Leather Seat Repair: Ball point pen ink
Does anyone know of a product that will remove ball point ink pen from leather seats. My 2 year old decided to do some "art work" on my Lexus GS300's tan leather seats. Hairspray, leather spot remover & "Goof off" failed to produce any results.
jasany "Leather Seat Maintenance" Mar 19, 2001 8:23am
but WHATEVER YOU DO-----DON'T RUB TOO HARD!
Modern leathers are dyed and you'll rub the color right off them...it will look ten times worse than the ink.
Also, don't SOAK the leather...whatever you put on, take off right away.
Depending on the condition of the seats and age of your vehicle, you may want all the seats redone completely. Believe me factory seat covers are not of the highest quality and custom work is far superior (Most Honda and Toyota seats are very low end quality especially).... Lot of guys go to an upholsterer to dress there vehicle up beyond the factory originals. Average price in Canada is about $1200-1500 for high end work (but there are many that will do it in the $700 range) for front and back seats.
My friend owns such a business, usually varsol I noticed is the common thing used on cloth seats. I;ve seen many limousine seats cleaned with a rag and a slight amount of varsol (not saturated heavily...very light preferred). Although I always suggest test first to be safe. As for leather, good luck. I would think you should be able to put a new section in for under $100 easily.....beats spending $30 on all types of cleaners.
Be very careful if you want to try varsol/trupentine on head liners. If over soaked it may unglue from the ceiling. It's best for seats and carpets. The odor is gone in a day.
He said even with new vehicles it is difficult to match perfectly the material, so in many cases what you do with one seat you must do with the rest. If you remove the front part of the seat on one seat...then do it with the rest of the seats (front and back).
Your cheapest bet might be going to a auto wreckers and hope to find the exact same color seat if your unable to remove it.
Good luck
So you might call and see about having it redyed if all else fails... I wouldn't get too agressive with the cleaners first. You might get something into the leather that the dye won't adhere to.
Solution which I can think of after reading all the posts from different people I would like to suggest that you should give that ball pen back to your 2 yr and let him complete his work which he started on one of the seat. So all seats will look same and you will have hand designer seats by a 2yr.
