Visitor Agreement.
thx.
78k and still running though expensively.
If u think u do, why not - get em fixed? The heated seats were a failure issue early on. When I ordered my 2001 new, the only option I left off were the heated seats because most ALL of them were failing on the 2000 LSes.
If this is a Fla car since new, I'd bet it has the original seat heaters in it and they probably never worked. You *might* be able to get Ford to do something if that's the case, but I doubt it.
I think it's about $300 for the dealer to fix it.
Got a new problem. Happened only one (so far) but potentially serious. Pulled up to a toll both the other day, paid the toll and started to accelerate away. Went maybe 15 feet and then I had no throttle response. Tach was showing rpms but was going nowhere. Parked it on the shoulder and sat there for a moment. Changed gears, nothing.
Finally turned the engine off, let it sit for a few seconds, then restarted the engine. Shifted into drive and drove away as nice as you please. No problems since then.
Software glitch in the computer tranny? Does not appear to be mechanical as in a gear failure.
Strangely enough had a similar problem about 3 years ago with a Cadillac Eldorado. Wife was driving home from work one dark, winter night and the same thing happened. Had it towed to my mechanic, left it overnight, next day it ran fine. Took it to an independent transmission specialist who had it for about 10 days. Ran all kinds of diagnostics, drove the hell out of it, changed fluid filters and could never reproduce the problem.
Traded it in on the LS--I did tell the Lincoln dealer about the transmission problem.
Any ideas?
They're great tires. Expensive, but great.
http://www.ford-trucks.com/tsb/tsb.php/m-LINCOLN
Choose the 2003 LINCOLN TSB Lookup, then the 2003 LINCOLN LS TSB Lookup, then scroll down to TIRES. You will see two of them, 17929 and 18133. They are related. It's interesting that these same two TSBs were carried forward into the 2004 model year which were the ones that I used. Print them out and take them to your dealer. It saves a lot of talking. I had absolutely no fuss from my dealer. But they had all my service records since new and saw that I had the original tires rotated at the prescribed intervals, etc. Good luck.
Is the michelin Pilot Sport 225/55ZR16 a good replacement?? I usually run 38-40 PSI and the tires just wear out. No high spots etc just loses rubber..
Jim in Front Royal
Do you rotate your tires?
I generally get 40K miles +/- out of a set of tires, which so far have included the original Firestone Firehawks, a set of Michelin Pilot Sport A/S & currently Kuhmo Ecstas.
Sounds like you're running your tires 5-7 psi higher than most do. Why?
Assuming they're not wearing unevenly it's either normal or it's the higher PSI. Check the tire wear rating on new tires and also use the tirerack.com surveys to see what others are getting.
I've got 90Kon my 01 LS. On my 3rd set of tires. All Firestones. THis last set I like the best: Firestone Wide Ovals.
On january 23, 2007 i was the owner of what i thought was a very safe and reliable 2000 Lincoln LS V8. I was driving only about 30 mph (thank God!)and all of a sudden with no warning my driver side wheel broke off! It wedged under my car as i struggled to maintain control and steer it to the side of the road. People passing were absolutely in awe and were pulling over to take pictures! It freaked me out...i wondered how something like that could even happen. After researching i found out there was a recall on that make and model (ones assembled at the Wixom Assembly Plant). SAFETY RECALL # 00S39 FRONT SUSPENSION LOWER BALL JOINTS. I bought the car from Import One and didn't own the vehicle at the time the recall was issued but a man at a Lincoln dealership told me something to the effect of the owner of the car at the time brought the car in to a Lincoln dealership in Lake Charles and was told the recall didn't apply to that car...i'm not sure if the vin wasn't included in the recall or if the defect wasn't occuring.
I wasn't quite sure of exactly what the hell was going on. This all was just insane and hard for me to process. Why did this happen? How could this happen? Wheels aren't supposed to break off cars!!! It was really scary for me to think of what could have possibly happened if i would have been on the interstate going 70+ mph...especially with my son (who was 1 yr old at the time) in the car with me!
I no longer have the car but have hired a lawyer and am seeking any information anyone may have regarding this matter. I am not happy and i want answers! I also want to make others aware so this doesn't happen to anyone else with possibly much worse consequences!
BTW, my '95 T-Bird I sold to my nephew just did the same thing, worn ball joint and the top of the wheel popped out in a parking lot. Good Luck.
