Hyundai Elantra Accessories and Modifications
12467
  • doohickiedoohickie Member Posts: 949
    It wasn't very hard; took 2-3 hours I would guess... and that was with a lot of trial and error. I bought three pieces of galvanized mesh gutter guard at [insert name of big box home improvement store here] for $1.30 each, and black of tie straps. I secured most of the mesh to existing features, but judiciously drilled a few holes to make sure it would stay put. The top can be anchored by slipping the mesh between the metal bumper and the foam "shock absorber" material. Email me for more details.
  • dbains2kdbains2k Member Posts: 9
    I have an '04 Elantra with the stock CD deck. I'm no car expert by any means. So I was wondering, that if I were to purchase a sub and an amp for my car, would I need to purchase a new deck as well? Or does the stock deck have the necessary outputs? Thanks.
    Do you have the Kenwood CD/MP3 deck or just the regular Hyundai deck?
    It's just the regular deck that plays CD and AM/FM. The model number is HCD50645P.
    I picked up the Tiburon sway bar and bushings this afternoon and put them on tonight. I still have the stock (plastic) sway bar end links though. I am looking into buying a set of metal ones online, maybe next week.
    The difference is noticeable, but not as pronounced as I had hoped. On the other hand, if I took it off and put the stock bar back on, I bet the handling would feel terrible in comparison. It feels a little better in the turns, but it also feels a LOT more in control.
    Update on the sway bar: First of all, I did buy the metal end links. I learned that you can buy them at auto parts stores under Moog part number K90360 or TRW part number 18343. In either case, they're made by Moog according to the markings. I paid $11.48 each. They made the feel marginally better in that the car still rolled a bit in corners, but it rolled gradually. With the plastic links, it seemed flat, then would roll suddenly.
    On another forum, though, I learned that the 19 mm sway bar has a green indentifying mark; there is an 18 mm bar with a yellow mark. I checked the mark on my sway bar, which is supposed to be 19 mm, and it's yellow. I contacted the parts department at the dealer where I bought the parts and told the guy I thought I had the wrong bar. He offered to order in one of each of the Tibby part numbers (55511-2C000 for the 19 and 55511-2C100 for the 18 mm, I think) and we will look at them and see if I got the wrong one. I found out this afternoon the parts are in and will stop by the dealer in the morning to see what's up. I will take my camera with me I think and take some pictures comparing the two bars.
    There are different bushings for the 18 and 19 mm bars; if I have the 19 mm bushings but only an 18 mm bar, that might explain why the difference in handling was not as pronounced as I had hoped; there may have been too much play in the bar pivot.
    Hopefully tomorrow or Saturday I'll report back on how much better the 19 mm bar is! ;)
    So I got to the dealer this morning and had to laugh like heck: They ordered one of each sway bar like I asked: the 18 mm 55511-2C100 and the 19 mm 55511-2C000. Each had a part number clearly marked on the tag. Each one had a GREEN spot. And each one was 19 mm.
    :confuse:
    The moral of the story is: If you order a Tibby sway bar, SPECIFY 55511-2C000 AND the GREEN MARK!
    I added something new to my car: cargo area storage. When looking at other cars, I was impressed by the provisions made by the Mazda3 wagon, Spectra5 and especially the Suzuki Aerio SX with regard to storage in the cargo area. So I built a cargo tray that sits under the stock floor. The result is the floor is raised about 3 inches (it started out 2-1/2 inches lower than the seats when the seats are folded, so it's actually closer to being a flat floor now). Under the OEM carpet is a large central tray, a covered compartment in each rear corner of the cargo area, and a flip-up door to access the child seat anchors just behind the rear seats. To get to the spare tire, just lift the whole tray.
    Here is what it all looked like before the carpet was added. The tray sections are 2-1/2" deep and there are two 4-1/2" deep plastic bins that can be lifted out so I can take tools with me.
  • 1racefan1racefan Member Posts: 932
    Good job. My car (Mitsubishi Outlander) has a very similar sorage setup under the rear carpet - and above the spare tire. It also incorporates a way to store the rear cargo cover/screen down into it if you do not want to use it.
    I have often wished that my Wife's Elantra GLS (trunk) had similar storage. Even though it stuff in the trunk can't be seen, I don't like stuff sliding around in the trunk, nor do I like using cargo nets and things of the sort.
    Update: The B&M short shift kit for the '01 Elantra (JEGS part 130-45119) is now only $115.99, but does NOT come with a knob. I checked with JEGS customer service before I ordered, because some phootos showed the knob and some did not. So now I don't know... one reason I was going to replace the shifter is that the little plastic ring around the shift pattern button on my OEM shifter broke off, so I need a new knob anyway. Do you know that the leather knob as on the Elantra GT is $95?!? So I figured I'd kill two birds. But without the new knob, it's not as good a proposition. Anyone know of a short shift kit for the '01 Elantra that does include a shift knob?
  • 5port5port Member Posts: 395
    Backy,
    My little plastic ring has partially broken off on my 01 so I took some silver paint and filled in the area that was missing. Looks good enough for me. I had to fill in the area a few times every time the paint dried to acheive the same height as before. I've been using the stock shift knob with the kit. I paid $119.95 and bought it from a Tuner shop in Ohio two years ago so the price dropped $4.
    I installed the B&M short shift kit a couple of years ago and have been enjoying it. Back then they included the silver B&M knob with the shift kit. If this is the knob you are looking for you can have mine. My e-mail should be turned on. The shifter in the pix is the stock one. The knob in the pix is the one I am talking about:
    Image hosted by Photobucket.com
    Sorry, I couldn't read your entire message nor reply directly to it because of a quirk on Town Hall where their ads overlay messages that have big photos in them.
    I checked two sites that sell the B&M shifter. One was clear that the shift ball was included with the pre-2001 shifter, and not the 2001 shifter. The other wasn't clear, so I called their customer service number and the rep told me the ball was not included with the 2001 shifter. I did find a nice-looking metal/leather shift ball on another site for only $25 that I could get.
    Sorry about that. I shrunk the pix and now its readable. The offer for the knob still stands.
    Thanks, that's very generous of you!
  • iowaelantraiowaelantra Member Posts: 58
    Hi all,
    I included the following question as part of writings on other threads. On Dec. 31 I purchased an 05 GLS 5door. The car has the #3 package. While I was doing my preliminary research one of my "wishes" was for a sunroof in a car. My new 5 door does not have a sunroof. The car salesman I worked with mentioned there are some really good businesses out there that install aftermarket sunroofs at a price comparable or less than Hyundai would charge to build one in. The salesman mentioned that they work with a company in Council Bluffs, Iowa who installs sunroofs for them when they get a customer who wants one. Do you think this is a good idea or not? Are aftermarket installations as good as manufacturer installed? Should I go for it down the road or leave well enough alone? Hope maybe someone out there has traveled this path and has some good advice.
    I used to work with a company that built both aftermarket and OEM sunroofs. Personally, I wouldn't add a sunroof as an aftermarket thing, but I don't think the company I worked for had many warranty repairs on their aftermarket sunroofs; i.e., they didn't have too many problems. As long as it's properly installed you should be okay. If you can get the name of the company that local dealers use for installation, that would be the best recommendation I can think of.
    The company also built convertible tops, and that's a whole other story.
  • dragonmp5dragonmp5 Member Posts: 2
    I have a 99 Elantra w/2.0L and am looking for a place, preferably in Arizona, that would be able to tune my computer for turbo. I am also looking for carbon fiber hood and if possible trunk. I know where to get everything else. :confuse:
  • elleteeelletee Member Posts: 2
    I just bought a used 2005 Hyndai Elantra GLS. The "used car dealer" I bought it from got me a remote but it needs to be programmed for this vehicle (It IS from an 05 Hyundai Elantra GLS just not this one. I was hoping to program the remote myself because,newly divorced and broke, I don't want to get screwed by a Hyundai dealer if it is something that I can do myself or with the help of a man. I printed out the instructions from the following site http://egt.gwebworks.com/garage4.shtml, however, it says for 01-04 Elantra. Well...I tried all of the steps and even took off the ETACS unit and found absolutely NO switch to be able to flip!! Has ANYBODY tried coding the remote to a 2005 Elantra. I REALLY need this remote to work!! HELP!!!!! :confuse:
    You read the part about the switch being recessed and covered by a sticker, right? You have to peel the sticker back.
    I'll look into WebTech and see what I can find. If you want to look into WebTech for yourself, email me through my profile and I'll guide you through it.
    On edit: I looked at WebTech and there are, in fact, two different procedures for remote programming. 01-03 uses one method; 04-current uses a different one. Unfortunately, the later one requires the Hi-scan tool. Don't give up yet; there may be a work around. Let me do some digging.
    One other thought: Does the "used car dealer" you bought from have a service department? If so, see if they have a Hi-scan tool; otherwise, see if they can find another shop that has one and will do it for them as a "favor". If you can locate the tool, I can tell you how to get to the procedure in WebTech so you can give them a copy.
    Still another thought: Register as an owner with your local Hyundai dealer (with some dealers you can do this on the internet). Sometimes when a customer indentifies himself to a dealer, they dealer sends a welcome packet that includes maybe a $20 off coupon for service.... and you can use that for the reprogramming at the dealer. (Or alternately, take the car into a dealer for a cheap oil change, and mention that oh, darn, this second remote never works!... they may offer to do it for free. They are more likely to give you a freebie if you're spending some kind of money there.)
    Your best bet would be to get a new alarm system and remote.
    That makes no sense whatsoever: elletee already has a perfectly funtional factory system and working remote that needs to be programmed. Even if elletee has to pay a dealer to program the remote, it would still be FAR more sensible than putting in a whole new system!
    Bad news, elletee: I talked to Anton, the guy who wrote up the instructions on the website you posted and he said,
    "hehe, that link was to my write-up
    looks like it's going to need the scan tool."
    So I guess you need to try one of my crazy ideas to get a dealer to do it for free. Where are you geographically? Maybe we can hook you up with someone who has a Hi-scan tool.
    Thanks for the feedback.
    I had already tried the "used car dealer" route to see if he knew anybody that might could do this for me and the answer was NO...that is when I tried that info off of the web on doing it mysel.
    I am in Arlington, TX so I will probably have to go to the Hyundai dealer in Fort Worth and pay them to do it. I understand that there is a recall on this car, as well, that needs to be addressed which, from what I read on these posts has to do with the passenger side air bag light...I already noticed that that is a problem with this car. When somebody is sitting in the passenger seat sometimes the light is on saying that passenger airbag is off...that is NOT very comforting.
    Hey! I'm in Fort Worth!
    I've had pretty good service at Allen Samuels and Freeman. Although I haven't had any work done at West Loop, they don't impress me as much. You may want to contact each dealership though and see if they will do the fob for free. When I go by Buz Post, they seem kind of closed or something; I think they either went out of business or are remodeling. But you may try them too. You might want to schedule an oil change and ask if they'll do the fob for free. I know you can make service reservations at Allen Samuels through their website- the email goes to someone names Sonya White. You might email her and ask her about whether they can do the fob for free with an oil change or rotate/balance or something. Also, check their site for coupons; they have several specials. If you want to try Freeman, they just sent me some coupons since I bought my car there; I'll see if they have any $X.00 off service work. If I have a $20 off coupon (and I think I do), this could be pretty cheap or even free for you.
    If you're interested, there is a Hyundai meet in Arlington this Sunday. I doubt I will make it since my wife broke her foot, but I've been to meets in the past and they have been fun... and you can learn a lot about your car. Hopefully we can meet at one of these events. If you want to learn more about our local Hyundai club or you want some coupons, email me through my profile. No dues for the club unless you want to buy a sticker for your car or make a voluntary contribution to the website.
    I checked and I do, in fact, have a $20 off coupon for Freeman Hyundai, if your interested.
    One thing I didn't like about my GLS with the basic stereo was that it didn't have the tweeters like the ones with the premium sound package did. I didn't mind updating the head unit but kind of blew my sound budget on that and a CD changer. I was a little disappointed with the high end sound of the stock speakers.
    So last Friday I got out to the junkyard and scrounged around and found an old Tiburon with dash-mounted tweeters. I pried them out and took them home for $5. In the 04 and later Elantras without TCS and all that, there are the two "useless bins"- one next to the driver's side vent and one by the passenger side vent. They seem to be too small to be good for anthing. I fit those tweeters in there, though. The bins can be removed from the back of the panel. I put a tweeter in each bin and covered them over with the fabric from the Tibby grills which is almost an exact match to the Elantra dash and voila! My high-end sound is much improved.
    I finished installing aftermarket fog lights this weekend; they look very similar to the OEM ones that fit into the bumper. They were easy to install- I just had to make some simple L-brackets out of aluminum and ran the wiring through the fender and into the body through the hood release cable grommet (in retrospect, the harness grommet may have been a better spot because it is better protected from the elements).
    While I was at it, I also wired up the rear fog lights. On the 5-door model, the marker lights on either side of the license plate are also rear fog lights- they have a bright filament (similar to a brake light) that is not connected on North-American market Elantras, although they are used for rear fogs in Europe and other markets.
    I ran a wire from the light socket up to the instrument panel and have two switches for the fogs lights- the front fogs go on with one switch (provided marker lights are on), and the rear fogs go on with the other switch (provided the front fogs are on).
    Some pics:
    Front Fogs:
    Rear without Rear Fogs:
    Rear with Rear Fogs (note brighter lights on either side of license plate):
  • xendlessinyxxendlessinyx Member Posts: 6
    would +48mm offset fit 04 elantra?
    I believe OEM 15 inch wheel is +46mm offset.
    From Drivers & Believers Garage Section, "The Elantra GT has an offset of 42-45mm depending on who you talk to"
  • tsgeiseltsgeisel Member Posts: 352
    When I got my car from the dealer, I didn't get any accessories - I wasn't entirely certain I'd need them, and the dealer prices seemed a bit inflated.
    I'm now seeing where a cargo net might come in handy, and the trunk tray could be very useful.
    Does anyone have sources for these items? I presume ebay, but anywhere else? And, given the longevity of the platform, is it safe to presume that any of these items for the Hatchback from 2002 (I think) to current will be suitable?
    Yeah... the basic hatchback design hasn't changed. I got a perfectly serviceable cargo net for my wife's Taurus from a junk yard.
    I tried hanging the cargo net in my Elantra in several places and it always seemed in the way. I finally hung it off the pins the rear deck pivots on. That puts it next to the rear seat. I can still easily reach it but it's not in the way of the main cargo area, and if I need to fold down my seats it comes out with the rear deck panel.
    Other accessories and mods to look into are fog lights (if you got a GLS) and an upgraded rear sway bar (easy but substantial suspension mod). If you want any info about these, let me know. I got aftermarket fogs that look like an OEM installation.
  • aphaltcommandoaphaltcommando Member Posts: 32
    Hi guys, I just bought a 2006 Elantra three months ago, and it really suprised me by the way it handles. I used to be stationed in Germany in the early 70s, and while there, I owned a 1965 1600 BMW. What got my attention, was the way the little car handles the corners out here in rural west Texas. I set the cruise at 70, and drive right thro :D ugh the turns on the two lanes out here. It "feels" just like my old BMW did in Germany.
    Are there any suspension parts available for the car that will take the handeling up another notch?
    Go back to around post 153 or so in this forum. Some members here have replaced the stock sway bar with the larger one off the Tiburon. Apparently it is a perfect fit (as long as you have the appropriate bushings and end links).
    Thanks racefan, I'll check it out. Can I get solid bushings for it? I know, if I would have gotten the Tiburon I probably would not have had to mess with it, but I own a restored 1940 airplane, an ultralight, and am building an experimental Flying Flea, and they have first shot at my money.
    Hey guys, I found the posts that apply to my question, they are number 162, and 163. I'll give the parts a try, along with some stiffer lower profile tires, and report back in a couple of weeks. ;)
    Energy Suspension makes polyurethane bushings for the sway bars. The sway bar diameters are as follows:
    GLS Sedan
    Stock Rear: 13 mm; stock front: 23 mm
    GLS Hatch and all GTs
    Stock Rear: 15 mm; stock front: 24 mm
    As has been said upthread, you can put Tiburon rear sway bars on that come in 18 and 19 mm diameters. Energy Suspension does not sell directly, though, but you can buy their struff through Summit Racing.
    I haven't done the poly bushings yet, but I'm thinking about it. After putting the Tibby sway bar on the back, the body roll is much better, but I think maybe putting poly bushings on just the front may balance things out a bit.
    I did a writeup on the whole sway bar thing here.
    Asphaltcommando: if you email me through my profile, I have some other information you may find interesting (no, I'm not a salesman of any kind!)
    Hey guys,
    I just got off the Summit Racing site, and here's what I'm going to get. they sell a 22mm sway bar for 149.95, and lowered springs from Eisman. That along with a set of Riken Raptor ZRs in 215/45-17. That, along with the solid bushings ought to do the trick. Now to find 17 inch wheels. Brie :shades:
    Just so ya know, that 22 mm bar will rip the lugs right off your struts. They will need to be rewelded on. It happened to an Elantra owner locally here in DFW. You're much better off (and it's cheaper) to buy the Tiburon sway bar at the dealer. Poly bushings will only make it worse, as more of the shock load will be transmitted to the lug on the strut.
    I would recommend canceling the sway bar order, if possible.
    Thanks for the heads-up guy, I was getting ready to place the order right after I got done reading my mail. Will it be O.K. to put the solid bushings on the 19m.m. bar along with the lowered Eisman springs? How about the super sticky 215/45-17 Reikens? Anyone know where I can get 17 inch wheels for the Elantra?? Brie
    w00t! I'm glad I caught you before it was too late! I haven't heard of anyone having a problem with the 19 mm Tibby sway bar, even with the poly bushings. Here is a guide I wrote about the sway bar mod.
    I'm :) GLAD :) that you included the link on your post. I read it, and put it on my toolbar favorites for future reference. I'm going up on the DFW site to get two of those DFW window decals, they are :shades: COOL :shades:
  • scottradzscottradz Member Posts: 9
    Normally I wouldn't have a problem with this, but I just bought an '06 GLS and I'm a little confused with the 6 speaker setup versus the usual 4. I've checked lots of places and found the following recommended for an inexpensive unit - Sony CDX-GT200. But I'm a little unsure of what exactly to look for to work with the 6 speaker system.
    Any recommendations from folks who bought a unit and got it working with the six speakers? I'm far from an audiofile, so I can live with the factory speakers for a while. In fact, I'd prefer that to start. I'm just stuck on the 6 versus 4 speaker install.
    The tweeters are connected in parallel with the front door speakers; just connect them the same way.
  • jeffguidryjeffguidry Member Posts: 1
    I like to listen to AM radio, so I got an aftermarket Pioneer CD player to replace the stock cassette player for a better tuner and CD capability. This helped, but I wanted a better signal, so I got an aftermarket antennae from the C. Crane Company. This also helped, but the main problem remaining with the unit is (I believe) alternator noise. When I switch the car off, an oscillating noise continues for a few seconds on the AM radio, and then it stops leaving me with much better quality audio. I assume this is alternator noise, can anyone confirm this and recommend a fix?
  • mrearlmrearl Member Posts: 8
    Have an 02 GLS with stock cassette---like to have cassette/CD on the cheap with stock look. Anyone know if the stock combo unit from 02-05 Sonata will fit with no physical or electrical problems? Looks like it will fit by taking out the shelf under the stock radio but I have no idea on connectors [the owners manual shows and discribes the combo unit but it was not offered as an option in 02] How hard is it to pull the radio from the dash? I'm 65 and so far this Elantra is the 2nd best car i've ever owned.
    Assuming the Sonata unit fits into a double-DIN slot, which I am pretty sure it does, the unit should fit into the Elantra just fine. As you stated, a similar unit (same??) was offered in some countries on the Elantra.
    There are instructions on Hyundai WebTech site. If you haven't registered yet you can easily do that, here is the URL:
    http://www.hmaservice.com/authenticator/login?returnAddress=http%3A%2F%2Fwww.hma- service.com%3A80%2Findex.jsp
    After registering and logging in, go to the first link in the upper left hand corner, Service Information. That will bring you to the WebTech site where you can look up tech info on your Elantra, including directions for replacing the radio.
    I can do better than that: To remove your radio, first remove the dash fascia. To do this, remove the two screws in the instrument cluster bezel (above the speedometer & tach), remove the ash tray, and remove the two screws visible when the ash tray is removed. Once those 4 screws are out, start at the bottom near the ash tray, and pull the fasca off section by section until you get to the vent by the driver's door (it is held in by a series of pop fasteners, just pop them one at a time). Finally, disconnect each of the electrical connectors that go into the fascia for switches, the clock, the cigarette lighter, etc. I think each of them has a catch or button that needs to be depressed in order to get the connector out, once you push the catch, just wiggle it until it comes out.
    This sounds involved but after you do it once or twice, you can do it in about 5 minutes.
    Once you get the fascia off, there will be brackets on either side of the stereo head unit. Remove the screws that attach the brackets to the car, then remove the head unit and the little bin below it as one unit.
    Once you get that all out, remove the brackets from the head unit and bin, and use those to mount your new head unit.
    Behind the head unit is a brace that may need to be removed to put your new head unit in. In my experience and according to others, the screws that hold that brace in are a b!tch to loosen. I wanted to use the screw to ground my new head unit and never managed to loosen it; I ended up using a different bolt for my ground.
    I think if you get a brand-new screwdriver that fits into the available space (or maybe a screw driver bit on a socket ratchet), you can get those screws loose.
    Except for that bracket, the rest of this job is actually quite easy. Putting everything back is simply the reverse of removal.
    Anyone know of an inexpensive place to get a wiring kit and harness? I've heard ads for crutchfield.com on the radio (and HD radio is sounding like a possible idea), but other advice is welcome.
    Yes, you can certainly do better, can't you? I'll just leave all these questions to you from now on, since you have superior knowledge. ;)
