Nissan Pathfinder Maintenance and Repair
1353638404155
    worriedmom1worriedmom1 Member Posts: 1
    SORRY FOR THE FALSE STARTS. 2OO2 PATHFINDER WITH 94000 MILES RUNS GREAT, NO SMOKE OR OBVIOUS OIL LEAKS. MAKES TAPPING NOISE WITH INCREASED TEMPO WITH ACCELERATION. MECH. DIAGNOSED 4 OF 6 THROTTLE PLATES THAT FELL OFF WITH ASSOCIATED SCREWS LOST IN HEADS OR PISTONS. NISSAN SAYS NO RECORDED PROBLEM HOWEVER HAVING HARD TIME BELIEVING THIS IS AN ISOLATED CASE AS THE 4 THROTTLE PLATES FELL OFF AT VARYING TIMES AND ONLY STARTED MAKING NOISE THIS PAST SUNDAY. ANY OTHER NOTED CASES? HAVE BEEN TOLD THAT ALTIMAS HAVING THIS PROBLEM WITH SEVERAL MOTORS CHANGED WHILE UNDER WARRANTY
    keeferbkeeferb Member Posts: 81
    I agree. I love my PF, but the interior rattles and squeaks are really disappointing. Seems like when I figure one out, another one rears its ugly head.
    muskyfevermuskyfever Member Posts: 20
    I want to replace my fuel filter for my 1995 Nissan Pathfinder SE. Is the fuel filter under the hood or in the gas tank?
    I'm no mechanic but would like to replace it myself if it is not in the gas tank.
    Thanks in advance.
    v6enginev6engine Member Posts: 10
    It is under the hood, on the right side of the vehicle next to the relay box.
    brudzebrudze Member Posts: 1
    I too am experiencing a "chirping and vibration" sound only in cold weather. It is most noticeable when it is in gear at a stop sign or traffic light. When I shift to neutral the noise stops. How did you solve the problem? Lubricating the bushing? or replacing it? which bushing is it and what is location? I would appreciate any information you can supply. Thank you very much.
    grubz916grubz916 Member Posts: 1
    I have a 1995 pathfinder XE. Recently this perplexing problem with the rear suspension on my vehicle started to occur. When the vehicle hasn't been driven for a few hours, and especially when it's cold outside, I hear a clunk when I get in the driver's seat, or push down on the rear bumper. It seems to come from somewhere around the driver's side rear wheel. The suspension on this side seems to stick, until enough weight is applied onto the rear bumper to unstick the suspension and make a clunking sound, like someone tapping on the gas tank. Climbing under the truck, it sounds like its coming from around the gas tank, but that wouldn't explain why the suspension sticks. Also, once unstuck, everything is fine. No rattles, and it tracks straight on the highway. BTW, teh rear shocks are Bilsteins, which I installed back in 1999, and seems to be OK. Any ideas?
    hannahjahannahja Member Posts: 6
    You may want to look at the message boards for murano and b9 before you do that.
    kris2kris2 Member Posts: 51
    I have a 2001 Pathfinder 3.5 LE and on a cold start when I accelerate the transmission hesitates before shifting. The engine revs before the transmission finds the next gear. It does not occur after I drive for 5-10 mins. I have had a transmission flush but it did not help. The dealer is unable to replicate the problem because by the time I drive to the dealer the engine is warm and the problem does not occur. Probably I should leave it overnight at the dealer and let them check it in the morning. Did any of you have a similar problem? Appreciate your time.
    smokey75smokey75 Member Posts: 434
    It sounds like you have the exact problem described in this TSB:
    http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2001/NTB01-055.htm
    I took my 2001 in for this when it was about a year old & this fixed the problem. If you're still within the 5 year 60,000 mile powertrain warranty it should be covered but I bet you're close. I would do like you said & leave it with them overnight. Print out this TSB & give it to them also. They should have it but at least that way they'll know you know about it.
    christinegchristineg Member Posts: 1
    I have a 2002 Maxima with the same problem, constant skipping. To the point that it is so frustrating that it's not worth using the CD player at all. I noticed that for me the problem seems to be worse when my car is cold. Although, it happens whether the car is hot or cold.
    What did you do to fix your problem? How much did it end up costing you?
    Christineg
    texas_sam_08texas_sam_08 Member Posts: 4
    I have been searching for a mpg increaser for my 97 2WD PF. There are several items on ebay that supposedly increase mileage by up to 31%. I would like to know if anyone has ever got one of these and if so, how much increase in mpg did you get? I am skeptical about a 31% increase, but I am wondering if its worth the 30$ for a more slight increase.
    Sam
    The usual answer is if these things worked, the car manufacturers would be installing them at the factory to help them meet their CAFE requirements.
    Gas Saving Gizmos & Gadgets
    xplorx4xplorx4 Member Posts: 621
    The biggest MPG increaser is a lighter right foot. The best I've ever gotten on my 97 LE 4x4 is 21mpg, and that was using cruise control at 55mph following a U-Haul truck on the freeway for 400 miles without filling up. High speeds and quick acceleration are MPG killers.
    1stnissanpathf1stnissanpathf Member Posts: 1
    I've recently purchased a 1995 Nissan Pathfinder, XE V6, 4x4, when I first accelerate it will make a "clunking" noise only from take-off or slow acceleration around curves (under 10 mph)and in reverse. It almost sounds like the brakes are hanging up. Wondering if rear-axle may be locking in 4-wheel. i do not no if there are problems with the rear hubs on this also checked rear upper and lower sway arms and stablizer bars, all of which seem to be hooked up. Please help.
    Also looks like oil at one time, may have been over-filled on axle. What is the proper level?
    annoyedmanannoyedman Member Posts: 4
    I have a 2002 Pathfinder SE 4x4. In mid December, 2005, my Service Engine Soon light came on. The only accompanying sympton was a decrease in my fuel economy. They told me it was an O2 sensor and that it was not covered by my warranty They also told me at the time that it could just be a loose gas cap. However, I'm a bit anal about making sure that the gas cap is on tightly, and I always turn it until I hear 3 clicks whenever I'm putting the cap back on after refueling. In any case, I had them fix the sensor for about $280.
    On 1/21/06, the light came back on, and I took it back to the dealer. They said that a "rear O2 sensor" needed to be replaced, and that I should also replace the fuel filter and clean the throttle body. Upon further examination, they also replaced the "variable timing solenoids". At the same time, I had them do the 30,000 mile service. Total cost was $572, of which $160 was for cleaning the throttle body and injectors, $348 was for the 30k mile service, $64 for replacing the fuel filter; and the variable timeing solenoids were covered by warranty.
    Today, 2/26/06, the darn light came on again, and because it's a Sunday, I can't even do anything about it until tomorrow. So I have no idea what the cause might be.
    Has anybody else out there had a persistent problem with the Service Engine Soon light coming on one a month?
    Also, if you have had such a problem, has the dealer cooperated with you in making it right? I've spent a little over $500 in December and January trying to track this down, and who knows how much it is going to cost me this time? By the way, the dealer is Performance Nissan in Duarte, California. One of the reasons I bought a Nissan is that I had heard good things about their reliability. I'm beginning to have second thoughts.
    Thanks for the replies, I'll be sure not to waste my money.
    jstonerock2jstonerock2 Member Posts: 1
    My service engine soon light also comes on.... and goes out and comes on again....
    It is totally at random but does seem to happen after I have gotten gas and have not tightened my gas cap to the 200th click. The manual says that it is caused by the gas cap not being tightened properly ( or being bad) and that after about 21 starts the light should go out. It always goes out. I haven't taken it to the dealer because I have read various messages about them not being able to fix the problem and that it returns. So I live with it. :)
    pathstar1pathstar1 Member Posts: 1,015
    The Nissan Pathfinder computer is set a little too sensitive. Ask the dealer about performing the TSB that reduces that sensitivity. You are probably going to have to pay for that service (should be around $50). A bad tank of fuel can trigger the light.
    There are four O2 sensors, one on each side before the cat. and one on each side after the cat. If one of the sensors failed and you only replaced it, there is a good liklyhood that others are in a similar state of wear by now, and will trigger the light soon. O2 sensors don't last forever. Yes, they are expensive.
    There are also two cam timing sensors, one on each side of the engine, that are known to wear and cause the light to come on. You can see them on the front of the heads (black plastic devices bolted to the front of the head on each side).
    If you read back in this forum you will find lots of posts on both. I don't think it's fair to say the vehicle is "unreliable" just because parts wear and need to be replaced from time to time. It's a complex machine that will need service.
    roy_destroyerroy_destroyer Member Posts: 1
    I have a 2000 Pathfinder 4wd. There is a steady vibration that exists while driving. I have replaced the tires and the U-joints. The vibration changed a bit after doing the U-joints. The guy who is working on it is thinking the rear drive shaft. He said that the vibration cut down alot when he took the front drive shaft out and drove it. Any one else have a similar issue?
    jnewland3jnewland3 Member Posts: 1
    any ideas on a nissan pathfinder that the speedo does not work faults read speed sensor circuit changed sensor and checked wiring from trans to firewall ok could it be computor or speedo head
    multiwrenchmultiwrench Member Posts: 1
    To Elbian. I need the SW Pennsylvania shop name. I assume near Pittsburgh, but wherever is ok. 93 PF needs experienced shop to do the same to pass inspection. Reinforcement in the frame arch over the rear axle is my guess. Thanks in advance.
    Thanks smokey75 much appreciated. I have scheduled an appointment for service and I will show it to them. I have 67K miles on it but I have an extended warranty till 95k miles and I am hoping it will be covered in that.
    teamsterteamster Member Posts: 2
    Had front shocks replaced by independant mechanic (non-factory). In order to install shocks, they disconnected the sensors (located underneath front seat) that controls the comfort ride, and sport ride. Noticed immediately the ride was off... I was told no... no... every thing is fine. The ride was never the same.
    As time went on, a jerking sway (right to left, and left to right) became alarming noticeable. Scary, especially driving on the highway, and is happening more often.
    I was told, by an other mechanic, that by disconnecting those sensors a roll over could occur. A Major safety problem.
    Also, told that the shocks for the 1996 Pathfinder was the only year these particular parts were used.
    Anyone out there have this problem? Please help!!!
    seacow1seacow1 Member Posts: 1
    I have a 2002 PF LE and the electronic heater will not turn off. You can adjust the settings to defrost, manual and automatic but the blower stays on full force. I don't think the temp control is responding either. As soon as you turn the car on the heater is full force. Anyone have any recommendations?
    If the front defroster is turned on the vehicle will respond as you indicate. It remembers if it was on when you shut off the vehicle and comes on again when you restart. Touch the button to turn it off (when the vehicle is running). It will also remember this setting.
    If you select "ECON" or "AUTO" you do not control the fan. The fan should stay off (once the above defrost button is turned off) until there is heat in the heater core. Then the fan speed ramps up as the system tries to reach the temp. you have selected.
    Hope this solves your problem.
    The swaying you describe is caused by rotted/worn bushings in the rear suspension's lower control arms. The problem has nothing to do with front suspension or shocks.
    roadrunner70roadrunner70 Member Posts: 241
    has anyone had to deal with hooking up the brake lock out solenoid on a late model pathfinder? how did you get power to the blue wire for the lock out? thanks. rr70
    nissandavenissandave Member Posts: 1
    I have a 98 Pathy. About a month or so ago, I noticed that there seemed to a be a little hesitation or miss every now and then. At idle, the motor purred perfectly. Anyway, this condition seemed to get worse and worse over time, so I took it to my local mechanic. BTW, when I took it in, it was driveable, but it was missing consistently and repetitvely. He took the distributor cap off and started to look around. He said that there is a plate below the optical eye and after pulling this plate off, there were very small, fine metal shavings all around below the plate. He cleaned it up, put it back together, and ran flawlessly. Well, yesterday, my wife is driving it home from work and it started again, but much more worse. She had to pull off the side of the road. When I got there, it would barely idle. When I tried to drive it, it felt like and sounded like the drive shaft was trying to fly off. It was shaking like one of those bulls like you see those bull riders on on tv. Anyway, it would not pick up speed or power. So I had it towed to the same mechanic. He checked the same place again and said he used canned air to blow out a few metal sahvings from the same place. Now it runs great again. He said that he has never seen this before and he does not know where this metal flakes are coming from. He said that the only place he could think this was coming from was the distributor shaft and that somehow it was working it's way up the shaft. He said that normally when distributors need to be replaced, they will rock back and forth, but mine won't budge. Has anybody heard of this problem before and is my distributor going bad?
    batch3batch3 Member Posts: 2
    Problem has been intermitting for 4 months, my daughter has been complaining the car would just stop or chug a long,with gas pedal to floor the car would not drive over 15mps. Every time I would go to rescue her the car would start for me. This past week she went to fuel up and the car would not start, not even for me. The car was towed to a local auto repair shop, he replaced the cold temp sensor
    however it did not work so he did not charge me for repair,
    I called the local Nissan dealer, he said they would not work on the car because it was to old. I have been told that it is fuel related that to much fuel was getting in engine . Any sugestions????
    xplorx4:
    Thank you for taking the time to answer my question. In addition to the sway problem, I was also was told that the rear links were worn and needed to be replaced, the job would cost for about $1000.00. Who do you trust these days????
    Thanks again...
    Dude, $1000 is about $700 too much. The sway problem is CAUSED by the worn rear links, not IN ADDITION TO. Sheesh! Some mechanics! Get another quote from a reputable suspension/alignment shop.
    The lower links cost about $68 each, and you can even purchase them online (click here). Labor to R&R should be no more than an hour per side, unless you live in the snow belt and rust/corrosion is a factor.
    The upper links don't need to be replaced to cure the swaying problem, so if you want to stage the repair so it's not such a hit to the pocketbook, do the lowers first, see how the truck rides, then do the uppers.
    docuksaedocuksae Member Posts: 1
    I've noticed lately when my swinging tailgate slams shut it sticks for a while and I can't seem to get it back open. Does anyone know what is happening? I was moving some furniture and now I can't get it out of the back of my Pathfinder. HELP!
    supersprintsupersprint Member Posts: 3
    Anybody know if you need special tools or tech info to replace the one of the rear 02 sensors on the 01 Pathfinder yourself or is it better to save time and trouble and have the dealer do it? I've been working on my cars myself over the years and have quite an assortment of auto tools to use. The dreaded SES light is on on mine and I paid $110 to my dealer to have it diagnosed. Now they want around $350 to replace one of the sensors and reset the computer. I called my local Precision Tune and they said they can do it for less but am not sure if they have the right diagnostic equipment to interface with the Nissan computer. Any input would be greatly appreciated! Thanks
    I found that Nissan sells the factory Pathfinder service manual (complete set of 4 manuals) for $295 new. On Ebay I found several members supposedly selling factory service manuals on CD for under $10.00 Anybody ever use the factory service manual and if so how detailed is it? How does it compare to a chilton or haynes manual? Any input would be great fully appreciated! Thanks
    Go visit www.nissan-techinfo.com. There, you can get subscriptions to view the online FSMs (in PDF format) for various lengths of time. For example, a one-day subscription costs just $20. If you know how versatile a PDF is, and you know how to right-click, well...
    Granted, this doesn't give you the FSM in printed format, but you can have the whole thing in electronic format at your fingertips.
    The FSM is very useful, as it describes in detail each and every system, and complements a Haynes manual well.
    bimmer4mebimmer4me Member Posts: 266
    FYI: I had one of my 02 sensors (01 PF) replaced after the SES light came on. I payed for the labor and part, but the reprograming the computer falls under the 8 year or 80,000 miles emissions warranty and you shouldn't have to pay for it. The Nissan dealer tried to charge me for the reseting...had to contact Nissan Corp and my local dealer reversed the charge.
    I replaced the left rear myself and it wasn't that bad. The service manual says to apply anti-seize with a thread chaser before you install the new one. I found a "spark plug thread chaser" at Autozone & it was the correct size & pitch. I'm not at home right now so I can't say what size it is. If it's the right check it out & see if you can get an open end wrench on it. If not, they make an O2 sensor socket that's open on the side to allow the wires to slip in. I used the Bosch sensor, which is the OEM, & it has plastic things spaced along the wires that pop into the existing holes on the vehicle to hold the wires in place. Some of these are a pain in the [non-permissible content removed] to get to. Expect scraped up arms. Bimmer4me is right on about the ECM reprogram being under the emission warranty. My dealer had me bring in proof I had changed the sensor & they did the reprogram no charge. www.bosch4less.com was the cheapest I found the sensor but it's not working right now for some reason... hopefully temporary.
    sitanositano Member Posts: 5
    Personally... I would never go too a dealer for repair work. Unless it was warranty work... I believe that consumer reports also advise you find a reputable repair shop rather than use the dealers. They have way too many overhead cost to make the work reasonable & reliable. Now too address your problem...
    I had a similar problem where the car would run fine, then stop, over too the mechanic & it would run fine... we did this dance maybe 5 or 6 times... finally he said just leave the *&^% thing with him. Several weeks later he called to say that they finally figured out the problem. He had attached a seperate fuel pressure gauge and for several weeks drove the car to & from work, runs for the shop & started to track the fuel pressure. The problem was garbage in the tank, clogged fuel filter but the main problem was a intermittant fuel pump.He installed a new fuel pump & it hasn't done it again. But it took him a while to find it.
    alleyezonericalleyezoneric Member Posts: 2
    hey! I have an 04' Pathfinder LE Platinum Edition that is extremely loud in the engine. My engine makes a constant rapid cluck cluck cluck noise. Each cluck in 1 second intervals so it is constant. Like others have described on here, it has a diesel engine sound to it, but not as deep and throaty a sound. I baby this vehicle. I service it faithfully and treat it better than my wife! So, this is why I can't figure out why it sounds this way. Took it to 3 Nissan dealers. All say it is normal and nothing is wrong. However, the PF did not make this noise when I bought it. It only has 18k on it too, so it's still somewhat new. I'm running out of dealers to take it to. I feel like I'm getting the shaft here, because noise does not sound right at all, but I don't know what else to do!
    mattauschmattausch Member Posts: 1
    The following is a description of a problem with a 1997 Nissan Pathfinder with a total of 125,000 miles with Michelin LTX M/S, 31.0x10.5 tires, running at 40 PSI (hard).
    The original front struts lasted for 71,000 miles and had to be replaced because they were leaking. Heavy duty KYB struts were installed and currently have 54,000 miles on them. They have worked great up until now.
    The original rear shocks lasted for 51,000 miles and were replaced with heavy duty Gabriel shocks. In June 2005, we started a trip to Ohio and experienced a "waddle" type of instability. (As opposed to the usual "porpoising" caused by a pair of weak shocks.) The Gabriel's had 61,000 miles on them and I replaced them with a pair of heavy duty Monroe shocks. It significantly reduced the problem , but didn't completely eliminate it. By October, the Monroe's had 11,000 miles on them and the problem of "waddling" was worse than ever. It is triggered by any road unevenness and I have to apply the brakes to keep the car from oscillating (from side to side) out of control. In October I replaced the Monroe rear shocks with a heavy duty pair of KYB's and it again helped but did not eliminate the problem. The rear KYB shocks currently have 11,000 miles on them. The problem is now significant enough to be unsafe.
    A "hands on" check of the front and rear stabilizer bars and their connecting rods cannot detect any looseness. The same check on the rear panhard bar feels tight also. However, this is within the context that my attempted wiggling of the bars are probably a small percentage of the tension that is normally on these bars. All the rubber connectors appear to be whole and undamaged.
    The key question: Is this a strut/shock problem or a stabilizer system problem? (Or is it something else entirely?)
    The "waddle" can be best described as rocking from side to side and not front to rear. It seems to be about equally severe in both the front and back. The whole car "waddles" and not just a front or rear event.
    I've read other posts here that suggest this might be caused by worn rear links or lower control arms. What do you think?
    Definitely worn bushings in the rear suspension lower control arms. This is a known issue on 96-99 Pathfinders. The mounting position of the shocks causes the bushings to wear faster than normal, since every up/down movement of the axle translates to a forward/back force induced by the shocks.
    The reason why the whole truck "waddles" is because the worn bushings allow each side of the axle to move forward or backward independently, effectively letting the rear axle "steer" the vehicle.
    Don't even attempt to troubleshoot anything else until after you've replaced the lower control arms, or it'll just be a waste of time and $$.
    shark715shark715 Member Posts: 382
    Xplorx, I may be starting to experience the same "waddling" problem on my '01 PF. It has 103K miles. I heard on the Car Doctor radio show this morning that Nissan issued a TSB on this in 1998. Is it likely I have the same problem, or was the rear suspension design changed after the '99 model year? Thanks.
    The rear suspension design was changed on 99.5+ models to reduce the premature bushing wear. This is the first time I've ever heard of an '01+ with this problem.
    However, with 103K miles on your Pathy, it's possible that some of your suspension parts may need replacing.
    One way to tell if your rear lower link bushings are worn is to park the vehicle on a level surface, chock the front wheels, release the parking brake and put the tranny in N. Then, grasp one of the rear wheels at 9 and 3-oclock and try to rotate it forward and back. As you do this, keep a very close eye on the stiffness/movement of the lower link relative to a fixed part on the frame, such as the gas tank skid plate, etc. Worn bushings will allow the lower link to move back and forth, instead of staying firmly positioned. You can also try to twist the link by hand. If it twists easily, the bushings could be worn.
    If you've never replaced the shocks or struts, I would first have that work done before doing the rear links.
    Thanks for the tip, Explorx. It's very possible I have a different, but related problem. My truck doesn't seem to "waddle" as noticeably as some others have reported with the older model years, but the handling in my truck is not nearly as stable as it used to be. How does one check struts and shocks these days? Thirty years ago we would bounce each corner of the car, and if it bounced more than once, it was indication that the shock absorber needed to be replaced. My truck is not more bouncy than it used to be, the handling is just not as stable. BTW, I do have an Airlift kit, but I've had it for 5 years. I normally keep it at 6-8 pounds of pressure (the manual says to always keep at least 5 lbs.) except when I'm towing my boat or carrying a heavier than normal load. Thanks again for your help.
    Shocks and struts- same method as 30 years ago. Also check for oil leaking around the strut and shock body.
    sndpsndp Member Posts: 1
    Hi, I had bought a 2002 pathfinder LE a few months back and I notice there is vibration in seat at around 60(in 2WD mode). Is this normal? If not, what can be the cause? Goes away at higher/lower speeds.
    I had steering vibration before this and got balancing done with a shop with hunter gsp machine and that part seems very much improved.
    I left my Pathfinder overnight at the dealer but they were not able to replicate the transmission slip/engine flare. The mechanic at the dealer (Woodfield Nissan) went through the TSB and said my car has the parts mentioned in the TSB. I come back home and start to work the next day and the engine flare is still there and it has been cold in Chicago the past few days and I get the problem everytime I start my pathy after resting it a few hours. The dealer did not charge me for checking it out but I had to pay for the rental car which was otherwise cover in my extended warranty.
    ckasprickckasprick Member Posts: 1
    1992 Pathfinder. It started to run rough about 10 miles from home, then proceded to run more rough and noticed smell of exaust (like a flooded engine) and high levels of smoke/exasut from the tailpipe. Now it won't start- it tries but won't catch. Before it stopped running I had to keep up the RPM's to prevent it from stalling. I replaced the fuel filter with no change.
    Any suggestions
