Nissan Pathfinder Owners: Accessories & Modifications
Mario
http://www.blackpantherskidplates.com/new_website.htm
bb
Any comments or suggestions are welcomed.
I am going to be driving over long distances with snow and mud but no heavy off roading activities.
These would be placed on a stock 2003 SE on the original rims at P255/70 R16.
Goodyear Wrangler AT/S
Goodyear Wrangler Radial RT/S
BFGoodrich All-Terrain T/A KO
Michelin LTX M/S
PS We haven't received our manual yet.
"ECONOMY" just disables the air conditioner (cooling). If you mess with the fan speed control (rocker switch on the right) the system goes into manual mode, and you control the fan speed (it will not speed up if the temp. diff. changes).
Any other ideas?
My front brake pads need to be changed on a PF 01?
I read from previous posts that Axxis Metal Masters are good and was thinking on getting them.
What other aftermarket pads have you used?
2001 X-Terra and had problems with little rust spots showing up on the rear deck lid. The dealer
did everything he could to explain this away. I am now experienceing this same problem on my
Pathfinder. And have recently learned from a local body shop that they have done several x-terra's that were still under waranty. I have a
claim with my dealer now, and I am waiting to see if it will be honored, for my pathfinder. I live in a area where they use pure salt on the roads, even if their is a hint it will snow.
I would appreciate any feedback. Thanks
Also, had them fave the white letters out and they really look nice.
Hope this helps.
Any suggestions ?
Looking at a Curt 13165 class III 5000 lb to tow my boat.
Anyone have experience installing / using this unit?
Anyone have experience towing close to 5000 lbs with their Pathfinder?
Anyone towing a boat, using 4WD low at the ramp?
Greatly appreciate any replies.
J
Looking serious at the Class III 5K lbs Curt 13156 - about $170 plus shipping.
Here's a look installed:
http://www.hitchsource.com/product_info.php?products_id=25856
a trailer hicth is a YEAR 2002.
Now looking at a 2005 (or maybe 2006). The under dash cowling is quite flimsy on the 2005, and I expect the same on the 2006.
Any suggestions?
