Toyota Highlander Accessories and Modifications
I inquired to pickuptruckaccessories.com as to getting chrome nerf bars for our HL (my wife's short), and they replaid that availability will be the end of April. Makes sense considering the vehicle went on sale in Feb.
And, I'm going to look at the idea of remote-on fog lamps for our base model (posting the the discussion group). Hopefully I can find ones that fit in the bumper where those stupid looking grills are.
1. I take ir that the plastic trim around the shift lever needs to be replaced. I looked at an '03 this past week and these trim pieces are different shapes. BTW, I have a Limited with the woodgrain trim.
2. Are the holes aready in the floor of the cabin for the mounting brackets for the console? I am assuming that these are weld-nuts and not sheet metal screws.
3. After removing the extra mounting brackets on the side of the driver's seat did you have to fashion new ones to mount the new side cover?
4. Could I trouble you to send me a complete list of parts required for the modification? I will be mail ordering my parts and would like to get it right the first time! Copies of your packing lists would suffice. My e-mail address is:
slund347 "AT" ieee "DOT" org <-- Some assembly required!
Please send me an e-mail and I'll send you the rest of my contact information.
Steve
This is a great vehicle. People don't believe me when I tell them it was less than the 4Runner.
We liked the HL becuase it did NOT have one. I'm not too worried about my cell phone - better not to talk and drive anyway
Anyone have more definitive information?
DennisD
I also installed a remote controlled relay that works with the HOMELINK system.
Check post #23 @ MEET THE MEMBERS
The remote operated relay kit comes with a complete wire harness,1- 30amp relay, 1- remote receiver box and two portable transmiters (program them, following the steps on the owners manual)to make them work with the buttons on the visor.
Yes you have to connect the power lead to the battery to feed power the relay. and find a good chassis ground.
It took me a good 2 hours two install the kit, make sure you get extra zip-ties because the kit only gives you 3 or 4.
The fog lights I purchased came from a dealer in the carolinas
www.toyotaparts4u.com
Very good service and prices.
Here's something I've been doing for the cars that I don't change the intake plumbing...
On my '01 Highlander I've drilled several holes (about 3/8" each) on the "BOTTOM,FIXED PART" of the air box. If you look, Toyota has put a few smaller ones. What this does is allow more air to enter the box on the pre-filtered side. I've noticed just a better "throat" sound on flooring the pedal, intake air sounds less restricted.
I hope someone develops a cold air induction ram air type tubing for the Highlander. I've seen a difference in my NSX with this set-up.
Still waiting for word on a lowering spring,strut setup. Maybe that TRD supercharger...??
DennisD
Wow....sounds like fun!
Hope that helps.
DennisD
P.S Fender flares are a nice touch also, and they will protect your fender wells against door dings, (not available in my area, CA)
enjoy your shopping, experience.
It is a square 4 wire connector which will require the Toyota pigtail to get to a standard
flat 4 connector. The part is Highlander Wiring Harness 00016-48102 and I ordered
it from Chris@toyotaguys.com - hope to try it out this weekend
This is a class 2 hitch with a 2" square receiver and thus lower rated than the 3500 lbs that the towing-package equipped Highlander can tow. But it should still handle the occasional UHaul trailer and bike rack fine.
The wiring harness (00016-48102) should complete the package.
You may also want to check out the Bageco site: http://www.bageco.com/cgi-bin/shopper.cgi?preadd=action&key=hhtoyotaround
Our HL has the tow prep package (primarily for the cooling system enhancements) and haven't decided if I'm going to get a hitch. Of all those I have found, I like the looks of the round tube hitch the best, assuming that their illustration is indeed the hitch you get. just my thoughts...
check the photo section at : http://clubs.yahoo.com/clubs/toyotahighlanderclub
Installed mine myself and the hiring harness works great - did some towing this weekend
The word on the center console is they are port installed, on back order and they might be able to be installed be dealers once they come in. The only to tell may be time, and I'm not holding my breath (nor do I want one - hehe).
not sure what brush guards are...
The bike carrier is manufactured for Nissan by Yakima (must be an exclusive contract).
The carrier comes with both short and long straps which fasten to the existing cargo tie down points, front and rear (i.e. no drilling, etc.), locking the support bar in place (straps pull equally from opposing tie down rings), and holds up to 2 bikes securely by gripping/locking the front fork (skewer type mechanism). A third very long strap laces through the tie down points and then though the frame or rear stays in order to keep the bike from potentially pivoting around the front fork skewer.
I purchased the optional wheel fork so that, once you release the front wheel from your road/mountain bike, you have a convenient place to keep the wheel from becoming damaged or bouncing around inside the cargo area.
I searched the web for best prices.
"With optional wheel forks, this accessory bike rack keeps two bikes secured inside the cabin, safe from low branches, tailgating guppies and anyone with bike envy." (www.nissandriven.com)
1. After-market fog lights
2. Brush guard (haven't seen any websites with HL configs)
3. Fender Flares
Also, ANDREC8513, do you have any pics of your sidesteps?
But you need to register to see photos first. Let me know if you find fender flares that dont require you to remove the mudguards. Happy Hling...!
Also, all the HL's w/ fender flares that I've seen don't have the mudguards.
I thought about the side steps, but I noticed that in getting in and out 1) you really don't need them 2) they rub the back of your leg and may get your pants or skirt dirty if they aren't completely clean. They do look nice, but I'm glad I opted out of them.
They really don't stick out very far from the rocker area, so it's a nice clean looking install. I don't use them too much for entry/exit...but they are great to stand on when washing/waxing the highlander
We also do some brook fishing far back in the woods from time to time...the property we own is accessible only by a somewhat overgrown road through a forest. With our other trucks (Toyota, of course), we found that one could stand on the running boards while another person drove slowly up the road...when you come to a branch/fallen tree/etc...that needs to be cleared from the roadway, simply hop off/hop back on. It sure beats getting in and out of the truck over and over.
Also, I talked to one of the reps at WAAG and she said they're working on a brush guard and tail-light guards for the HL. They should be available in a month. It'll be interesting to see how they look.
Yeah, I discovered that last night. : ) Luckily all it needed was to go up a couple inches - the jack handled that just fine.
The installation was a little tougher than I imagined due to the install on the driver's side. And I'm not proud to admit that I lost one of the t-screws inside the frame somewhere. That caused a lot of swearing. But so far no rattle.
However, after almost 2 hours of crawling on asphalt, it looks terrific. The bright anodized steps really go well with the silver of the HL. My neighbors came by to admire the steps, and to crack jokes like "how many computer engineers does it take to work on a SUV?" (Answer: three....but one guy was just handing us tools).
After I give the entire thing a wash this weekend, I'll try to post some pics.
Anyone seen this item for a highlander out there?
Thanks you any information.
Best Regards,
Philip
http://www.toyotaguys.com/sunwindefac1.html
Philip
Is your wind deflector a after-market product?
If's is a Toyota product do you have the part number listed on any paper work that you could give me.
Best Regards,
Philip
We had the same problem. We didn't drill a new hole. Our Highlander has the tonneau cover for the wagon area. The cover has clips in the back of the seat, including one in the center. We removed the center cover clip from the back of the seat and replaced it with a child car seat tether bolt. Worked like a charm. Good luck!
Alyse Peterson
apeters1@nycap.rr.com
Maria
Best Regards,
Philip
