Infiniti I30/I35 Accessories and Modifications
A mechanic at Infiniti has admitted to there being a problem with the factory bose stereos, and that they start to skip to the point where they won't even play AT ALL....people are constantly bringing their cars in to get the stereo fixed. If there is such an issue with these systems, why aren't they recalled?
Is anyone else having problems with their Bose player skipping?
Is there any solution to this Bose disaster?
I am very disappointed in Bose. I can't believe they would actually put their name on something like this and not offer to fix it. As much money as they charge for their systems, it should only be expected that they should work properly. :confuse:
Ok thanks for letting me vent!!
Good Luck.
J
Baiscally, if the lock is turned withthe key, it will move a chunk of metal past an induction coil, so the alarm knows that it is legitimately unlocking. If you jam a screwdriver in the lock and turn, the whole unit turns, and not chunk of metal is passed by the induction coil.
Problem is that the sensor can fall off. Take the door apart. There should be a horseshoe shaped sensor with a wire leading off of it, clipped onto the lock cylinder. If not, look at the bottom of the door to see if it fell off. If it's still attached to the lock, then it could be a bad sensor, or bad wiring.'
thx.
I have an 04 I35 and having the same problem with the sub going off and on at random points and recently my speakers (the left channel) are very low esp when i turn the cd player on. Please let me know if you figured out the problem or not because it is very annoying esp during the traffic or long commutes.
Thank you very much
