Both V6 and V8 have Torsen.
Does it go to the front (slipping) axle or does it go to the rear (traction) axle??
Or does it stay at 50/50??
With the advent of the new Torsen system on the same A-Trac system, the story I am getting is changing slightly. Our training manager told us that it was fairly easy to alter the front/rear power split. I'm not sure this guy knew exactly what he was talking about though. Unfortunately, finding a factory guy who can explain this stuff and is available to the dealer level to answer such questions is not easy.
Bottom line for me is that when in 4WD in the 2002, you have an extremely capable vehicle. There is VERY little it can't handle. The 2003 is even better with even fewer situations it can't handle. Personally, I'd love either version in my Tundra.
Maybe the Torsen allows for more consistent, faster, & smoother shifting of power front to rear because Torsen has a set of programs to distribute power under certain conditions (70/30, 30/70, 50/50, etc.).
I never could get why ATRAC and stability control are not on trucks. Maybe the rear end is too light and therefore would turn the system on too often?? Anyway, truck is where these systems are needed MOST! Trucks are notorious for sliding sideways and losing traction on wet surfaces. They need it much more than sports cars!
1. Cost. The Tundra and Tacoma are already pretty expensive. Adding something like this would certainly add to their prices in an already competitive market. Until the 2003 MY, ABS was an option but now that they have it standard, the upgrade would not be as bad.
2. Consumer distrust. Pickup truck buyers are generally not as motivated by technology as SUV buyers. They tend to want it simple and easy to understand and function like every other truck they have ever owned.
Those are my theories. I don't like either one but I'm sticking to them. I for one would love a Torsen center on my Tundra.
This past weekend, a friend of mine told me that I could install a rear locker on my 2002 2wd 4runner? Any truth behind this? What's the point in putting a locker on a 2wd?
A locker will help traction on slippery or rough terrain (like off-roading). I would not use it on dry land, not even in light rain.
The new torque-sensing feature allows the torque split mid-point to be more biased toward the rear, sending more torque to the rear wheels, providing better stability control whether the driver is accelerating at high or low speeds. The static rear-drive bias favors stable tracking on- or off-road, decelerating or accelerating. The Torsen™ type sensing provides three dynamic torque split ratios, depending on the available traction on the vehicle at the time. A static torque split favors the rear with a 40/60 percent front-to-rear split. When the front wheels slip, up to 71 percent of the split ratio goes to the rear wheels. When the rear wheels slip, up to 53 percent of the split is applied to the front wheels.
I'd even settle for a 2-mode diff'l, like the old Aerostar, 30/70 F/R until slippage and then 50/50.
The Porsche 968 has a transaxle and is RWD, so I don't see that a transaxle vs a transmission enters into the equation.
On the other hand I'm also beyond my depth since I haven't a clue as to why or how the HL and the RX manage to bias the torque toward the front so severely when both ends are directly driven from separate outputs of the center (open) diff'l.
I believe that the Mazda Tribute and its Ford counterpart have traversely mounted engines and are (incorrectly) marketed as AWD and 4WD.
They seem to have adopted the Aerostar method, it's basically FWD with an "automatic" AWD mode which engages the rear drive only if the front is slipping and a mode wherein it can be locked into 4WD (part-time) only on low traction surfaces.
Suspect it had a torsen center diff'l very much like the new 4runner except only two modes.
Just stopped by the Toyota store to look at the 03 4runner and pick up a sales brochure. I'll take back any statements I have made about the 4runner vs the HL or RX, the 4runner is just plain too damn big and bulky.
But.
From the brochure on the TORSEN limited slip diff'l:
"For example, when the vehicle is traveling straight, 40% of the torque is distributed to the front wheels, while 60% is allocated to the rear (40/60), providing the driver with a feel typical of a rear-wheel drive vehicle."
WHEN THE VEHICLE IS TRAVELING STRAIGHT ????
Is it entirely possible that Toyota has figured out how to design a truly excellent AWD vehicle?
The statement implies that the torque to the front wheels might be something other than 40% if the vehicle is turning. I have always firmly believed that it is wrong to have driving, motive, force to the front wheels while turning.
Motive forces, acceleration or deceleration, to the front wheels should be reduced altogether when turning, or as a function of the level of need from tractive adhesion to be allocated to directional control.
Maybe, we can hope, Toyota has arrived at the perfect AWD solution.
40/60 normal, 29/71 w/front slippage, 53/47 w/rear slippage, AND 29/71 (5/95 severe turn??) when turning.
Now, can I have an RX with this feature next spring?
Or even an HL??
"My guess would be electronically, electrically actuated clutches, like the Ford Aerostar."
Er, no need to guess on an important question. It's sort of like guessing that the X5 has bi-xenons.
A simple search on the Internet will provide something like:
http://www.howstuffworks.com/differential8.htm
Hope you find the article useful, or find other articles easily searched for. Torsen is purely mechanical, it does not rely on locks or clutches or viscuous fluid.
But the 4runner seems to have three torsen modes which to me means something outside the torsen "box" itself is switching from one mode to another. That's what the Aerostar did with an electric clutch. The Aerostar simply detected F/R driveline rotational disparity and automatically actuated the 50/50 mode.
Apparently the 4runner is normally in 40/60 mode and automatically goes to 29/71 with front slippage (only) or 53/47 mode with rear slippage (only). The way I read it there is a distinct possibility it decreases the engine driving/braking torque to the front driveline as the VSC ecu "senses" the need for the front tires' roadbed adhesion coefficient be dedicated to directional forces.
I don't think any torsen gear-based "box" can do any of that of itself.
With regard to bi-xenons the BMW site actually said it had them and I already apologized for believing what BMW published as factual.
The Torsen diff uses an interesting setup of worm gear and side gears. The driving principle is that a worm gear can turn a conventional gear, but reverse the torque and the gears cannot turn the worm gear due to a lack of leverage. They work great in racing, but for offroading where tires frequently spin and go airborne (zero traction) seem to need the back up of a traction control system or they spin helplessly.
On the transaxle comment. A transaxle is merely a transmission and axle built into one assembly. It is common on laterally mounted engines (most) and there's no reason save limited space that a true 4WD system could not be engineered with this setup. Porsche uses this setup (originally called the Weissach Axle) for weight distribution, but most manufacturers of mass produced FWD vehicles use it for low cost and space efficiency.
IdahoDoug
The 03 4runner note seems to imply that the torque distribution when driving straight is different from when turning, say a tight turn under serious throttle.
Were I given the responsibility to design the perfect AWD system it would be one wherein I monitored the yaw sensor (accelerometer) for centrifical force level and the steering wheel position sensor and decreased the engine drive/decel torque to the front wheels accordingly.
I remain hopeful that this is what Toyota has done with the 03 4runner and further hopeful that the technique will soon be ported to the RX. Unless the MDX gets there first.
I believe there have been several systems available that do use these sensors to optimize AWD power distribution. I have a buddy with an '02 BMW Xi and it is able to vary things constantly based on lateral acceleration, steering wheel angle, vehicle speed, shaft speed differences, etc. Over 10 years ago, Porsche also used these inputs on the mighty AWD 959 to vary torque split to each wheel.
On your 4Runner note - yes, it is different. As previously stated, when a vehicle turns the correct torque split would be different than the straight line split. So Toyota is only stating what the straight line split is since the split varies depending on the turn.
IdahoDoug
When turning the front tires travel a greater distance than the rear, rotate faster than the rear. Therefore if the straightline torque split is 29/71, then with the front wheels appearing to slip more torque would be allocated to the rear.
Right?
Do I stay with the 4x4 models or consider the PreRunner with TRD?
To get around in MN, I'd definitely get a 4WD - particularly in a light rear ended pickup. Having said this, I believe you can get a TRD 4WD pickup with a rear locker, no?
IdahoDoug
