Does anyone know if there is anywhere other than the dealer to replace them? I've got a price of $102. for the remote & $44. to program plus taxes. Yikes! That's a lot of money! I've only had the car a month.
Any help w/b appreciated. :mad:
someone wrote that they were have cracked and uncomfortable seats. After buying my car a 100 miles from home, I noticed an irratation on my right butt cheek. In examination of the seat the right rear corner of the seat was missing a piece of foam and I could fell the heater spring. I took my car to my local dealer and told them I wanted a 30K service and the seat fixed under warranty. This jerk sends the car over to the upholster whod does all their cars. It come back with a piece of foam stuck under the spot. I refuse to take the car, so he sends it back to this guy who tells me the "Service Mgr" told him to do it that way. So apparently he sends it back once again and they put new foam under the cover, I see it and it has wrinkles, and this so called SM tells me thats the way leather is. Now knowing this
not an Mercedes or any other high dollar car. I take it, while I there I don't see the manusl release cable for the gas cap in the trunk, this imbicle tells me my car does have one. I go home and undo to plastic nuts, reach behind and lo and behold there it is. I get a hold of the agency's general manager and tell him he's got the wrong man for ther job, and I asked hin to look at the seat with all wrinkles in it, he tells me it's normal and has less than the Azura he's driving, this is after Hyundai has relaced the bottom seat cover, I refused to believe that you cannot get the wrinkles out of leather. So... I take it to an upholster who had done some work on my motorcycle, and aked him if he can fixed it, he says yes, He charged me $110. took off the cover placed a new thicker piece of foam, resiults: not a wrikle, not a crease, and talk about comfortable!!!!!!! It has the seat of an Audi quality. Sorry about the long post but I thought you people needed to know that always something can be done, If you let them run over you, THEY WILL.
Does this sounds right? Shouldn't it move up or down to the pre-set stations? I think they've goofed here.
What do you think? :confuse:
In short, it's not going to void your warranty, but if an issue occurs because of a faulty aftermarket install, it will not be covered under the manufacturer's warranty. Having it installed by the dealer, if they cause an issue, they're ten times more likely to fix it without cost to you.
I would like to get some tan mats that will match the interior but some of the tan mats out there look more brown than the light beige of my interior. Has anyone used gray mats with the beige interior? I was thinking it might look OK since the dash is gray.
Any comments on any of the following mats? Quality, color, etc?
Weather Tech floormats
click
All-Weather floormats
click
Rubbertite floormats
click
I believe that there is a brown set as well.
Check out Advance Auto Parts as well.
Note: we have Weather Tech in our SUV and the kids car, they are great and pretty indestructible... just hose them off once in a while and alll is good again.
Larry
To the point of the post - I saw this on a Hyundai dealer site in Delray FL. We live in Boston MA area and called our local dealer. They said that they've only installed one in 15 years. Have any of you installed these? We had them on our Subarus and it make a difference on cold days.
http://www.hyundaioemparts.com/Sonata_EngineHeater.asp
I agree block heaters are a life saver on very cold mornings. Had one in my Lumina.
http://jerrystout.us/sonata/tsb/center%20console%20and%20door%20panel%20removal.- pdf
This is an online manual
You can find it at the following link...It is the first Cold Air Intake I have seen for the Sonata.
www.globalautoshop.com/accessories/automotive/hyundai_index.htm
I was just wondering if anyone has any experience with this and how well it works.
www.youtube.com/watch?v=Avs-p8ieLoo
The exhaust consists of custom Y Pipe feeding into two dual pipes. The mufflers are two Cherry Bomb Turbo Mufflers (actual three chamber mufflers, not the glass packs). The factory resonator is still installed and an aftermarket 15 inch long 3 inch wide "bullet" glass packed resonator is added prior to the custom Y pipe to tone it down since the factory resonator is actually quite un-restrictive and left the Cherry Bomb Turbo mufflers too loud and raspy.
If you want anything close to a stock sound (which I actually wanted) use OEM replacement type mufflers and just remove the factory resonator to get a more aggressive sound. If you use aftermarket performance mufflers or else you will have to add a big bullet resonator (like I did) to quiet them down.
The Cherry Bombs replaced two Magnaflows that I tried with the factory resonator. The result was a disaster. The drone was terrible and did not go away even at highway speeds. Every single time I stepped on the gas it droned terribly and you could hear it from a block away. Driving the car was almost unbearable. I tried the bullet with the Magnaflows and it was still too loud so I replaced them with the Cherry Bombs.
I was hoping to remove the 15 inch bullet resonator and just use the Cherry Bombs by themselves but it was still too loud and buzzy.
The car drives quite well now and is only slightly louder than stock with a nice muscular tone you can really hear it when you step on it. The car has a lot more personality now and is more fun to drive now (especially when you use the manumatic mode).
If you go with a custom dual set up or you want to replace your factory muffler I would recommend replacing the factory resonator with a big straight through bullet resonator to tone it down. The factory resonator will not tone it down enough by itself so I would recommend just cutting it out.
If you want to keep the factory mufflers appearance I would also recommend cutting out the factory resonator entirely and replacing it with straight pipe. My first attempt at a an exhaust modification was to replace the factory resonator with a smaller bullet and I was happy with the results. However, after seeing how un-restrictive it is I figured I would have been better off either leaving it alone or removing it entirely if I would have kept the stock muffler.
If I were doing this all over again, I would try to get the stock exhaust from a wrecked 2007 or later V6 Sonata. After you remove the plate that covers the unused space on the left rear side of the Sonata it already has the screw holes where you can attach the hangers for the stock V6 exhaust. Plus you could also use the heat shield from the V6 Sonata (which I don't have).
Also, go with a recommended shop with a reputation for doing good custom exhaust work. I actually had to have my exhaust completely re-done by a second shop when the first shop overcharged me for a truly horrible job.
Thanks for the ideas.
Just trying to prevent someone from making the same mistakes I made. Normally I would expect a factory resonator to quiet down aftermarket performance mufflers (that's what my 99 Mercury Cougar's factory resonator did).
Some other mufflers I wish I would have considered are the new three chambered Thrush Hush mufflers. I assumed that the Cherry Bomb three chambered mufflers would be relatively quiet...boy was I wrong. The Cherry Bomb three chambered mufflers were almost as loud as the Magnaflows.
I actually wish I would have kept the Magnaflows with the 15 inch bullet resonator on my car and saved some money since it was only slightly louder than the Cherry Bombs...and the Magnaflows were stainless steel..
Since I can't do any work on my car myself and I was using a muffler shop I didn't have the money to keep switching out mufflers.
In the future if I ever do a custom exhaust I will have the shop use clamps instead welding them on on until I make sure I like them...then I will get them welded.
www.youtube.com/watch?v=FnBfLCljAhQ
Thanks, van
I bought one a few months ago for like $10.00+ shipped.
Make sure your fob numbers match the unit your buying...
Example:
FCC ID: OSLOKA-310T
Transmitter Assy: 95430-3K202
Its on the back of the fob you have.
Although you'll have to go to Hyundai to have it programed. Bring all the fobs you have, because once they reprogram it any other remote to your car will not work unless reprogrammed also. Usually your year Sonata has two....
Thanks again, van
Symptoms while the fuse is out is also interesting. As soon as you put the key in the ignition, it acts as if the doors are open and the "ding" starts playing.
Also, each time you put the key in, it resets the MPG readout on the odometer display.
Just wondering if others have experienced this. I'm going to bring it in for a short-circuit examination.
