It's only around a turn that the tires would be forced to scrub off any difference in speed. Let's hope she didn't do too many U-turns!
-juice
By the way, I doubt she did any u-turns!
Also, what fluids need changing? I don't want to look like a complete idiot (that I am) when I bring this baby in.
-mike
But...locked in 4WD, they mechanically must spin at the same speed. That's called "binding". The tires lose grip by force, and scrub off any difference in the diameter of the turn.
That's why many systems are for slippery surfaces only. Permanent AWD systems that send power to both axles at all time usually have a center differential to limit slip, but still allow some slip around the curves.
-juice
Whats the difference between a locking center diff and locking t case? Is one better than the other
A Transfer case is a box that takes in power from the transmission, (from an input shaft) and sends it out two ways, (front and back)
Transfer cases, may have any of the following functionality
Locked Hi and low range (not center diff)
Neutral
2wd
Full time 4wd(means the t-case has a center diff built-in, like Jeep select trac or discos)
however, the T-case doesn't have to have all settings. the LR for instance doesn't have a 2wd setting. AFAIK(not sure about defenders)
Some t-cases with diffs contain Automatically locking devices such as(haldex or quadradrive or some funky electric clutch thingamabob)or can be a VC rather than a true diff,
Some systems don't have t-cases, as the output of the tranny is split and goes straight to the back, and front (like a pilot or Audi quatro), so a separate box to split the power out of the tranny is not needed
The honda pilot system could be characterized as an auto engaging part time system, as there is no center diff. It is a front drive vehicle that locks into part time 4wd for short bursts
However, on most of the audi's, they have a center torsen diff. so all the wheels are getting power all the time.
Nomenclature is confusing, but it can be simplified this way,
Forgeting about hi and lo range for a second and whether there is a t-case or not.
a part time system locks the front and rear axles together, should be only used part time when slippy.
a full time system has a center diff or VC to allow for turns, etc and all wheels get power all the time, 50/50 split, 60/40 etc
a auto engaging part time system usually powers one set of wheels, and has no center diff, and when too much slip occurs, locks in the power to the other axle. a good example is a VC system, where one axle gets 90% torque and the other 10, it is essentially driven by one axle, and when slip, the vc locks and it becomes a temporary part time system because the front is locked to the back.
What adds to the confusion, is that full time systems can also be auto engaging part time, when they lock.
And the technologies used to transwer power between the directions are the same. VC's, electric or hydraulic clutches. (when auto diff locking is used)
So For me there are only three types of 4wd.
Manual part time (2wd, unless manually engaged)
Full-time,(with or without auto part time)
2wd with auto engaging part-time
I'm waiting for the system that has
Neutral,
Driver adjustable torque split center diff 5/95 to 50/50 split with an auto locking center diff
I don't know what Drew will call that.
Sorry for the long post
Whats the difference between the 2 and how does the G's center diff attach to the t case? Thanks.
They both "lock" the output shafts front and rear to the same speed, same as most part-time systems and other "real" 4wd trucks.
-mike
Essentially any t-case that has 4-hi/4-lo is a "locking" t-case or locking center diffy.
Full-time t-cases or center diffys have a mechanism (electronic or mechanical) that allow speed differentials between the front and rear drive shafts, this allows them to be driven on dry pavement. Part-time systems that can only be used on slippery/offroad situations, do not allow speed differentials between the front and rear drive shafts thus you need to have slippage in the system and in the part time case it's the ground-wheel point that is the slippage point.
-mike
Anyways I guess what I'm asking is what does a center diff look like. Does it look like a normal rear or front diff or does it look like something else because I can't see how something that looks like a rear diff can be attached to a t case and 2 driveshafts. Thanks.
-mike
-mike
Whats the advantage/disadvantage of each? Thanks.
-mike
http://www.rubicon4x4.com/transfercases/
some have built in diffentials(full time), some don't(part time)any t-case for a part time only system is locked by default, there isn't a center diff.
when the t-case contains a center diff, it may or may not be auto locking, for example the NV242 in some jeeps, and the system in Discos'needs the driver to shift from full to part time. when that happens, they've locked the center diff, and it is now a part time system.
so, if the vehicle can drive in 4wd on street, it needs a center diff. if the vehicle can be shifted into part time 4wd, then the center diff can be locked,
You need to consider what the mechanism is for locking the center diff.
Is it manual? is it hydraulic or electric, is it auto locking? Does it have lo range and neutral? those are the things to compare constrast.
I prefer fulltime systems that auto engage the center lock hydromechanically, like the jeep quadradrive, rather than electric systems, but if I was in the outback, I would want a manual system,
With that said, the electric locking systems and open center diffs with traction control work fine for the road, and as long as you're under warranty, it will be fixed if it needs to be.
-mike
-juice
Also, is it a good tracking/traction 4WD when it is not in high mode? My point is, when in high mode, I assume all cars have the wheels locked together, so there aren't major differences one car to another. The issue is driving along the highway at 60mph in A4WD on the Expedition...
Anyway Auto-4wd is not AWD. It is Rear wheel drive, once the system senses a wheel phyically slipping it will engage the 4-hi mode temporarily to regain traction. This is a re-active system which helps get you un-stuck but doesn't help much until you've already skidded or are partially stuck. A system that puts some power to both axles at all times is a better syatem IMHO.
-mike
Obviously they are rear biased, but I'm wondering if they are 100% rear unless slip is detected, or if they are always some percentage front, or variable by speed, etc.
-mike
That'll be pretty tough to get one stuck. Unless you high center. The wheelbase is very long so the break over angle won't be that good, either.
-juice
For instance, the RWD STS has Stabilitrac, but not 4WD, obviously.
-juice
-mike
I really enjoy reading your messages and I truly admire the level of expertise coming here from all corners of life. Recently I purchased my first SUV - a used 2001 Dodge Durango SLT with 77,000 km and 2WD, 4WD-high and 4WD-low driving modes. So, finally I also have some questions to ask:
1/ What goat-like surprises can I expect from 2WD Durango in the winter? Any tips how to improve its behavior?
2/ Since I live in the area of sometimes questionable winter driving conditions (Ontario), I wonder whether AWD mode couldn’t be a better choice (in the summer, I often pull a camping trailer, nevertheless my questions relate to winter driving only).
3/ I would also like to receive your advice about when I should safely engage the 4WD-high mode while driving on-road (rain, heavy rain, snow, snow storm, ice?)
4/ And when exactly to apply 4WD-low
5/ Are skid plates really needed for a heavy snow? When mounted, do they create annoying obstacles for future maintenance of the vehicle?
Thanks in advance!
Vlad
4-wd Hi- Engage it when the road is snow covered or ice covered, you could use it in rain, but I wouldn't suggest it. I would also get some good tires, they make all the difference in snowy conditions
4-wd Lo- Use this mode if you are stuck in a rut or need to break through a snow drift or pull out of a parking spot where you got snowed in by a plow etc. Don't use this mode above 25-30mph.
Hope this helps.
-mike
Many thanks for your practical info, I really appreciate it!!!
Best,
Vlad
AWD takes the guess work away, because usually it's full-time or engages automatically.
Tips? Drive smoothly, no sudden inputs, respect that 4WD helps you go but doesn't help you stop. Maybe even practice a bit in a snowy parking lot to get used to the dynamics of that truck.
Edmunds Live (in 2000) had one and it walked right through their muddy hill off road section even in 2WD with good tires mounted.
-juice
Vlad
-juice
-mike
If you are on-road 70% of the time, and it's dry, you should disengage 4WD. You probably don't need it anyway.
-juice
So relax and enjoy your new ride!
-juice
Is the locking differential in an AWD Chevy Express Van activated manually by a button on the dash, or does it engage automatically? If automatically, in what conditions? Is it located on the front axle, rear axle, or in the middle?
I live in Denver with 3 kids and need to know the best buy for a used vehicle. We currently have a Mountaineer but it doesn't have 3rd row seating so it's too small but it is AWD. I am looking at the Navigator but my husband wants a mini van. I'm not a very experienced snow driver so is AWD mini van better than 4W Navigator? Any other thoughts for us?
An AWD minivan would likely suit the needs of most folks, light-to-medium duty stuff. And it's easier to live with the rest of the time.
The Sienna has an AWD option, so do the Grand Caravan and the Montana.
Then there are cross-overs that try to blend the two, cars like the Freestyle, Pacifica, and the upcoming Subaru B9 Tribeca.
-juice
Thank you in advance -
cromero
I believe the fluids are serviceable, so let's hope it's just that simple - a fluid change.
-juice
