Volkswagen Beetle Maintenance and Repair
in Volkswagen
Here is the new place to discuss your VW Beetle problems. Thanks for your participation.
Pocahontas
Hatchbacks Message Board
Pocahontas
1. When I first open the driver's door, I hear the "whirr" of some small electric motor. What is that?
2. Sometimes when I drive, I hear a faint "beep" noise, somewhere in the dash. Any idea what this is?
3. Sometimes when I turn off the car, I hear a brief, high pitched warning sound. Any idea what that is?
4. When I start the car, the blue "engine cold" light comes on. About 20% of the time, within 30 seconds or so, it changes to the read "engine hot" light and the high-pitched beeping sound goes off. Within a few minutes, it either goes back to blue or turns off. Of course the engine can't be too hot; I've just started the car, the temperature around here has consistently been in the 40s or 50s. I assume it's a sensor error. Anyone else have this problem?
beep noise could be from changing volume on the stereo or source (FM to tape or CD)
the turbos continue to circulate oil after the car is turned off, may be the noise you hear.
The temp light, mine goes from blue to nothing being lit up.
PS: I bought my New 2001 Techno Blue New Beetle on 3/02/01 & totally avoided the car salesman negotiation hassle by going through AAA's WHEEL-EZ car buying program. With tax & lic. I paid $21,000. Definitely worth it to not do the "let me ask my manager" thing!
Need something really reliable for South Central LA driving. Is this the car?
Most people from what I heard have problems with the 98 and 99 New Beetles, but I think they worked out alot of the "bugs" in the Beetle for the 2000 and 2001 models. I know alot of 2000 and 2001 New Beetle owners that are very happy with their cars.
If anyone has any questions about the New Beetle feel free to email me I love to hear from other bug owners or potential bug owners
Christine
I would appreciate any hints at what is wrong and how to fix it as the warranty is expiring.
Great ride.
The guy at Circuit City said they generally don't replace speakers in Volkswagons, as VW uses a diffferent impedence than most car and stereo makers. He sounded like he knows quite a bit about car stereos, but I've never heard of this before.
The main problem that I have heard about getting the oil changed is that some of the quicky shops don't always pay attention to the recommended oil grade and level. Grade is important, espically for the deisel. The level is important for the turbo (both the 1.8 and the TDI). Too much oil will flood the turbo, causing early failures and possible fires. Currently the dealer covers the first three recommended services, 5k, 10k, and 20k.
Go test drive a couple of different engines. The TDI is hardest to get and probably the one the dealer won't budge much on. When I bought mine, they wouldn't deal at all. If they don't have a bugs on the lot with each engine, then drive a Jetta or Golf with that engine. Same engine, just different body. You can also check out www.newbeetle.org for other fanatics.
years!
So we're taking it into the dealership on Tuesday and have them keep it for the day to figure out the problem. We hope this is just a fluke.
The problem, they said, was that the transmission bolts fell off. In addition to leaving me stranded on the highway, the engine shifted and also damaged the radiator fan, the fan casing and the fan belt - all of which VW replaced.
I picked my car up today at 2pm, drove back to work and by 6:30pm this evening I was waiting for the tow truck again. Same symptoms - only this time there was an audible pop sound before the major grinding started up. I only drove it the five feet it took me to get it out of the way of traffic.
The dealer said this was a fluke and that they'd never seen this on any kind of car - much less this one. But now I'm afraid to drive it even if they fix it again.
Has anyone had this problem? When is it appropriate to file the car as a lemon? I was lucky enough to be in a good neighborhood during both of my breakdowns - but living in a metropolitan area, I won't always have that fortune.
Thanks for any insight,
Jen
I recommend to look very close before purchasing one.
My web page is <http://www.geocities.com/bugsinvwbugs> You can see all 40 items that have repaired on the car.
First snow tore off plastic piece under engine. Warranty
Plastic piece which runs between windshield and dash cracked in two. Entire dash was taken off to replace this item. Also the VIN number is on this piece. A replacement VIN number sticker is very difficult to get replaced. Warranty
When the dealer replaced the plastic piece all of a sudden the radio didn't work.
Dealer said the failure was "unrelated" and replaced the radio with a new one from another car on the lot. Warranty
Check engine light came on. Dealer "cleared" the codes in the computer. Warranty
Driver side window switch popped out. Dealer repaired under warranty. Window is now hanging up and will not go up automatically all the time. Dealer said this was "unrelated" to having the door panel off. Replaced window mechanism. Dealer replaced even though my warranty had run out. First fill-up after service, fuel door will not open. After my wife was stranded for two hours, we take it back to the dealer. They found a broken connector on the switch. They insist this was unrelated to them being in the door working, but replace the switch as a "good will" gesture. Dealer tried to get me to turn this in on warranty ($50 deductible). I refused.
Check engine light is on again. Dealer replaced mass airflow sensor.($50 deductible)
Thank God we bought the extended warranty.
Keep your eyes open for other related articles, tools, and Town Hall discussions in that area. ;-)
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
QUESTION #1: Is there an advantage of working directly with VW or should I work with the BBB Autoline which provides mediation and/or arbitration which I am NOT bound to accept. QUESTION #2: Are there any expenses I may be overlooking? (see below) QUESTION #3: Should I pursue under the LEMON LAW in spite of their present offer?
SYMPTOM: MIL, EPC, CHECK ENGINE lights, and engine revving while in PARK or DRIVE.
SERVICE #1: Dealer "tighten connections on throttle body assembly". Approx. mileage 300. SERVICE #2: Dealer "replaced junction panel". Approximate mileage 700. SERVICE #3: (car in shop last 30 days waiting on back-ordered "electrical harness" from Mexico. VIN specific part per Parts Expediter.) Local VW rep indicated that there is some concern whether or not this will correct the problem. Approximate mileage 800.
While it appears the LEMON LAW is in effect, VW of America response indicates willingness to repurchase and reimburse for some expenses.
VW dealership provided me a rental while car is being serviced.... but it's not a New Beetle! They put me in a Cavalier. (grrr....)
Sent certified letter to VW of America requesting remedy. Asked for:
- replacement, prorated financing and insurance retro to purchase date, financing at or below original agreement, rental reimbursement until delivery of replacement, misc. fees licensing, taxes, title, etc...
VW of America faxed letter which essentially offers to:
- give full trade-in allowance equal to purchase price (replacement), prorated financing and insurance retro to purchase date. VW suggested I work with the dealership to have them agree to providing a rental until the replacement comes.
Rental is important to me since I may be waiting 2 months+ for replacement. Not available in the immediate 4-5 state region. If I accept, I will benefit from refinancing at 4.9 % -- I currently have 6.49%.
Btw, here's some lemon law information from Edmunds' Advice section that you might find helpful. On that page, look for the link to Autopedia.com where you'll find state by state lemon law information. Good luck and please keep us posted.
Revka
Ken
2.The AC stopped working by the beginning of our second summer (the first summer was only a month or so long). The expansion valve was fixed/replaced.
3.Anti-knocking module had to be replaced after only 39K miles
4. 4 months after owning the car, the trunk wouldn't open. It was fixed by a dealership in Indiana who simply replaced the bad piece. The trunk had not been closing easily from the day we picked the car up. But Reydel (Edison, NJ) failed to fix it. At least three times, they just patched up the trunk piece.
5. Last, but not least, OIL CONSUMPTION. We cannot drive even 2K miles before we have to add oil. We tried to bring it to two different NJ dealerships. They just changed our oil and said to come back in. however, we couldn't get an appointment to come back in. Finally, in November, our engine light came on. They replaced the purge valve (which they said could have been damaged by oil leakage-- not that they can find it). Two weeks later we are make at the dealership because another engine light came on. This time they replaced the mass air flow sensor and connector. This equal about $1000 in two weeks. You would think the oil consuption would be fixed. However, here it is January and we still are burning oil like there is no tomorrow.
I love the beetle but cannot believe VW built it so badly.
Please drop by and introduce yourself in Meet the Members.
KarenS
Owner's Clubs
I've recently developed a problem on my 99 GLS where the car wont' start for about 1 to 2 minutes after I fill it up at the gas station. I'll work the Clutch and gas peddle for about 2 minutes till it starts finally and afterwards is fine till the next time I need to fill up the tank.
I took it to the local import repair; the local VW dealership is too far away and has a bad reputation, and they have been working with VW for 2 weeks trying to understand why this is happening. VW is at a loss and my mechanic has been working on VW's for almost 20 years. They've checked the fuel line and gas cap pressure but the problem still keeps happening. The car basically acts flooded after a fill up and the check engine light keeps coming on.
Any thoughts???
Collin
What route do I use to increase the quality? New speakers? Completely new radio?
I don't care about having a heavy bass, nor do I want a radio that can be heard three blocks away - just want some basic quality sound.
Revka
Hatchbacks & Station Wagons Boards
