Lincoln LS Recalls & TSB
Here is the text of the TSB:
Some vehicles built prior to 9/27/2000 with a 3.9L engine and 5R55N transmission or built prior to 10/17/2000 with a 3.0L engine and 5R55N transmission may exhibit delayed Reverse or Drive engagements, harsh upshifts or downshifts, erratic upshifts, or delayed downshifts near 32 km/h (20 mph). This may be caused by the calibration of the Powertrain Control Module (PCM).
If you have these symptoms see your dealer.
Mark
Mark
We just came back from Wixom and Dearborn. The 2002s are being produced. We saw them coming of the line. Lots of new colors and the addition of the LSE Package. You will like them. There was a problem with a Vendor supplied part that was causing a few to Overheat. The issue has been corrected. By the way it is a great engine. An interesting tidbit about the V8 many don't know about is that it can run without water if there is coolant loss. Like Cadillac's Northstar.
Airwolf1000
Some LS Owners have already seen the 02s at the lots.
R
Tom
If you do, please foward this to me as I would like to bring it over to my dealer. Thanks
THE OTHER ISSUE I NOTICE IS WHEN THE TEMPERATURE IS BELOW 40 DEGREES OUTSIDE AND I FIRST DRIVE THE CAR THE RIDE IS ROUGH FOR APPROXIMATELY THE FIRST MILE. IT A VERY "BUMPY" RIDE. EVERYONE I HAD IN THE CAR HAS COMMENTED. I CHECKED THE TIRE PRESSURE AND THE PROBLEM STILL EXIST.
WHEN THE TEMPERATURE IS ABOVE 40 DEGREES I HAVE NEVER ENCOUNTERED THIS PROBLEM.
I PURCHASED THIS CAR USED AND HAVE DRIVEN THE VEHICLE FOR ONE MONTH. THE MILLAGE IS 24,000.
As to the headlight, these should be replaced under warranty unless you are out of warranty for some reason (time?). Originally, L-M was replacing all the fogged up headlights then they stopped and required some analysis. It seems that there is supposed to be some way for moisture to enter and then leave the headlight assembly. In other words, the fact that they fog up in car washes or in driving rain AND THEN CLEAR UP will not result in replacement, but if it persists or does it all the time, they will replace it. If the warranty does not cover it for some reason, you might want to go to E-bay as there always seem to be LS headlight assemblies on there. Apparently it is a very popular aftermarket item since it will fit many of the small Japanese imports that are so popular with just some small modifications so kids are always buying or stealing them.
TWO--Your turn signal broke. There is no rash of broken turn signals as far as I know in the LS line. I have had my 2000 LS V8 Sport for almost three years and have never had a turn signal problem. Stuff breaks. That is why they have a warranty. Recurring problems on the LS (early build) involve the rear window regulators and the dreaded 52 mph drone. Otherwise it is a pretty normal car. I have over 30,000 miles on mine and have never had an unscheduled visit to the dealer. That doesn't mean nothing has ever broken, just that nothing has ever broken that couldn't wait until it was convenient to visit the dealer (various mileage oil changes). The warranty items made it so I could get a loaner car. I have found it to be extremely reliable and while not bullet proof, fairly rugged.
Thanks in advance
Jack
power windows open. The first time the driver window was halfway down, and I thought that I must have hit the button by accident. The second time [end of October] they were down all the way and the moon roof was open. At the time the car was parked and locked at the train station. I took the car back to the dealer who replaced the driver door module [per a TSB]. Two weeks ago I found all the windows down approximately 1". Again, took it back to the dealer. There was an update to the earlier TSB, and he replaced the timer module. Just went outside and found both front windows down approx. 1" and the back windows down approx. 1/2"[very uniform, huh]. I called the dealer and he's at a loss. I had been thinking it had something to do with the keyless entry system, but this time the car wasn't locked [although I had used the keyless system to open the trunk]. Has anyone else encountered this problem, and does anyone have any idea as to what the underlying problem might be?????
Now, my brother has a 99 F-150 and was getting the engine light and a little rough operation from the engine. I put the diagnostic on it and it said random misfire. His ignition system is different in that it has 2 coils, one for each bank of 4 cylinders and I don't know if the system can tell which cylinder is misfiring. So I can understand the "random" misfire for his engine.
Have you changed the fuel filter, tried a different brand of gas, do you use 91 or better octance gas?
The problem was faulty ignition coils. They replaced only thoes coils that were bad, there is one per cylinder. So far so good.....no more problems. I hope this is helpful to you.
Dan
The nhtsa website has a full list of tsb's for many makes and models of vehicles. I think you can even find them here on edmunds.com..... yeah check right here
http://www.edmunds.com/maintenance/MaintenanceServlet
In my humble opinion you cannot go wrong by taking this car to the dealer for repair and maintenance. It is monsterously over engineered which requires knowledgable people that has direct access to the engineers that built and support it. It is a pleasure to drive but with pleasure comes pay and that is all i am going to say.
bought michelins off tire rack and no problems with Ohio winter and 3000 miles a month. will likely do the same with my 04.
let me know what you find.
If the "hum" is a lower pitched noise that seems to come out of the rear of the car, it a drone from the half-shafts resonating with the drive shaft. This occurs when the torque converter is locked and the engine is under load. This can be fixed by replacing the rear half-shafts with updated parts.
As far as the 50-80 vibration goes, it could be from the tire's and wheels or it could be from the drive-shaft.
If you do not know... basically the balance operator will try to find the wheels and the tires high spots and roate them out from one another before the application of weights. The reason being is that the more weight you add from center the more likely you are to have wobble.
It takes more time and may cost you more but is well worth it.
