I own a Highlander Sport 2WD. I know the Sport suspension is a little firmer than others. I have some questions. Could someone please help me....
Is the Base model and Limited is having the same suspension? Can we convert the Sport Suspension to a Limited Suspension? Or we can make it a little softer with some modifications?
Wanted to share that I recently installed fog lights on the 08 Base model. I used cheap Yaris fog lights from e-Bay($45) and Toyota factory fog light bezels pre-painted in the car color (purchased from the dealer for about $35 each).My base model came prewired for fog lights. I spliced 2 wires from light switch on the steering wheel and connected them to the Toyota style button that came with Yaris fog lights. Button fits exactly in the place on the left side where blanks are. Fog light area is accessible from the top of the vehicle. I removed the battery and window washer bottle holding bolt for easy access.
I love hearing these stories of folks with the base model and all of the aftermarket time and $$ they've spent accessorizing their HLs to be equipped like a higher-level model. If you've got the time and inclination, more power to you; for me, I'd rather just purchase a higher trim level from the start.
Curious though...you say the Toyota-like switch from Yaris fit perfectly into the slot. The fog light control for those HLs that have them factory-installed is on the turn signal column. Is that what you're referring to?
I would like to replace my factory headunit in my non-JBL in-dash setup. I purchased a Sony mid-priced unit. Anyone had any success doing this? I need the specific brand and model number of the installation kit used and any photos you may have. I've heard of Scosche, American International and Metra.
I already purchased the wiring harness.
This is a Single DIN unit in a 2001 non-JBL setup.
I just purchased an 09 Highlander (thanks tax credit!). I got the base Limited with Option Package #7 which basically ads Blue Tooth and 6 CD changer. I also go the Power Lift gate. I have a few option questions:
Remote Entry - is it worth having the dealer put this in. I know I want it and am afraid if I have it installed elsewhere and they mess up the wiring it will void my warranty. ($695)
All weather mats - I know I'm probably better off getting these OEM.
"Protection Packages" - I've never had leather seats before, so I'm wondering if this is worth it. $328. "Environmental Corrosion Protection" (basically rust proofing) $250. "Acid Rain Protection" - $499.
All of the "protection" packages you mention are a ripoff. OEM all-weather floor mats are a good investment and if you're more comfortable with the dealer doing the work on the remote entry if you know you want it, then go for it.
Did they explain to you what exactly they do for the protection packages, and could they tell you the difference between "environmental corrosion" and "acid rain?" Did they do so with a straight face? I'm wondering how these con artists sleep at night?
On the weather mats I'd get the ones from Weathertech as they contain any runnoff and protect the carpet better then the Toyota ones (Had them both)
For the Protection Pkgs. some are rips offs as mentioned, but depending on where you live I would go with the rust proofing only. On my 06 I had the paint sealant (thrown in on the deal) and I could see the buffer markes in certain light conditions (night) so I was mad from day 1, on the new 08 left over I just purchased I had the rust proofing and interior protection, as it does the carpets and they say the leather as well and with the lighter interior I didn't want a stain. For the outside I'll use Griot's paint sealant and apply myself with a good carnuba wax.
I ordered an after market trailer hitch package with electrical connections included. All went very well, until I tried to hook up the 4 prong connection in the "trunk". I have a third seat and don't know how to access the prewired connection, that my directions show would be located under the third seat. Does the compartment with tools for changing a tire pull out to expose the wire connection? I was reluctant to do a lot of pulling of the tool tray, not knowing how it is attached. Pls advise.
I have a 2001 V6 Ltd with the Toyota towing package - does anyone know off the top of their head what connector it has (7-pin round, 6-pin round, etc)?
I'm buying a light kit for my utility trailer which has a four-pin flat connector so I expect I need an adapter, I just don't know which adapter. My wife has the HL so I can't go check.
A Toyota dealer service guy just told me it has a 6-pin flat, which I can't find any reference to elsewhere.
In case anyone's interested, the HL connector is a 4-pin flat, at least on my 2001. So at least I don't need an adaptor - too bad I already ordered one on the trailer accessory company's assurance that the HL had a 7-pin RV connector.
I have an '08 Highlander Limited, so check to see if this helps. The trailer wiring connection is under the storage compartment at the left rear of the luggage compartment. Lift the rear two floor covers, then remove the fastener at the top of the left edge between the compartments. Also remove the two plastic nuts at the bottom of the storage compartment. The compartment should then lift out. There are two connectors on the floor beneath this compartment. One is for the trailer wiring which must be purchased from a Toyota dealer. The other has a cap on it with wires inside. If you remove this cap, be sure to reinstall it firmly. Failure to do so will cause the backup lights to not work. ( My dealer didn't know this one, but then they are the worst in the country.)
I know you were pretty clear in your post so please bear with me, but I just spoke with WAAG today regarding this part (18326) because I just bought an '07 HH and want to install one.
They *refused* to sell it to me because they said it will not fit the Hybrid as the frame and attachment points are different than the non-Hybrid.
They said the same of their rear bumper guard piece (16742.) (What is the T&H single pipe? Is there a website where I can see that?)
Anyway - not trying to refute your personal experiences, just writing to verify I understood your post correctly and that you were able to install WAAG 18326 on your '06 Highlander Hybrid without any problems.
Thanks so much, would greatly appreciate your response.
had Best buy install it. Now I can play my ipod, pick up blue tooth cell calls and FM radio as well as play CD's of various types but lost traffic reports on favorite am station re: apparaently there is only one connection on Pioneer deck for antenna but you need two with Highlander set up to get both FM and AM. Anyone run into this. Also picks up some noice when accelerating anyone know of noise reduction techniques?
I have the same dilema with an 09 Highlander Limited. My connector is under the rear drivers side compartment. The nuts and push plug are remove but I think the jack tool tray needs to come out. How did you get the tool tray out to access the plug.
The schematic drawing with the wiring kit is not accurate. It shows the connection to be under the jack/tool kit area. It is not there. Pull out the three removeable pieces that are over the jack/slide cover. That is, the one big piece in the center, then the smaller pieces located on the left and right. Remove the bar/slide cover used to cover up packages in the back of the vehicle. Look on the left (drivers) side under that small cover that you removed. There are two nuts (plastic caps) in the bottom of that storage well. Remove them, as well as the upholstery screw/peg that is adjacent to where the left edge of the bar/slide was. Once you have these three attachments removed you can pull out the plastic well that they held in place. I know you have to force it some to pull up on its outer edge and then squeeze over the portion that lies under the side adjacent to the third seat. But I have taken out mine successfully twice without it cracking. Under this piece you will find your plug. Also there is a hole through the fender well to under the car that is covered with a rubber plug. I strung my wires through here and reinserted the plug.
I have no idea if this is the "correct" way to install the wiring, but it worked for me and my trailer lights work great. The rest of the instructions provided to install the wiring were right on the mark, only the schematic was goofy.
The Toyota dealer where I recently purchased a 2007 Highlander confirmed that my model does not have an information panel, where the outside temperature display and compass should be located. Can anyone suggest how I can obtain displays for these 2 features (is there a rear-view mirror or other aftermarket instrument with these features?) Thanks.
I just bought a 2010 Highlander Base and wanted to add a navigation system that looks stock. I really want the new Head Unit to have a good gps, ipod/iphone integration, bluetooth, and a rear camera out.
I've been looking on ebay and there are a lot of units that are shipping from China and Hong Kong. They ship the entire HU with the stock control panel so you can have your Navigation look stock. However, none of these sellers tell you the brand of the GPS. Anyone have experience with these units or have recommendations when buying one?
From usability point of view - get yourself a Garmin, much better then Toyota's built in nav or any Chinese clone. With Garmin you'll get quarterly map updates, traffic, and if you want to be fancy get a Garmin ecoRoute HD Vehicle Diagnostics Communicator.
Well I already own a portable Garmin. I'd like to ultimately upgrade my stereo system but if I can buy a navigation then I can also write it off for business. It looks like the Kenwoods have garmin navs built in. I've looked into the ones on ebay but they seem to be POS aftermarket units that aren't getting good reviews. I just don't want to ruin the look of my stock dash but it's near impossible to upgrade the stereo without changing out the headunit.
Anyone here installed an aftermarket Navigation into a Highlander? I want to know how the install went and if the LCD looked too out of place with the overall console?
If you purchased a rearview camera for your car, a reporter wants to hear from you. Please email pr@edmunds.com by Wednesday, October 6, 2010 with your daytime contact information and your thoughts on the system. Thanks, Jeannine Fallon Corporate Communications Edmunds.com
MODERATOR /ADMINISTRATOR Find me at kirstie_h@edmunds.com - or send a private message by clicking on my name. 2015 Kia Soul, 2021 Subaru Forester (kirstie_h), 2024 GMC Sierra 1500 (mr. kirstie_h) Review your vehicle
I'm brand new to the Toyota family and I'm finding it extremely hard to find Highlander resources online. Everytime I look for help on installing a stereo, I only find info on the Tacoma. I'm trying to find a service manual from Haynes and they have most Toyota cars outlined except the Highlander. Very few custom sites/blogs just for the highlander and nothing on Youtube for the Highlander.
Is there a definitive place I am missing for this car? Are people not as interested in modifying this car because it's traditionally more a family car? Where can I buy a service manual that shows me how to take the dash apart or the side doors?
I was in the same boat as you a month ago. Toyota Nation is the place for you. See the link below for DIY Modifications and Maintenance. Inside you'll find a link on installing a custom radio
I just completed installation of a Pioneer AVH-3200BT with XM receiver module yesterday in a 2006 Highlander Limited. The Limited had the JBL system (with amp located under the floor by tailgate latch). I thought the Kenwoods looked OK too, but I didn't want the nav in the upgrade radio. Reason: I always stick my TomTom on the window near the rearview mirror. There I can see it looking straight ahead and while glancing to the rearview. Look at the radio location in the Highlander. Your attention would have to be taken too far from the road to make me feel safe. I don't even like it built into our month old 2010 FX35. Too far from the road. I'm not going to go into the price of built in- ridiculous. Even the add on for the Pioneer -and all other - aftermarket is way too high. I'd rather spend on a portable I can move to a rental or friends car, and upgrade to a newer when I want, for a reasonable price. Bottom line, the Toyota equipment is way too skimpy. FE, my 2006 having a cassette (!!???) and a 6 CD changer that couldn't play MP3 !!??? J-U-N-K! iPods had been out for years by then and other manufacturers were putting in docks for them. Toyota put in a cassette player. Whooppee!! My [wifes] new car is an Infiniti with so many electronics I will never learn them all. And my [her old] highlander now plays iPhone movies, DVD movies, has Bluetooth, plays my 8 Gig music library from a 16 Gig SD card, and lets me listen to XM, all for less than $500. And I have my TomTom. Her name is Brenda.
A double DIN aftermarket works fine, BTW, with the plastic ear accessories to fill up the gaps on the side of the wider faceplate on some Highlander JBL radios. Most aftermarket radios like the Pioneers let you set the color of the LEDs to match the rest of the instrument cluster lights. There is no reason an aftermarket should look out of place. Now, my 2006 original instrument cluster has a blue/white glow while the climate and OEM JBL radio has dark green LED glow. Like they had leftover parts they wanted to use up before they made everything look the same. Who can figure out Toyota anymore? Installation is easy if you take it slow. I hated the steering wheel controls so I did not buy the adapter for them. My hand was always changing something (2006 Highlander). If you want to connect front seat video you have to connect parking brake wire. If you put in the rear view back up camera you have to connect that wiring. Those 3 things are optional and will increase install time & labor. Good videos on installing Highlander radios on You Tube. Crutchfield and others have wiring harness adapters and the $12 gap fillers. When finished it looks factory.
I purchased a 2011 highlander limited a few months ago. I noticed on the window sticker that it included a "Tow Prep Package". I thought that it would have included a hitch or at least a receiver but after calling the dealer they explained that the vehicle is rated to tow but the hitch and wiring must be added. I then inquired how much a Toyota Hitch and Wiring would cost, $600 installed. I was taken back on the cost but am also little apprehensive about putting after market parts on a brand new vehicle still under factory warranty. Not to mention that I purchase the toyota care extended warranty. Any suggestions?
I purchased a receiver hitch and wiring harness from my Toyota dealer in NC for my '08 Highlander. It was not the Toyota "factory" hitch shown in their brochure or accessory booklet, but rather an after market Class III Reese hitch that came from their Toyota Southeast supplier, Southeast Toyota Distributors, LLC. I had attended a "Get to Know your Toyota" seminar the dealer did, and there met the parts manager who sold it to me for around $250. The installation instructions for both were straight forward and it went on without any problem.
In December I traded for a 2011 and the dealer through-in on the deal accessories I had installed on the '08. I am now waiting for warmer weather to install the hitch. Installation instructions were not included in the carton, but the dealer's parts department voluntarily offered to print them out for me. Part numbers are: 00016-48730 hitch and 00016-48730-01 wiring harness. I don't see how adding an aftermarket hitch would void the warranty, especially if the vehicle is equipped with the Tow Prep Package.
I have a 2011 highlander limited with Thule base rack system. Interested in add a cargo box and looking for highlander owner experience with Thule and Yakima.
I am 5'6" and find the toyota highlander the most uncomfortable headrest I have ever experienced. I don't know how to get comfortable. I like to sit straight up......not with my head bent way forward. I feel that the headrest keeps me in a "Prepare for an accident state" at all times than a "be comfortable state". I also feel that it will destroy my good posture with a neck that protrudes way forward. It will make me look old before my time. I thought at the dealership they said that it could be adjusted......which it can't. I really need to find a solution. We will likely remove the headrest....but I wish Toyota could provide an alternative even if I have to pay for it. I feel neck pain (which I don't have) after sitting in the seat.
The Part Numbers: 00016-48730 hitch and 00016-48730-01 wiring harness are Toyota parts or Class III Reese? Did the aftermarket hitch look clean on your '08?
These part numbers are on the cartons that the Reese hitch and wiring harness came in are supplied to Toyota dealers in the Southeast by Southeast Toyota Distributors, LLC. The receiver hitch is fabricated with 2" square tubing and is welded to a piece of flat steel that fits under the exhaust pipe. Some of the other after market hitches have the piece fitting above the exhaust pipe.
On my '08, I had added the stainless steel exhaust tip which dressed the car up a bit. The Reese hitch setup gave a "functionally" clean look in my opinion. The receiver socket, the part where your ball attachment fits into is trimmed with a chrome ring which adds some aesthetic look to it. The Toyota receiver hitch that is shown on their accessory website and in their accessory booklet does have a different refined finish look, but you must part with more $$ for it. The bottom centered panel is replaced with a cutout and their receiver is a bit higher off the ground.
Google "reese hitch for highlander." You can find links for the Reese hitch and can see what it looks like.
This is doable (hint - use Google). You'd need to find someone with similar car but with only 2 seat rows. Many people would love to add a third row and will be more then happy to swap parts with you.
Highlander is very easy to be stolen. They know how to drive the car without key in 5 minutes. They are high technology guy. I am thinking, simply break a major circuit wire, install a switch, hide the switch in the glove box. It could be the power supply to the control broad, or the wire to the starter. I am sure they can not find my switch, they never thought there is a wire switch. The simple trick will block them. Anybody has good ideas? Thanks Lionel
I'd like to update some of the interior on my 2012 base highlander. I'd like to get leather seats and it seems like SE interior can be found on junk yards for less then katzkin leather would cost, plus I'd get power driver seat, lumbar support and heat (with SE dashboard). I know it's not new and katzkin is probably better, but I'd like to weigh pros and cons.
I know the 2011 model was slightly refreshed, both interior and exterior. Is there a complete list of changes between 2008-2010 and 2011? I know 3rd row has changed. What else?
I'm thinking of attaching a chrome tube-step on our 2011 Highlander that still does not have a receiver hitch. Does the task of installing the receiver hitch requires needed skills? Previously, we had a chrome bull bar installed by professional installers & now we're thinking of matching the rear with a chrome tube step.
I'm trying to find a rear bumper guard (double tube preferably) for my 2010 Highlander that will install with an after-market trailer hitch. Have tried to talk to the Steelcraft, Broadfeet and Black Horse people and they haven't a clue. Can anyone please point me in the right direction?? Tks
When I purchased my 2013 Highlander it had the side molding on the doors. I want to add the Toyota door edge guards. There is about 1/8" from the end of the side molding to the edge of the door. I have asked parts dept., Toyota parts suppliers, and even Toyota whether you can install the door edge guard with side molding installed. For some reason no one has been able to answer my question. Has anyone installed door edge guards when there is side molding installed?
JC
Thanks in advance.
Is there anything else I desperately need?
Thanks for your input.
Mary
http://www.runningboardwarehouse.com/stainless-steel-step-barss-toyota-highlande- r-2008-2009.aspx
Jonas
Rey
Lots of luck,
Larry
Jeannine Fallon
Edmunds.com
Review your vehicle
Lionel
http://www.youtube.com/watch?v=NEUZF9vbUQ4
Is there any after market applications sold for this to install?
If you guy have DIY kind of video, please send a link.
Tks
Watch out for a restocking fee if you decide to go this route.
