Volvo 240 wagon stalling
My 240 DL has 140,000 miles. It has been running fine, but lately has been stalling. It has stalls at lights and also stalls when the car is just cruising. After 10 minutes or so the car will start up again. The mechanic put in a new ignition wire harness and ignition control unit. After $800, it still stalls. Someone told me it was a fuel pump problem. The mechanic said it was not. Can someone help?
What the mechanic needs to do is borrow the car, and when it stalls, test for spark and fuel. This is not rocket science, but sometimes intermittent problems can be very time-consuming, so mechanics often don't want to spend the time (and rightly, they find it hard to charge for driving around trying to "catch" your car's problem).
good luck
