Toyota Sienna Maintenance and Repair (2003 earlier)
1555658606172
  • deepandeepan Member Posts: 342
    this is just left over oil thats burnt which when scraped comes off.. The Oil fil area is bent (90 degrees or so) and you cant see the engine through it.
  • steine13steine13 Member Posts: 2,825
    Thank you for the reply.
    And I'm sorry for the trouble with your van -- this is a big deal, to the tune of $5k or so, so I hope it works out.
    Your story is unwelcome news -- the 2003s are not supposed to do this. It's not like the earlier ones were designed to fail, but some time before MY '03, the design of the PCV system was changed, because that was part of the reason for the early failures.
    I would speculate at this point that your van has some other problem that lead to the failure... 31k is too early, unless the oil was NEVER changed. I'm inclined to believe you, mostly because of your stated "5k-7k" interval.
    What I hear from service managers and dealers -- all of this internet and/or seconhand, mind you -- is that when a sludged V6 comes in, the owner always claims to have the oil changed at 3,000. And has no receipts, or has Quickie Lube receipts covering a 3-year period, but consecutive invoice numbers. There are all kinds of shenanigans going on.
    It's unfortunate that you change your own oil. Did you keep receipts? Probably not... I didn't keep them either until I bought my 03 Sienna, and I only keep the oil/filter receipts because of the sludge problem. I also keep a hand-written log. The dealer will ask you for proof you changed the oil. I change at 3-5k, depending on conditions, and probably will go to "3k or less" because of your post. Better safe than sorry.
    This whole thing makes no sense. If the problem is with engine design, then why do so few of them fail? It's a percent or so.
    If it's just the owners neglecting the cars, as the "Toyota Lovers" camp claims, why is it only the "car and minivan" V6, not the one in the Tacoma?
    The only theory that fits all the known facts and "facts" is that the engine is more susceptible to sludging under certain conditions, and that for some reasons, neglect among them, it happens on a small percentage of them.
    But if you turn it around and ask "what percentage of minivan owners neglect their van", how could it be less than a percent or so??? From the global point of view, the Toyota version ("Neglect!") fits the facts.
    None of this is much help if you change your oil on schedule and then the engine sludges up.
    I'm still waiting for someone, somewhere to have an ironclad case of Toyota dealership receipts of 5k or better oil changes and sludge at any mileage. If *YOU* have receipts for oil and filters for your DIY changes, that would be nearly as good.
    Because I, for one, would like to know what's really going on with these engines. Right now, I don't know.
    -Mathias
  • coastcoast Member Posts: 4
    I never thought I'd hear someone say, "it's unfortunate that you change your own oil". I've been doing it for the peace of mind - especially after knowing about incidents where Jiffy Lube personnel did not tighten the oil plug and all of the oil ran out causing someone's engine to lock up. But I do understand the statement in this case; if I had the dealership change it, I'd have a leg to stand on.
    Instead, you're exactly right. I never kept receipts, because I never thought there'd be a need to. I'd never had a need to do so up until this point.
    I did have Jiffy Lube do the first oil change on the Sienna though because the factory filter was on so tight that I couldn't get it off. They even had a hard time getting it off with the best tools they had. I did check everything after to make sure that it had the right level - no overfilling, plug/filter was tight and so on.
    I guess that I would have changed the engine oil more frequently on my Sienna regardless of break-down had I known about the sludge problem. Since we bought the mini-van in August of 2002, we never received the letters from Toyota that went out in April(?) and July of 2002 which warned of the sludge problem.
    And then again, if I had known about the sludge problem and thought that I would have to provide extra care above and beyond the norm, I probably would have bought another brand of minivan anyway. As I said before, I truly believe that my vehicle would have suffered this fate (maybe somewhere down the road) even if I had changed the oil more frequently. I certainly can't tell you why my van did when so many others haven't - who knows. But I can tell you that this should not happen with this mileage regardless of poor maintenance - I'd bet a year's salary that it wouldn't have happened with the Tacoma - even with, let's say 2 oil changes for that mileage.
    All I've ever kept is a hand-written log of mileage and dates. I did not keep this log as verification of maintenance for manufacturers, but as data for myself to assist in checking and replacing the oil, oil filter and air filter. From what I've been reading online, I'm doubting that Toyota will be willing to work with me at all.
    I can and will accept blame for part of this as the dealer did actually state that receipts should be kept if you do your own maintenance when I bought the vehicle. And I could have done more research before buying the 2003 Sienna anyway. The stories about the sludge were already out there to be read and I could have found them myself.
    I design databases and write software code as well as troubleshooting problems with software and data. The majority of problems I find can be explained, but there are a very few that we never find explanations for - we just fix the problem and keep going. I'm thinking that this is one of those problems with Toyotas.
    I too would like to see a concrete example of this happening with proven good maintenance. Maybe then, Toyota would anty up on this.
    Again, I think it's a common sense thing that says this shouldn't happen even with almost the worst of maintenance. And with that said, you shouldn't need maintenance records. 31,000 miles isn't that much. And what about those with approx. 20,000 miles - that should definitely be a no-brainer.
    If I was closer to the 60K mile powertrain limit, the case would be arguable from Toyota's perspective.
    Have a great day and thanks for the info!!
    -Coast
  • mawelshmawelsh Member Posts: 1
    Just dropped off my 2000 CE at the auto auction, at the end of a 54 month lease. We were allowed 81,000 miles, and did 78,570. I had the vehicle dealer maintained to the letter of the manual, especially after the "sludge" issues appeared. Oil changes were at about 4,000 intervals.
    This vehicle was still running strong, nearing 80k miles and will make a great used vehicle.
    Never did our Sienna leave us walking, unlike the Dodge Stratus it replaced. Never did we have so much as a warning light, except to warn us of a punctured tire. Never had to do brakes, and the original battery was still good. The only thing that broke was the door handle on one of the sliders...those door stuck a bit. Yeah I tore through the original Dunlop tires, but that was to be expected.
    Our new '04 LE will be in next week. Hopefully it will be just as good.
    I already replied, but here's an update. I took the Sienna in to the dealership today. They said that it did look like the oil had NOT been changed enough, but they felt like the log I provided was authentic. They did think it odd that my Tacoma was running smoothly while the Sienna was in such bad shape. Why would I change the oil in the Tacoma with 130,000 miles and neglect my nice, new Sienna? They did tell me that I definitely need to change it more frequently (in the future) than with the Tacoma - every 4,000 miles, at a minimum, versus every 7,000 to 8,000 miles, but they really don't have a good explanation.
    And I did read another post on Edmunds, from a guy with a pretty good background, that seems to make much sense, so maybe my comments about problems surfacing even with frequent oil changes are off the mark. It's at: Town Hall Maintenance & Repair Maintenance & Repair - Archived Discussions Engine Sludge? (message # 5271 by bobistheoilguy).
    They did feel as if I'd made a reasonable effort to change the oil and the manufacturer is taking care of the repairs under the warranty.
    Maybe this all could have been avoided had I received the letters that had gone out in April and July of 2002. It seems like the dealers should have been handing them out as they sold the vehicles. On the other hand, I probably would not have bought the Sienna. Would you?
    Coast
    Excellent, it sounds like they're standing behind their product.
    "On the other hand, I probably would not have bought the Sienna. Would you?"
    Sure would. I've been following the sludge saga for some time and still bought a used '98 in '02 and a new '03 a year later. The '98 is gone (deer accident), the '03 is going strong and is getting the oil changed at 3-4k.
    -Mathias
    Lesson learned for me... My wife and I have been trying to decide whether to keep the Sienna after repairs or trade it in. As Toyota is coming through on their end, I think we'll keep the Sienna, move to changing the oil under 4k and even keep every receipt for oil purchases. I might even start changing the oil at 4k on the Tacoma.
    Maybe I'll never understand the difference between the two scenarios, but I do feel as if the Toyota Dealer went the extra mile for us and I'll feel good about buying Toyotas in the future...
    Best of luck and thanks for all the info...
    Coast
  • dustykdustyk Member Posts: 2,926
    Coast,
    The scenario you just related to this board is just about the same as the five others I've heard live. I think Toyota would like to leave you with the impression that there's nothing wrong with their design or their mechanicals and give you the feeling that they've gone the extra mile for you.
    Our Avalon has never gone over 2500 miles without an oil change, yet Toyota told me the same thing!
    Dusty
  • dillydilldillydill Member Posts: 118
    My 99 Sienna just came back from an oil change and the shop said one of the tie rods was worn. . . I thought he was just trying to get some more money out of me. . . is there a way I can check if they are worn and how soon do I have to replace them? I am thinking about taking the van to another shop for another opinion. Any thoughts or advice would be greatly appreciated.
    Dillydill
  • masterpaul1masterpaul1 Member Posts: 421
    My advise is to have it fixed right away. If the tie rod brakes, you will not be able to steer the vechicle and could be in a serious accident. The tie rods is what holds the front wheels in place when not being steered and when one tie rod brakes, that wheel will just flap around. Have the mechanic to show you the worn tie rods. Usually, you can tell if they are worn by having the wheels off the ground. Stand in front of the wheel as if you are about to change a flat tire. Grab the back and front of the wheel with out spinning it. Then try to move the wheel in and out by pushing and pulling the wheel as if it was being steered. If the wheel moves just a little, the tie rode may need to be replaced. Either way, have it checked immediately
  • ronsdevuronsdevu Member Posts: 2
    Oil pressure light came on and now the engine needs rebuilding. Used Royal Purple with no problems until the local dealership change it accidently. Then I starting using regular oil and engine failed 6/04, after 1 1/2 years of using normal oil. The funny thing is that I just changed the oil within the last 1500 miles and it failed. What's up with this???
  • freebirdfreebird Member Posts: 77
    How many miles are on it? What was your drain interval when using RP?
    Oil pumps fail....
    Van had about 84000 miles and Oil was drained as recommended by RP and filter change at half point!
    I am guessing that the Royal Purple drain interval is greater that what Toyota recommends, right?
  • emmakitemmakit Member Posts: 1
    Did you ever find out what the problem was? I am having the exact same problem with my 2000 Sienna?
    RE the 98 & 99 engines being discussed above could you let us know at what intervals the oil& filter was changed.
    If i read post 2969 my understanding is that the filter was only changed once!.
    I doubt the filter was changed only once. The oil change interval was probably something like every 15,000 miles with the filter being changed at 7,500. Maybe the poster will update us.
  • aclarke3aclarke3 Member Posts: 12
    Yes my '02 pulls to the left. I have had it alligned twice with no change. The dealer told me it may be a bad tire. I have also rotated the tires to no avail.
    Clarke
    our #2766 of 2974 Pulls left!! by pemarsh Dec 18, 2003 (7:29 pm)
    Does anyone have a problem with their Sienna pulling left..no matter how many times they allign it???
    Have you tried adjusting air pressure in the right tire? Drop it 3-4 lbs and see if it compensates.
  • sharona17sharona17 Member Posts: 2
    In January, my 2003 Sienna went in for service and a week later it would not start. At first we thought it was the battery, but our neighbor noticed that the dashboard lights were coming on. He has a Solara and told us to rock the van. The van started. It has happened numerous times since and each time if we rock it we can get it started. The dealership that serviced it, basically told us we were crazy so we brought it to the dealership that we leased it from. They have been great, but unable to replicate the problem. First they replaced the alternator, but it continued to happen. Originally it was only occuring at our house in the morning when it was cold or when the parking brake was on, however, last week it occured 50 miles away from our home at night when it was hot. Occasionally we can just keep trying to start it and it works, but usually it has to be rocked. The van is back at the dealer today. However they really have no clue as to what the problem is. Has anyone experienced this problem?
  • mcdawggmcdawgg Member Posts: 1,722
    is the neutral/park safety switch.
    That sounds likely.
    The dealer's service dept appears to have NO clue. How can it be the alternator if there is juice in the battery?
    -Mathias
    Thanks. According to the dealer that has already been tested.
  • dajotadajota Member Posts: 1
    I am considering a used Sienna, Possibly 2000 or 2001. If I do have the first owners maintenance records how am I supposed to prove proper oil change intervals?
    If it's Toyota Certified this should mean it's been given a clean bill of health, correct? ;)
    As with any previously owned vehicle, if it is not maintained properly, then the expected life of the engine and other components will be shortened. The best thing to do is have the car inspected by a qualified mechanic.
    The Toyota Certified label just gives it an extended warranty.
  • scoti1scoti1 Member Posts: 676
    I would not buy any used vehicle, particularly those covered under the sludge program, without documentation of proper maintenance from the previous owners. If you are purchasing used from a dealer, get their assurance that they will cover engine sludge, should it occur, even though you are not the original owner.
    If you choose to proceed, have the valve cover pulled by a trusted mechanic, as this is the only way you can verify whether the engine is sludged or not.
    We rotated the tires back and the steering is much improved. My wife is currently on a long trip with the vehicle and she is quite pleased with the change. I think that the dealer was correct and we have at least one bad tire. These are not the original tires and not a matched quad. The culprits appear to be one or both of the Firestone tires.
    I think that I saw a thread here regarding some of the best choices for tires for the Sienna and will refer to those posts.
    Clarke
    I have the Michelin Symmetry, available at Walmart for $95 each, installed. They drive well.
  • momto2boysscmomto2boyssc Member Posts: 3
    Just wondering if anyone else has experienced the paint on their rear bumper bubbling. Nothing is cracked - just bubbles developed under the bumper. Some type of moisture issue, as the bubbles would fluctuate size depending on the time of day (larger in the morning when it was cooler - smaller in the heat of the afternoon).
    The dealership just finished repairing this (of course, they had my car for EIGHT DAYS and still didn't have the time to change the oil. Typical of this dealership - but that is another story...).
  • serenamom2serenamom2 Member Posts: 1
    My Check Engine light came on, one mechanic told me after a diagnostic check that it was my spark plugs, I got that fixed and the check engine light is still on, the mechanic that fixed it told me that it could be a sensor? HELP
  • ldav31ldav31 Member Posts: 7
    Check the gas cap and make sure it is tight.
    In addition, did you change brands of gasoline on the gas in the tank when the light came on. Some brands have additives that may cause the light to come on, one of which is that er aaa..., can not think of the name but it is basicly corn whiskey.
    I have had both of the above make my check engine light come on another vehicle.
  • behrend1behrend1 Member Posts: 5
    Hello all.
    I'm trying to solve a problem with my 2001 Sienna.
    Basically, the battery was low so I jumpstarted it off my other car. Everything was going fine, until I was unhooking the jumper cables and I accidently arced the positive and the negative. The engine on the Sienna immedietly died. It now has power from the battery, but will not start. All the other accessories work. What I'd like to find out is: Did I fry the alternator or any other major component? Could I have just blown a fuse?
    Any answers will be greatly appreciated. My wife needs the van on Monday, and today is Saturday. I only hope it is something minor like a fuse, or even if I have to change out the alternator thats not too bad as long as it is done by Monday.
    If you "fried the alternator", that would be pretty minor, in the grand scheme of things. What you really are afraid of is frying one or five of your proprietary computers (Engine Control, ABS, climate control...)
    With any luck, though, nothing happened except during the short, the engine simply cut out. If the battery was empty before, chances are you didn't let the van run long enough to recharge the battery. It takes ~200 Ampere to start an engine; it takes a small fraction of that to run it -- and with the alternator running, you only need the battery to be part of the circuit and hold 12V, that's all.
    So hook it up and jump start it again, just be more careful... don't worry about additional damage; a "jump" is a source of 14 Volts just like anything else. If it's busted, it's busted; if it's okay, you won't break it. Just be more careful.
    And please let us know how it turns out.
    -Mathias
    First, I would find a new mechanic. If the check engine light was on, it has associated code(s) for the mechanic to read. This mechanic took a guess and was wrong. These engines come with platinum plugs good for 60,000 miles.
    The one of the O2 sensors would be my best bet for your "check engine." If you have Autozones parts stores in your area, most of them will read the codes for you.
  • jinvirginiajinvirginia Member Posts: 1
    In the last couple of weeks, my Sienna (75K) has developed a whine when accelerating, especially up to about 35-40 mph. I have also heard it in reverse (a couple of times) It's not as pronounced when first operating the car, but seems to get louder the more you drive. I can't swear it's really "gone" at highway operating speeds (maybe drowned out by road noise?), but it seems to be. Also, the noise gets worse as the engine RPMs increase, then drops after the car shifts, up to about 35-40 mph. (It's much easier to hear with the windows down, driving alongside a curb; you don't tend to hear it with the windows up and the A/C blasting.)
    Had it checked out by the dealer, thinking it might be a transmission problem. They said it wasn't, but that both front hubs and bearings needed to be replaced ($922--ouch!), and that they recommended an alignment (another $80). It doesn't sound like any bearing problem I've heard, though, so I'm still on the fence. Anyone out there have a similar problem??
  • headers8headers8 Member Posts: 23
    The manual says, that one should consult the dealer first, before installing a twoway or CB radio in the Sienna. I am not sure what the reason for this is...
    Has anyone installed a two-way or CB rdaio in their Sienna? I am planning to install a CB radio using a cigarette lighter plug for the power connection and a magnetic base antenna
  • quest4suvquest4suv Member Posts: 12
    I put the Michelin Harmony on my 2000 XLE and they are wonderful. I live in Michigan and they perform very well in the snow we get.
    I have a 2000 XLE with 83000 miles and about 3 weeks ago the horn simply stopped working.
    I have checked the fuse and it is good so I replaced the relay and this did not solve the problem either. There are no other electrical issues with the van.
    I took it back to the original salesman and he has never had this happen in 8 years of selling.
    The service department says it will take about an hour to diagnose the problem at the going hourly rate plus what it would take parts wise to fix. They said they would absorb some of the cost if they can fix the problem.
    Has anyone ever had this happen to them before and if so could you help me out if it is something that a normal person might be able to fix? I would like to save some dough if possible.
    Thank you in advance for the help!!
    My 2000 XLE has another issue.
    I will try and explain it as best as I can.
    When you use the lever to open the gas flap there is a arm that drops down in the well of the drivers side slider door. This keeps the door from being slid open too far and damaging the fuel cover flap.
    Well when I try and close the door it closes very hard. I thought it might need to be lubed so I have sprayed WD-40 and it does seem to help (not fix) but help. After taking it to my local Toy dealer I have been told by the service department that the cable is broken and that it will cost about $400 dollars to fix. You can imagine that I almost dropped something when I heard that.
    Has anyone ever had this issue before or had the need to replace this part?
    Like the other issue with the horn, I am mechanically inclined so if it is something that I might be able to do I would like to save some money.
    Any help is appreciated!
    Thank you, again, in advance!
    I run a 25 watt 10 meter SSB ham rig in my 2002. Never had a problem.
    I also use a magnetic antenna base and run off the lighter plug.
    Are you sure it's not just a striker adjustment issue Quest4suv? Sliders generally have front and rear striker assemblies.
    Seems like a broken cable would prevent either the flap or door from working at all.
    When I open the manual gas flap on my Quest, it just causes a hook to grab an L shaped bracket on the back of the slider.
    Thank you for the response Steve.
    In thinking about it I would have to think that if the cable were broken then it would not drop the arm down at all.
    This is an interesting arm that drops down when the gas flap cover is released from inside the vehicle. When you close the gas flap it is retracted back up. In the down position it prevents the drivers side slider door from opening all of the way. I am not sure how to adjust it or where to even look to adjust it.
    Is this something that I can do myself or should I take it to the dealer and explain what we think it might be?
    Thank you, again! :-)
    You could probably access the assembly by taking a panel off, but I'm not sure if you'd need to pop the sliding door panel off or the trim in the rear of the van.
    I always manage to break a clip or two popping door panels off and I've never popped the rear trim off the sides of my van. But Home Depot/Lowes/Ace supposedly sell replacement clips - guess it depends on how much exploratory surgery you want to do.
    Anyone had their interior trim pieces out?
  • duckshooterduckshooter Member Posts: 156
    Our 2000 Sienna LE was flawless. Somehow we missed out on the squealing brakes, transmission problems, sludging, etc. But at 84,000 miles and with all the new bells and whistles on the new models, we thought it was time to upgrade. To those considering an older Sienna I would suggest many of the problems listed here are fairly limited issues - I know three other people with 99-01 Siennas and none of them have had any problems whatsoever. My most significant repair in 4.5 years of ownership was a busted hood support rod clip (set me back about three bucks). But we maintained everything by the book. Replaced tires at 42K; 30K and 60K services done by Toyota. Everything else was me or Jiffy Lube. Again, we only upgraded this year to get a bigger van with more space and more goodies (we got the XLE Limited).
  • cjd100cjd100 Member Posts: 1
    When driving at night, the light behind the instrument panel, where the AC Temperature Selector does not always come on. It does if I tap on it. Any idea how to replace this bulb? Thanks,
  • rickafoleyrickafoley Member Posts: 5
    2001 xle. 62,000
    Had the engine check come on for the first time.
    Did not look forward to taking to the dealer or any other mechanic and spending $$$ :(
    Solution: Autozone has a tool that will provide the codes (for free!). I searched the internet for solutions. It ended up being that the gas cap was not on tight. A few prior, I had someone else fill it up and they did not click the cap a few times.
    I went back to Autozone and they cleared the codes for me, again for free.
  • accprof1accprof1 Member Posts: 1
    I bought this Siena with the premium JBL sound system in hopes of enjoying music. However, for sometime now on a random basis, I hear this skipping noise (chak chak chak chak . . . .). It happens regardless of whether I have the radio or the cd on. I informed the dealer and since they were unable to verify it (remember it happens randomly mostly on long raod trips), they are not willing to do anything about it. I was wondering if anybody else has had a similar problem and if they have been able to get it fixed. Thanks in advance.
    I wanted to give an update to this problem-
    I took it in to get it fixed on Tuesday morning and I have still not gotten it back and today is Wednesday night. They say that they can not locate why the horn is not working. They feel it is a broken wire some where but can not find it. They have the entire dash opened up.
    They asked me if I had ever been in an accident and it has never been. I explained that the only people who touch the vehicle are Toyota certified mechanics. I had it in several times for a dash board rattle that never actually got fixed and that would have been when the dash area would have been opened up.
    I am really getting disappointed in the Toyota brand. This will definitley not be a dead issue if I find out that one of the Toyota techs caused this to happen. I have $140 dollars into this already and it is not even fixed yet.
    On the cost of things: They gave me an inital discount to $45 dollars for the inital diagnostic and when they could not locate it during that time they asked for another hour at regular price. I authorized this... that is $95 dollars. They told me that they will not charge me any more for the diagnostics or labor since they can not locate the problem... Thus the $140 dollars so far. I will update when I get more information.
    Hmmm.... I am in the market for a new small size SUV.... Honda looks real good!!!
