Oldsmobile Aurora: Modifications
I put KYBs in the front of my 95 last spring. This is what I wrote about them then:
...After adding the KYB struts, the ride has changed significantly. The body roll has been dampened as well as the disconcerting "float" of the front end over rises/dips in the road. The body stays more level and gives a greater sense of confidence while maintaining a comfortable, even ride.
And after almost a year, I still like the ride and handling.
Jim
I had been advised by folks that sold aftermarket parts to stay with the GM to make sure the fittings on the load leveling system matchup.
Have you run into problems with the LL system??
A few posts above, I wrote about the KYBs I put on the front of my 95. I need to do the rears soon too. What do you think of KYBs on the front and Monroes on the back? Do you see any problems with that setup?
BTW: Are the Monroes any firmer than stock? And what model are they?
Jim
Also the doors are lined in plastic. Would it be wise for me to cut out the plastic behind the speaker or should I leave it the way it is? The magnet is much bigger than the stocks.
Colour codes
Right rear + dk blue - lt blue
Left rear + brown - Yellow
Right front + lt green - dk green
Right F tweeter + lt green - dk green
Left front + tan - grew
Left F tweeter + tan - grey
This is for a 96 with the standard 6 speaker system. I believe it should be the same for years 95 through 98.
MY TIRES SUCK!
Cheers
I'm going with some Kenwood 3/4" tweeters, 170 watts each.
I need to replaced them bad, every time I turn up the volume on my Kenwood eXcelon deck I can hear the tweeters rattling in there, there for sure popped.
I'll let you all know how it went.
Http://www.cardomain.com/id/javidogg
I had to take the whole door panel of the frame of the door, to get inside the back of the door and unplug the whole wiring, placed the door panel on a table and spliced the wires to add the tweeters that came wich also came with a In-Line High-Pass Filter to my 6 3/4 Kenwood speakers.
At first I thought I was going to keep the original tweeter grill that came with the Aurora but, the installation did not allow me to keep the original Aurora tweeter grill, So I did a flush installation using the Kenwood tweeter grills which fit perfectly, and man it looked so sweet.
I'm very happy with the outcome and the sound is 100% better than the stock tweeters.
If anyone out there has their tweeters blown, replaced them right away you don't know what you've been missing till you replace them with newer ones, preferly aftermarket ones if you have an aftermarket radio like me.
Peace.
Javier
I didn't think I could replace them. Do you all have the non-bose system?
Javidogg, Mike98c: Ok, I'm confused. I have the Bose system in mine and the speakers sound great for how I use it (and yes, I've been known to rattle a few mirrors).
_________________________________________________________
I have in my 1999 Aurora the Non-Bose sytem, I guess for me is a lot easier to replace and upgrade my tweeters.
I think for some people like larryfl it would be some what challenging to upgrade or replace their 1" tweeters simply because I believe the speakers that are in a Aurora that has the Bose system come with a separate amp for the speakers, that might include the tweeters but ah, I could be wrong.
I have a tip, if you are looking to replace them call or drop an e-mail to Crutchfield.com or call a Product Advisor at 1-888-955-6000, 8am - midnight, Eastern, for more information.
Trust me those people at Crutchfield know their stuff.
That's all I have for now, I'll be enjoying my new set of tweeters for now.
Peace.
I got it all set and it sounds nice, my system is not like heard blocks away but ah, it gives it that bass that is needed for some cruzin' jams, I got the amp bridge and the JL Audio speaker is hooked up in series, so the dual voice coils are actually being used at it's fullest, as well as the Excelon amp.
I'll try to get some pictures up and running as soon as I get a chance at cardomian.com.
Peace.
http://www.cardomain.com/id/800wattaurora
I've replace the front door and rear deck speakers (non Bose) in my Classic with Polk 2- and 3-ways, respectively. But, I haven't yet replaced the tweeters. Do you think it will make much a difference if I do?
I wish Olds would have put them on the dash-- Tweeters sound so much better there.
Does anyone here know the correct part number for both the Aurora and Impala switch box?
I know somewhere out there, there is a GM website listing the part numbers but ah, I'm hoping some would know these.
Any input on these would be greatly appreciated.
http://www.cardomain.com/id/javidogg
The driver's side ("master") power window switch is GM part number 25606315. I know this because the switch for my '98's window is sticking (both up or down), causing the window motor's switch to work intermittently. Paging my warranty company...
--Robert
I've spent $6K worth of repairs on my $6.5K card >:(
Anyways, I want to replace the struts and shocks, but not to my surprise the rear load leveling compressor is shot and I dont want to replace it (way to expensive).
Everyone here is saying good things about KYB struts, but what shocks on the rear would work ok with KYB's up front? Although I'll also be happy with Monroe's all around if I have to.
I've never installed struts before, I imagine its required to use a spring compressor (which I dont have), so I suppose I'll order the struts online then have a local shop install them.
Should the strut support pad be replaced aswell? The Aurora (Or as me and my GF call, joke and call it, "The OldMan", hahaha) has 116K miles on it (70K on the new motor)
Any suggestions would be great, I only wish I had found out about this site sooner!
u g l y
I did not mount the antenna on the top of the car, like you're supposed to, but up on the dash on the A-pillar on the passenger side. I still get 3 bars of signal. Only time I have problems/issues is *sometimes* going under an underpass.
I'm using the car kit w/cassette adapter (never listen to cassettes any more, with the 12-disc in the trunk and the single disc in the dash). I have to figure out how to try to mount the cradle up on the dash sweep near the DIC - the third-party brackets I've seen (which hang off the right of the radio) would cause the radio to hit my wife's knees, so I've got to move it up higher :-(
One question (and I apologize in advance, I haven't looked in my owner's manual); I know the car has retained accessory power for the radio, windows/sunroof/etc., but the minute I turn off the car, power is cut to either cigarette-socket outlet (thus shutting my Sky-Fi off). Is it supposed to do this/does it work this way on everyone else's Classic (I've got a '98)? I'd appreciate a response.
Thanks, and go check out XM Radio,
--Robert
(not employed by XM, just deeply happy I can finally listen to music in my office at work - can't get FM through the thick concrete walls, but can get satellite. Go figure!)
With the XM, I don't ever listen to FM anymore, so I decided to install a rocker switch to disable my power antenna. IMO, the mast kills the look of the car from behind and besides, mine always freezes up in the winter. I'll have to dig up the pictures I have of the project, the switch is actually located next to my ashtray. That way I can flip up that little door in front of the shifter in my classic and switch the antenna on or off, then close the door to hide the switch. I got the idea from a guy on the boards here, but it's worked out nice for me too.
I couldn't tell you about the power loss to the cigarette lighters..mine is wired right in to the radio, but I thought I'd share my XM story.
Steve
My Corsa system has always sagged a bit where the resonator hits the catalyst. I thought the spacer I recently installed would fix that as there would be more overlap of the two pieces, but it has not. My father and I are going to take a weekend trip to Cedar Point, Ohio to sample some of the best coasters in the world. I am going to stop by Corsa while there and see if they can't weld it up a bit. Jim Browning Jr. was quite friendly and helpful when I corresponded with him about stopping by. I am looking forward to seeing the plant there and how they make those awesome pipes.
Is your Aurora classic or 2nd gen? I don't remember how long you've been on the board, so please pardon duplications I may write here.
Garnes and I made the same airbox mods about the same time. I installed a remote thermometer in the air box of my '97 to measure the inlet air temperature. When driving at normal highway speeds, the temp is 2 to 3 degrees F higher than the dashboard temperature display. Stop or get slowed down to a crawl by traffic, and the inlet air temp rises quickly to much higher than ambient. On a hot day I have seen my remote thermometer hit its maximum, which is about 160 degrees. Because hotter air is less dense, we lose about 1% power for each 10 degree F increase in temp.
I like your idea of ducting outside air to the airbox. I have not figured out a good solution for the classics yet. A scoop below the existing front end will restrict ground clearance unacceptably. Hood scoops are out -- at least for me. Tomorrow I hope to have the time to remove my Aurora's driver-side fog light. I think there may be a path through the fog-light opening to the airbox area. What I have in mind is flexible tubing or hose to route air from the opening to the space under the air box. Since the last part of the hose will by oriented vertically, I think water ingestion will not be a problem. I plan to experiment with making both a tight and a loose (leaky) connection between the hose and airbox. For me, cool/cold air is the objective as opposed to any kind of a ram effect. I don't like the idea of losing my left fog light, but if that will get me substantially cooler intake air, I'm willing to make the sacrifice.
One thing to consider with any cold air set-up is that I would not be to happy with something that required a lot of tubing with several bends and perhaps a small diameter in some places to squeeze through a small opening. Such a solution may end up restricting flow at the higher rpm's.
garnes: I added the remote thermometer after modifying the airbox and haven't undone the mod to check.
My idea about accessing fresh air through the driver-side fog-light opening will not work without cutting the panel behind the fog light -- which is something I do not want to do. Yesterday I finally got my Classic on ramps so I could get under the front end. Removed the air baffle to gain access to the rear of the fog light. I found several interesting things. There was much oil seepage on the right side -- not enough to account for my one-quart-in-1200-miles problem. Looks like it may be coming from the oil lines to the cooler in the radiator. It didn't look like it was coming from the threaded connections, but from the areas where the rubber lines were crimped (or whatever) to the metal fittings.
When washing my Classic, I was always surprised by how loose the front fenders were just in front of the wheel openings. I found that the brackets on both sides were not connected to the fenders. Furthermore, the inner fender liners were missing some of those plastic fasteners. It was obvious that sometime before I owned the car, someone had not reassembled the parts completely.
garnes: I disagree with you on a point you made yesterday, "I don't know if running a hose through the bottom opening would help much. I think you will pull the same amount of fresh air behind the fender with the standard box by just removing the plastic insert." The reason I disagree is that there is no specific opening for air intake into the space around the airbox. That space is bounded on the top and outside by the fender; on the rear and bottom by the fender inner plastic liner, and on the inside by another panel. Looks to me like all the air accessible by the airbox gets there by "infiltration" through the loose openings between the surfaces I mentioned above. I think this is why I observe the high intake air temps at stop and low speeds -- most of the intake air comes in from the area of engine and radiator.
Therefore, I believe opening up a direct path to fresh air will result in lower intake air temps. I agree with you about not wanting restrictions and small openings. Maybe the best way to describe the solution I am trying to describe/achieve is to open up an alternative air path without taking away any that already exist.
With the air box mod, air comes from under the box (air behind the fender) and through the original side opening (same air behind the fender). I think you may be referring to that side opening but I'm not sure. With the box mod, I do lose that little bit of "horn" that extended about an inch toward that side opening. But the opening in the box (without horn) is still no more than 2 inches away from the opening in the side of the inner fender.
I've looked at it and gave it some thought in the past and I just don't think much air (if any) would snake its way from the engine and around the box to enter the original side opening. The path of least resistance is directly across from the box about 2 inches away - big opening in that inner fender. The stock horn thing did not fit up against it either.
Plus a lot of air will be coming from the bottom so the amount pulled from the side is probably decreased by 1/2 or more.
Anyway, that's the way I see it. I could be wrong, but I really think any air supplied from the side will just come across as it did before.
I did the ram air mod this weekend . I took out the left fog light and routed a flexible radiator hose from there to the stock air box .
I will put it this way you can have both .ram air and you can still have it sucking from normal place.use a y shaped couper at the bottom of the airbox . one side uses the hose and the other the regular air . I say this because just routing the hose to the airbox is not enought air for the engine to start (I found this out)ram air is not getting air until your car is moving. the best way to do this is to lose both fog lights . use mesh in the place where they were to keep trash out.you would route the two hoses to a coupler and then send it to the y coupler at the airbox. If you did this right I think that it could be benificial but it would take time and alot of head sctratching so I honestly do not know if it worth it.
