Visitor Agreement.
Anyways, I think if they heated up instantly, it would be a lot harder on the system and the leather seats themselves. Just my thoughts!
-mike
200 miles after driving it, it needed a new transmission. I got mine from a dealer that got it from a defunct dealer whom I suspect I used it as a parts car. They(the first dealer) eventually closed. It stickered for 30,495. I ended up getting it for 21,495. All the options cept moon roof.
After getting the tranny replaced by a factory refurb, I was skeptical. I was proved right...for about 3000 miles, the the tranny "flared" into 3rd gear. That is, on shifting into 3rd the rpms shot up 1k or more.
I called the dealer, the mgr said "that's because of a tight tolerance issue, it will go away shortly or you can bring it in, we'll replace the tranny again. Well, it went away since I didn't relish spending another 10 days waiting for a new transmission. The service manager told me that driving it wouldn't void the 120k mile warranty.
Now that I've driven it for just over 8k miles, I find that the mileage is tolerable at around 18. I drive 80 miles a day to/from work. The 4x4 TOD works well on wet roads where it unplants the right rear. I.E. Right turn, uphill, wet road.
I've found that if I drive this vehicle uphill on a curve in 2 wheel drive, it can get "loose". I find that's an issue of the garbage goodyear invicta tires. If it wouldn't cost me $500 to replace them, I wouldn't complain so much. The stock tires really stink.
I say go for it. Any links for the locker, I would like to check it out.
-mike
-mike
I could get a great price on them from Tire Rack in size 255/60-17 ($113.00 a piece). The tire wheel calculator says they will only be off by 0.07% or .05 mph at 70mph.
My question is will this size work on the stock wheels and has anyone else gone up to this size?
What kind of problems could I expect if any?
On previous vehicles the air-conditioner would definitely cycle off during the winter months as it is not required when heating the interior.
Any thoughts on this one? Do your Axioms do the same thing?
Jeff
-mike
But, still, it is inconvenient to turn the A/C off every time going to Auto mode. I wish the previous Auto settings stay in memory when turning climate control to Auto next time.
What exactly did they replace for $2800?
-mike
-mike
You need to check on the warranty after a large component has been replaced.
I have never had trouble braking with the Integritys but could break the rear end loose under hard acceleration on both dry and wet pavement if I wasn't in TOD. Since I have put the Cross terrains on, I haven't had the rear end break loose once. The traction and all around performance of the cross terrains are very good.
Anyone buy a larger tire without any mods? I'm not looking to lift the ax at all, just curious what others have experienced.
Thanks, Happy Holidays Everyone!
Here's my take on what Isuzu is trying to tell us...
Key the music...
You have a truck that will last you a lifetime.. The only problem is trying to find service... Your traveling down a road and see an Isuzu dealer... Then you realize... You have just entered... The Twilight Zone!
See what happens when you watch too much TV!
Happy New Year Everyone!
What's your best and worst fuel economy for your Axiom?
The best highway I have recorded was I believe 23.2 or something like that. Mostly flat with cruise set at 65.
Jeff
I have been getting reasonable gas mileage, have about 4400 miles on the vehicle, I drive a 60+ mile roundtrip commute daily over the expressway system. The MPG on the first tank was 16.9 MPG this has gradually improved to about 18.9 MPG over the same roads.
I just took a 1200 mile trip, about 900 miles was interstate driving at 70-75 MPH, averaged 20.0 mpg, the highest highway gas mileage on the first leg was 20.2 mpg. The remaining 300 miles was running around in the city. All of these MPG figures are based on the trip computer reading.
