M.
The ac compressor will not run if the radiator electric fan is not running. Check this first as these go out. Get it hot and look.
I don't know what the burning was ?
the ac compressor needs a certain freon level to run also.
Good Luck let us know tttthe results. rogjack6112
Oh, my automatic lights go on and off randomly, even during the day, the car will be sitting in my drive with the lights just going on and off. What the tire pressure gauges too, i've had to replace 3 already.
I'm done with Chrysler, their lousy products and customer service. Apparently they don't want to stay in business. Just watch the news.
Well, I decided to drop by and say hi. It's been a while. My warm hello's to bigmike5, tayl0rd, laurasdada and everyone else that has been on this forum since '05 when I joined.
I sold my '02 Chrysler 300M and got my mom into a 2008 Infiniti G35 Sedan w/ Premium & Sport. I got fed up with the service Chrysler was offering and am glad the local dealership is going out of business. It's been long overdue. Before purchasing the G35, they forgot to put oil in the transmission while performing valve body work under the extended warranty. After almost costing me my life (thank God my mother didn't pick it up from the dealership) and refusing to give a new transmission until I got a lawyer, I finally got rid of the car.
I'm not trying to rock the boat but I will never purchase an American car again in my life. I've been patriotic enough
#598 First failure in 30 mons - cam sensor chk eng lite by naatz1');">naatz1 Sep 21, 2006 (7:37 pm)
.....I had the check engine light come on about a day or so after filling with gas, it would go away after a few engine on/off cycles AFTER tightening the GAS CAP. So I was sure it was the "gas cap thing", but the dealer insisted they needed to check it out. Sure enough, it was a bad (intermittent?) cam sensor problem & they replaced the sensor, totally coincidental about the gas cap even though it did that 3 times. Both my wife and I had it lurch/stumble once each so I was suspicious something worse was amiss, I guess the dealer had the correct hunch on this one. First real fail in 30 months & 29,000 miles since new, if I go another 30 mons w/o anything I will feel just fine!
New to these forums but have reading thru them. In short, my 2001M has 108k miles. One time on the expressway, I hit 40mph, and it began to drop down to non acceleration. Cruising to the shoulder, my M began to emit grey smoke and leak (red) transmission fluid. I shut it down, when the car was restarted at a shop, it made a loud sort of rattling sound which seem to be on the passenger side. Until this point there was Never any loud rattling noise from my car. The fluids were check and (as I knew) the mechanic said everything looked clean; however, my trans fluid looked to be overfilled/too much fluid. Additionally, the engine codes were checked and seem to be locked and/or reset such that they were not able to get a diagnostic reading.
The shop said they "thought" it was the engine becuz of the noise but they couldn't determine this for sure given the locked/reset codes. An army who did simple look over, recommended getting all the little stuff checked--hoses, sensor, pump--and that it was definitely a trans issue given the non-acceleration but the engine just locked up becuz of this issue.
Any info or assistance you can offer would be intensely appreciated! Many thanks, in advance for your efforts.
