Most importantly, the torsen (center differential) does not lock or inhibit speed differences during braking, thus allowing all 4 wheels to rotate independently at their own speeds when no power is applied. The torsen diff'l only locks in a power application situation while the VC locks during acceleration OR BRAKING. The torsen has a torque sensing characteristic while the VC has a rotation sensing characteristic.
The VC's rotational sensing characteristic initially caused lots of problems for the engineers. Electronic anti-lock braking systems, ABS, rely almost entirely on speed differences between the four wheels to detect a locking wheel. Thus, when the VC tries to force all 4 wheels to turn at the same rate, during moderately heavy, or severe braking, it creates serious difficulties for an electronically implemented ABS system, and since it would telegraph the front wheels' (slower) rolling rate to the rear wheels it might cause loss of control of the vehicle.
The engineers had to use a variety of HACKS to get around this problem. Mitsubishi delayed ABS for awhile for its first generation GSX, then finally decided to make ABS and rear VC limited slip mutually exclusive options. The VW syncro system simply disconnected 4WD the moment the brake pedal was depressed via a secondary clutch. Most other vehicles using this implementation of VC have a very simular disengage feature. The very successful World Rally Championship Lancia Delta Integrale even went so far as to apply a bit of power (via the engine ECU) to reduce the drag of the VC when the brakes were applied! Some very crude (sophisticated?) VC systems used an overrun device (Chrysler T&C) conceptually simular to a bicycle crank. This meant that while 4WD was disengaged during braking it was also inoperative when reverse was engaged! (The T&C overcomes this VC implementation flaw by adding a dog-clutch to lock the over-running clutch in reverse).
The easiest VC "HACK" was to
REDUCE THE EFFECTIVE VISCOSITY
of the fluid in the VC coupling, so that it never (NEVER{?}) "TELEGRAPHED" the front wheels' rolling rate to the rear wheels, possibly causing them to lock up and cause loss of vehicle control, and ABS could still perform its task, rather than have the more heavily braking front wheels "dictate" their rolling rate.
This also meant that the VC's "normal, and overall locking effectiveness was reduced, in some cases significantly so, but that might be quite acceptable for a vehicle used primarily below the snowline and never off-road.
The VC's "attraction" is its simplicity and cheapness, not it's sophistication.
Lexus RX300 AWD.. CHEAP ??!! NON-SOPHISTICATED ??!!
None of this tells us why the RX300, with an open center diff'l but with a FLACCID VC, still remains predominantly FWD.
But...
Any questions class?
Original document prepared by Eliot Lim.
Editing by WWEST
Sorry, I don't remember the specific site.
Do you like yours with walnuts or pecans. I vastly prefer pecans.
This is just a guess, I pressume the RX's traction control (part of VSC) is more agressive on applying the brakes to the rear thus quickly rerouting torque to the front. It is less agressive on braking the front since it affects steering and thus routing less torque to the rear on slippery situations.
My reasons:
TRAC is an electronically implemented system with the only mechanical "time delay" being the time needed to pressurize the brake calipers. Lexus says that TRAC will activate on detection of "impending" wheelspin. The VC on the other hand works on a fairly long time constant, it typically takes many milliseconds to heat the viscous fluid through the friction of the disparately rotationing VC clutch plates. Additionally the on-set of the VC activity must be designed for a fairly long delay to prevent its activation during turning manuvers and to prevent undue interference with the ABS.
So the VC's incremental activation is totally dependent on sustained disparate rotational rates of the two sets of clutch plates and this would never happen if the instantly acting TRAC were to be used to allocate torque front to rear or rear to front.
More...
Anyone ever hear of a front axle LSD?
Both of my Jeeps had rear LSD and a part-time 4WD mode with a locked center diff'l. The thought of having a front LSD had never enterd my mind and I don't remember any sales document offering it as an option.
I doubt that TRAC can be designed to function very well as LSD on the front axle. It seems to me that any left to right, or VV, TRAC activity on the front axle would provide such a horrid level of jerking feedback to the steering wheel that it would be extremely discomforting to many drivers.
If not forewarned might they react to a suddenly jerking steering wheel in basically the same way people who first encountered pulsing brake pedals reacted?
Traction control. This can be fine tuned to equalize wheel speed on both sides thus acting as electronic LSD. I believe this feature is used by Audis, VW's and Volos. I haven't heard complaints about unfavorable steering effect/feedback due to traction control activation but I theorize that it can.
As far as I know there is no ABS/VSC/TRAC system that can moderate, modulate, the application of any of the brakes, the brake is either fully applied or it is off. The only modulation is that which is implemented through the rapidness of the on and off cycling.
Absent some way to moderate the brake fluid pressure to the front, front LSD with TRAC would result in the steering wheel "pulsing" in the same manner as does the brake pedal on ABS application.
About electronic front LSD, you might want to test drive a passat or jetta equipped with such thing and experience it for yourself. Technology has advanced so much that it is possible to modulate brake pressure and maintain a desired wheelspin. Pulsation is so rapid and mild that it can hardly be perceptible.
Anyone have a report of this type for an RX or an HL?
pschreck:
Your Toyota is predominantly RWD right?
Did your trac system act on brake, the front wheels at all, and if so what was the affect felt by the steering wheel?
Is this something that an aftermarket supplier might be willing to custom fabricate?
Reading all this I am thankful that I have a simple AWD system: All open diffs with manual lockers.
HiC
I think I recall feeling a slight thumping through the steering wheel, but I won't swear to it. I was very much caught up in the moment. I can tell you that the system is at least as effective as my old 97 K1500 pickups' old time 4WD system. I can't speak for the other Toyota systems but I can say that for my needs this is a choice system. You get 4WD with a low range that can be driven ANYTIME IN ANY CONDITIONS.
I think that the best way to describe this type of system is to call it Part Time Rear Wheel Drive.
The bottom coil spring support plate surrounds the strut and is within less than an inch of the tire tread surface. Even cable chains would have to be kept extremely tight so as not to strike this plate.
And I can assure I will NOT be chancing that!
Would I be correct in saying it has two distinct modes.
1. Torque distribution, control, left to right or right to left.
2. Traction control, exactly like conventional TRAC in this mode, applies brakes on wheels.
Oh, forget it, cheaper to go buy the manuals.
cliffy1 May 16, 2001 2:59pm
If the sequoia has three open diff'ls, what is the need for pushing ANY button to engage 4WD, and then "waiting" for the gears to match up so it can "slip" into 4WD.
I'll go read the book.
1. Selection for two wheel drive
2. Selection for four wheel drive, center diff open.
3. Selection for four wheel drive, center diff locked.(Like a conventional part time system)
Two things are different
1. The Sequoia has traction control that utilizes the brakes to stop a spinning wheel.
2. The center diff only locks when the transfer case is in low and the transmission is in L.
You need to wait for the four wheel drive to engage because the gears need to line up to mesh, like with a gear based locker for a rear diff.
Gary
"3. Selection for four wheel drive, center diff'l locked...."
(Second "2")
"2. The center diff'l only locks....."
Isn't the first instance above a NO-OP?
This is one of the problems I have with cliffys explanation, if the center diff'l doesn't lock then you are still in full-time (open diff'l)4WD as in "A" 2.
"MY" 92 Jeep Cherokee Limited had RWD, Full-time 4WD (pretty useless), Part-time 4WD, and Part-time 4WD LOW (otherwise know as "grunt and groan", never went there) The Part-time modes were so "named" because they could not be used full time within incurring serious damage to the driveline, and your knuckles.
Question: Does the current 4Runner with Active TRAC have a 4-channel ABS or 3-channel???
I know the earlier versions before ATRAC have 3-channel. With the incorporation of ATRAC, don't you NEED 4-channel to INDIVIDUALLY control the rear drum brakes???
Also, the REAR axle of the 4Runner is the same as the Tacoma's, right??? What size is it??
What is the size of the Land Cruiser's rear axle??
http://home.off-road.com/~bibelheimer/diffs/diff_info.html
In short the ring and pinion sizes are different between the Tacoma and the Runner so one diff won't match up to the axle on the other. 8" for the Runner and 8.4" on the Tacoma.
I'm fairly sure that it's is a four channel ABS. Is there something special you're planning on doing?
Gary
2001 AWD RX300
Only conclusive test indicates maximum torque to the rear is approximately 25% and TRAC does NOT activate for F/R torque distribution.
1) To get out of driveway into street?
2) Once she is in street?
Thanks in advance...the manual doesn't help a non mechanical kindo of guy.
I was moving very slowly because it was a narrow street with cars parked on the side, and brakes were lightly applied. My question is, should the VSC have acted to counter the snowplow effect? If so, what could have caused it to stay idle? If not, in what snow conditions would it act?
Would have over-ridden the VSC ecu.
1.) Do not order the limited slip or skid control and have a vehicle with just 1 front and 1 rear wheel actually applying power to the ground.
2.) Order the limited slip and at least if one wheel slips, either front or rear, then limited slip will kick in, and the opposite wheel on the axle that slipped, will then place power to the ground.
3.) Order the Skid Control, and the brakes will be applied to a wheel when it slips and power will be transferred to the opposite wheel on the same axle like limited slip, and if the vehicle is sliding at any angle, more braking will be applied to straighten out the vehicle.
If this is correct, then option 2 or 3 is my best bet for added traction, and if I was to make sure the vehicle is more stable, then option # 3 is my best choice.
Rear LSD would sent some torque to the wheel opposite the slippng rear wheel.
The TRAC portion of VSC/TRAC is used to manage torque distribution left to right and vice versa NEVER front to back, that's the purpose of the VC, viscous clutch, across the center differential.
Lexus TRAC implementation, traditionally, will first brake a slipping wheel or wheels, and then dethrottle the engine almost immediately if the driver isn't quick enough lifting the gas pedal.
From the way the "01" shop manual reads I suspect that in the case of a single slipping front, primary drive wheel, dethrottling is used instead of differential braking. Differential braking might inadvertently break a few peoples thumbs or knuckles.
VSC includes a yaw sensor and a steering wheel position sensor and these are used to determine if the vehicle is following the desired line of travel. if the vehicle is understeering both rear brakes are applied (so says the manual), if oversteering then the outside front brake is applied, sometimes so moderately all you hear is a strange noise coming from the frontal area.
The VC.
Most VC implementations of this type are designed to quickly "tighten" up and "lock" the center differential if slippage occurs front to rear or vice versa. The VC implementation in the HL and RX are referred to as a "simplistic HACK" by the AWD experts such as Eliot Lim.
The Chrysler T&C AWD, for instance, has a VC implementation that will actually come into play very quickly and will truly "lock" the center differential if that is what is necessary to fully eliminate front to rear slippage.
But, if the center differential is "locked" (it never is, just "stiffened") and you apply the brakes severely or moderate heavy the rotation rate of the rear wheels are "locked" to the rotational rate of the front wheels and the ABS could not do its job to help you stop quickly while maintaining directional control. Remember that the VC would have stiffened only if you were on a low traction surface and the lack of ABS capability in this circumstance could be disastrous.
To prevent this from happening the T&C has an over-running clutch to de-couple the rear wheels rotational rate from the front in a forward motion braking circumstance. But what about reverse? The T&C has a dog-clutch which engages automatically in reverse so the T&C remains AWD even in reverse.
The HL/RX has neither of these so the conclusion must be that the HL/VC VC implementation is so "slack" or "flaccid" that it never becomes stiff enough to rise to the occasion. And that actually proved to be the case in a test of the RX on a four wheel dyno, it can only route a maximum of 25% of the torque to the rear in the very worse of circumstances.
Additionally due to poor suspension clearance snow chains cannot be installed on the rear and while recommending snow chains ONLY on the front in the owners manual Toyota/Lexus readily admits that this configuration can be extremely hazardous.
Bottom line is that you will likely get just as good "service" from a FWD HL/RX as a "pretend" AWD version.
Wwest, Eliot Lim was siting the Chrysler T&C AWD an example of having the "simplistic HACK" , and no mention on Toyota/Lexus AWD.
RX300 and Highlander has front and rear open diff and viscous limited slip center diff.
Each of four wheels always receive 25% power and slightly more power on wheels with traction whenever wheelslip occurs due to the viscous limited slip center diff. Traction control further help by preventing leak of power from a slipping wheel.
You also mentioned "The Chrysler T&C AWD, for instance, has a VC implementation that will actually come into play very quickly and will truly "lock" the center differential if that is what is necessary to fully eliminate front to rear slippage."
The Chrysler T&C AWD has NO center differential, it is a misnomer. It only has an over-running VC that connects the front to the rear axle.
The front is the primary drive and receives 100% power at all times. If the front slips, the VC limits rotational difference between front and rear and thus sending some power to the rear. Engineers play around with different axle gear ratios between front and rear to fool the VC to send trickle power to the rear when there is no front wheel slip.
Hope Cliffy would come in and clear this out.
On a four wheel dyno set to "limit" the speed of the rear wheels the front wheels "ran away". Seemingly, "braking" the rear wheels with "friction", had no adverse affect on the engine driving the front wheels, and it only took about 5HP to limit the rear wheels to 20MPH. Obviously didn't push this test too far for fear of damaging the poor VC.
And, Eliot Lim refers to a VC HACK as being one that is designed to be so "flaccid" it cannot interfere with the ABS in its fully "tightened" mode, that description fits the RX/HL design to a "T".
And speaking of differing final drive ratios why does the RX and HL have differing final drive ratios front vs rear?
Survival in most "normal" AWD conditions is more a function of finesse, not more HP. Now if you are going to take it off into the woods then cliffy is absolutely right, the only thing that will help you get unstuck deep in the woods is horsepower, normally somebody else's though.
Like Dr Moore(torque) has said, the better traction your SUV has, the deeper into the woods you can get before becoming STUCK!
