My first car was a CJ-5 with optional locking hubs. Never got it stuck, so obviously I wasn't off-roading hard enough.
Quest4suv, try the Sienna Owners: Problems & Solutions discussion or the Got a Quick, Technical Question? one.
Bp3959, the Subaru Crew here is very active and can help you better than me. But if it's a used one being sought, tell your friend to stop older couples driving one in the grocery parking lot and ask them if they are ready to upgrade to a new one and tell them that you're interested in their old one. Several of us got ours like that (my '97 cream puff had ~34,000 miles on it when I got 15 months ago).
Ok, back to playing in the mud with Toyota's!
So even in 2wd it is a safe and capable vehicle.
Interesting way to buy a vehicle. That's actually a pretty good idea as this we be benificial to both sides. They'd end up getting more than trade value, and you get to buy it without the dealer markup.
I have a '99 fwd Tacoma with standard transmission and full-time hubs. Toyota says that no Tacoma can be towed 4 wheels down. Sometimes a manufacturer will make these decisions for legal, not mechanical reasons. Can anyone give me a mechanical reason why I can't tow it behind an RV? If I were to do so, what transmission/transfer case configuration would be best (i.e. both in neutral)? I do not want to install a driveline disconnect like Remco sells.
http://4wheeldrive.about.com/cs/towing4wheelsdown/a/aa070601a.htm
VSC/BA/Trac all rely on the ABS pumpmotor to continuously replenish the brake pressure. This motor is NOT rated for continuous duty and is disabled for a cool down period after about 45 seconds of continuous use.
ABS & locked center diff'l.....
During braking the front brakes do about 80% of the work. That means, typically, that the front wheels will turn a lot slower that the rear. Except, of course, if the front and rear are locked together via the driveline.
Obviously ABS cannot operate at the front independent of the rear in those circumstances. That's the reason the Chrysler T&C AWD system has an over-running clutch in the rear driveline.
Most SUVs disable ABS becuase of this, some actually disengage the locking mechanism instead.
For the third time, my Landcruiser (and I imagine 80 series cruisers with ABS as well) does not disengage the locked center diff or disable ABS when driving in part time 4WD with the center differential locked. It does not seem to cause a problem, either. Isn't ABS the exact or equivalent opposite of TRAC (traction control), by releasing the brakes instead of applying them? Isn't TRAC designed for 4WD? What's the difference?
Washington Post
Full-time 4wd:
The terms that can indicate this type of 4wd are limited slip center differential, open center diff, or unlocked center diff. Full-time 4wd is more common than part-time 4wd, although alot of vehicles with full-time will also have a part-time mode. In this mode you can drive on dry pavement or slippery conditions.
A flat tire should not damage your drivetrain going slow for a short while unless you have a clutch-type limited slip(common in 2wd vehicles as well), your rim is another story though. If the vehicle has traction control, a flat tire will probably freak it out pretty good, so it'd be a good idea to disable this if you have a flat.
If you have 2wd and full-time 4wd, you should drive a few miles in 4wd every 3-4 oil changes.
Generally you shouldn't drive on a flat tire in any vehicle unless it's an absolute emergency, if you dislike changing tires that much go get a roadside assistance plan
Part-time 4wd: This indicates you have a locked center differential(or transfer case), and your manual will cleary indicate that it's for low traction surfaces only. This should never be used on dry pavement or any other high traction area(unless you are crawling over rocks, but it doesn't sound like that's your goal). Having a flat in snow shouldn't damage your drivetrain, since that tire will just slip around.
AWD: Most vehicles that have AWD will have this as thier only mode. Should not be driven with a flat.
Snow tires or all-terrain tires are a good idea with any AWD, 4wd, or 2wd vehicle in the snow as your drivetrain will only help you go, not stop. All-terrain tires are a better idea than snow tires as they ride better, last alot longer, and do not need to be changed out when winter is over.
Unless your manual explicitly says otherwise, you should assume that a vehicle with any type of 4wd or AWD system should only be towed with a flat bed unless you have an aftermarket driveshaft disconnect installed.
The reason that alot of people prefer a vehicle with both full-time and part-time 4wd modes is that you can use full-time 4wd all the time, and switch to part-time 4wd if you ever get stuck. Part-time 4lo can get you out of alot of situations that AWD and full-time 4wd won't touch(ever been in a ditch, or part-way on a sheet of ice).
When you buy a several thousand dollar vehicle, please take the time to read the manual. At $20 an hour it takes 125 days of work to buy a $20k vehicle, and only a couple hours to make sure you know how to care for it and use it properly. If there is something in there you aren't too sure of, we'll still be here to help out.
I live in the Northeast, in an area that gets a lot of ice and snow. I own a 2004 4Runner V6 with 4WD. The beauty of it is that I can drive it around in 2WD when 4WD is not necessary. This way I save on gas and drive train wear. But if I need 4WD I can turn a switch to 4WD mode (on the fly if necessary) and that's all I have to do. It is then in a full -time 4WD mode that can driven on any type of surface (including dry pavement), and can be left in that 4WD mode indefinitely if I choose to. I also have the ability to lock the center differential, for special low traction situations. Having, as standard equipment, ABS, TRAC, and VSC also helps both handling and especially safety. My feeling is that if you want the best all around 4WD system that is also idiot-proof (if you want it to be) , the 4Runner fits the bill. If all you’re looking for is the ability do drive in snow, on ice and/or wet roads I don't think you'll ever need to lock the center differential anyway. If the roads were that bad, they'd have a ban on driving altogether, we’re not in Montana <grin>. Your other questions were answered throughout this forum. Just use the search facility to find the answers. Hope this helps!
If you need something larger, maybe a Highlander or a Honda Pilot will make you happy.
Stick with the Japenese products. Personally, I wouldn't buy a Cherokee with my hard earned money. They seem to fall apart quickly. Read the Jeep forums.
1. do, connect slip chains,
i know they work they have saved me from lossing loads before, but
make sure they dont drag, if they do, wrap them once around the tounge of
the trailer, same with you brake and turn signal wires
2. WIDE TURNS, the way you do it is like a semi, stay in the right lane to
make a right turn tunr you signal on, check left lane if clear start to move
to the left then cut right... BUT BEFORE you cut right make sure nobody
has moved his way into you turn space
Left tunrs are also like you see semi trucks do it, if a double turn lane
use the right lane not the left...
3. your are not going to pass anthing but a turtle on a hill without
>destroying your drive train... So no shifting, our TLC´s know what to do so
just drive it, and remeber, no shifting, get in the right lane select the
PWR switch if you need it, and let people pass you on a hill.
4. before you depart, get jack, emergancy equipment, spares cotter pins
whatever you need.
dont forget water incase you boil over, TLCs rarely do but you never know.
Check your brake lights and turn signals, not on your car but on the
trailer...
5. Make sure you know how to use your emergancy equipment
6. If travling in the mountains speed limit those posted yellow signs with
the´suggested´ speed for turns ect. but also mind the people behind you if
they are there for a long time find a space to pull off and let them pass.
Road courtesy always makes people happy... well usualy
7. Make sure you are using the right sized ball for the recever on the
trailer, i didnt one time and would have lost my trailer if i had not
attached my safty chains
DONT´S
1. Shift... its not a manual transmistion... it knows what to do...
2. if going over passes, on the decline try to avoid downshifting, it heats
up a transmision quickly, but also do not ride your breaks, pump decrease
speed let off the brakes and let the cool, then again ect... if you feel
that they are getting too hot (and you will know when, lots of squeaks and
more preassure is needed) then, on a 5 speed auto you can push the shifter
into 4th, while applying the brakes (if you are traveling at less than 75
mph, you must be very carefull when downshifting, in a 5 speed or 4 speed...
because if you are going down hill with a mass behind you with no brakes on
it it can swing out, and if you down shift at a speed to high for that gear,
the SUV will jolt into that gear, you will hear the engine rev high, as it
attempts to slow the mass down, but do not I repeat DO NOT downshit on a
curve. If what i have explaned happens the trailer can swing around
potentialy causeing a rollover... Another thing... : you are going down
hill, you feel it is ok to downshift, so you shift into OD or 4 (on a five
speed) if it does not down shift into that gear withing 2 seconds turn the
OD on or shift back into drive, this is when the car says no... its telling
you that it knows that it is going to fast for that gear, and will not allow
the downshift... now it will down shift, if left in OD off or 4, but only if
the SUV slows down, bt mind you when it does downshift its is not going to
be smooth, that is why you shift back.... ahh i hope you understand all of
that blabber....
3. attempt a U turn unless you have plenty of room. I would suggest taking
your trailer to a large empty parking lot with another friend and practice
backing up and turning... I know it sounds funny and ´back to the basics´
but i did it when i trailered for the first time and it helped me learn...
4.dont Look back all the time to make sure the trailer is there, it is
always following you just watch the road and other cars and you will do fine
Do have fun its a whole nother driving experiance, you will enjoy it!
With the torque converter locked up there would be no danger of the transmission fluid overheating....
Tom
Oh, without the increased torque, due to the converter AND the higher engine RPM, with it locked towing uphill, or even on the flat, the clutch disks and/or bands might slip and fail.
Tom
Congratulations on your purchase.
OK, guys, since the newer models have Torsen, does that mean its better than open differentials (with traction, stability, etc.)?
All you ever wanted to know about the Torsen:
http://www.sonic.net/garyg/zonc/TechnicalInformation/TorsenDiffer- ential.html
Tom
