Nimi
I was the owner of a new beetle 2006 automatic transmition, i had it for two weeks and I return it. The car since we took it out of the dealer the blinkers did not work!! the alarm was with problems, and when the car had 165 miles (new car) the engine light came on..I was so in love with the bug, that i really did not wanted to return it, but the car was not safe at all with all the problems. I know that this is no gonna help nobody, is a lemon comment, but for future owner of a beetle, think it twice, the VW have a lot of electrical problems, and here in Atlanta i see at least one broken down on the road every month.
they are beautiful, but hopefully VW will make them in germany and no in Puebla Mexico, so probably the price will be higher but the quality too.
any ideas where i can find a free service manual online
(looked @ vw but they wanted me to purchase it)
thanks,
rachellmt
If one of these switches is not working properly... the alarm system does not "snese" that you unlocked and opened a door - thus it thinks it is being stolen.
The self-locking is completely normal. If you unlock the doors with the keyfob and NOT open any door -- they will relock after a few minutes.
You did not mention if you have problems with the engine starting and then immediately shutting itself off. This is good news... that means that the IMMOBILIZER is likely not part of the problem.
Dont confuse the ALARM with the IMMOBULIZER.... they are 2 seperate systems.
I feel better about going to the dealer now
And now, the weather is cold again and the problems have returned. In fact, they have gotten worse. Instead of just occuring when my engine is cold, it happens all the time, in 2-3 second intrevals. So I took my care to a AAA approved mechanic. I got a new battery, new timing belt, new spark plugs, new engine coils- but nothing has fixed the problem. They said they checked my fuel injection, my catalytic converter, and various other parts, which were all working properly. No engine codes appear on the diagnostic tests and they basically gave up on my car and told me I would have to take it to the dealership.
I know very little about cars, but I do know that I hate the dealership. So does anyone have any ideas as to what the problem might be? Could it be the power supply relay switch? The oxygen sensor? Posessed by the devil? Somebody please help me!
For some reason the car starts to make a strange whining/whistling noise just before reaching 2k rpm, and/or 3k rpm. The engine also gets sluggish and doesn't seem to want to shift. It corrects itself when I let off the gas (which is an instant "panic" reaction I have to above whistly-whiny noise). I'm taking it to Aamco tomorrow (the dealer here isn't trustworthy) and would like to be well informed so as not to get taken for an expensive ride. Anyone have any info/experience?
Thanks! :sick:
A few days ago I noticed my car was struggling for power while I was driving it, out of nowhere the engine seemed to lose power and the engine got a little shaky? I don’t know why? I changed one of the rear brake lights that was out and that seemed to fix the problem for a few days. Today the car was struggling for power again and every time I would go on neutral the car would completely turn off? Has any one experienced this type of problem? Any thoughts on what could be wrong? I really need some help here don’t know much about cars. Thank you so much!!!
The first thing that I notice about the problem you describe is that is sounds VERY much like a problem with one (or more) of the ignitors (ignition coils). There was a bunch of defective ignitors that came from one of VWs suppliers which caused all kinds of problems with the 1.8T engines. These were recalled by VW.
If you have not already had the ignitors inspected, that is the first place to look. It is very easy to look at the PartNumber on the ignitors and determine if yours were among the bad ones. (the suffix letter on the PN is the key)
Let us know what you find.
allmat
A side note to bpeebles, when my car was at the dealership they told me that a broken rear brake light switch could cause the car to loose power. It doesn't make any sense to me either, but nothing about this German engineering does.
I didn’t have enough money to replace it that day and he had to order the part from the dealer. I will try to have that done by next weekend.
I found a really good article on how to do the job your self. It seems like a pretty easy fix so I will do it my self and save me some money!!! Hopefully that fixes my issues. Other than that the car is doing great! Thanks for everyone’s comments I really appreciate the help. For bpeebles comment I didn’t say that replacing the light bulb had fix my engine problems but I know for fact that after the light bulb was replaced the car did not struggle for power like it did.
Here is the link to the article.
http://www.europeancarweb.com/tech/0302ec_maf_sensor_diagnosis_replacement/index- .html
For bpeebles comment, I didn’t say that replacing the light bulb had fix my engine problems but I know for fact that after the light bulb was replaced the car did not struggle for power like it did. I don’t know why but you saw what 1winter81 had to say. See message #717 Confirmed by a dealership mechanic.
If replacing the MAF sensor doesn’t work I will certainly look into the ignition coils!! Thank you for your feedback.
I am sure you read past appends and know about the Warantee extension which covers your MAF up to 7 years and 70,000 miles. The MAF in my daughters 2001 was replaced for FREE last year. Perhaps you have more than 70,000 miles on your car?
Also, if you have read any of my past appends, you will know that you can unplug the electrical connector from the MAF (ignition OFF) and try driving like that. If your MAF is bad, oftentimes, this will result in BETTER running. (unplugging the MAF will cause the CEL to illuminate... but at least you can drive your car.)
If you REALLY are beyond the extended warantee on the MAF... you can order one from one of the several repuatable online VW parts sources.
Here is a great source for VW parts ==>World Impex
A MAF is VERY easy to replace. It takes about 5 minutes.
IMPORTANT: Never-ever use one of those oiled-guaze type of air-filter (like K&N) in a VW... it will DESTROY the MAF.
The next day, I was driving off a highway on a ramp. I stepped on the brake, and it slowed down to about 15-20 mph. Then the surreal thing happened. Suddenly I lost steering, the brake didn't work, the engine died, and the red Check Battery/Electrical System light comes on. Luckily I was able to pull over without any accident. I shift the transmission back to P and restarted the car. It worked again and nothing seemed to have happened.
This happened twice that day. I was scared and took it back to the dealer wondering if it was caused by the recall repair. But the dealer checked it and said they couldn't find any error code and my car is fine. So I paid the 98 plus examination fee for no answer.
Then I contacted VW North America and told them what happened. They couldn't give me an answer either because there is no "black box" equipped in this car and they don't know if there are other similar cases. The best I can do, they said, is to call the dealer right away if the same problem happens again, and to have the car towed (on my own expense, VW stressed!) to the dealer for check up again. What a satisfying custom service!
The same problem did happen one more time. Did anyone have similar experience, or know what the problem might be?
:confuse:
About once a week the oil light starts flashing with an alarm. It only goes off when I am stopping and am under 12 miles per hour - lasts the whole time I am at a red light and shuts off again when I start to move.
I have had the car into 3 different mechanics about 5 times now and nobody can find anything wrong because the lights alwasy stop going off right before I get there, and the computer doesn't register what is wrong. Is there any way to find out what is wrong without hooking my car up to a computer? Or anything I can do to fix it?
:confuse:
Your oil-pressure may be low when engine is idling. This is a VERY BAD THING and can destroy the engine. Have your oil-pressure checked with an accurate meter to determine if the problem is REALLY the oil-pressure... or just a faulty snesor/guage.
Also, using too THIN an oil can cause low oilpressure at idle when engine is hot. You can try adding a can of "STP oil treatment" to the crankcase. This will thicken the oil and help improve oilpressure at idle.
Here are 2 links which describe repair procedures.
Doorswitch link 1
Doorswitch link 2
If this is happening with MORE than one door, then you have a problem with the alarm system.
EVAP system: (short for Evaperative Emmissions)
Basically, this sytem captures the fumes coming off of the fuel in the tank and stores them in a "charcoal canister" . Under specific running conditions, this stored fumes is fed into the intake manifold to be burned in the engine.
The EVAP system does 2 things for us...
1) it helps the envrionment by not allowing the hydrocarbon vapors from escaping into the atmosphere.
2) It prevents EXPLOSIONS in underground parking decks where the accumulation of these highly flamable gasoline fumes could ignite.
One of the things that the EVAP system must do is to allow fresh air INTO the system as the engine consumes fuel. The gascap has a one-way valve in it to allow air to enter the fueltank.
QUESTION: Does the engine run OK if you leave the gascap removed? If "yes" then replace the gascap to fix the problem.
I purchased this car used 1.5 months ago. We had a fantastic mechanic look at it before we bought it, and he determined that the car was in excellent shape. The dealer had the car for a couple of months before selling it, and it had no problems other than that the CO2 sensor needed replacing. We did that 2 weeks ago, at which time another mechanic looked at the car and said it was in wonderful condition.
The past owner saved the recall notices for the brake light switch, so I scheduled an appointment at Herzog-Meier today to get the switch replaced.
I got to the dealer (with my 18 month old son in tow) and they told me it would take a 1/2 hour to replace the switch. It did. Then I got in the car and drove it away.
As I was driving up the road, I noticed that the brake pedal had something unusual about it. At first, I got really scared and started to think that my brakes weren't working at all. The brake pedal felt a little bit tight, and when I would press it slightly, nothing would happen. However, when I applied a significant amount of pressure to the brake pedal, my car stopped abruptly. Something was really wrong.
So, I started driving again and at about 25mph I shifted into 3rd gear. My car started lugging badly and then I reached a slight incline in the road. All of a sudden my car started decelerating. I pressed the gas pedal, but nothing happened. I shifted back into 2nd gear and the engine revved up and began accelerating again.
Obviously something was wrong, and I felt positive that it had everything to do with the service that I had just recieved on my car. I turned around to drive it back to the dealer, but I had to keep my car in 2nd gear, as none of the other gears were working. After a few minutes, smoke started wafting out of the left-front side of the car. I was really unsure as to what was going on and didn't know if I should keep driving. It felt as if the emergency brake was on, but it wasn't. It smelled like burning rubber. I was really scared to have my baby in the car with me.
All of a sudden, about 3 blocks away from the dealer, there was a loud "POP!" and my car lurched forward uncontrollably. Immediately afterward, I felt some sort of 'release' in the brake pedal. I pulled the car over. Even though smoke was still coming out of my car, it seemed like no more was being produced and so I merged back in with traffic. The brake pedal felt like it was back to normal, so I tried to shift the car into 3rd gear. It worked. Everything seemed fine. Even so, I pulled into the dealer and told them what happened.
The mechanic told me that it could be that the new brake light switch was faulty, or that it had been installed incorrectly. He said that the smoke was definitely not from my clutch and so he could only assume that it was from the brakes. We both agreed that this must have to do with the service I had on the car, since there were no problems before I had the brake light switch "repaired."
The mechanic installed a new brake light switch and drove the car in a small circle, telling me that everything looked fine. I then got in the car and began my 20 mile drive home. I drove a couple of miles until I got to the freeway and once I merged in, I cautiously put the car into 5th gear. Everything seemed very fine.
After a few miles, I got off the freeway and began driving through downtown. I made it to within 3 miles of my house before more problems started. At this time, I would downshift, and as soon as I had the clutch pressed down and took the car out of gear, my car would lurch forward as if I were pressing on the brakes really hard. As soon as the car went back into gear, it would begin moving forward again...but it seemed stalled. Once again, it felt as if the parking brake were on. I tried putting my car in neutral and coasting to a stoplight. My car would not coast. It would stop as soon as I took it out of gear.
I still kept heading for home, and within a mile of my house the same problem started to happen with 3rd gear. My car would start lugging at 20 miles an hour in 3rd, and then at 30 mph in 3rd. I tried shifting into 4th gear to check that it wasn't the gears, and 4th did the same thing. I had to finish my drive home in 2nd gear and when I made the turn to my house, the car stalled out. So, I barely got it parked in front of the house.
I called the dealership and they are sending a tow truck to get my car tomorrow so they can check it out. I called Volkswagen and reported what happened so that I could try and figure out if it was a problem at the dealer or a problem with the switch. The woman I spoke to on the phone said that she couldn't get me any information but that they would call the dealer tomorrow and then call me back.
I am very upset and saddened that I took my car in for a simple procedure that resulted in this. I feel like my son, and myself were put in a really dangerous situation...far more dangerous than if the brake lights had quit working. My car was stalling out and refused to coast on streets posted at 50mph.
That said - I would also expect a VW dealership to KNOW how to do it right and to check for dragging brakes when they get done.
Coincadently, my daugher had an identical problem to yours when she had the brakelight switch replaced on her New Beetle. The brakes were dragging so badly that they started to smell. (This happened within 7 miles after leaving the dealership at about 35 MPH.)
She called the dealership and they told her NOT to drive it and immedeately sent a towtruck and redid the brakelight switch properly.
If you were driving at highway speeds, it is entirly possible that your brake pads or rotors have been damaged by the extreme heat.
I can imagine that your brake rotors were glowing red-hot!
If you ask them, they should feel abliged to remove the wheels and inspect the brakes for signs of heat damage.
Also, the grease in the wheelbearings may have been "baked"... I would not be surprised if you have bearing problems within a couple years. (I have seen dragging brakes ruin the bearings)
I talked to the guy on the phone today...he didn't even apologize. He acted like it was routine to mess up on a job this badly. I am so disappointed.
I just called and asked them about the brakes and the bearings and they said that there was no heat damage. Argg...I just don't trust them. We are going to take the car to our trusted mechanic (who I wish would have been able to do the install in the first place) next week, so thank you for the information so that I can ask him to specifically look at those things. I am just so upset about this. I really thought that this would be a simple thing and that I could trust for this to be done at the dealer.
"I have spoken to the technical engineer and learned that there is a very small but real possibility that some vehicles with a certain brake booster can exhibit your vehicle’s exact symptoms. When the switch is installed it can allow the booster push rod to come out of position. If this occurs it extends the length of the rod just enough to lightly apply the brakes after a short period of driving has occurred. When the last brake switch was installed it could have pushed the brake booster push rod back into proper position. However, the engineer feels that to eliminate this from happening in the future the brake booster should be replaced. Our Volkswagen Representative agrees and would like your brake booster replaced at no charge to you. I have already arraigned to have a brake booster held aside for you in our parts department.
Although we are very busy I feel it would be best to accommodate your schedule and perform this repair at your earliest convenience. Please contact me personally via email or call my office @ 503-372-3165 so I can set up a time that is best for you.
Now that I have that out of the way I would like to apologize for your inconvenience, loss of time and our apparent lack of attention for what must have been a very troubling experience. The technician that performed all the repairs and inspection is our best technicians for quality and has a near zero repeat repair rate. He has been with us for several years and has replaced an average of roughly five switches a day over the last couple months. I am telling you these things about this gentleman for one reason; I want you to feel very comfortable driving your car knowing that all the workmanship was of first rate quality.
While your vehicle is here having the brake booster replaced I would like to offer re-inspecting your brakes, rotors and wheel hub and bearing assemblies to put you mind at rest. The wheel bearing as per the technical engineer could not be damaged by over heated brakes because they are designed to withstand temperatures well in excess of what brakes are capable of producing. The hubs and bearing need not be disassembled because if there was any damage the grease would have to be forced out past the seals and would be evident outside the hub.
Rather than just offer a simple but sincere apology for your inconvenienced I would like to offer you a more substantial apology in the form of a free tire rotation and exterior car wash.
Thank you for letting us know how you feel and allowing us the opportunity to possibly regain your trust and future business."
So, I'm a little bit unsure as to what happened. VWOA was told by the dealership that these were faulty switches, and I was told by the mechanic that they were installed incorrectly. Now there is a whole 'nother twist to this situation: The Big Bad Booster!! What to do? What to do?
Well, I just wrote him back and told him how nice this whole thing was and that I would love a new brake booster (ohhh...I hope I'm making the right decision here. gotta have some really big faith to go back to this place for another brake-related replacement. needless to say, i will not be bringing my child if i can help it.)
Anyway, I figured that you are all super awesome and it would be a good idea to post this letter for opinions, as well as to swallow this whole experience and say that...hey, the dealer and VWOA are really trying here and I appreciate that, and lastly...what if someone else has this problem? Probably good to know about.
Personally, I feel that offering you a "Free" brake booster seems almost like a bribe (and perhaps inviting more troubles especially since your current one has been touble-free for a long time thus far)
Dont forget that the VW corperation will actually be paying for most of the "free" brake booster anyway. Dealerships LIKE to do this kind of work because it 'seems' free to the customers and they get paid anyway.
Certainly the offer for a tire-rotation is nice... but most tire-places do this for FREE as long as you own the tires they sold you anyway. (some car dealerships even do this for free as long as you own the car you purchased from them) Rotating tires is done by the LEAST experienced person in the shop and takes about 10 minutes. (they are not even going to BALANCE the tires????...why bother?)
So, in the end, it is nice that they apologized and offered somthing. Too bad it is not more like $50 or $100 off your next scheduled maintenance which would be somthing you could really use.
I once owned a Honda Civic which I purchaed from one of the top Honda dealership in the country.... After experiencing the kind of red-carpet service from there, all other dealerships pale in comparison. (aka....Free state inspections for as long as I owned the car!) Even if they sensed that I was dis-satisfied, they would "make things right" and then some. (Free lunch at a nearby resturant while my car was in shop!)
Currently, I drive PAST 2 VW dealerships to get to KINNEY MOTORS. Again, I selected KINNEY because of the service they provide. (Free loaner car while my car is in shop)
I have had recent problems with having to replace a brake light that went out (that was a b**ch to do myself) along with a front headlight cover that popped off (still searching for a replacement without having to buy the whole light assembly!). Yet more issues have surfaced.
A couple days ago my check engine light went on, and the manual says I need to take it to a dealer. I have 57K miles on it, so would anyone know why this light went on or the best way for me to fix the problem without having to pay a VW mechanic.
And to make things more exciting, yesterday the EPC light went on. It has turned off once I drive more than 10 miles, but has been on and off since then. Again, manual says to take it to VW dealership. Any advice on this one?
Finally, if that was not enough, the light which indicates that the ESP is engaged (a VW extra for aggressive driving) turns on and off independently, and I cannot turn it off by pressing the ESP button. What does this mean, since it turns on when I am driving carefully/pensively? I thought it turned on only during fast aggressive driving or in harsh conditions.
Any advice is appreciated and I was curious if all these lights turning on and off are legit or an electrical problem- something I have read here is a major problem with Beetles.
My only remedy, other than cursing at the car, was to press the unlock a couple times, then press the lock button. Most of the time, the driver door would then lock. If that didnt work, for some odd reason, I would just lock and engange the alarm manually with the key, turning right until I hear the alarm beep. This way always ensured the driver's door locked.
However, I now experience no problems with the doors locking using the keyless entry, but I have no clue if I did anything to resolve it or if this is just another sign of my erratic Beetle!
An engine "wears" the most during the time while it is running but not yet at operationg temparture. This is because of the different expansion charactoristics of the various metals. Thus, it is important to get it up to temparture as quickly as possible without putting undue load on the engine.
The quickest way to get engine up to temp. quickly is to DRIVE it. Just be gentle and do not accellerate quickly until the engine is warmed up.
Other bad things that idling a cold engine can do are. (besides undue wear)
*) Excessive blow-by can crud up the EGR.
*) more engine-deposits (crud sticking to combustion chambers)
*) Cold oil does not flow well.
*) Takes longer to get heat into cabin.
*) Waste fuel
*) Bad for envrionment (more emmissions from cold engine)
Please do not take my word for this... READ THE VW OWNERS MANUAL. It clearly states to DRIVE the car to warm up the engine.
I am very appreciative that you corrected me and I am sure I am not the only owner who has been told about this incorrect way of starting the Beetle.
You are correct about the manual indicating that idle engine warm up is not recommended. I know very few people who read their manuals with such attention, and though I read through the manual the first day I purchased it, I can see I missed a few things and will reread carefully the manual.
