Shop does not know what the deal is, nor can they duplicate.. has anyone had a similar problem
All-Anyone need chrome Chrysler Medallion replica hubcaps???
http://www.suburbanwheelcover.com/
EasyRider300M
I was amazed at the number of trucks parked along almost every exit ramp as the drivers slept for the night. I have never been on the interstate that late at night before so I didn't know that they just pulled off on the shoulder on exit/entry ramps.
Is this the new hotspot for postings on the 300M? The AOL posting boards have gone very very cold.
Nice reading all your comments about your cars.
Lee
The person with the wet floor said it happens when it rains. The air conditioner runs with the defroster which might be on when it rains. Perhaps the water is from the evaporater? Could the evaporater drain be plugged up? Just a thought....
All-I drove up to VT a few years back and was also amazed to see all the trucks pulled over and in rest stops for the night. That has always been illegal in AL for some reason, so it was a new sight. Had my oil changed for the 4th time today (13K miles. Full synthetic every time.). Asked about tranny fluid change. They do the power flush method instead of drain and fill and it runs $80. I am going to have this done next oil change. I have heard a lot of folks say this improves the shifting, so what the heck! My wife, the wizard of the tax refund, might have us set up so that I can get my duals, dash wood, tires, and JetChip (If it finally is out by then!!) all at once!!! Keep your fingers crossed!!
Hey tell your wife to go ahead and fiqure in a set of 18" O.Z. Volcanos SWEEET!!! As far as the chip, fuggeddaboutit!!!
Racefan9
http://www.ozwheels.com/r16.html
what do you all think???
Easyrider300M
I am waiting for Dayton to contact me for their true spoke rims (like the lo-riders use) which come in 18" to 22".
Can anyone recommend good dry weather high performance tires for the 300M?
Stumpy
They have a UTQG of 300 AA A which should last awhile (better than most Z Rated Rubber)...
They are 245/45ZR-17's and look great with the chrome razorstars
thanks!!!
Thanks for the heads up. Even though I have a 2000 and this was in the 1999 TSB list, I might have a leg to stand on.
I wonder if Chrysler will honor TSB work after the warranty period?
Anyone know?
Have fun. I am going for pricing tomorrow for tires and wheels.
Anyway... I brought mine to my 5* dealer for normal servicing and had them check out the seatt. Come to find out, they agreed with my assessment and ordered a new seat assembly. I took the MMMachine back to the dealer and had it installed last week. Tthe difference is substantial. The part was $800, so get it fixed while you are still under warranty.
I would not recommend letting this one go. The driver's seat and how it bolts to the car is going to make a huge difference if you get into an accident. A slight movement during an acceleration off the line or stopping quickly may not be so slight when going from ?? to 0 in an collision.
I hope this post helps.
All in all - I continue to love the 300M and have had no issues (except the seat movement) to date. Happy MMMotoring
So far (knock on wood) the only problems I've encountered in putting another 7000 miles, so far, on my M were replacing one window motor assembly on warranty (known problem, supposedly solved by redesigned motor) and a 4 wheel alignment, which I had to pay for, required to correct a slight pull.
My car has the PHP option, big stereo, moonroof, spoiler, and chromed Razorstars. With 1 year and 11000 miles on it, I paid $24,000.
If you decide to buy an M, I sincerely hope that you enjoy yours as much as I am enjoying mine.
Lynn
View the installed kit at: http://albums.photopoint.com/j/AlbumIndex?u=1501794&a=11408326
Never had a problem getting around with my SHO (with no traction control), but that had less aggressive rubber.
Was going to work last Moday, in the middle of a snowstorm, and came upon a VW Golf trying vainly to get up a hill. Couple other cars had slid off the side of the road in their attempts to get up. Decided to turn around and take the longer (but less hilly) route to work.
I'm not normally a pinstripe guy, but yours looks pretty trick. I like the front pattern, kinda like an eagle.
Looks like you get your share of snow, how are the Goodyear snow tires?
-space
-power
-features for the $ (cup holders, heated seats, trip odomoter, etc.)
2) What three things would you change about your car?
- don't buy first year model!
- slightly bigger trunk
3) What has been the most troubling problem you have had with you car?
- engine blew up after 3 weeks (1999 model) - still didn't run properly for approx. 8 months until they reflashed the PCM
-continued problems - doesn't start if below 20 degrees; experienced known window motor problem;
- very non-customer focused in arbitration process (which I lost)
I am trying to find a non-Chyrsler to replace my 300 with as I simply don't trust this car. I am having trouble finding anything big enough etc., even within $10K! Would I be an idiot to buy another, simply to unload this lemon?
I was zipping along a highway at 80-85 mph. About 1/4 mile ahead, there was an intersection where cars can enter from a stop sign (no ramp). So this suicidal Accord jumps on from a stop sign. I go in the left lane and pass him. I think I am far ahead and can safely return back to the right lane. Put my signal on, start switching. See him in the mirror not too far behind. Apparently he thought that I was cutting him off, because he became very aggressive. He goes in the left lane and starts catching up with me. I think "OK, come closer and I will show you". He comes closer, I downshift and start accelerating. He is passing me... I am flooring it, but he is still passing me! When he is 1/2 car length ahead, his rear doors are lined up with my head, he starts switching into my lane, cutting me off. I then had to press my brakes. He went ahead of me. I followed. Up to 115mph. Then I figured he was too crazy and let him go. He kept on accelerating like crazy.
I still have a question - what was that Accord on?
I did go and ask 4 of the other service people what can be reprogramed on the car and they all agreed with the manager. It was just my luck to get a person that doesn't know what she was talking about.
Sorry to get some of your hopes up. It seems you were right in the first place.
This car handles like a dream and is superb in the snow with the factory Goodyears. Plenty of interior room and very comfortable seats plus all the ammenities.
Plus the fact that I got a great deal on the car with .9% financing makes me a happy owner. The fact that it is one of the best looking full size cars on the road doesnt hurt either.
Dump the 99 and get an 01 if you can afford it. Otherwise, just service your 99 regularly and keep ahead of any problems. Is yours still under warranty? If it is, then make sure to have any little problems corrected before the warranty expires. Good luck with your decision.
Easyrider300m
One drive on snow with 4 performance winter tires will convince anyone that winter tires are a good investment north of the Mason-Dixon line.
The Goodyear Ultra Grip Ice are an excellent choice, as are the Michelin Arctic Alpin, I have had both on a 300M. Another good choice is the Vredestein Snotrac which we have on my wife's '01 Sebring Sedan.
You are right about the pinstripes, they end in eagles, courtesy of the USPS (modified to keep the postal inspectors away!)
Why you were spanked? Simple power to weight ratio. That Honda weighs about 1000lbs less then the M.
That Accord had only one exhaust pipe, had to be a 4-cylinder.
I think he had nitrous.
Race-Should I try to talk her into the full Lorinser kit while I'm at it??? ;-)
Got email from them that said 30 days. So that's 2 weeks & 30 days now
