-June 2024 Special Lease Deals-
But in the meantime you will have a much more robust and reliable LSD, AWD or 4WD system wherein no engine dethrottling will be required to preserve the brake rotors.
And please note that many of these brake apportioning AWD systems only allow AWD "activity" for about a minute or so of semi-continuous operation before disabling the ABS pumpmotor to prevent its failure from overheating.
2006 RAV4's "On Demand 4wd" is basically 2WD with extended control traction like Honda CRV and Quadra TRAC II. True, the transfer clutch wear will be minimum since it will be very rarely used in most typical usage. (Unlike CRV, MDX engages the transfer clutch every time it accelerates (0-18MPH) thus having more wear). Highlander & MB MClass also use extended traction control but the difference is, they are AWD all time and hence the chance of slippage is reduced very much, unlike the new RAV4. In Highlander, the traction control is used just until traction is regained. Neither ABS nor TC is turned off because of heating. Highlander AWD system is simple and neat for most purposes. Of course, it is not necessarily meant for the Rubicon trail. Agreed, there are a few other true all terrain vehicles but they are more expensive and sometimes less reliable.
Both instances are commonly known and recognized by the public as being simple ONE-WHEEL DRIVE vehicles.
point well taken. most of these AWD systems are not all that useful when conditions get rough. I'm amazed at how easily I can spin some wheels on my Passat 4motion in the snow. My 4X4 '99 Blazer, when locked into 4WD-hi does much better, and better still when I go into Low range and the center differential is locked.
What can you tell us about the 4WD system and capabilities of the new Rav4 when put into 4WD mode?
TLT
it's true that with open diffs the torque will go to the slipping wheel. Just as with the RWD with an open diff.
The 4wd fulltime advantage is that each tire now is driving the car, so the chance of breaking one of the drive wheels loose is greatly reduced. (by half)
Think of it this way, with RWD only, the torque that needs to be transfered to the road must go thru only two tires, thus they need twice as much grip.
With a full time system, the torque/friction requirement to accellerate per tire is 1/2 of the RWD set up,
So, with the same tires, and the same slippery surface, the same car with 4wd, rather than rwd, could accelerate twice as fast. Or drive up a steeper hill, or up a more slippery hill.
best regards
Be that as it may when it comes to my need for excersizing directional control or maintaining directional control I NEVER want my stearing, front, wheels to have ANY traction responsibility other than laterally.
Maybe I'm stupid Willard, but what are you trying to say here? :confuse:
Great idea.
Your preference may be for Rwd vehicles, and one might successfully argue that they are sufficient with the right tires and driver for most situations. For people in warmer climates it may definately be the case.
But that doesn't erase the fact that 4wd just cars go better in slippery conditions regardless of the driver.
Best regards
Otherwise I'll stick with RWD, or rear biased AWD, and not put my life at risk, thank you.
"...4Wd cars just go better in slippery conditions..."
Granted, adsolutely!
But now let's talk about operations at the very limits of roadbed adhesion...
What about stopping? 4WD is no help there, and might even be detrimental if engine compression braking is high enough to make ABS non-functional.
And what about turning? 4WD can actually be detrimental!
Coming to variable torque drives (VTM-4) they are good for fuel efficiency/good acceleration etc., (especially, with bias on the rear on dry pavements) but many times these cars also give the option of locking at 50:50 torque distribution for better traction in bad situations like ice.
Sporty and safety are two different things. People have their own preference, I guess.
Ya, God forbid should you have wheels up front pulling you through the corner as opposed to being pushed straight ahead by the rear wheels!!!! The only time that 4wd is not goig to help in a corner is if the wheels are locked up because you have braked too hard and/or the anti-lock failed. Even then, the 4wd will not hinder.
What does anti-lock do? Keeps the wheels from locking up. What happens if the wheels get power? They continue to turn, allowing for control. I grew up in North Dakota, and anyone who has actually driven on ice to any extent knows that the constant compression slowing down is much better than intermittant braking for maintaining control. Of course if you want to go from 60 to zero in the lenght of your car, 4wd will not help, but about the only thing that will is a massive log chain wrapped around a solid structure or a couple JATO rockets pointed blasting forward.
"...wheels up front pulling you through the corner..."
Apples and Oranges comparison. If there is enough traction for the front wheels to "pull" the FWD vehicle around the corner then clearly there is an EXCESS of traction for lateral control at the front of a RWD vehicle.
ABS cannot alleviate, moderate, engine compression braking at the front wheels of a FWD vehicle. The only way to do that is to release the clutch with a stick shift, shift into neutral with an automatic, or maybe have the DBW aspect of the engine/transaxle ECU match the engine RPM to the rate of rotation of the rear wheels.
And yes, back when I lived in MT (before FWD) if engine compression braking at the rear didn't suffice then a slight application of the parking brake often helped.
Is that a good thing? I mean if you are going offroad you need to lock the center diff anyway to disengage the VSC and TRAC (not A-TRAC), to allow for more wheelspin. If three wheels are spinning due to ice or whatever the case may be, then isn't it an advantage to have A-TRAC send all the power to one wheel, instead of to one wheel on each axle?
I find that very interesting. For one thing, I never had any trouble in snow, mud or anything else with my Tundra in 4High. Also, switching to 4 low does nothing but increase power. It does nothing at all for traction. Infact, low range can be a disadvantage in snow and ice because of the added torque.
4-low vs 4-high increases the level of torque available at the drive wheels, not the level of traction.
You could have very likely accomplished the same thing in second or even third gear, and quite possibly even in 2WD. Next time try feathering the throttle just a bit to the point wherein the tires do not quite break traction with the surface.
slvrfx :shades:
I agree, one would get high torque with 4LOW. But, I think it is the reduction in wheel rotation rate associated with 4LOW that helped to get better traction. Like taking baby steps when the surface is slippery.
Concur in other deductions.
Except for an engine check light being on everything will now operate as normal except for VSC/Trac which remain disabled until the check engine light clears after about 4 drive cycles.
Instruction given to me by the service manager at Lexus of Bellevue WA.
No, all the traction you can use already exists as a function of things like stiction of the tire surface with the roadbed, weight of the vehicle, etc. The only ways I know of to INCREASE traction readily is to add weight, sand bags, and/or studs or chains.
What this discussion is about is how to make the best use of the traction we already have, as in distribute the engine torque over a greater contact area (locker) and/or make it easier for the driver to modulate the torque, feather the throttle, at a much lower level (granny-grunt gear ratio).
Not by any means saying the locker didn't engage in a shift to low range, but what I've been trying to point out if that the effective "gain" of the accelerator pedal was also reduced significantly.
In many instances the best way to get going initially is to just "ease" the throttle open ever so gently and slowly. If you happen to be driving a new Corvette that might be really difficult. The Corvette engine has so much torque at the low end it is practically impossible to "soft" start it.
But reduce the final drive gear ratio to 100:1 and even full throttle wouldn't move the car forward fast enough for the TONS of torque now available to break traction.
In a previous 4wd SUV, I had several options with regard to 4wd. The first was a "Full Time" 4wd, which meant the center diff. was NOT locked, allowing to drive on dry pavement - without risk of damage.
Next, there were the traditional 4hi and 4lo, that locked the center diff, and were only for slippery (off road) conditions.
Now the question:
On my Tacoma, when in 4hi, is the center differential locked? The manual indicates that it is for slippery, or wet pavement. But in my experience, wet pavement may not provide enough "slip" to operate a true 4wd system, where the center diff is locked, without risk of torquing the drive train too much.
I hope I've explained my question well enough. Any info would be appreciated.
Check out this very good summary.
cliffy1, "Toyota 4WD systems explained" #4, 16 May 2001 4:00 pm
You may want to check out the first 5 posts to this thread (authored by cliffy) to get a good understanding of the pros and cons of your (and my) tacoma 4wd system.
Isn't the auto tran FJ the same as the auto tran 4Runner, which has a F/T AWD system?
Is the FJ with auto the same as the new Rav4 with auto (so then these 2 models are different from the 4Runner with auto)? Confusing...
Thanks alot.
This does not address the Tacoma specifically but...
No 4X4 can be operated on a high traction surface absent an "open" center diff'l of one type or another. The only difference between a "transfer case" and a center differential ("case") is that the transfer case contains both a CD and a low range gearset along with the ability to lock the center differential during times of operation on poor traction surfaces.
There are, currently in the market, part time 4X4 systems without a "transfer case" and only an open differential that can be locked for part-time use on low traction surfaces.
But yes. Since the Tacoma does not have an open center differential, then it would be detrimental to drive the car on dry pavement while 4wd is engaged.
