I have never used those straps nor can I forsee using them.
Regards, BGood
Curious what do you and others use those straps for?
The straps are the seat belts for the third row seats. They have two seat belt buckle type connectors on them. When the third row seat is raised, you plug the buckle at the end of the strap in to holder at the outer end of the seat and then use the second buckle normally as a seat belt. However the plastic receptacle into which they are supposed to clip when not using the third row seats does not hold them secure. I just let them flip around but if the buckle is laying in a position where it rubs against other hard components, they rattle. Judicious use of a rubber band around them seems to work.
Cheers
Graham
To me they are distracting when looking into the rear view mirror and also flapping in the breeze when wiindows are open.
That is weird. I have never known a car manufacturer to install something as expensive as seat belts if they do not need to. The third row seats are normally folded flat and form the load floor. If you slide the second row forward you can see the head rests for the third row and the release has a handle in the middle of the floor. If there is no third row, the third row seat area is replaced by a storage area.
Cheers
Graham
My 2003 HL 4cyl. 4wd. heater control is not doing it's job. Intermittantly, no matter where the dial is placed, HOT air is coming out.. :mad: ...This also happens, sometimes, when the A/C is on as well. After a minute or so of playing with the dial and fan settings, I can get things back to normal....but not always.
Any ideas where the gremlin is? This whole thing is "heating me up"!
Why Toyota didn't put a locking device on the nut is a mystery to me. I am not cynical enough to believe they are trying increase dealer profits, but this is something they should have fixed years ago. I wonder if the new model Highlander has the same problem.
I'm glad to hear it's probably an easiy fix.
Thank you again,
Rpell
Is this a common problem?
Can you just get this little piece and replace them?
I may try touch up paint.
I would like to have some backup data before I go to dealer mgt. and ask some serious questions. I've waited several months to do this in order to cool my jets!!
How much did they charge for this service?
Jonas
Removal is very straightforward. Squeeze in each side of the glovebox very firmly, and lower the glovebox down. Disconnect the string on the return spring assembly if necessary. Be careful as the string end is swaged back on itself and can break at the swage.
The fan is directly in front of the glovebox and above it is a plastic panel about 10 inches wide by 1 inch high held in place by two plastic clips at the upper edge. Release the clips and you will find a tray style filter behind. The tray holds a removable paper element that can be removed, shaken out and replaced if required.
The complete job takes less than a minute
Cheers
Graham
Took out my volt-ohm meter and started checking. All fuses are OK, all three fan relays are good. I can bypass the relay contacts with a jumper and the fans turn on but the idle does not. The problem is there is no voltage to operate the relay coils when the AC turned on. With air flow over the AC condenser, the AC will not work until you drive it. Obvious.
The check engine light is NOT on. It's either a sensor or the computer is wacked. Anyone have any thoughts or have had this problem?
At Midas the mechanic said that this is fairly common now, Rotors are being made to wear out like exhaust systems and typically only last from 40,000 to 60,000 miles. In the past I've driven vehicles over 120,000 miles and never had to replace a rotor. He also said the typical cost is about $425 an axle, although the Highlander rotors are more expensive.
I'm wondering what other Highlander (or Toyota) owners experiences have been. If you could reply in the following format:
Make: 2004 Highlander
Miles (Before Replacing Brakes): 55,000
Costs: $900
I'll try and collect the information and see if my experience is typical. If so, I think it's a shame that automakers have decided to use planned obsolescence in order to boost profits. If Toyota doesn't watch out, they're going to end up in the same shape as US automakers. :sick:
Other factors are if you live in hilly or mountainous area, you'll use your brake harder than say in Florida where I live. Also, how hard or fast you drive is another factor. Maybe on your first brake pads were replaced a more aggressive pad material. Most pads today are semi metallic, that means there is metal in the pad material to get the friction up. When you see cars with very bad brake dust, most of it is metal dust sticking to the metal wheels.
As a general on the first set of pads, the rotors should be good for at least one cut and the end of life when the second set of pads wear out. A lot of repair shops will also want to replace the brake caliper because the dust boots on them can be deteriorating because of the high heat that builds up especially during hard braking. Also, the brake fluid can also be contaminated because of moisture can be absorbed into the brake fluid and the excessive heat from the pads will transfer to the brake fluid and it can boil if it gets hot enough. With anti lock brake systems, you do not want to push this old fluid back into the brake system when the brake piston is pushed back into the caliper.
Therefore, a full brake job, at least for the front wheels, could be a set of pads, two rotors, two calipers, fluid flushed, and labor. You did not mention if the brake quote was for two or four wheels. For two, $900 is very high. A repair shop should be a round $450-$500. Today, dealers will charge over $100-125 an hour for labor, and my mechanic on the corner repair shop charges $85 per hour.
check out this site for some good info
http://auto.howstuffworks.com/auto-parts/brakes/brake-types/disc-brake.htm
Good catch.
My son has an 04 Tacoma and the pads were replaced at 40K miles and the rotors were turned, total cost $200.
http://www.detnews.com/apps/pbcs.dll/section?category=AUTO01
Since brakes are a safety issue, I am not qualified to give advice. But the following is a quote from the "Tech Correspondence" column in the July issue of Road & Track: "While full-thickness, dead smooth brake rotors provide the most fade resistance and best pedal feel, the cost of replacing good rotors with perfect rotors has never added up to us. Unless the discs are heavily scored, warped or undersize we simply replace the brake pads."
I found a set of original equipment pads for a little over $100. Brake grease is only a couple of dollars. I am going to just change the pads when needed. I did this on my Honda Accord and the brakes worked fine. But safety is involved . . . best to decide how important it is to save a few bucks.
Curious thing is that I heard no sound at all when I braked, and the service rep said that the 2004 had no brake indicators. So I wouldn't expect to hear anything even though he described the wear as being basically metal on metal at that point.
One other point is that brakes on a vehicle with manual transmission tend to last longer than on a vehicle with an automatic. I had a 1994 Corolla station wagon that I traded in when I got the Highlander. It had a manual transmission, and I never had to have the brake pads or rotors replaced in 111,000 miles.
Brake usage is very much dependent upon usage patterns. I have 112,000km (say 70,000 miles) on my Kluger which is used in a combination of city and freeway with some on-dirt. Last service suggests pads are at 55% remaining wear and rotors not significantly worn. However, rotors do warp if wheel studs overtightened (actually noticeable after wheels rotated).
I tend to drive to minimize fuel usage, reading traffic ahead, coasting to lights and minimizing braking, but keeping up with traffic flow or ahead. TYpically, I find that the aggressive driver ahead has made it to just in front of me by the end of my commute, so not overly laid back.
Cheers
Graham
But what you are saying that since the low pressure switch cuts out the AC clutch, it also cuts out (to the computer) the idle speed control and the AC fan?
I've had this happen on other cars, as the low pressure switch cuts out the clutch, the low pressure side slowly build up some pressure and the clutch kicks in again and this on/off cycle continues. Usually, the idle and fans still operate as if the AC was on and working 100%.
The blinking A/C light typically means the ECU is trying to run the compressor but the clutch or the drive belt is slipping. In that case the ECU would initially go ahead and open the throttle and turn on the fans as the expectation was that the compressor is operational.
Did you say the engine stalled when the A/C was switched on..??
The economy is bad and dealers aren't making money selling new cars. Service departments are their cash cow. It certainly shouldn't hurt anything (but your pocketbook) to change the pads early, but it makes me nervous when service reps don't tell the truth. I am going to start checking everything they tell me from now on.
My 2001 still had pad thickness over the wear limit, which IIRC is only 1 mm, at ~60,000 miles when I replaced them because the VA safety inspectors were worried about them lasting another year.
Costs - I get coupons from three competing Toyota dealers, and there is almost always an active 25% off parts special going on, which makes original equipment competitive with discount stores, and original equipment is almost always better quality.
If your servicer recommends resurfacing or replacement of rotors, ask why - look at the surfaces of the rotors if possible. They don't need to be glass smooth, new pads will bed in quickly to minor irregularities in the surface. The only reason to replace rotors is if they have worn too thin (or they somehow have huge gouges), and the shop should show you a measurement, and refer to a service limit. HL pads are not very aggressive, and shouldn't wear rotors to replacement by the first pad change (or the second).
In my expereince brake rotors do not "wear" too thin, only being turned on a lathe results in the rotors being too thin to be turned yet again.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
(2002 Highlander Limited)
tde
We just turned 95,000 miles a few weeks ago.
There was still almost 1/8" on each pad remaining, less before the 'squeakers' would have started contacting the disc.
Phil
I had poor experiences using Midas to do brake work on my '93 Geo Prizm. They insisted on turning the rotors; their brake pads squealed when they got warm; they replaced the pads with the exact same model pads at no charge but insisted on charging me again to turn the rotors again. The brakes still squealed. I ended up taking the car to an independent shop and they replaced the pads with ones imported from Australia; silent brakes once again. I will not go back to Midas.
