Merry Christmas,
I have a 1996 manual in a genuine fake leather wallet that I would like to trade for a 95 window sticker can anyone help. Oh, and I finally cracked the left hand corner of my dash. Mine was only 95 I never saw broke. Now it's complete. Any repair kit suggestions?
Phil
PLEASE if enyone has any suggestions on how i can make it softer - share. carida2001@gmail.com
My '97 experienced a similar but not exact same problem. Turned out the wire to the thermistor under the front bumber was broken.
Les
Thaks in advanace,
tim
I had both upper and lower radiator hoses replaced, thermostat replaced, all 3 or 4 oxygen sensors replaced, heater/heated coil hoses replaced and after all that my car is still running at an average of 225-250 degrees. I can not get rid of this pesky anti-freeze leak and if my car starts smoking again I think I may give it a reason to be smoking ;-(
Can anyone offer any advice to what may be wrong with it...after replacing all those things?? Other thing is I absolutely love my car driving down the street I can spot it 3 miles away from the front, back, and sides I can't fathom me selling it but as a broke college student with a not so rich mom I don't know if I can afford it. Should I sell it now before the time comes that I may experience the more drastic and expensive stuff that has been posted???
Signed "Don't Wanna Let My Baby Go" aka Jazmine :sick:
Signed "Dont Wanna Let My Baby Go" aka Jazmine :sick:
I have only 116k on my 1995, and I am thinking of letting it go. I really don't want to sell it because once its gone, there will be no other Auroras in my future. A unique creation that will soon only exist in the history books.
Welcome to the Hotel Aurora, you can check out any time you like, but you can never leave. . . .
Just thought I share my Experience with the Warning light
Please Help Me
Thank You
I don't know which VATS system you have...
http://vats.likeabigdog.com">A better VATS info link
I don't know if the Aurora system is like the Buick system but the security comes on when the right key is put in and then should go out if it reads the correct resistance. If it doesn't read the right resistance it flashes and won't let the car try to read another key for 3 minutes. This delays someone from using varying resistances in duplicate keys or a box because each wrong try requires 3-4 minutes.
I really helps to have a factory service manual for your specific car (Helminc.com) because it shows location. The G-shopmanuals are 1/2 price until Dec 30. Aurora manual
I like the bigdog link for my car using the connection on the right side of the dash instead of working with two fine wires at a connector at the base of the steering column (working upside down).
This last time they checked it, it turns out it was the ignition switch. So they replaced it. And I guess some wires under the steering column where checked too. When I would move the steering column up or down, it would do something to the wires.
Well, now it's been about 4 months, and so far no problem. It's been running great and no problem starting. So have the GM dealer check the ignition switch, and insist on it. The guys at first didn't think it was that when we told them it may be that. Then they finally checked it, and it was that.
Or I have heard some have had problems starting their Auroras and it turns out it was their starter. So have the ignition switch, under the steering column, or the started checked. It just might be one of those.
I wish you luck. That problem has been a real headache for me with this car, but I still love my Aurora. Specially now that things are going great with it. Don't give up. I'm hoping for you!!
I celebrated my 6th year of owning my 2001 Oldsmobile Aurora 4.0 (v8 engine) yesterday with a little scare on the highway while driving to the airport.
I was about 4 miles into my journey, and my radio volume started varying big time as did the needle on my speedometer - dropping from the 65 MPH to around 10 MPH then bouncing around ... the car was definitely slowing down while this was going on.
I tried moving through the 3rd, 2nd, and 1st gears, but it had no noticeable change. The electrical seemed fine and I could hear my engine revving, responding to me putting the gas pedal down. The car was still pulling forward, but at a much slower pace - almost like it was idling and letting the downward slopes carry it a bit (hard to tell speed - it was 4am in rainy/windy conditions in San Francisco).
2 miles of nervous driving with my emergencies on and listening to the engine rev big time, but a steady slow paced movement, the gears seem to kick back in and off I go down the highway to airport at 65 MPH again. How weird, right?
I returned from my morning meeting in Arizona, and braced myself for a non-working car experience - but the car worked just fine. I drove my 11 miles back home, parked the car. Later in the evening, I took it on a 5 mile grocery store run, and it was also uneventful.
Has anybody experienced something similar with their 2001+ Aurora? If so (or even if not), any ideas what may have been going on? I'm reluctant to take it to GM dealer cuz he always seems to charge me $800 and up.
Thanks! zennedjim@msn.com
How much are you asking.
Don
C
Les
Concerned there work may have unplugged a sensor.
Picking the car up I keep getting the LOW OIL MSSG at startup. Put in a qt of oil and it's at the full mark. I really dislike the color of the dipstick - makes it difficult to read the stick properly.
Anyone run into the low oil level mssg although the motor was at the proper level ? If yes what was the fix ?
Henri
Norris called me yesterday to say that THIS time it was the starter...
Anybody else have problems with this? The service advisor told me this is why the prior owner might have gotten rid of the car. That's fine, however, I reminded him for all the money I've paid them the last year, I would think the problem would/should have been fixed.
HELP!!! thanks
Good luck and I hope this helps!
Any advice is helpful to get Oldsmobile to honor their parts and faulty products!!
Regards :mad:
