Cadillac Escalade Maintenance and Repair
What should i look for when i pick my 2002 suv up any thing guys
My Escalade is beautiful and I still believe in all the hype but mine is eight months old and the first nite the power steering went out,then their was some kinda of noise in the rear underneath witch turned out to be a heat shield,and the rear hatch needed to be adjusted because in a turn it would turn on the interior lights,then the 02 censor needed to be replaced,now the awd has a drive line noise that they cannot fix,also the rattle in the dash (first they have to find it)!
The driver side mirror won't adjust out enough to see down the side. Any one with these problems?
Bill
David
I can get it to do it pretty consistently if I drive the truck long enough to warm up, then put it in drive, hold the brake and accelerate to about 1500rpm or so. More of a nuisance than anything,and something for which I originally made plans to have fixed, but I've decided just to wait 'til my next scheduled service.
good luck
The heated seat inside my BRAND NEW 2003 Escalade caught on fire as I was driving. The fire department said that it had to have been smoldering for many days!
I also noticed that the drivers heated seat is unusually hot. I am afraid to put my toddlers back in the car, repaired or not.
I have been told the clunk is from the transmission moving out of gear when coasting and when the accelerator is pressed, it clunks back into gear. May not sound good, but believe this is a common feature for the 4L60E and 4L65HD transmissions. My fix: I am playing around with a Diablo Sport Predator Programmer. So far I have uploaded the performance program and will test this out for a while to see if the quicker shifts help eleminate the clunk. Next I will begin modifying the shift points. I just did this last night, no test drive yet. I'll keep you posted.
Intermittantly on start up, the mirrors and driver seat reset to factory presets, not those programmed by the driver. What's even more bizarre is that driver's rear door window acts like you've activated the express down feature (not a factory installed feature on Escalades)According to dealership personnel, the memory chip located under the driver's seat, has a programming error which GM Engineers are working to correct. Until a solution is found, you just have to live with it and laugh!
when the car is still cold and slowley driving i hear like kick sound when the transmmission change from 1st gear to the 2nd , when the car temp come over the kick not come again ... is any one have idea about this .... thanks
According to Cadillac, GM engineers are looking for a programming patch to correct the problem. I'll probably be on my next Caddy by then, however, we have found a temporary fix to the gremlin power window... place your foot firmly on the brake, release the parking brake and start the vehicle. There's some electronic link between the active parking brake and the memory issue... problem solved, if only temporarily.
If you have a Denali with the same issues, the same fix will probably work for you too!
If someone can prove that it is a defective design, the issue can be forced. Aside from that, manufacturers will continue to use that same excuse.
Any ideas would be greatly appreciated.
P.S. Have also noticed that some people with 00 are having the same problems.
Jeannine Fallon
Corporate Communications
Edmunds.com
