Nissan Sentra Problems
One of my friends has a 97 nissan sentra gxe and it will not start. The car is in excellent condition with under 80,000 miles. The battery works fine. I think it's the starter but what do I know. Does anyone have any ideas?
Can someone tell me what is this for and how critical is it for the operation of the vehicle.
Does anyone know what thumping noise is? Please give me some suggestions! THanks
Again thanks for your help :-)
Good luck with your thumping and shuddering!
i took it to the mechanic and told me it was the timing chain
he changed it and still the diessel sound
anybody has any idea before i go again
You know, all you have to do is put a stethoscope or screwdriver against the timing case cover and it'll about blow your ears out....why did this guy miss this?
Bearing noises usually show up only under load, and besides your car wouldn't go very far with very loud bearing noises.
You may have a bad camshaft and/or lifters.
Next time, go to someone who doesn't guess with your checkbook.
Some later '95's are OBD-II compliant, require a scan tool to retrieve stored trouble codes, and have a data link connector under the dash like the one shown here:
http://www.batauto.com/obd2.html
Earlier model trouble codes are accessed like this:
http://batauto.com/nissan.html
My Corsica noise in reverse (auto-trans) also is back to perfect health. Engine mount replaced. BTW what life can I expect out of the auto trans in a '92 Corsica V-6. Fluid has been changed 3 times and the vehicle has 126K. Its had Mobil 1 ATF in since 70K, for what its worth.
Heater hoses not leaking, brake cyl-not replaced, just seal kit-no leaks. Life is good-thanks for the many words of wisdom.
Al
The 3T40 (TH125) transaxles are pretty reliable units. About the only thing they like to do is bu**er up the converter clutch solenoid. Even that's not a really big issue, pretty simple replacement once you get the end cover off. You'll invent a few new words if the heater hose/tube starts leaking, though. LOL
I know the horn has a solenoid, but I am not sure what is going on with the cruise control. The turn on light comes
on but when I press set it the cruise light does not come on and the cruise does not set. If anybody has any advice
let me know. Also anybody knows were to get a horn solenoid, other that from the Nissan people.
My battery was drained two days ago, I recharge it and it works fine. But now the Air bag light blinks all the time.
Any suggestions
Any help is appreciated. Thanks.
