Jaguar XJ-Series
in Jaguar
I am considering buying an XJ series Jag - say from 1995 to 1998.
(1) What advice can you give me ? XJ6 or XJ8 ?
Models to avoid ? What mileage range would be advisable ?
(2) What about the "unreliablility" of Jags - true or false for these model years ?
(3) What extended warrenty is best among those available ?
(4) Any other advice to someone "new to Jag" ?
Thanks! CC
Thanks! CC
"Unreliability of Jags?" Corrected in the early 90's by Ford. No need to worry on newer cars.
"Extended warranty" Sorry, no idea in this dept.
Any other advice for new Jag owner? Yup. www.jag-lovers.org Will tell you more than you ever wanted to know about these cars. Just be sure you look under the "Modern" section and not the "XJ" section, because the "XJ" only covers cars made in 1987 and earlier.
Personally, I would opt for the XJ6. There wasn't a huge improvement switching from the I6 to the V8. To compare, the I6 had 245 bhp, and 289 ft.lb. of torque. The V8 has 290 bhp, and 290 ft.lb. of torque. So, in day to day driving, where torque is more important, they are equal.
The body styles are nearly identical, the XJ6's will be cheaper, interiors almost the same (I prefer the XJ6 interior design to the XJ8 actually). The XJ8's will come with more standard equipment, but any Jag buyer would load it to the gills anyway.
We got our XJ6 used, as you will, and it had the "Select Jaguar Warranty" I think it's called. It's whatever Jaguar gives to it's used cars, that's the name. And it pretty much covers everything.
I would say go for a 1996-97 XJ6. It's always better not to buy the first year of a car. I would also say to go for the Vanden Plas, as the rear-seat room in the standard wheelbase is pitiful.
As for the reliability problems, Ford had owned Jaguar for a number of years when these models came out, and they worked out most of the bugs.
They are great cars to buy used. The mileage isn't really an issue, since the engines are engineered to high standards. I'd say somewhere in the 60,000m range.
I think you will be happy with either an XJ6 or an XJ8, but I would advise to go for the XJ6. Better fuel economy, and not much of a difference from the V8. Good luck.
A.R.
http://www.jag-lovers.org/
Hope this helps.
I think that an XJR with the I6 would be a great car. I don't know too much about them, but if I were going to buy a regular wheelbase Jaguar again, I think I would go for an XJR, because otherwise there is no advantage on a standard Jag over a VDP.
As for winters, as long as you get a car equipped with traction control and/or limited slip differential, it should be as good as any other RWD car.~ A.R.
Pat
Sedans and Women's Auto Center Message Boards
On the snow opinions- I entirely agree that the Jaguar should not be driven in the snow. My thoughts were just that the Jaguar would do as well as any other RWD sedan in the snow. But I never take it out, even in the winter. I live in Canada, where we have snow for about 4 months of the year. And most of the time, we get a lot of snow. The Jaguar is parked from mid-november to about mid-april. I just find that the body rusts easily, even when it is just exposed to the rain. So, if you are planning on buying a Jaguar christchurch, whether it be the XJ8 or XJ6, try to keep it out of the snow- it will last much longer that way.
But, I think we can all agree that a used Jaguar is a great investment. Your money will be very well spent. Good luck~ A.R.
I thought we needed a special place to all enjoy the special character and peculiarities of these "felines" !
I appreciate your adding additional comments in response to mine on the "high end luxury site" to our discussion of Jaguar motorcars from which I transferred here my response.
I tend to agree with you that the XJ8 is probably an improvement over the "the old workhorse" engine of the XJ6, but may be more a matter of taste (dashboard configuration, etc., engine hp, etc.).
The safety issue is always one for me. I do think that the addition of side air bags increases ones protection in what is an otherwise quite safe vehicle.
Thanks for confirming the reliability of the Jag.
In the public mind this seems to be a caveat from which many run.
One further note, you say you drive them "till they collapse".
Have you ever purchased an "extended warrenty" to cover what could be costly repairs?
If so, what company have you found provided the best coverage and was the most reliable?
Any other purchase or ownership advice ?
Thanks, christchurch
Jag and Rolls/Bentley have always done things their own way. The pros cut up Jaguar for it's quirky ergonomics, but I like it that they have not conformed to the norm. There is no comparison to the woods they use. Even though Mercedes wood may be real, it looks so fake.
I absolutely love Jaguar. I am hooked! I hope we will be able to tell out various experiences on here in the posts to come!~ A.R.
Others describe their cars like the BMW / Benz / Lexus / etc. as "drivers cars". They share the taut steering, tight (read rough) riding suspensions, rocket like acceleration, etc. Motor magazines and "techno" types continue to try to convince the public on these "standards" as the norm.
Because Jags still preserve the "luxurious" ride and refined traditional elegance they are judged to be "not with it". That is,what they mean is. that they are not Germanic enough.
Personally, I am happy to enjoy a "touring car" with its gentle and wonderfully smooth ride. I can leave behind the jarring, stiff ride of what has been labeled as "the new standard". When I drive a car conforming to these this "standard" it seems like driving a "Fred Flintstone car... one with stone wheels"!
No thanks. I will take a Jag and enjoy a luxurious ride all the way past the competition and not need a chiropractor at the end of the journey!
For me Jags preserve the historic driving expierence...codeld while srouronded with burled walnut and coney leathers. I know of no better way to enjoy motoring?
Keep XJ's coming our to our shores....they only get better !
christchurch
These are great stories proving once again that there are a lot of people who have had very positive expierence with the "Cat" !
It must have humbled the caddie dealer to see her pull in "six or more times" in her Jag following behind a tow truck with the caddie dangling !
Wonder why people "don't get the picture"?
Keep the Jag lore coming our way.
christchurch
These JAGS are really one or two passenger drivers cars since the back seat leg room is very cramped. A passengers legs are humped up and are therefore without support of the rear seat which is low to begin with.
In other words, if you are going to have passengers opt only for the VDP or L series. The 5+/- inches makes rear seat occupants appreciate the ride and Jaguar style. Without it, anticipate stiff legs and ornery passengers, particularly on a journey of any length.
It is time to stretch the legs !
christchurch
Or go for a coupe- about the same rear leg room!~ A.R.
Once out of warranty, I think some repair cost protection is in order.
I know that you indicated that the Jaguar dealer's warrenty is great. But, what if you didn't buy through them ? Can you still do so?
All cars are expensive to repair JAGS being no exception and particuallry at dealerships. Luckily, a good "back ally" mechanic can also work with warranties.
Has anyone had experience with them?
I hear frightful stories about endless hassles, unpaid bills, denied claims, argumentative "customer reps.", and so on and so on.
If you have had an extended warrenty with your JAG or know of someone who has, let me know.
What are the pros and cons ?
What companies are the most reliable?
Got any ideas on these questions?
Happy "Jagin" !
christchurch
By the way, there is a company in Dallas called Texas Mustang Sales that sells used Jaguars at wholesale prices to the public. See www.texas-cars.com. The prices are $6K - $8K lower than the local dealerships.
Dan
The Texas Cars Direct in Dallas has the best prices on wholesale cars. I was watching their website for weeks until my wife decided on what color she wanted. But as I was watching the Houston paper ads, a 1998 VDP Jag with 40k miles was listed as the same price as Texas Cars Direct.
The price was right and the car was immaculate.
So I now have a 98 JAg VDP white/tan. We have put around 300 miles on it and I can't believe the car. Jags were always noted for speed but the 290 hp flys. We love this car. After several Lexus. and a 420SEL BENZ we decided on a Jag. I am sure glad we did. I bought an extended warranty up to 100k miles. We bought the car from AutoPlex in Houston from Mike Roa. He gets immaculate used Jags in from time to time at a fair wholesale price. You might give him a call. I have heard also that Texas cars direct in Dallas was also good.
I note that you indicated that you bought a warranty with the car.
May I inquire regarding the following?
What mileage was on the car when you bought it?
Who recommended the warranty and/or what was your consideration in selecting it?
What company supplied it?
Also, if you care to share it, I'm curious as to what you paid for it.
Your warranty advice would be appreciated as I am in the market for the same.
I congratulate you for joining "the ranks".
It sounds as though you bought right and that the car is "show room" in condition.
You will have many years of great pleasure. You will find, in addition, that there will be all sorts of people who will inquire of you about your car. These "cats" have a seductive affect on those who admire elegant styling. Soon you will be a promoter of Jaguar automobiles and will, thereby, gather many interesting stories.
While Lexus and Benz (which I have owned and driven for years) are quite fine automobiles in there own right, there is a special charachter....a personality... that is only found with Jaguar. There is a tireless quality in store for those who drive a JAG. The Jaguar is quite extordinary, a very special "touring" car, indeed !
christchurch
My consideration when I bought it was that I wanted to be covered for any major problem. Engine, Trans, drive train, etc. I would hate to come out of pocket for a complete engine overhaul.
Could you reproduce the pamphlet for us on the web?
I am sure we would all benefit from such, apparently, sage advice.
Appreciativly,
christchurch
I havn't heard of the company that you mentioned.
I am wondering which companies you checked into and what you decided regarding each.
I am in the market for a warranty and there is so much discussion owe way or the other.
(1) I would appreciate anyone helping with these decisions regarding warranties and reliable companies.
(2) Does the XJR have the lengthened wheelbase or is just the L. designated XJ series and VDP 1995 and newer?
(3) Has anyone had any expierence with "on line" JAG buying?
Happy motoring... christchurch
While I'm here, if anyone really wants the supercharged engine but needs a long wheelbase, Jag now offers a supercharged Vanden Plas. It is a beautiful and evilly fast car, but bring money (83K or so).
The latest news "on the street" is that the current xj series will be replaced in , I believe, 2002-2003. This new xj is being designed with very innovative safety considerations (perhaps, on the example of the Volvo (also, owned by Ford and to which its design team has input).
In any case, the safety ratings on the current xj series are among the best in the industry.
Safe Motoring !
christchurch
"Old gentlemen" often have sage advice. So, if you can find the "treasure" deep in the trove, pass it along to us so that we can be mentored thereby.
In anticipation of the "find".
christchurch
As you have noted elsewhere in my correspondence, I would strongly suggest to any prospective JAG owner that they purchase the L. series. The only short wheelbase version I would buy would be as a personal commuter vehicle in which I anticipated no rear seat passengers.
I treat the short wheelbase JAG "as a coupe". The back seat is reserved for briefcase, golf clubs/tennis gear,groceries and the golden retriever who claims this seat as his private domain !
I can't help but believe that a beautiful retriever in the back seat of a JAG conveys an air of elegance fitting for the JAG mystique !
The only other purchase consideration would be a color combination which "would correspond to that of the retriever".
What an picture, what an advertisement!.... Jaguar, golden retriever and all!
christchurch
