Melissa
Hope all is well with your Honda!
/DA
To those ends, we will be shutting down the general make/model discussions and work exclusively with specific issues. This requires us to populate the make/model subsections with relevant, interesting and timely topics. Rather than having the hosts simply create boilerplate topics for each make/model, we feel that you, the owner, the make/model enthusiast and the prospective buyer can best judge what those topics should be.
You can help by adding a discussion (it's easy!) or suggesting one here.
To add a discussion, click on the last link in the "You are here" line at the top of this page. That will take you to the topic page for this make/model. Review the list of topics and click on the "Add discussion" link when you've decided what topic you'd like to add. Follow the directions and you're done! Feel free to add more than one. Just avoid duplicating existing topics and try not to make it TOO specific!
Your help and continued participation in the Forums is greatly appreciated! Thanks.
Did you buy it from a Land Rover dealer they should have told you about the big service at around 60,000 miles?
is there any info on service bulletins on tranny failure?
anything that can be done??
THANKS
por2001996@hotmail.com
:confuse: :confuse:
I am looking for help to. Has she had any luck ?
My truck is in the shop... not being worked on until I can get back to them. PLEASE HELP!!
In '05 the engine sucked a valve (is what they call it) needed to be rebuilt - approx 5.5K - I was over warranty by 3K miles but they covered it. I had to pay 1K for timing belt and other parts - quote since it's apart lets do the maintenance. Rear window motor went last month - another common problem.
Started to hear other clunking noises in the front end when turning - not sure what that is.
Last week - Transmission started slipping - dealer quotes it 5400 - like 4600 hundred for the trany and 1000 for some leak plenum leak above the tranny. Car has 68K miles and I do not have the extended warranty. I still owe 6100 on it
Dealer said they;d give me 3K for the car - Joy - can you guys screw me any more please?
I will be contaced the lemon law site hopefully something happens with this piece of junk car.
brakes, brakes, brakes, fuel pump, defective fuel pump, etc.., pattern on this - don't know what to do.
Does anyone have experience with changing the tire with that pidly tire jack.... I had a blowout on a tire and the thing broke while trying to fix.....
I can't get rid of my car either - upside down on the loan and - still owe
if anyone needs info on the used vehicle they purchased:
There is a recall on these 02-04 vehicles for --
1. interior door handle where the occupant can open the door when the CHILD SAFETY LEVER is in the ON position and can FALL out into the traffic.. The recall began 9/05 and you should call this number 800-637-6837
2. The A-Pillar trim failed to comply with requirements "Occupant Protection in Interior Impact during testing... recalled 12/05
If there is not a class action suit i think we should start one, this is RIDICULOUS.
I purchased a new 2004 Freelander in February 2004. I have serviced my vehicle at the required intervals with Land Rover. At 48,500 miles, my truck started to overheat. I took it to my local mechanic who looked it over and was puzzled. He couldn't see where the coolant had gone and suggested I bring the car to my local Land Rover dealer in New Rochelle. I had the car towed to Land Rover and the technicians there fixed the so-called ‘problems’. The technicians informed me that a cracked reservoir and a malfunctioning fan were found. 5,000 miles later (now that the warranty had expired) the car begins to overheat. I went ahead and had the thermostat replaced by my local mechanic with a Land Rover Thermostat (where was I to tow my car at 9 PM?) , 2 weeks later it overheated again. I took it the dealership once again. They told me that coolant had leaked into the engine and that I needed a new engine. 6,800 dollars. A 3 year old car needs a new engine?
I’ve been notified by Carolyn at Land Rover North America that they will not compensate any of the money because the car is out of warranty. I also spoke with Jeff Brown at Land Rover New Rochelle and he also said there’s nothing he can do( he was at his limit with “Goodwill” money. He also stated that I was offered an extended warranty which I declined. I would have never imagined an engine would be compromised so early.
This is not the first time this has happened with the Freelander. A business associate of mine leased a 2003 Freelander from Land Rover Paramus and at 48,000 miles the same exact thing happened. There’s an apparent problem with the head gasket with the Freelander.
I believe I should not be held responsible for a defective engine and that the manufacturer should be totally responsible
Thanks all
LR North America and the dealership both said that they can't do anything since it's out of warranty. This is unreal. I'm thinking of taking it straight to the junkyard where it belongs. I highly doubt that I could get anything on the trade in since it seems the dealerships all know what a lemon the car is.
I agree, if anyone finds a lawyer I'm in. I know that the FL owners in Europe already started one against Ford. Maybe that's why the FL will be discontinued.
Worst part is that I DID buy the so-called "Land Rover Assured" warranty, and they are still refusing to cover the new engine because the technicians can't show where it's leaking from! Initially they told me that I just needed to keep driving the vehicle until it "broke more" so they could prove it to the warranty people. I told them that was unsafe and ridiculous. Now I'm in the process of trying to get them to give me a good trade-in value for the freelander and a great deal on a new LR3. I definitely feel stuck, though, because I don't think any dealer will give me much for trade-in value. At least with this Land Rover dealer, I can try to appeal to their sense of guilt (if they even have one).
I'd be interested to hear if anyone has been able to get much for their freelander on as a trade-in after this coolant leak problem.
It's a long shot-
Have your Radiator checked. It could be as simple as that. (by a REAL mechanic)- maybe some one that works on Mercedes, Porsche etc. If they (Land Rover)can't find where the coolant has leaked, then they are not qualified technicians. News to follow.
I had a "seasoned" mechanic who rebuilds and works exclusively on Mercedes, Porsche and best of all Range Rover engines take a look at my engine. He was disgusted, and appalled that the dealership said I needed a new engine. Mmm. All he did was replace the radiator, because it was warm on top and quite cold on the bottom-and that restricted the flow of coolant! oh and he replaced the oil filter- it hadn't been been changed in quite a while and it was thick. Let's see, I took it in for the "scheduled" Land Rover
maintenence, aren't they suppose to change the oil and filter? I guess for $104.00 an hour isn't enough. My mechanic has driven the car for 5 days and it hasn't lost any pressure, it hasn't overheated and the engine is sound.
This is not the end..............
TIA
Very sorry this car has the reputation it does, really enjoy driving it!
