Volkswagen Beetle Maintenance and Repair
1141517192022
  • bpeeblesbpeebles Member Posts: 4,085
    WOW - I am glad to hear that noone was seriously injured in the roolover.
    I am curious - you mentioned that the "kit" from TDIparts had the "wrong" timing belt.... Are you aware that those kits PURPOSFULLY include the 100,000 mile TB? This is intended to allow you to "convert" your VW over to 100,000 mile TB changes.
    What was the problem you encounterd with the TDIPARTS TB? Did you send eMail to TDIPARTS to get refund? (I have always found them very easy to work with)
  • oldbugoldbug Member Posts: 11
    The number on the timing belt for my Beetle is 038109119M but the kit they sent included a much smaller belt that began with the number 028... Peter at TDI parts was very good about it and sent me the correct belt in 2 days and also sent a prepaid mailing label for return of the wrong belt. I finally took the Beetle to a local dealer that used my parts from the kit to do the timing belt. I was still waiting for my injured mechanic to email me that he was feeling up to the task but I didn't want to wait much longer. The dealer replaced everything that came in the kit except for the valve cover seal as he said they didn't have to take off the valve cover. Fine with me, the job is done and should last several years now. BTW, my "03 is the 100,000 mile interval belt from the factory.
    Cheers!
    It is good to hear that it all worked out for you. (and hope your mechanic is OK too)
    My 2003 Jetta is only at 77K miles.
    I realize this is a NewBeetle forum but on a roadtrip from Vermont -to- Pittsburgh and back. It is measurably getting 58MPG on the highway. (which is over 800 miles per tankfull.)
    I still wonder why most other folks are driving gassers. I could never again contend with under 40MPG from a passenger car. (Like my daughers 2001 NewBeetle)
  • sbmolversbmolver Member Posts: 2
    As usual, the wife didn't listen while i was away. She let the battery on the bug go dead. We replaced the battery but upon installing it, the idle rev'd from 900 to 2000 continuously. Talked to VW. They said to turn key to on and back to lock position 10 times. Ok.....reving fixed but car falls on face and gives various fault codes. VW then says they need to set ECU back to factory settings. I asked if this is normal when u change a battery...they said yes.
    Question......does this sound right to you guys? Is there a short-cut or "trick of the trade" to do this at home? I will have to tow this thing 100miles if not. As always...any and all help is greatly appreciated.....
  • lou747jeepslou747jeeps Member Posts: 5
    I hope that is not normal. If it is, then one should regularly replace the battery before it fails. Before changing the battery, I would connect jumper cables to the battery connection terminals to keep power to the system when the terminals are removed from the car battery. This should ensure there is no loss of electrical power to the car. While doing the change, make sure the positive terminal does not touch a ground (metal) causing a short.
    A simple 9V battery plugged into ciggerete lighter socket will suffice when changing main 12V battery.
    It is NOT normal for the enrire electrical system to go haywire.... somtimes your radio may think it has been stolen and go into "SAFE" mode... but the rest of the symptoms you describe are NOT normal.
  • guns2guns2 Member Posts: 3
    Howdy folks..Just like many of you, I have the high temp light coming on and going off--even when I first start it in the morning when its cold it will come on (the high temp) light. It's a 2000 new beetle. Coolant level fine, dont see any apparent leaks, even replaced the thermastat and gasket--still having problems. Any of you have any suggestions to help me out?
    Greatly appreciate any replies.
    Thanks All,
    Guns
  • madmax85madmax85 Member Posts: 4
    This sounds like it relates to a problem I'm having. On the same day, my "opened hatch" icon appeared on my dash and my car quit beeping when I locked it. I'd like to fix it myself rather than take it in for service. Any ideas?
    Since all the doors including the hood and the hatch must be sensed as "closed" before the alarm will 'arm' with a beep.... It sounds to me as if the sensor-switch on your hatch-latch is the problem for BOTH of the symptoms you describe. (light on dash and not beeping when alarm is set.)
    Exactly what I thought, but I don't know where the sensor is on the hatch. Do you? Is it something I can repair myself? I'm out of warranty.
    I am assuming you have a Gulf (since you refered to a "hatch")
    I had to disassemble and lubricate the latch on the hatch of my daughters Gulf a couple years ago. As I recall, I had to open the hatch and remove the trim from the inside to gain access to the latch mechinism.
    Once it is apart, you can follow the wires to the microSwitch which acts as the sensor. I dont recall if the uSwitch was in the latch or not.
    No, I have a 2003 Beetle.
    Whoops - my bad.... this is a Beetle forum. I should have known better. (I follow all the VW forums and I was not paying attention)
    In any case, I would be very surprised if the design is much different from the Gulf. The Gulf, Beetle and Jetta are all built on the same basic platform.
  • 99buggy99buggy Member Posts: 7
    I have had to fix about 10 things on the car already. It still has bad radiator fans. Problem is, I don't believe it will run after that job. What should I do? I got myself an accord at a very good price, so all I want to know is about my options. Should I part it out, junk it, push it over a cliff and walk away? Or should I get it to yet another mechanic and see how to fix it?
    Things I have to change: heater core, timing belt, coolant leak, oil leak, alternator bearing, serp belt that burnt away because of the alternator bearing...
  • orbit9090orbit9090 Member Posts: 116
    NEWS: Volkswagen recalls nearly 800,000 cars
    Defective brake lights on Golf, GTI, Jetta, New Beetle and R32 are a potential safety hazard and should be replaced.
    February 26, 2007 - Around 800,000 Volkswagen vehicles have been recalled Monday because of faulty brake lights, the National Highway Traffic Safety Administration said.
    The 790,000 vehicles include Jettas, New Beetles, Golfs, GTIs and R32s...all in the United States.
    The specific years and models affected are:
    1999-2005 Jetta sedans
    2001-2005 Jetta wagons
    1998-2007 New Beetle
    2003-2007 New Beetle Convertibles
    1999-2006 Golfs and GTIs
    2004 R32
    The malfunctioning brake lights and brake light switches could fail to come on or remain stuck on.
    This recall expands on one announced by the carmaker last year, when 362,000 Jettas and New Beetles were recalled due to the same defective part.
    Gees.
    ...I would be very surprised if the design is much different from the Gulf. The Gulf, Beetle and Jetta are all built on the same basic platform.
    Uh...no the Gulf is not. However, the "Golf" is.
    Please do not post the very same thing in multiple forums. Many of us are tracking ALL of the VW forums and have to read thru it multiple times.
    Besides , this is ooolllddd news.... Anyone that has properly registerd their VW with VWOA will have already received their recall notice by now anyway.
  • wanwanwanwan Member Posts: 2
    Hello, it seems that there are many technical/mechanical problems with Beetles :cry: . What about for the new cars with warranty? Is that a problem then? If that still is, what about paying the insurance options with all the highest coverage?
    I really like beetles, but also don't know much about how to maintain a car. Please give me some suggestions! I really appreciate!
    Back in the 60's most cars were still simple enough for just about anyone that could turn a wrench to do most of the work needed; grease, oil, and filter change, wheel bearing repack, tie rod ends, exhaust & etc. New cars today are so technical that most of the work has to be done by propriotory mechanics trained by the manufacturer. For good reason I think! If everyone of us that came from the do it yourself generation of car owners tried to keep up on the technical aspects of repairing a car today, we'd be going to school during our retirement. There are tons of valuable resources on the web for reference. I always chose a car that I knew I had the expertise to maintain myself. For that reason, I have had fewer off the show floor cars than most people my age. If it was beyond my capabilities i.e. transmission repair or motor ovehaul, I would take it to a proffesional. Get a car that you can comfortably do the expected owner chores on and then take it to a professional for the rest. Always make sure that you observe the maintainence schedule and follow it precisely. New cars with warranty? That's fine as long as you trade the car for another before the warranty dies of old age. If your financial situation allows you to do that you may have nothing to worry about. I personally don't know many people that can keep buying new cars every two to three years. I don't know that Beetle have any more or less problems than any other model. The point is, if you are not comfortable accepting what comes with a used car, then by all means buy new ones with warranty.
  • becksbugbecksbug Member Posts: 6
    I bought my 03 Beetle used w/38,000 miles in May of 2006. within 2 months, had sensor light go bad, window motor go bad, then,replaced front and rear brakes (rotors and pads) and new tires. I now have 87,000 miles so just had the timing belt,water pump tensioner, spark plugs and trans flushed to the tune of $600.00. Since this was done 1 week ago, the car feels like it is not accelerating easily and stalled on me coming off the highway today. I called the repair shop about this problem I didn't have before bringing to them, he claims nothing wrong w/ timing, probably a fuel pump/filter and he'll have to look at it. I can't trust the dealerships as they don't know anything,can't trust this repair shop and can't get any info from VW, I have spent over $2000 in just over 1 year and am worried. Any body out there can guide me on what to do next? I Drive 100-200 miles a day and can't afford this car! Thanks
    I agree, I thought I was getting a great car, the newest one I've ever owned - 2003 Beetle, and the cutest, but the most expensive! Can't contact VW, the dealerships are clueless except on taking you everytime you come in and the warranty doesn't cover the problems we are all afflicted with.
  • mrrk47mrrk47 Member Posts: 104
    Okay, it seems like the one of the major functions of carspace is to allow disgruntled owners of newer cars(Beetles and other makes as well) to vent their bad experiences to make those of us who haven't yet encountered problems with cars fear the next tick of odometer as it might be a multiple thousand dollars problem ahead. It seems to me any car if properly maintained( with fair money spent in the process) should last and work well.
    I have just purchase an used 01' NB with 99,000 miles and it seems fine save for a touchy alarm that goes off at night at arour 11 pm. The carfax looked good and the dealership did an inspection and all that jazz....was this purchase a mistake?? I really wanted a Beetle, so I chose to buy for a dealer and was very picking about the one I wanted.......Is someone on here going to tell me that without a doubt there will be a 5,000 repair on the horizon.
    I sure hope noone is suggesting that!!
    On these forums, you will read mostly BAD experiences from people who are disgruntled in some way. It is human nature to not say anything unless there is a problem. You should read these Edmunds forums whith this in mind.
    VWs are very nice vehicles. VW would have gone out of business loonng ago if they were not. Lets keep things in perspective here.... VWs are sold in nearly every continent of this planet. The NorthAmerican (NA) VW market is MINISCULE compared to the rest of the world.
    ALL vehicles have their share of issues/problems. These very forums are testamant to that fact.
    The bigger problem with VWs here in NA is that decent repair shops are hard to find. There are not a lot of competent VW/Audi technition to be found. The result of this fact is overpriced repairs that may not fix the problem. (and may cause other problems)
    Another thing about VWs (and German cars in general) is that the owners are EXPECTED to follow the maintainance schedules explained in the owners manual.
    As a comparison... many Asian vehicles are designed for owners which generally ignore the maintainance schedules.... (You drive a reliable- but BOORING car)
  • arch07arch07 Member Posts: 3
    We (my wife) had a 2000 NB that we bought new and put 88K miles on it. The car never really had any problems to speak of. It had a power relay ($30) fail at around 80K. The car was maintained as per the maintenance schedule, by the local dealer. Properly maintaining any vehicle will cost a fair amount of money, but we feel its money well spent. I just traded the car this past May. I needed a pickup truck for the kind of work that I'm doing now and the Beetle just wasn't big enough. My wife has a 2006 NB that we also bought new. Now this vehicle has had some problems, mainly failure of the coil paks. It has had 4 failures in less than 12,000 miles. The dealer has repaired the car to factory specs each time, but obviously there is something wrong with the coils or something is causing them to fail. VW has directed the dealer to replace them each time, I think the dealer has to have authorization before they can repair a repeat problem. The reason that we bought another Beetle was due to the service that we got from the 2000 model. I think the future of the 06 NB will be determined by a court of law, since VW and I have a difference of opinion about the reliability of this vehicle.
  • ladybugblueladybugblue Member Posts: 1
    I have the same exact problem and thought I was crazy. I have just had the cat. converter replaced as the wrong one was put in. For a week it ran great and we didn't think this was the problem anyway. But yesterday it did it twice to me. The dealership thinks it may be the ignition reader coil which will be my next step. It also could be related to the fact that my unauthorized key entry light comes on sometimes when I am having start problems. This has been going on for a year now. Let me know if this helps.
    Thanks to the two posters who responded to my rant. I agree with the human nature thing and everything. I think the NB I got has been taken care very well, I plan to take this car up to 200,000 miles before it's done, with a mild investment it should happen.
  • hey there beck. at 200 miles per day the car should be costing about $100 per day... about 50 cents per mile - maybe a bit less - check the "TCO" pages. so if you drive only weekdays, that's 52000 miles per year. so it ought to cost you about $25k per year to operate. maybe $20k. including insurance/depreciation/everything...
    the car should never stall like that of course. something is rotten if it stalls and you are right to suspect the previous service. dealer would have charged a lot more than $600 for that work, i bet.
    I know there have been a few threads about randomly sounding alarms on 2001 beetles..well.. I have one. My 2001 GLS 2.0 with 99,000 that I have only had for a little over a week sounds the alarm at nighttime or dusk only!
    I can have it armed all day at work, then take it home at night and about 6pm or so it goes off, I can shut it off by pressing the unlock button on the remote, but a while later it may go off again. I just took it to the dealer for 2 days and they thought it was some wiring issue to do with the radio, I picked it up and at 5pm it goes off.
    Has anyone had similar problems...please let me know..can I simply have them unhook the alarm all together?
    you said ... I can shut it off by pressing the unlock button on the remote, but a while later it may go off again.
    Are you suggesting that the alarm will go off again EVEN WHEN IT IS NOT ARMED?? (the doors are unlocked)
    No, if I leave it unarmed it will not sound, if I re-arm it after shutting off the alarm it may go off again while armed. Sorry for the confusion..
    OK- at least that makes some sense.
    I know this much, the alarm will sound if ANY of the following are sensed as being opened.
    *) Hood
    *) Hatch/Trunk
    *) Any Door
    I am suspecting that one of the micro-switches that sense the above may be the culprit. It may be very difficult to isolate the problem. You may have more luck using the process of elimination.
    Since you did not mention that the indicator on dash which shows Doors and Trunk open has not been seen while driving... I am suspecting that the switch on the hoodlatch may be suspect. (because there is no indicator on the dash for it)
    Try this, with alarm set... try to wiggle/jiggle the hood open and see if you can trigger the alarm.
    Another thing you can try is to bypass the hoodswitch with a jumper. Leave jumper in place for several weeks to see if that fixes the problem. The hoodswitch is pretty easy to get at while the other switches are burried inside the body-panels. This is another reason to isolate that one first.
  • in my experience this sort of failure is inevitable with car alarms. you might consider locating out which wire to cut in order to disable the alarm's power forever, and cut it. i've had to do this in the past, but not for a VW.
    (i think car alarms are essentially useless and far more trouble than they are worth).
    Hello I'd like ask a few owners of New Beetle's if they or people they know have positve reports and good ownership experiences with this good little cars,....that brings up a question, are they good cars? I understand that these forums are mostly for disgruntled owners who want to share their bad electrical systems, stuck-on headlights, and faulty power windows with the rest of us, but are their Beetle owners out there who have owned one of these for a while and have gotten a good one?
    I just bought an used 2001 GLS,auto that seems to a diamond in the rough...after 400 miles of my use that is. It has 99,000 miles on it and according to the carfax and various records I have has had it's small share of the problems...brakelights, window motor replaced, but that's largely it. It had a radiator replaced at 99,000 miles, but isn't that kind of expected?
    Does a car have to be a Honda or a Toyota to last a long time and provide reliable service? I do read the Toyota forums because I am also a Camry owner and it has had it's share of bad PUB recently, but it still retains that gleeming reputation of great reliability with the public at large.
    Can I expect to get to 150,000 miles or more without a terrible multi thousand dollare repair bill. Thanks for reading my post .
  • auntccauntcc Member Posts: 2
    I HAVE A 99 BEETLE AND HAVE HAD IT FOR 8 YEARS. I HAVE HAD MANY OF THE PROBLEMS THAT OTHERS HAVE LISTED. I HAVE HAD THE CHECK ENGINE LIGHT COME ON SEVERAL TIMES OVER THE YEARS. WE WERE TOLD BY SEVERAL PEOPLE THAT THIS SOMETIMES HAS SOMETHING TO DO WITH YOUR GAS CAP. THIS ALSO HAPPENS TO MY HUSBAND'S 2001 JEEP. SOMETIMES WE FILL THE JEEP UP TO THE TOP WITH GAS AND THE LIGHT GOES OUT AND ABOUT A FEW WEEKS TO A MONTH MAY GO BY AND IT COMES ON AGAIN AND OFF AGAIN. MY LIGHT CAME ON IN THE BEETLE AFTER I HAD THE TIMING BELT, WATER PUMP REPLACED. MY HUSBAND NOTICED THE OIL FILTER WAS LOOSE AND TIGHTENED IT AND IT WENT OFF AND THEN CAME BACK ON AGAIN ABOUT A WEEK LATER. HE FOUND OUT THAT THE TEMPERATURE SENSOR WAS UNPLUGGED AND HE PLUGGED THAT BACK IN BUT THE LIGHT IS STILL ON. MY CAR IS NOW PAST INSPECTION AND WE ARE TRYING TO GET THE LIGHT TO GO OUT. ANY IDEAS? THANKS MUCH!
    I have gone over 150K miles out of at least 4 VWs over the years.... your milage may vary.
    I can tell you that each of my daughters and myself have VWs and would not even consider anything else.
    With the new 140HP TDI coming out in 2008... why would ANYONE consider a car that gets less than 45MPG?
    Among comparable models, VWs consistantly has better-quality features, attention to details and that German roadcar handling not available anywhere else. Many folks forget that VWs are essentually Audis at a lower price-point.
    With VW, you get things like 4-wheel disk brakes and indipendant suspension and antiroll bars that actually do somthing for you. For grins, I just went online and compared my 2003 VW to brand-spanking new 2008 Honda and Toyota models.... It is my VW which gets better MPG and has more features. I think I will keep my TDI for awhile longer. (like 200K miles)
    As for predicting repair-bills - any vehicle on the planet is a crapshoot... but at least with VW, you are starting with high-quality components and great engineering.
    VagCom
  • odudeodude Member Posts: 6
    I have researched dozens of tires, trying to find the best deal on tires that would improve the ride and safety of my car, making sure to buy tires that would address performance. I do not live in an area where snow and ice are issues; however durability and traction against wet and bumpy roads are major priorities.
    I decided to choose either the Michelin Pilot Sport AS (around $180) or the Michelin Pilot Exalto AS (around $165). Both gave exemplary reviews from VW owners, including the GTR. None were from Beetle Turbo S owners, so was I curious if anyone, esp turboS drivers, had any good advice. I know these tires are pricey but improvements on ride, performance, and traction from the original tires is of utmost importance. Any advice would be appreciated.
    Exactly what is VagCom and how do I use it?? Will it tell me how to fix the problem or just what the problem is?
    This has been discussed many times already. Have you tried typing "vagcom" into the search box above? You may also wish to visit the Vag com website to get more details.
    One cannot fix a problem until one know exactly what the problem is. The VagCom tool can tell you exactly why the CEL (Check Engine Light) is on Only with that information can you even begin to figure out what to do to resolve the issue.
    You asked for ideas....
    If you do not wish to invest in a VagCom, there are lists on the internet of people that own a VagCom who are willing to scan your car for you. Example of one ==> http://vag-tool.kicks-[non-permissible content removed].net/
    Additionaly, if you had used the search feature, you would have found that it has been discussed many times that some autoparts stores (Autozone?) will scan your car for free and tell you what code is flagging the CEL.
    In any case, you need to know why the CEL is on before moving forward. Once you have the specific code, then you can look it up here
    At that point - you can come back to this forum and tell us the code. We may be able to assist you from there.
  • billingsley1billingsley1 Member Posts: 2
    I love my Beetle and have had it since 1998. I have a few problems, but have reached 110,000 with only a few main issues. My other friends own different models and have as many if not more issues so I haven't thought too much of it. I've owned VW's for almost 20 years and I can't do not one mechanical fix on them, but the dealer service departments have been very reliable. My most recent issue which I posted but got no response was that my driver's seat broke. The mechanism that holds it in place came loose and the seat flew back. No explanation for that, but otherwise I'm a happy owner and would buy another Beetle.
  • rhinodecals77rhinodecals77 Member Posts: 9
    I have a 2000 beetle and the speed, rpm, and fuel gauges are not working. they are all the way over to the right.
    does anybody have any ideas.
    Asking about my 2001 GLS Beetle again, what is the 3 letter/number designation that the auto tranny goes by, 01M or something like that??
    My mechanic says the fluid is a little dark, what does it mean? How long do these trannies last....
  • basskleffbasskleff Member Posts: 4
    I have a 2003 NB GLS TDI that I purchased last year at 52k miles. I wasn't looking for a Beetle at all. I bought it for the TDI economy, and this car happened to be one of the nicest TDIs available. My choice seems to have been prescient as the car has been a good experience.
    This is my second VW and my take on them is this.
    They are a good car that require owner involvement.
    They are different cars. They behave differently than the run of the mill Japanese or American car. They offer unique value, like the suspension, handling, 4 wheel disc brakes, heated seats,one touch power down windows all around, etc-> at a competitive price point. They have a diesel option. They are the only passenger car right now in the price point with the diesel.
    But this comes at a trade-off. You have to be involved with them. You will have quirky things act up and go, that you have never seen on your other cars. You need a reliable VW dealer for warranty work, and a really reliable independent VW repair place for out-of-warranty. You have to read forums to get advice to manage costs that come up. You have to really adhere to the maintenance schedules.
    Most of the above you could probably lapse or take a short cut on with a conventional Japanese or American car. Not with a VW.
    Now having said that, I truly feel with active maintenance, that my Beetle could go well over 200k miles. Plus, VWs have great bodies and rustproofing. They don't rot like Toyotas.
    In general stay away from early years of a model, and avoid certain automatic transmissions. Mine has the 4spd auto 01M, and they have a reputation for failing. Although mine drives great.
    Could mean the fluid is a little burnt.
    As I mentioned in my previous post, the 01M that you have, I also have, and unfortunately they have a bad reputation.
    But, I wouldn't worry over it. Mine drives perfectly. I've had it for 32k miles.
    You have to change the fluid and filter at least every 100k miles if not sooner. It is supposed to be lifetime fluid, but that is a crock. Have a good, reputable independent VW place change the fluid and filter if it hasn't been done.
    A number of people have these lasting well into 150k+ range, some over 200K+. It seems the valve bodies on the trans can go.
    It's me again with my newly bought used 2001 NB GLS, I really dig this car and no big problems 1000 miles in. But, the brakes still squeal loud, I'll probably have the rotors replaced because my mechanic said they're fine with 80% left, but they squeal like nobody's business!
    They only gave me one key fob, I have no key code....so who will be the 1st on here to tell me I'd better not lose this key because I can't copy or replace ...or am I wrong. Does anyone have exp. with replacing one of these and the cost of it. Can it be cut from the one I have....as far as the immobilizer is concerned can the VW dealer simply reprogram my key fob and one I may purchase....can someone tell me if I;m making sense. Thanks.... and yes I asked if the dealer had anymore keys for my car.
    There is a wealth of info on the internet about VW/Audi keyfobs.
    Basically, a replacment needs several steps taken including cutting and reprogramming.
    If you have a known-good one, then re-programming it involves plugging one in the ignition and the other in the drivers door.
    This is another great time to remind others to INSIST that both keyfobs and the valet key is supplied when purchasing a used VW. Make it part of the purchase-agreement that the seller will purchase any missing keys. (Keyfobs can cost over $100 each!!!)
  • we've misplaced both our 06 VW NB TDI key fobs and are using the valet key now. to get a new key fob it's $280 and that will also require another $100 for the valet key to be reprogrammed too. then when we find the old key fobs they would also have to be reprogrammed for $100 each as well. ugh.
    $280 per keyfob is a ripoff!! If I were you, I would do some more research before paying that kind of moola.
    If you do find the old keyfobs, they should just work. Are you suggesting that they would somehow become DEprogrammed just because you misplaced them?
    If you DO need to reprogram a keyfob, you can reprogram them yourself. There is no need to pay dealership to perform this simple process.
    As I said before... to reprogram , one goes in the ignition and the other in the drivers door.
    The moral of this story is... The security of a system that makes your car almost impossible to steal also means that lost keyfobs are expensive to replace.
    Incase you did not know... your RADIO is also protected by a security system. I sure hope everyone has writtten down the code to unlock their radio.... lest another expensive trip to the dealership is forthcoming. (example... replacing the battery in your VW may cause the radio to go into SAFE mode and reqiuire that code to unlock it)
  • hilihili Member Posts: 7
    My 2005 convertible has brakes which squeal, only first thing in the morning, and only wen I back it out of the garage. After that, it's fine. Is that typical, or is it a water condensation on the brakes that is eliminated when they warm up? I mentioned that to the dealer and he's at a loss as to the cause. Does anyone else have the happening and if so, what's done to fix it?
    I have a peculiar problem with my 2005 convertible. The brakes squeal like mad when , in the morning, I back out of my garage. Then, they're fine all day long. The same thing happens almost every morning, and only in reverse, and only first time used. The dealer is completely puzzled. So am I. Does anyone else have this problem, and if so, how do you fix it?
