I had to get a loaded truck with the 4.0 to get those darn doors.
Don't get me wrong I love my 4.0 but the 2.3 mileage sure would be nice now.
This is a cylinder, usually silver and black. About the diameter of a 35mm film cartridge, and about twice as long. On left side on intake. Has a couple of wires going into it.
This is just a solnoid and valve which meter air into the intake for idle control. It can be removed (2 bolts) and cleaned, use car cleaner on the valve part. Do not get carb cleaner into the electronic end, it will eat up the coil in there. Be careful removing and do not damage the gasket.
If cleaning does not fix it, you need to buy a new one. About $60??????
(I know you can't get the 2.3 with the 4 doors. As far as the doors go I think you got taken as I have a 98 3.0l Super cab with the four doors this was the first year. In fact I was just looking at a new 05 super cab with the rear doors with a 3.0l engine.)
Nope atleast not in the 2 wheel drive models. I've owned a 2001 and currently have a 2002 and in both years if you wanted the 4 doors in a 2 wheel drive you basically had to get a loaded truck with the 4.0 liter. Atleast in 2002 they added limited slip though because it was kind of scary driving the 2001 in the Washington rain sometimes
thanks in advance for the help.
Carolyn Oldman
FYI... Gasoline in our area has recently hit a $1.00 a litre - a litre is slightly smaller than a quart. that would be about $3.80 a US gallon.
link title
high range is for higher speeds (but no more than 45 mph), when the road conditions are slick and require better traction
Carolyn Oldman"
Nope all though the engines may be similar in size they are to totally different engines. As for it fitting in his Mustang. You now what they say. If you have enough money you can make just about anything fit. I'd be a whole lot easier to to just go find an older 2.3 or even a 5.0 since there are so many kits for them.
the 4hi is the system you will use the most. In snow mud and such and for 4lo you use that to drive slow on old tank trails and rocky trails that you will manuever slowly. I have driven in 4hi in heavy rains for the safety and traction but you have to be careful in taking corners, nice and wide and not sharp as the system will bind on you and it will let you know. by the way you can engage the 4 hi while driving below 35-40 mph as well as disconnecting it. For 4lo you must be in park ( or neutral not sure its been a while since I used it) and your foot n the brake to turn it on and you must come to a stop to turn 4lo off. Hope this helps
I would appreciate any help or advise.
Thanks in advance Dan
I was unlucky enough to find out that I could not access the mirror assembly through the door...I have already bought a replacement drivers side mirror and would like to know how to go about replacing it?
Do I need to cut through the metal inside the door, or can I go at it through the outside?
Any help is appreciated..
Can we just hit a reset button? I hate to leave her truck in town for long, and on a friday night ...ugh.
Any ideas what would have caused this? :confuse:
