1. Does the single red wire contain only the positive wire, or is somehow the ground wire also part of that red wire?
2. What kind of female connector is on the end of that red wire? And what kind of male connector is required to connect into it? What tools/supplies/directions would be needed for installing the right connectors needed?
I have a GPS unit and radar detector to hard wire and neither have the type of connector that would fit into the end of the red wire on the Add-A-Circuit.
Thanks in advance for any advice and assistance or even to be pointed in right direction for this information.
Bud H
Were you able to solve your problem with the power locks on your 02 sonata? I have the same problem - doors will unlock with my remote but will not lock. Is there a faulty solenoid/sensor in the the driverside door?
http://en.wikipedia.org/wiki/Tire_pressure_monitoring_system
Door lock problem was solved by the
dealer installing a power lock new relay.
kcochran
I was lucky I was only going 4-5 mph, since of course I lost the power steering etc. It's scary to think of it happening when on a freeway or something. Anyone else have this happen? Ideas? Never had any problems with the car before (44,000 miles).
I have 2001 Sonata GLS with 79k miles on it. Recently i have inspected vehicle at Firestone. He suggested me to change my rear wheel brakes immediately. He told me that i need to change brake pads, rotors and fluid as well. He is quoting around $470 to get done all these things. According to him, i have very minimal brakes on back wheels. Do i need to change immediately. Can some one suggest me cheaper alternates.
Thanks for the reply. When i bought it has 57k miles on it. I have changed front wheel brake pads. Nothing done to either read wheel breaks or break fluid. I will check with other stores. Firestone is suggesting me to change read wheel brake pads, rotors and fluid for close to $480 which seems to me very high. Any other reasonable stores.
Don't squeeze in every last drop. If the fuel pump has an auto shut off, stop fueling when it kicks off, don't force more fuel into the tank.
I am just wondering if somebody knows a good mechanics for Hyundai (Sonata) in LI (maybe in Port Jefferson). I got few mechanics here but am not sure if they can provide a good diagnose for this car(which I bought last week). I would also like to buy a warranty if it is possible. It is 2001 and doesn't have any warranty.
Thank You
Live in New England. A day or two after our heavy snow storms and lots of rain, I went to start the vehicle after it had been resting for almost 24 hours. The day before I had done a lot of driving through snow and slushy snow. The temps when I started the car were high 20's Fahrenheit.
I started to turn the key. The engine began to turn over, but before it made it all the way, there was a 4 - 5 second period of a loud thumping and bouncing sound coming from under the hood. The way I can describe it is imagine a 5 pound basketball bouncing around inside the engine and under the hood. I held the key in the start position during this, in shock and horror, and then the car started. That was a week ago and I've had no problems since.
Have service appointment scheduled for later this week. Anyone have any ideas? Thanks. Love these forums, I'm always lurking.
Next time, you might consider aborting the start.
(Also looking at the Blizzak WS 60)
I like thse tires as well. The only downside I've noticed is slightly higher road noise.
This is my story go out to the garage to get a book out of the car. Do not have my keys with me. Go back inside the house and get my keys off of the second floor. Head back to the garage and unlock car door. Get what I need and leave car unlocked. Hour later go back to return book to car doors are re-locked. Do not have key. Repeat above steps. I assume if you do not place keys in ignition car assumes you unlocked door by mistake so it re-locks them. Aggravation occurs
I only notice this if I hit the remote to unlock the doors and don't open a door. As long as I open a door after hitting the unlock everything seems to stay unlocked. Not sure what is happening to yours.
I WILL be looking through my maintenance / repair bills but I cannot remember the last time anything was done relating to the spark plugs and wires. I do remember rejecting getting them replaced due to the cost (because I had only recently lost my job and didn't want to spend the money) - that was at the end of 2005!. Cost for plugs, wires and that ever lovable hourly maintenace rate...came to about $500.00.
Guessing worn out plugs affects mpg, right? Do wires HAVE to be replaced at the same time or is this another one of those things that we get hosed over...like twice a year dental cleanings for adults. Yeh...the dentist won't tell you that they are NOT needed!
Do worn out plugs cause any other problems to the car's running?
Ok...hit me with your best shots.
http://www.hmaservice.com/files/331/1361804/06-40-010.pdf
BTW twice a year tooth cleanings are really not required as long as you do the preventative maintanence. Plug wires are like flossing. Kinda like X-rays. Every "few" years are ok.
Good luck!
To be honest I have never gone to National Auto-parts or Advanced Auto-parts or Napa to see if they would laugh at me if I asked for Plugs and Wires for a Hyundai.
