Best Hot Hatch - SVT, Civic Si, GTI, RSX, Mini, Beetle...
>>is one of them...
>Are you saying that your car should have cost $21-22k?
Sort of...had it been offered by someone else. There's a lot of factors that go into what a product ultimately costs. In addition to regional cost of living, economy and exchange rates, etc, you also have the variable of R&D costs (cost and extensiveness), plus then also how many units those costs get amortized across. The implication is that producers with higher production volume will predictably have lower MSRP's because of a larger denominator. Because some manufacturers have better dealership networks, market penetration and access, they sell more of their product. Since a product with their label on it will sell more units than the same exact product from Obscure Motors, their effective economy of scale advantages are translated into being able to ask a lower MSRP if they wish. So what this boils down to for me is that I generally expect that all products offered by the lower volume automakers will need to price their products 10-20% higher than the mainstream (assuming all other factors equal).
> If the Z had been available when you bought your car, would you have bought one?
No. The Z has no back seat and "no" storage (7ft^3), so it effectively duplicates my 911.
>>intrusion worth to you? YMMV, but my life is worth a heck of a lot more than $10K.
>So why didn't you buy an even more expensive car? Again, the compromise.
Sure, but for one thing, the C does better than the more expensive 3-series in crash tests. And in terms of performance for the investment, there's usually a "knee" in the curve above which you get into (strongly) diminishing returns. The knee is usually the sweet spot to look for for best value.
>>Since the only other RWD I looked at was the BMW...
> It wasn't clear before this email that your #1 priority was RWD, in which case you didn't
> have a lot of choices in the 'hot hatch' category.
RWD wasn't my #1 priority, but it was a consideration. It plays a part in that from an Engineering standpoint, we do know that when properly executed, RWD should generally outperform FWD (despite being slightly heavier), and that FWD is generally going to be less expensive to produce. FWIW, it is interesting that this comes up, as I suspect that FWD is assumed when most people try to define what is/isn't a "Hot Hatch".
-hh
That is true, but to me it just means you are getting less for more money.
>The knee is usually the sweet spot to look for >for best value.
Where do you get your crash test data? Can you do a comparison between the Si and your car? I'm curious how they compare.
>RWD wasn't my #1 priority, but it was a that
>this comes up, as I suspect that FWD is assumed >when most people try to define what is/isn't >a "Hot Hatch".
I agree with you, and I would prefer RWD. If I didn't need something more practical, I might have bought a Miata. Do you consider the RWD of your car to be properly executed? I wish we could all take our respective cars to a track or autox course and take turns driving them. That said, I'm sure that there are going to be more hot hatches coming, with BMW and Audi bringing their respective vehicles over in the next few years.
Honda Civic...basic ratings:
http://www.hwysafety.org/vehicle_ratings/ce/html/00031.htm
Intrusion Measures:
http://www.hwysafety.org/vehicle_ratings/ce/imcompoutc.asp
Go to this page and work your way down through the menu choices.
Or go to this page which has the hard numbers:
http://www.hwysafety.org/vehicle_ratings/ce/html/grey_small.htm
For reference, here's the URL for 'midsize luxury cars', which is where the MB C-Class is listed:
http://www.hwysafety.org/vehicle_ratings/ce/html/grey_midlux.htm
Also scroll down to the lower section which has "Driver Injury Measures". The Civic has a net aggregate score of HCI=468, whereas the MB is HCI=251. I'm not sure why the Civic appears to do relatively poorly (it appears to do well in many of the catagories)...my guess is that what is intuitively "out of line" is the 126 g's of force on the left foot, which is way out of line with everyone else (at least 50 g's higher, and 100 g's higher than the MB).
There's also a European crash data website at URL:
http://www.euroncap.com/index.htm
I'm not sure if these are the same as the USA models, but here's the two pages:
http://www.euroncap.com/details.php3?id=honda_civic_2001
http://www.euroncap.com/details.php3?id=merc_cclass_2001
http://www.euroncap.com/details.php3?id=car_127_2002
For these tests, Euroncap claims that the MB provides a 91% performance value and the Honda gets a 79% score. You need to read the details of the website to fully comprehend what these numbers mean. Note also that the Euro website also rates the cars for how they perform when striking pedestrians.
There's also http://www.nhsta.gov
The website http://www.crashtest.com points to both of these, once you figure out their webpage interface.
-hh
Does your car really weigh 649 pounds more than mine? You really do get good gas mileage for so much weight.
The US site rated both cars as Good in every category, and while the intrusion measures favored the Mercedes, but I didn't really see this reflection in the injury index (but I didn't understand all of it). Why would your peak Gs be 44 and mine 16? But that was a lot of fun to look at, and the Jetta/Golf did poorer than I thought it would.
That said, 650 pounds says a lot in an accident.
I bought an '84 Civic 'S' new with a stick and then a '93 Si, also manual. Combined mileage on both was 450,000, all accumulated by me. Those were hot hatchbacks in their time.
I test drove the RSX several times, both base and "S" models, and never did think I was driving a hatch. It is a coupe with a third utility door. The reason I was test driving them was to MOVE AWAY from the hatch. Sure, that is a debate in itself, but if you want a Honda product and also a hatch, you get a Civic Si. Try stuffing a Christmas tree in the back of an RSX like I did annually with my old hatches.
The RSX didn't do anything for me visually, looking like the new Civic coupe (shape of a watermelon pit) coupled with a plain cockpit. Neutral looks, neutral handling. There are a million on the road, it seems, all silver, and impossible to tell from even a short distance which trim level.
A little off topic: I did test drive the 2003 MR2 Spyder with sequential shifter. It took some getting used to, but basically I kept my left foot plastered to the floor and shifted with the stick using thumb and index finger. There are shift tabs on the steering wheel, front and back, but that was too alien. Shifting is super smooth once you get the hang of it, but it would be a lot of work keeping the car in "VVTI" mode with the current gear ratios. The salesman was VERY determined to sell it because they had to move it and no one else seemed to show much enthusiasm, meaning: I knew more about the car than he did. Eventually the 1.2 cubic feet of storage convinced me to look elsewhere, despite the offer to have a limo drive me to the dealer as a last ditch effort.
Eventually purchased a slightly used lease return 2000 Integra GSR at the credit union. Super deal, beautiful condition, and the most driving fun I've had in a long time, for about $10,000 less than a new RSX-S, and NO salesman.
anyway, its not so much a voting issue. Just what folks prefer (or drive out of necessity), that's all. Neither is the wrong choice.
as far as the CVT Mini, no, I haven't driven one. I just really like the idea of a CVT and I LOVE the Mini. Yeah, I'm sure many folks think its underpowered, but try one out and decide for yourself. I think it may surprise you. And, if the ride is an issue, you can get it equipped many ways. I think (IIRC) there are 15", 16", and 17" wheels all available based on the packaging you get. The 15s will offer the softest ride, of course.
The MINI CVT is an advanced transmission. It isn't as fast overall as the 5-speed manual since there is more parasitic drivetrain loss (not as much as a slushbox but still more than a gearbox) and the redline is lowered a bit with the CVT (5500RPM redline with 6000RPM limiter instead of 6750RPM redline with 7250RPM limiter on the stick) but max HP is around 6000RPM so you aren't losing as much in a way, especially since the CVT doesn't need the upper buffer like a regular gearbox does (you want to shift as high as possible with a gearbox since the next lower gear will come in below max HP but with a CVT you just sit at max HP until you are done accelerating).
The MINI is surprising for speed. 115HP looks sucky but with a 0-60 of 8.5s for the manual I think the engine spec might be underrated. Some other cars with 140+HP are much slower (e.g. ION, Aerio). In some really tight autoX courses the CVT is faster than the manual and even the S due to gearing.
I drive an 02 Si, with a stick.
I AM IMPRESSED by the Si!!!!
Unfortunately Honda does not make big V8's to compare to LS1, but Nissan and Toyota do.
Nissan 350Z with 3.5 liters will give LS1 run for it's money. Toyota Chaser will make Camaro blush with shame. Nissan Skyline with 2.5 liter will outperform Camaro in most aspects. Come on, push rods of yore can not compete with advanced and economical engines of today.
A VX45 ( I think this the engine code for Nissans engine) with 4.5 liters of displacement, 1.2 liters less than LS1, will outperform LS1 in all aspects and give you better fuel economy.
A Camaro LS1 with a 6 speed gearbox would have been a nice contender. I am sure there are numbers out there to prove that LS1 with 6 speed box is faster than LS1 with slush box.
Being a hot hatch is not about who is faster in 0-60 alone. Camaro being longer is not as agile as Si.
High performance is not about brute HP and Torque. A real HI-performance car in my eyes is a hybrid. To extract as much power from as little fuel as possible, that is HI-PERFORMANCE!!!!
This is where Si will definately outperform Camaro with LS1, at the gas station.
I agree that the Camaro is not a hot hatch, but not because of its length. It
>a 350 right? 350 is 5.7 liter. So a Camaro with >5.7 liter and Civic Si with 2.0 liter, hmmm. Let >me see, 1/3 of displacement and IS threatening a >camaro driver.
An Si is in no way threatening a Camaro driver. 1/3 of the displacement, and 3 seconds slower in the 1/4. And I drive an Si.
I love my Si, but compared with any LS1 powered car, I am NOT impressed by it.
>Unfortunately Honda does not make big V8's to >compare to LS1, but Nissan and Toyota do.
Depends what you define as run for the money. The 350Z is significantly faster than the Z28/SS, and much more expensive.
>for it's money. Toyota Chaser will make Camaro >blush with shame. Nissan Skyline with 2.5 liter >will outperform Camaro in most aspects. Come on, >push rods of yore can not compete with advanced >and economical engines of today.
Don't start with push rods vs. overhead cams. That argument is as pointless as import vs. domestic. The important thing is the end result, not the method used. And the only Skylines that are faster than the Camaro are much much more expensive, and heavily turbocharged. I am not that familiar with the Chaser, I know what it is, but I don't know anyone who has driven one.
>A VX45 ( I think this the engine code for >Nissans engine) with 4.5 liters of displacement, >1.2 liters less than LS1, will outperform LS1 in >all aspects and give you better fuel economy.
In what car? There is no Nissan sold in America that is faster than the Camaro was.
>A Camaro LS1 with a 6 speed gearbox would have >been a nice contender. I am sure there are >numbers out there to prove that LS1 with 6 speed >box is faster than LS1 with slush box.
It is faster, but there are plenty of people who drag race Camaros with auto boxes, because they are well made and consistent.
>Being a hot hatch is not about who is faster in >0-60 alone. Camaro being longer is not as agile >as Si.
That is true. A car that size isn't agile, it would do better on a track.
>This is where Si will definately outperform >Camaro with LS1, at the gas station.
True, but it doesn't get 3 times the gas mileage, even though it's engine is a third the size. I've spent some time in an LS1 powered camaro, and I consistently got around 20mpg. (although it was easy to get less, through methods you can imagine). My Si consistently gets 27-28.
anyway, the camaro is dead, so it doesn't matter. HOWEVER, I just wanted to chime in on the hatchback vs. fastback. If the Camaro is not a hatchback, then neither is the RSX. As a matter of fact, the Camaro rear window was even more upright than the Acura's.
In a way the Camaro was a victim of its own success in earlier years. It wasn't a very practical car and a buyer needed to sacrifice some things to get the raw performance the cars were really all about. Between the car's performance, reputation and buying demographic it became more costly to insure, particularly for young males.
The performance market has migrated down to more affordable and practical imports and thus the Hot Hatch idea.
More bang? More and different, vs. the Si, I'd say.
More buck, too, by about $7K over 5 years.
Hmmm, what can I do to an Si for $7K? If I want a Camaro beater?
I think $7 grand is not enough to match the speed of a Camaro. If I wanted to, I wouldn't have started with an Si anyway.
My point is that in these comparisons, the cost needs to be factored in. I'm saying this as a former Mustang 5.0 hatch owner who loved that torque and overall performance package. Given the cost of the Si, you can do a whole lot to it and still come out ahead bucks and quality wise.
Revka
Hatchbacks & Wagons Boards
And I found this odd:
However, the Focus' suspension tuning allowed the inside wheel to maintain contact with the pavement when powering out of corners. The Mini's just went up in smoke. Add in the Mini's inherent lack of low-end torque and you're left with a car that has to be hammered on for maximum performance.
So, let's see, the Mini could turn quicker lap times yet this is saying the Focus was better in the corners ..... ummmm.... ok.
Then we have the comment about having to hammer on the Mini to get maximum performance. Ok, here's a tip, to get maximum performance from ANY car, you have to hammer on it. If you aren't hammering on it, you aren't getting maximum performance. So does this mean they weren't hammering on the Focus? You mean the Focus was not being driven to its absolute limits? If that's true, then maybe we need some more agressive drivers to test these 2 on the track again, huh?
SVT - $33,666
Mini S - $31,024
Si - $25,233
Honda's 240hp V6 gets 30mpg highway - same as the Civic Si's highway mileage with 80hp less.
As I said before, if someone can afford a $40k SUV, the price of gas is of little concern. Sad but true.
And gas prices are predicted to fall now that summer is almost over.
The only way to get people out of SUVs is to heavily tax gasoline (as is done in Europe) up to about the $5/gal level. Why not run for office with that as an issue you support and see if you get elected.
