He may also want to check tire pressure. As the temps rise, so does the tire pressure which will can make a harsh ride. PSI increase 1psi for each 8 to 10 degree F increase (does the reverse in late fall going into winter). Check the tires when cold or at least 3 hours after driving.
Will clips from other Toyota models work?
I was parked in a driveway and when I pulled away a big oil slick was on the driveway. Oil was pouring from the front of my SUV. I took it to the dealer and was told they could not find what was wrong at first. Then I was told it was the rear main seal at a cost of $2000.00 to fix. Does this make sense to anyone? Much Appreciated.
First consider getting a second opinion. Also, consider taking it to an independent shop that has a good reputation so hopefully you can save some money.
I'm back with my 5 year update on my 01 highlander. Problems I've had are the heater would stop blowing hot air intermittently, and a check engine light. I fixed the no heat problem myself by replacing the complete manual climate control assembly with one I got off ebay for $35. The dealer wanted $611 for the part! I found the cause of my check engine light to be a disconnected hose to the air filter housing. I just had my highlander serviced at a Toyota dealer ~150 miles prior. I assume the dealer forgot to reconnect the hose while inspecting the vehicle. The HL has been pretty trouble free otherwise. I've read through some previous post and see others have had similar issues. At least I'm still ahead of the cost I didn't pay for the extended warranty, knock on wood.
Time flies doesn't it?
Thanks for the update; that's a good run you've had with your Highlander, and great detective and d-i-y repair work.
Please take a few minutes and fill out a consumer rating & review. The link is at the top of the discussion.
I drive about 8,000 miles/year and its mostly to work and back which is on regular street driving. I do drive on the highway alot also when we visit family/friends who live nearby.
Toyota recommends changing my oil once every 6 months no matter if I have 5,000 miles or not between oil changes. My question is since I don't drive alot it ok to change my oil just every 5,000 miles? The last time I changed my oil I only has 3,200 miles from the last time I went.
Should you have a major problem with you engine in the future, you may need to prove that you adhered to the scheduled maintenance. Of course, do the schedule and the likelihood of a major problem is less.
Michael
I doubt any damage was done since it was on the rear.
I bet as another poster said, you're more likely to have cracked a wheel well liner or splash guard than most anything else.
a bent rim is always a possibility, but presumably, the tire place would have pointed that out to you.
i've told my wife that if she is on a quiet side street in the atlanta suburbs to stop the vehicle immediately when she notices the thump thump, in an effort to save the tire.
but if in traffic or on the highway, to slowly exit traffic / highway and get the car to a safe place to exit the vehicle...i don't care if the sidewall or rim is damaged in the process if her or our children's safety is in question.
i'm sure your dealership would do a cursory inspection on a lift if their workload was light.
after you undo the two clips
do you
1. have to take off any of the hoses?
2. or just raise the box?
and does the air filter slide in from the fender side or the front of the car siide?
I do not want to break anything
Not to be a wiseguy but assume you verified it isn't the radio station that's the source of the problem (occurs on different radio stations?).
Also are you positive it isn't coincidence you haven't heard it on CD/tape yet? First inclination is the problem may be in the output stage/power amp but if it is indeed isolated to the radio then it has to be confined to the radio subsection, which says the problem is probably in the headunit (radio/CD/tape unit) which would need to be replaced, in the connections to this unit (try moving around the cables going to the headunit in the back to see if this instigates the problem), or in the antenna/associated antenna amp going to the radio. The fact it occurs while the engine is running implies the vibration from the engine may be exasperating the intermittent connection -- try banging the radio with your hand to see if this affects the problem.
Assuming the problem occurs with CDs/tapes too and you just haven't heard it yet (my hunch), then the problem could also be with the power amp driving the speakers (I think on '04-'06s it's located in the rear of the vehicle on the passenger side under the black plastic tray containing the tire changing tools) (on '01-'03s it's located in the rear of the vehicle on the passenger side immediately behind the second-row seat behind the carpet where it swings upward to mate with the cargo area) (non-JBL systems do not have a separate power amp). Wiggle the connectors to the power amp to see if they are intermittent while the stereo is playing.
Just some random ideas...
Would it work?
Very glad no one was hurt.
A couple of years ago I was up in a ladder in my garage and felt myself loosing my balance -- I fell on my HL -- my hip hit the left fender which dented, essentially breaking my fall. It cost quite a bit to repair the fender, but it was a small price to pay considering I still had my health!
This is the scariest thing that has ever happened to me. I had absolutely no control over my car until the truck stopped it.
i believe, most uncontrolled acceleration issues come down to a stuck accelerator pedal - most likely because of a floor mat -or- the spacing between the accelerator and brake - people applying accelerator when they thought they were applying the gas. it's also possible that because of a mechanical imperfection in your accelerator pedal, it "stuck" at the last significant demand level instead of immediately returning to zero demand when your foot left the pedal.
if your highlander has a throttle by wire (or drive-by-wire) design, it means the accelerator and throttle are not linked by a mechanical cable as they used to be, but instead, the engine control unit interprets the demand of the accelerator pedal, then commands a certain position on the throttle and (i believe) looks at throttle position and closes the loop to null the difference between demand and position of the throttle. the engine control unit(ECU) can then do various things to modify the demand based on other parameters being monitored before commanding the throttle to go to a particular position.
so in theory - it's possible your accelerator pedal was only slightly depressed by your foot, and yet the command to the throttle was messed up by the ECU. It's also possible the throttle-body was reporting the wrong position (because of a position feedback sensore problem) and was driven to the state of further open than it should have been.
it's really hard to say what happened exactly.
unfortunately, i would expect the dealership to say you *probably* were depressing the accelerator instead of the brake. if you are quite certain there was no issue with the floor mat, and you are very sure you weren't applying the accelerator instead of the brake, then have them perform tests *** and document *** results on the ECU download, the accelerator pedal mechanicals and position sensors, and throttle body actuator (motor) and position feedback sensors.
if they repair your vehicle and if you have a subsequent event / claim, this will be important documentation to have.
you might want to google the issue, and even report the event to the NHTSA web-site.
As far as a floor mat, would it have to be on top of the gas pedal in order to make it stick? I checked that right away, and it wasn't.
