A car that lists for over $76,000 should have adjustable sunvisors!!!!!
So, it's out of the game.
PS. my friend looking at the car cannot be in the sun (skin cancer) so it's a MAJOR issue.
Mark
nomasjag
I almost lost an 04 VDP accelerating on a slippery on ramp. The stability control and traction control cannot always react quickly enough, especially with the power these cars have. Yours has the winter advantage of more "road hugging weight" than newer models (though obviously it is not an advantage in terms of dry handling and mpg). Get FOUR good winter tires and use them They make a world of difference, and they don't have to be studded. In really bad conditions, throw some tube sand bags in the trunk. You'll be able to go anywhere.
Ski rack suction cups have scratched the clear coat on our Town Car, so I've been loading them inside from dash to rear shelf. Just returned from Whistler after a week up there.
"TAH TAH"!
to another British tradition. :P
Go to autotrader.com. I think they allow you to put in three models in one search. Do years 2004 to 2006, models XJ, Van den Plas, and XJR, and up to 100 miles from your home. You will see that prices are all over the place (depending on whether it is a competing dealer or Jag dealer or private). You could possibly get a VDP for that money, and remember, the listed prices are before negotiation. These are great cars, but they are not selling well, so you can get a 4 year old $70K or $80K car for about 20, if the mileage is around 40K.
Don't buy a car that doesn't have the manuals and everything that it came with from the factory. The manual will tell you all about required maintenance. If you are buying from a dealer, they have to do whatever is due.
as i have exactly the same faults on my 3.2 v8.
i have also tryed a new battery but to no avail.and the time between it restarting is getting longer..........regards alan
Thanks for any input or suggestions on how to reserach this.
JagMonkey56 :shades:
I got that taken care of, and put on a new set of Firestone SZ50s. The car now has 16,000 miles, and I think I'll be lucky if they last through the end of this season! They're worn evenly, but that's only 9-10,000 miles out of these tires.....
I know that both sets of these tires are "high performance", and as such, don't last forever. I also realize that the "big cat" is a pretty heavy car. But only 16-17,000 miles from the two sets of tires, on a conservatively driven car, is a bit much...
How have you other XJ8 owners done on tire wear?
The XJ8 and TC weigh about the same, neighborhood of 4,000 lbs.
I've never had to hang iron with Michelins, but carry chains in case they're required.
and show little wear.Just because you paid for alignment does not mean it was done
correct, I own a Tire and Alignment shop and advise that you find a small shop that
does Alignment using the yellow pages and explain your problem over the phone.
Good Lucky
The first alignment I had done, at around 6000 miles, when I first realized that the rear tires were heavily worn. I had this done at the shop where I had been going for the last 25 years. They got the car "in spec" however they told me that they had used up all the adjustment to get the camber adjusted.
I just had the car done again at the local Jag dealer, beacuse the camber looked negative to me. They recently bought one of the newer "high tech" alignment machines. They said that there was a "little bit" of camber adjustment left, and they were able to make the necessary adjustments.
Either way, however, the little bit of negative camber wouldn't cause an overall shortness of tire life. Inside edge wear, yes, most definitely, but not the remainder of the tread.
I realize that "normal" passenger tires might last longer, however the car, in theory, should be outfitted with "Z" speed rate tires, and they generally are the 280-320 wear rated tires. As I mentioned, however, I think 10,000 miles is a little too quick to wear out a set of tires...
1. the reviewers consider the 2006 XJ8 roomy, both front and back seats...did they lengthen the new design so that the 2006 XJ8 has the same rear seat room as the 2002 XJ8L???...(which would make the newer 2006 XJ8L even longer still???)...
2. HID headlights are standard on 2006, along with adjustable pedals (I am rather short, and moving pedals are a dream for me), not an additional option???
3. the standard 4.2L 300 HP engine is rated at 27 mpg highway...does anyone get close to this in real life???
4. off the wall question...since Jaguar prior to 2008 (2007?) was owned by Ford (now sold to Tata Motors), are all those pre-2007 Jags covered under warranty by Ford, or did warranty responsibility also transfer to Tata???...in other words, if I found a 2005/2006 XJ8 or 8L with 25K miles, and wanted the Ford ESP warranty, can they sell it to me, or is EVERYTHING now covered (or NOT covered) by Tata???...obviously, I would feel better with an ESP warranty from Ford...
5. the reviewers, both editors and consumers, rave about the build quality of the newer Jag...have folks here found it to be solidly built with all the new aluminum on it???
6. for those who have been in wrecks, does the aluminum dramatically raise the cost of body and chassis repair, and have your insurance premiums gone up much???
Thanks for any offered thoughts...
The 2005 Jag has one of the best reliability/build quality ratings in its class. Jaguar, not Ford, provides the warranties. If you buy a certified used one, you can get coverage to 100,000 miles.
The aluminum body is more expensive to repair and insure, but not as bad as the Audi A8. Jaguar will ship your car to a shop that does proper repairs if you are out of range of one.
Mileage before 2008 adjustments was rated at 29 mpg highway. You should be able to get 27 easily if you are not driving like a bat out of hell.
The 2006 on has some extra features included that the 2004 and 05 did not. Even more sound insulation is part of that.
I think it is a great car, and it sure is a bargain used. Drive one and see what you think.
Further, the back seat of the 2002 XJ8 is actually quite cramped...but, it almost seemed like the 2004-up XJ8 has more seat room whereas the "L" version was needed prior to 2004...in other words, a newer XJ8 may have as much ear seat room as the previous stretched 8L...is that correct, or am I just a failure at reading???
Lastly, can Ford dealers around the coutry repair Jags, or only Jag dealers???...since I occasionally drive from Atlanta to Mississippi to vist relatives, if a Jag broke down, there may not be a dealer for 200 miles...
The 2004 and up XJ is classified as a large car. The 2003 and before was considered mid-size by the EPA. The legroom in a regular wheelbase XJ now is within half an inch of the amount offered by the pre-2004 long wheelbase version. But in addition, you have almost 2 and 1/2 inches more headroom. It goes from cramped before to quite adequate now.
BTW, a Jag is unlikely to break down on a long distance trip. They are quite reliable and long distance driving puts the least stress on key components.
THANK YOU. That is the exact info I was trying to determine. So, buying a newer XJ8 (which seem to make up 90% of what I see on the roads, the 8L, of all years, seem quite few) will give me the rear seat room of the older 8L, plus, even as short as I am, I had to duck to get into my friend's 2002 XJ8...
So, a 2005/2006 XJ8 will give the the dimensions (length) of the older 8L, plus the roofline is higher...sounds like a solution to me...
Now I can add this car to my never ending list of "possibilities", which may surpass five thousand...if I live to be 200, I may live long enough to whittle down the list...
PLUS: the 2006 is only 2 years old, and check the site of a local dealer, had them in the mid/upper $30s...another month or two, and the 2006 will be 3 years old, and the price may drop to the twenties...this could be nice...
Heck, if I ever actually BUY another car, two thirds of the posts on these topics will disappear, and 4 hosts may lose their jobs, simply because no one will be needed to read the "few" remaining posts...:):):):):):):)... :P
Thanks, gregg, I needed those answers...
Anybody any idea what that could mean? The manual says nothing about a possible message of that sort, nor does a Google search.
Supercharged engines are an exception, as the electronics may not be able to adequately adjust to an octane change under more extreme conditions.
On the other hand, most cars that take regular fuel are not set up to gain hp from using premium. Using premium when your vehicle calls for regular may net you less mpg, rendering premium the "inferior" fuel in that case.
94 Lincoln Twn Car 4.6 141000 miles
Each runs better and quieter using Mid Grade or 89 Octane. My source for fuel does not inclue Ethenal either.
You are fortunate BTW because here in WI it seems that all mid-grade gas has ethanol in it. Consequently, I avoid mid-grade.
Any significant problems w/ this model year I should be aware of?
