Visitor Agreement.
Is the Base model and Limited is having the same suspension?
Can we convert the Sport Suspension to a Limited Suspension?
Or we can make it a little softer with some modifications?
JC
Curious though...you say the Toyota-like switch from Yaris fit perfectly into the slot. The fog light control for those HLs that have them factory-installed is on the turn signal column. Is that what you're referring to?
I already purchased the wiring harness.
This is a Single DIN unit in a 2001 non-JBL setup.
Thanks in advance.
I just purchased an 09 Highlander (thanks tax credit!). I got the base Limited with Option Package #7 which basically ads Blue Tooth and 6 CD changer. I also go the Power Lift gate. I have a few option questions:
Remote Entry - is it worth having the dealer put this in. I know I want it and am afraid if I have it installed elsewhere and they mess up the wiring it will void my warranty. ($695)
All weather mats - I know I'm probably better off getting these OEM.
"Protection Packages" - I've never had leather seats before, so I'm wondering if this is worth it. $328. "Environmental Corrosion Protection" (basically rust proofing) $250. "Acid Rain Protection" - $499.
Is there anything else I desperately need?
Thanks for your input.
Mary
Did they explain to you what exactly they do for the protection packages, and could they tell you the difference between "environmental corrosion" and "acid rain?" Did they do so with a straight face? I'm wondering how these con artists sleep at night?
For the Protection Pkgs. some are rips offs as mentioned, but depending on where you live I would go with the rust proofing only. On my 06 I had the paint sealant (thrown in on the deal) and I could see the buffer markes in certain light conditions (night) so I was mad from day 1, on the new 08 left over I just purchased I had the rust proofing and interior protection, as it does the carpets and they say the leather as well and with the lighter interior I didn't want a stain. For the outside I'll use Griot's paint sealant and apply myself with a good carnuba wax.
http://www.runningboardwarehouse.com/stainless-steel-step-barss-toyota-highlande- r-2008-2009.aspx
I'm buying a light kit for my utility trailer which has a four-pin flat connector so I expect I need an adapter, I just don't know which adapter. My wife has the HL so I can't go check.
A Toyota dealer service guy just told me it has a 6-pin flat, which I can't find any reference to elsewhere.
Jonas
So at least I don't need an adaptor - too bad I already ordered one on the trailer accessory company's assurance that the HL had a 7-pin RV connector.
There are two connectors on the floor beneath this compartment. One is for the trailer wiring which must be purchased from a Toyota dealer. The other has a cap on it with wires inside. If you remove this cap, be sure to reinstall it firmly. Failure to do so will cause the backup lights to not work. ( My dealer didn't know this one, but then they are the worst in the country.)
I know you were pretty clear in your post so please bear with me, but I just spoke with WAAG today regarding this part (18326) because I just bought an '07 HH and want to install one.
They *refused* to sell it to me because they said it will not fit the Hybrid as the frame and attachment points are different than the non-Hybrid.
They said the same of their rear bumper guard piece (16742.) (What is the T&H single pipe? Is there a website where I can see that?)
Anyway - not trying to refute your personal experiences, just writing to verify I understood your post correctly and that you were able to install WAAG 18326 on your '06 Highlander Hybrid without any problems.
Thanks so much, would greatly appreciate your response.
Rey
I have no idea if this is the "correct" way to install the wiring, but it worked for me and my trailer lights work great. The rest of the instructions provided to install the wiring were right on the mark, only the schematic was goofy.
Lots of luck,
Larry
I've been looking on ebay and there are a lot of units that are shipping from China and Hong Kong. They ship the entire HU with the stock control panel so you can have your Navigation look stock. However, none of these sellers tell you the brand of the GPS. Anyone have experience with these units or have recommendations when buying one?
Anyone here installed an aftermarket Navigation into a Highlander? I want to know how the install went and if the LCD looked too out of place with the overall console?
Jeannine Fallon
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Is there a definitive place I am missing for this car? Are people not as interested in modifying this car because it's traditionally more a family car? Where can I buy a service manual that shows me how to take the dash apart or the side doors?
DIY Modifications and Maintenance
If you want to connect front seat video you have to connect parking brake wire. If you put in the rear view back up camera you have to connect that wiring. Those 3 things are optional and will increase install time & labor. Good videos on installing Highlander radios on You Tube. Crutchfield and others have wiring harness adapters and the $12 gap fillers. When finished it looks factory.
In December I traded for a 2011 and the dealer through-in on the deal accessories I had installed on the '08. I am now waiting for warmer weather to install the hitch. Installation instructions were not included in the carton, but the dealer's parts department voluntarily offered to print them out for me.
Part numbers are: 00016-48730 hitch and 00016-48730-01 wiring harness. I don't see how adding an aftermarket hitch would void the warranty, especially if the vehicle is equipped with the Tow Prep Package.
These part numbers are on the cartons that the Reese hitch and wiring harness came in are supplied to Toyota dealers in the Southeast by Southeast Toyota Distributors, LLC. The receiver hitch is fabricated with 2" square tubing and is welded to a piece of flat steel that fits under the exhaust pipe. Some of the other after market hitches have the piece fitting above the exhaust pipe.
On my '08, I had added the stainless steel exhaust tip which dressed the car up a bit. The Reese hitch setup gave a "functionally" clean look in my opinion. The receiver socket, the part where your ball attachment fits into is trimmed with a chrome ring which adds some aesthetic look to it. The Toyota receiver hitch that is shown on their accessory website and in their accessory booklet does have a different refined finish look, but you must part with more $$ for it. The bottom centered panel is replaced with a cutout and their receiver is a bit higher off the ground.
Google "reese hitch for highlander." You can find links for the Reese hitch and can see what it looks like.
I am thinking, simply break a major circuit wire, install a switch, hide the switch in the glove box.
It could be the power supply to the control broad, or the wire to the starter.
I am sure they can not find my switch, they never thought there is a wire switch. The simple trick will block them.
Anybody has good ideas?
Lionel
http://www.youtube.com/watch?v=NEUZF9vbUQ4
I know the 2011 model was slightly refreshed, both interior and exterior. Is there a complete list of changes between 2008-2010 and 2011? I know 3rd row has changed. What else?
Is there any after market applications sold for this to install?
If you guy have DIY kind of video, please send a link.
Tks
Watch out for a restocking fee if you decide to go this route.
