BRAKES-1992 Buick Regal GS w/ 3800 Engine
My ex has a 1992 Buick Regal GS w/ 3800 Engine.
She went to have brakes put on...they told her $950.00. They said the reason it is so much is that she never used the emergency brake. They advised her that GM should have told her when she bought the car that if you don't use the E/B every week..the cables all rust out and it effects the rear pads. (The car has 4 wheel Disc Brakes) They said we should go back to GM on this one...anyone out there "been there-done that?"
P.S. The shop wouldn't happen to be Just Brakes, or Quick Stop would it.
Let's follow the logic here.....she didn't use the ER brake so the cables "rusted up" and "affected" the rear pads.
Now then, follow me here...if the cable is rusted out, the cable can't pull on the rear calipers, right? So how does that affect the rear pads? Or if it does somehow pull on the calipers and make them drag, then the ER brake is working, right, and just needs a lube or a new cable, yes?
Or, at worst, a new cable and rear pads if she's been driving with flames coming out the rear wheels for the last few weeks. Seems doubtful, doesn't it?
This sounds like one of those "shotgun" repairs, where they replace everything their greedy little eyes can see.
A good shop.... a GOOD shop...gives you an itemized estimate, SHOWS you the damage needing repair, and explains the entire process to you.
You need a second opinion before you do ANYTHING with this car.
Anyway, one poster suggested that your particular car might be prone to defective calipers...which is not exactly what you were told but should you hear some story about caliper defects on your car they might be true. Another poster has never had this problem but keep his emergency brake cable well used and well oiled.
But in terms of this problem, have your brakes, brake rotors, brake calipers and emergency brake cable inspected at a second shop.
If, in fact, defective calipers caused this problem, then the problem as it was described to you is still mis-diagnosed.
