They have instructions for removal and installation of the thermostat there. It's very simple, really, but the pictures help a lot. Once you get your logon, Click on Service Information (in the upper left under the Hyundai logo), enter your car's details in the pull-down menus, select the SHOP tab and go to Engine Mechanical System > Cooling System > Removal (and follow similar links to ...> Installation).
Everything you need should be there.
Dennis
it was from my car. After I drived another half a mile and entered the parking lot. I saw some smoking from my hood, and the checking engine light(low engine oil) turned on. Immediately I stoped the car,turned it off and opend the hood, there was a lot smell and smoke from the hood. On the ground below the car, there was also a lot of black and thick liquid dropped from the car. I checked the engine oil level, almost no oil left. Definitely the mechanic of the local Hyundai dealer service department messed up somewhere during the oil change. I have just had the car towed to the local Hyundai dealer. Any suggestion or comments , what I should do tomorrow
in the hyundai dealer. I am very worried of the engine because of the low engine oil level and not sure if there is any other damage for the car because of the smoking and other things. I greatly appreciate your suggestions and comments.
This is good info. I have always done my own oil and lubes and have used Purolator 14459 oil filters on my 05 Elantra GT. They do have the oil pressure regulator. In fact, they look near identical to the Hyundai oil filter. Anyway, I have been hearing a crackling noise during light to moderate acceleration - especially uphill. I always attributed this to slight engine pinging. Anyway, I will change to the Hyundai oil filter when I do my oil change today and let you know if it cures the crackling noise.
Happy Motoring
Tomorrow I will drive to this dealership to talk with one of their director. Any comments?
Thanks a lot,
when i first started my car, went in reverse everythings fine. go to shift in first gear, there's no pickup for 10-12 sec...finally kicks in full power (assuming its not the clutch going)..go to shift in 2nd same thing happens..eventually after 10 sec it picks up full power and 3rd and 4th work fine..get to a stoplight, put it in 1st, same thing happens and the "check engine light" comes on...so i pull over and keep the engine running...after 10min i decide to try and drive back home, only being a few miles away..car drives fine no problems with the clutch picking up or any repeat problems...no im not too savvy with cars, so i dont know if this might be a transmission fluid problem or something more serious...ANYBODY WHO CAN HELP I WOULD GREATLY APPRECIATE IT!
any suggestions?
The computer diagnostics should be able to tell the service tech where the problem is. The good news is you still have at least one year and 13k miles of warranty left, so if it wasn't the gas cap, the light should re-appear in short order and you can take it back to the dealer.
So once again I am asking for recommendations from high-mileage users (over 20K) who live in the snowy parts of the country (like you Backy). I moved from Michigan and will be spending my first winter in Maine. Tire Rack's website has plenty of recommendations for the Kumho Ecstas, and my dealer is recommending a Cooper SLE Touring T-rated tire, but he can get "any" tire I might choose.
Please post your tire experiences and recommendations. Maybe Edmunds should offer a separate tire discussion for us.
A few more days will confirm the fix.
That said, I buy most of my tires from TireRack online and get them mounted cheap at a local dealer. Lately I have been getting some Kumho tires for various non-performance cars and trucks and have been really pleased with the quality for the price. The also make some higher performance tires as well (the MX, for example) but the "touring" and "all season" type tires are SUPER values for the money.
Dennis
I'm glad to read this. I hope your passenger seat continues to function well for you!
Does it pull with the car is accelerating, slowing down, and at a constant speed? If so, then it would be in the alignment or tires. If not, then under what conditions does it pull?
You could hit a pot hole on your way home from getting an alignment and knock it out again. Some places will sell you a "lifetime" alignment for a little more than a single alignment. If you are going to keep your car for a long time, it is well worth paying the extra money then it costs you nothing to stop in when you feel a problem.
Dennis
Very nice . . . so what exactly did they do? I think you said earlier they reinstalled the seat? Did they physically remove and replace it, reprogram the software associated with the sensor, or some combination of both?
I have a problem with a 1998 Accent GL. When we fill up with Gasoline, about 5 minutes after we fill the tank and drive off, our car will stall, as if it's starved for fuel, and when we're driving the engine wants to stall, but always re-starts due to the car moving.
Darrell
When I brought my car in. They removed the seat in 1/2 hour, ship it back to Hyundai Motor for reprogarmming and asked me to bring the car back when the seat was ready.
That was it. Good luck.
Is this a prevalent trait of Elantras? Has anyone determined what causes the problem and what can be done to rectify the situation?
I'll report on the Yokohamas as time drags on.
Dennis
I still have to deal with the shimmy problem. Have never been able to get it to completely disappear, although it is much less than with the Micheline's.
I have about 300 miles on the Cooper tires, and I love them. I had the car aligned once again when they put the Cooper Tires on, and now the vibration is gone. I don't know if it is due to the tires themselves, or the method they used for the alignment, but the car is really smooth and quiet now. We say it rides better than when it was new.
My 02 GT got new tires, Kumho Solus 716, from America Tires last week. My OEM Michelins lasted just over 34K miles, which could have been a few thousand miles longer if not for a big puncture caused a huge screw-head nail I picked up somewhere on the road.
Overall, I am quite pleased with the new tires for the money. Although it hasn't rained yet, their dry performence is on par with OEMs, if not better.
Although I have heard about the shimmy problems on Elantras before, I don't know it could happen to me until now. Right after I have the Kumhos, I started to feel some shaking on highway driving around 65 MPH. I thought it was a balance issue and went back to the America Tires shop, who also rotated and balanced my old Michelins, to have the front wheels rebalanced. To my surprise, it didn't cure the high speed shimmy at all.
Now, I am a bit frustrated about it. I know someone on this board recommended the "Hunter" machine for balancing and I know a local auto shop who has it. Having been paid life-time rotation and balancing for the new tires to America Tires, I am hesitated to pay for balancing again. Even if it can fix it this time, I don't see I am going there everytime when the tires are being rotated.
So, what should I do? Kumhos are good tires and I don't want to experiment another brand. Right now, I am planning to go to a different America Tires shop to rebalance it. If they cannot cure the 65MPH-steering-wheel-shaking, how much damage could it have done to my car if I can live with it?
Thanks for your time and suggestions.
Min
I'm thinking about changing the rotors. There is a lot of weight there that may be causing the shimmy. Anyway, this is really annoying and has made me have second thoughts about buying another Hyundai. I just took the car on a 600 mile trip and the shimmy is really tiring after a few hours on the road.
I had the original tires rebalanced about 4 times thinking that would solve the problem. It didn't. New tires and balance didn't fix it.
Then there was my '67 Austin Healey. When you heard the electric fuel pump suck air, you had about 30 seconds!
