toyotaparts4u web site, but could not find any hitch wiring
related items or instructions.
both the holder as well as the filter number.
I too also have a 2001 Highlander that does not
have a Cabin filter builtin. Thanks.
dealer and retrofit my 2001 HL. Thanks once again.
I'm heavily considering the 04 HL V6 AWD. I like the ride but wanted to take some feedback on the longterm performance - any issues with the engine or AWD in snow. I saw a lot of complaints on noise, has that been improved on the 04 models..
ANy help or feedback is appreciated.
I was going to purchase a 2004 Highlander Limited, but instead found a 2004 Mitsubishi Endeavor XLS out of lease with 6,000 miles for $22,000.00 loaded with everything. So far I love the Endeavor, the sound system is incredible unlike the Highlander. My Endeavor has a 350 watt Infinity system and I can not wait to hook up my iPod. Have not tried the Mitsubishi service net work yet, but it can not be much worse than Toyota. Also the Endeavor running on 89 octane gives me 20-22 in mixed city driving, I only wish my Highlander achieved this.
Again would like to hear comments on break system.
Stan in Philadelphia
Incidentally, whoever had the idea for washing the cabin air filter out in soapy water deserves recognition. The filter now looks almost new and it saved me about $30 for a new one!
What really upsets me though is my concern with the brake system. I can live with poor weatherstriping and paint, but the brakes really cause me concern for my safety.
Good luck with your weatherstriping replacement. The dealer told me that they are familiar with this problem and it is caused by door unevenness.
In the meantime turn off the A/C but with the blower on medium, the rear windows down, and slowly empty an entire spray can of lysol into the air intake at the bottom outside of the front windshield passenger side.
If you have a pollen filter remove it first and install a new one afterwards.
The odor is the result of the thin film of moisture left on the A/C evaporator each night after a days use of the A/C. Damp and dark interior of the A/C plenum during the night offers an excellent breeding ground for microbes that comprise most mould and mildew spores.
If you garage the vehicle at night it will help to lower the windows each and every night to allow the thin film of moisture to more readily evaporate away and OUT!
I added 45mm spacers all around on my 01 RX and upgraded to 17x8 wheels 235/65/17 tires and used rear snowchains ONLY quite successfully this past winter.
Also, not sure about your shifting problem, but new transmissions these days ahve a "learning curve" and get smoother as you drive more. In my Highlander it seemed worse as I slowed down to a stop at a light-it would downshift noticably. It is now fine.
How do you clear the codes? In my Mazda you have to disconnect the battery and apply the brake for a certain number of seconds. Is there a similar procedure for the HL? I don't have my manuals handy.
"If the malfunction does not reoccur in 3 consecutive trips, the MIL goes off automatically but the DTCs remain recorded in the ECM memory."
MIL - Malfunction Indicator Light
DTC - Diagnostic Trouble Code
what are the otehr two for.
all 3 are to the right of the mirror adjuster
Champion Toyota advised me that there is nothing wrong with my brakes. Took vehicle to independent mechanic and again advised that master cylinder is not operating properly. Went back to Champion Toyota and requested that service manager please go out with me in vehicle to see what I am experiencing and if he says situation is normal I will accept this. Told I do not have vehicle normally serviced at Champion, and that I am a nuisance and that they will not look at the vehicle and not to return to their service department. At that point I did become a nuisance and advised them that should I have to I will take legal action. I have never liked going to this dealer, it is the closest. Took vehicle to another Toyota dealer who road tested the car with me in it and said that the car is stopping OK, but that there may be a problem in that the brake pedal is not what it should be. This dealer's technician also said that the Highlander basically has a Camary break system and it may not be adequate for an SUV. Vehicle to be checked out on Friday, will give follow up.
Contacted Toyota customer service and related my dissatisfaction with Champion Toyota.
I have other Toyota products and have never experienced severe problems with them. I do not always use the Toyota dealer network because the vehicles are frequently in New Hampshire and the closest dealer is 250 miles away.
Not all HLs do it, but there have been many posts to that effect here.
Please keep us informed.
Close guess ;-)
It's the switch for 115V AC power outlet, which is part of the package with rear entertainment system.
If smell is sort of like old dirty gym socks then the problem is likely mould and mildew in the A/C evaporator.
I did manage to find a Toyota technical bulletin number TMSNTC01092 which states "Customers may complain of excessive brake noise and increased pedal stroke when applying brakes". Faulkner had no knowledge of this service bulletin. I elevated the brake noise by replacing the front brake pads, put on Thermo-quiet premium semi-metallic asbestos free severe duty brake pads, with sound insulators. The noise is gone. Incedinently Faulkner said that aftermarket brake pads are not of as high quality as Toyota's - Bull Sh--.
I have gone on the NHTSA line and here are a list of some of the complaints:
1. The recall work subject to campaign 01V22800 was not performed correctly. The vehicle still has excess pedal travel, and the pedal feel is mushy.
2. Brakes feel spongy whenever they are applied, no extended braking distance has been noticed.
3. Brake master cylinder failed prior to recall notice resulting in an accident the dealer denied any brake failure and the vehicle was returned to the consumer, a few weeks later the dealer called the consumer to bring the vehicle back to repair the brakes.
4. Approximately 3 weeks after my accident I received a recall from Toyota for brake master cylinder. Contacted dealer who immediately denied any brake failure before even checking the vehicle. ***Vehicle is finally ready to be picked up I repeatedly ask if brakes have been checked and fixed. Toyota of Knoxville insists that they have. Four weeks later Toyota of Knoxville calls requesting that I bring the vehicle back because they have not fixed the problem. They assire me once again that the vehicle is safe. I do not trust Toyota of Knoxville to service the vehicle.
I could go on listing these problems reported by Highlander owners regarding the brake system on the Highlander. I definitely do not trust Toyota or their dealership metwork when it come to the problem that I am experiencing with the brakes on my Highlander.
DOES ANYONE KNOW ANYTHING ABOUT A CLASS ACTION SUIT AGAINST TOYOTA PERTAINING TO THE BRAKES ON THE HIGHLANDER. I have been told that there is a suit started and I would certainly like information regarding it.
when i tried jacking the HighLander up with my roll under jack it bent over somewhat the side frame rails- is there a roll under rear jack point?
They said only 2 plys on the sidewall
Again, I can't imagine that nobody does sidewall repairs anymore, except that by refusing to do so maybe they sell more new tires?
This mechanic states that he has fixed the problem with the Highlander brakes by replacing the master cylinder with a new Toyota master cylinder and then installing GE Silicone brake fluid. The mechanic states that Toyota is aware of the problem with the master cylinder and moisture getting in giving mushy brakes, but isn't doing anything to correct it. The mechanic states that he has done this for a customer and the brakes now work properly. I am going to try and talk with the customer and see their Highlander.
I am trying to decide whether to spend $215.00 for a brake cylinder that I believe Toyota should replace under warranty and than about another $150.00 for the work.
Has anyone heard of this or done this to their Highlander?
My hitch did not come with the converter box. But with your description, it sounds easy enough to pick one up and install it myself. Thanks for the info.
only onJapanese made HL and RX
#584 of 1438 STEERING VIBRATION by veekay1 United States of America Apr 01, 2003 (5:07 pm) Mark Reply
Hi folks!
This board has been very helpful.
I am reporting a steering vibration when braking at 65-70mph. This happens intermittently. Front brake pads recently checked were reported "OK". Any other ideas? Anyone else has had the same problem?
Thanks in advance!
