Mercedes-Benz G-class (Geländewagen)
As you can see in some of my real world pics, side lean is rarely the only lean. You are generally going up or down, sometimes at a substantial angle, at the same time.
IMO the G and Rovers are the best at building in a low center of gravity. That is the biggest factor. For instance Jeeps are pretty tippy in stock form. Ideally they get lengthend wheelbases and get wider at the axles. If you look at the frame on a jeep, there isn't much steel there. If you look at a G you will see at least three times as much steel. The majority of the wieght is near the tops of the tires, the towering body does not carry nearly as much relative mass. So the G and the Rovers are heavy beasts compared with similar competition. They use much of the wieght in the frame to make a sturdy vehicle. The added benefit is a low center of gravity.
You get her over to 45 degrees and the static angle where gravity wants to roll her over is nowhere near the downhill contact point of the tire (XX). But adding weight (bodies and gear) effectively raises that CG, and you're soon spooky-close to the rollover point.
I have a '02 4Runner Limited 4x4. I am an avid off-roader. I was just wondering if you guys have any idea about the 4Runner's rollover status. The 4Runner has a very strong body-on-frame design, which i guess would lower it's center of gravity. The only difference is that it has an IFS. Track width on the 4Runner is pretty wide for the body. Thanks.
Here's a trick, hang something small from a string on your mirror. When you get leaned WAY over, pause for a moment before continuing and refer that dangle-angle against something vertical like a tree. Then compare that to something on "your" vertical, like the edge of the mirror. Form the angle in your mind by comparing the two. It's a quick reference. You can even mark a safety line (say, 30 degrees) on your mirror glass with a magic marker before you go out.
It's a poor man's incline guage. Cool.
Has anyone read the latest review of the G-500 on Edmunds? Reminded me of all the reviews that I read when I was looking for my vehicle and how much I didn't have in common with the "average" car buyer.
Funny thing is, back in '94 they tested one with someone to actually demonstrate the cars capabilities. They proclaimed the $120k, in 1994!, G320 to be likely worth the price of admission. You are absolutely correct though. Vehicles like this are not meant to have mainstream appeal. You gotta be a little wacko.
Steve
Maybe the reviewer's should have taken a look at v12's pics first.
Even with luxo stuff bolted to the G500, it is still crude in many ways. Just to get the triple sealed doors to close they have to be slammed. This just doesn't equate in todays soft genteel society. What sells to most $75k customers is wood and stainless trim, a good stereo, comfy seats and a creamy ride. Then package it all in a rugged looking vehicle with a pedigree, walla, you have sales.
That is OK though. I would prefer that all of my nieghbors didn't run out and buy G's. Prior to MBUSA importing the buggers I had one of six in my state. Now I have two of probably 40. I still probably have the only two within a hundred mile radius of home though :-)
The fact that most never go off-road is a shame, they are really fun to use. People are always very surprised to see the G getting some exercise. Most are intrigued by it, some Jeep guys though look the other way in disgust. Oh, Well!
Unfortunately many SUV owners now use them only to run to the mall, and independent suspension, low NVH and humongous cupholders are what sell. I'd wager you could ask 100 SUV owners what side their differentials line up under and 95 would have no idea... nor know why it matters... nor even have two solid axles.
In my humble opinion the Discovery is perfect: it's affordable and it's basically a Defender with 10" more wheelbase (and bodywork your wife won't divorce you over). Sadly, the new DiscoveryII has gotten softer and with its overhangs I wouldn't even think of offroading one now. In my book the DI is just right. Add some lockers and tall springs and you've got a real workhorse.
Like you, I've surprised a lot of people showing up in gnarly places with my "luxury" 4WD. The best definition of "luxury" to me is the luxury of not having to replace it every 5 years.
Best regards, -Bob
http://www.rutas4wd.com/offroad/imagenes/edicion1/32.jpg
For some, it can never be fast or powerful enough. For others, it can never be too red. For me, it's all in the suspension, and it's all at walking speed.
I just hope the court cases remain sensible enough that we don't lose our selection of truly fun toys.
I have an ML430 and I tow my fishing boat on a tandem axle (5000lbs) and it does fine, but the Gwagen tows a lot better, first, is a heavier vehicle, (rated at 7000lbs tow cap Vs 5000lbs tow cap for the ML). Second, it has a very short distance from the axle to the hitch point, very little overhang (main problem with swaying). Third, it has solid axles and a lot sturdier frame and suspension, if you know anything about the history of the Gwagen, it was designed as a military vehicle, it was the first 4x4 in the world with three lockable differentials, used by many NATO armies for years, later MBZ experimented with the vehicle to see if civilians would be insterested in the vehicle, more or less like AM did with the Hummvee, in essence what you are getting is a military vehicle "with added" luxury.
With the Gwagen think military, in its class is second to none.
From the danish army, this is a serious hitch on a Gwagen.
http://www.vinthers.dk/images/DK_GD9.jpg
It underscores the vast differences in use by potential buyers. Some want cush (hence the Escalade) and others want capability ... hence the Gwagen. Too bad they didn't include the new Land Rover and let it take both categories!
And then I got it. Have you seen the rain gutters on this thing? Perfect! You could custom build a killer Quik 'n Easy setup with those gutters. Almost worth the price of admission just for them.
Did you hear something about mounting a GM diesel V8 6.2/6.5L into an old series 460 Mercedes G? I only saw one converted G in Germany but don't have further information or details about this beast. Many Land Rovers have been upgraded with this engine in Britain but such a conversion is rare with Mercedes G's. As I'm planning to upgrade my sluggish 300GD, I would appreciate as much information as you could gather regarding this operation. ( links, texts, magazines or whatever)
Thanks in advance,
Pere
Barcelona/EUROPE
I had a job in the far north arctic and many of the trucks there had this engine. Once I buried a Suburban in a huge snowdrift at -75F ambient with 35mph winds. The engine didn't have enough power to spin all 4 wheels until I went to low range. Then I was able to do a little digging and "rock" the truck fore and aft until I freed it. I was seriously concerned for my safety, due to conditions... but largely because I didn't have the power to get through the drift, or to free myself once stuck.
I understand the desire for a diesel... perhaps there's a better choice out there?
Best regards
Anyway, I just got myself a new G500 (well, actually it's a 2002 with 12,000 miles), and I just hope it is as good, fun, and reliable as my 00 DII was. I sure do miss my old friend "Rovie".
I was also surprised at the low re-sale, or trade-in value of my "perfect" Discovery II (it cost $ 44,000 new equipped with all the goodies I had, and got a trade-in of $16,000). I was also equally surprised that I could buy an '02 $76,000 window sticker G for $56,000. I guess that's the used car business.
I can't wait to use the G as it was intended and get some pics as it does it's thing. I've done the LR test track at the dealer, as well as the Hummer test/show-off track, and the G just laughed, and said: is that all you got to offer?.
Happy holidays to all..
TMV new car prices, used car pricing, used car values at Edmunds
How to sell your car.
Good luck!
http://www.edmunds.com/reviews/generations/articles/102468/articl- - - e.html
As for pricing, this is the kind of vehicle where you should really get a professional appraisal, so you know where you stand. Being a gray market truck in 1985 means you really can't price them against the newer US models very accurately.
Sometimes if you cruise on Google, you can find a couple 80s models for sale. I saw a 1989 for sale through a dealer for $13,500 but just offhand that seems pretty high, and this one was four years newer and with very low miles. So I dunno.
What you need to do is a lot of Internet research to come to an accurate number I think. You may find more comparables for sale in Europe than in the US, say through searches on Ebay.com, which is fine, since with Ebay and the INternet we now enjoy a much more "international" market for unusual cars and trucks.
As for where to sell, I think www.hemmings.com is one good place and the bulletin boards of any G-Wagon clubs would be another good place. And don't forget Ebay--this type of "vintage SUV" might do very well there. Just be sure to include LOTS of pictures and a good deal of detailed description if you do an Ebay auction.
Keith
http://www.edmunds.com/future/2006/mercedesbenz/gclass/100511160/preview.html
When it is that thing. It looks like anybodys SUV. All wrong for a true G imo.
M
Ant
Many hits were in German, but I found a few like Planet Auto.
ASSETS
